SEALED MOMENTARY CABLE SWITCH
NEW PRODUCT BULLETIN 619
FEATURES & BENEFITS
• Waterproof and Dustproof to IP67
• Rated for 0.25 Amps, 30W max AC,
non-inductive load
• Available in 8 different configurations,
allowing for a wide range of circuit
configurations and cable diameters (see
details and schematics on pg. 2)
• Tested for a minimum of 20,000 Cycles
48VDC, 0.25 Amps (50 mΩ max)
125VAC, 0.25 Amps (50 mΩ max)
• Easy field installation
APPLICATIONS
• Traffic control override
• Outdoor instrument applications
• Industrial controls
• Outdoor amusement applications
• Nurse call switches or infusion pumps
5555 N Elston Ave | Chicago, IL 60630 | 773.792.2700 | sales@switchcraft.com | Made in USA
www. switchcraft.com
SEALED MOMENTARY
CABLE
SWITCH
SEALED
CORDETTE
SWITCH
PENDANT CABLE
3.38
3.01
C
2.22
0.90
C
SECTION C-C
0.85
913S/913DS MOMENTARY SWITCH
Housing - Nickel plated copper alloy
Button seal - Thermoplastic, black
Insulators - Rigid plastic
Terminals - Silver plated copper alloy
O-ring - Thermoplastic rubber
0.69
0.53
SEALING HANDLE
Handle - Thermoplastic, black
Overmold - Thermoplastic rubber, black
NOTES:
1. Completed assembly on acceptable cable shall meet IP67 rating.
2. Outer jacket of cable used in assembly must be smooth, round, flexible, and fall within the
specified cable range per the handle.
3. Using cable OD closer to the cable range maximum per handle will ensure a more robust seal.
4. Button and O-ring shipped unassembled.
5. This part is RoHS compliant.
SCHEMATIC
1-B
1-A
ASSEMBLY
PART NUMBER
EP913S14
EP913S17
EP913S20
EP913S23
EP913DS14
EP913DS17
EP913DS20
EP913DS23
1-C
BUTTON
PART
NUMBER
BUTTON
CIRCUIT
913S
1-A
1-B
1-C
913DS
1-A
1-B
1-D
1-D
CABLE
NOMINAL O.D.
RANGE
0.140 - 0.170
0.170 - 0.200
0.200 - 0.230
0.230 - 0.255
0.140 - 0.170
0.170 - 0.200
0.200 - 0.230
0.230 - 0.255
All dimensions are for reference only.
很抱歉,暂时无法提供与“EP913DS20”相匹配的价格&库存,您可以联系我们找货
