EP913DS23
EP913DS23
    SWITCHCRAFT
    MT NUT, STRT, NICKEL, SIZE 14"
EP913DS23 数据手册
3.38 3.01 C 2.22 0.90 C SECTION C-C 0.85 913S/913DS MOMENTARY SWITCH HOUSING - NICKEL PLATED COPPER ALLOY BUTTON SEAL - THERMOPLASTIC, BLACK INSULATORS - RIGID PLASTIC TERMINALS - SILVER PLATED COPPER ALLOY O-RING - THERMOPLASTIC RUBBER BUTTON BUTTON CABLE ASSEMBLY PART NOMINAL O.D. PART NUMBER NUMBER CIRCUIT RANGE EP913S14 0.140 - 0.170 EP913S17 0.170 - 0.200 913S 1-C EP913S20 0.200 - 0.230 EP913S23 0.230 - 0.255 EP913DS14 0.140 - 0.170 EP913DS17 0.170 - 0.200 913DS 1-D EP913DS20 0.200 - 0.230 EP913DS23 0.230 - 0.255 0.69 0.53 SEALING HANDLE HANDLE - THERMOPLASTIC, BLACK OVERMOLD - THERMOPLASTIC RUBBER, BLACK NOTES: 1. COMPLETED ASSEMBLY ON ACCEPTABLE CABLE SHALL MEET IP67 RATING. 2. OUTER JACKET OF CABLE USED IN ASSEMBLY MUST BE SMOOTH, ROUND, FLEXIBLE, AND FALL WITHIN THE SPECIFIED CABLE RANGE PER THE HANDLE. 3. USING CABLE OD CLOSER TO THE CABLE RANGE MAXIMUM PER HANDLE WILL ENSURE A MORE ROBUST SEAL. 4. BUTTON AND O-RING SHIPPED UNASSEMBLED. CUSTOMER DRAWING 5. THIS PART IS RoHS COMPLIANT. THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 0E NOTES 02/19/15 TS - 1. ALL DIMENSIONS IN INCHES 0D PART NUMBERS 01/22/15 TS - - TWO PLACE DECIMALS 0.02 0C CABLE RANGES 05/13/14 TS - - THREE PLACE DECIMALS 0.005 CABLE DIAMETERS 08/02/13 TS 05/30/12 DATE 0B 0A REV INITIAL DRAWING ECO NUMBER REVISIONS SIZE WIDTH MULT FINISH - BY TS - 05/30/12 TS BY APVD SolidWorks CAD File SPEC No. SCALE 1:1.5 - DATE DRAWN DO NOT SCALE DRAWING A TEMPER MATERIAL SPEC No. FIRST USED ON NAME LBS/M CHKD TS 05/30/12 APVD - SEALED CORD SWITCH ASSEMBLY, ROHS SHEET PART No. 1 OF EP913_S__SERIES 1 REV 0E
EP913DS23 价格&库存
很抱歉,暂时无法提供与“EP913DS23”相匹配的价格&库存,您可以联系我们找货
