Sign In Search
Home About Us Products Applications Resources Contact Us
Home > Industrial Products > Connectors > DIN > Locking DIN Cable Mount
Male plug with ground key-rib. Unique 30° turn lockring securely fastens two halves of connector. Mates with lock flange female
connectors and receptacles. Insert screw holds insert assembly in shell and also retains lockring on shell. Flexible black strain relief
with 7/32" diameter cable entry. Heavy duty clamp.
Questions? Contact Switchcraft Customer Support at 1-773-792-2700
Downloads:
Produc t
Desc ription
05CL3MX
DIN Cable Mount Connector, Male plug with ground key-rib, 3 pins at 180°
05CL5MX
DIN Cable Mount Connector, Male plug with ground key-rib, 5 pins at 180°
06EL5FX
DIN Cable Mount Connector, female plug with ground contact, 5 contacts
at 180°
09CL4MX
DIN Cable Mount Connector, Male plug with ground key-rib, 4 pins at 210°
12CL5MX
DIN Cable Mount Connector, Male plug with ground key-rib, 5 pins at 240°
13EL5FX
DIN Connector Receptacle, female plug with ground contact, 5 contacts at
240°
15CL7MX
DIN Cable Mount Connector, Male plug with ground key-rib, 7 pins at 270°
15CL8MX
DIN Cable Mount Connector, Male plug with ground key-rib, 8 pins at 270°
Specification Sheet
Associated Products:
DIN Right Angle PC Mount
Receptacles
DIN Panel Mount
5555 N Elston Avenue
Chicago, IL 60630
USA
773-792-2700
Home Support Contact Us Login
很抱歉,暂时无法提供与“12CL5M”相匹配的价格&库存,您可以联系我们找货
