MULTI-CON-X® FIELD INSTALLABLE CONNECTORS
Cable Pin
Panel Mount
P/C Tail Panel Mount
3X8X-XPG-XXX
Matching Mates:
• Cable-Cable
4X8X-XXG-XXX
Matching Mates:
• Cable Pin
4XXX-XXG-XXX
Matching Mates:
• Cable Pin
5X8X-XSG-XXX
3X8X-XPG-XXX
• Panel
• Cable Socket
4XXX-XSG-XXX
3X8X-XPG-XXX
• Cable Socket
3X8X-XSG-XXX
3X8X-XSG-XXX
Cable Socket
Cable to Cable
Mechanical Back Shell
3X8X-XSG-XXX
Matching Mates:
• Cable-Cable
5X8X-XXG-XXX
Matching Mates:
• Cable Pin
(Style #5)
5X8X-XPG-XXX
3X8X-XPG-XXX
• Panel
• Cable Socket
4XXX-XPG-XXX
3X8X-XSG-XXX
Square Flange
Adapter
Square Flange
Gasket
4296
4297
Molded Cable Assemblies
Cable End
Dust Cap
Winged Coupling Ring
4295
W/4482
(See pages 3 & 26)
Cable to Cable
Right Angle
601 East Wildwood, Villa Park, Illinois 60181 • Telephone (630) 834-7504 • Fax (630) 834-8540
14
Dimensions
(See pages 3 & 26)
1.110 [28.2]
2.000 [50.8]
2.065 [52.4]
1.455
[36.9]
CABLE END ASSEMBLY
CABLE TO CABLE ASSEMBLY
CABLE END ASSEMBLY
STRAIGHT BOOT 0.500 [12.7] MAX. CABLE O.D. STRAIGHT BOOT 0.500 [12.7] MAX. CABLE O.D. 90º BOOT 0.365 [9.3] MAX. CABLE O.D.
15
Part Number to Order
X X XX-X XG-XXX
Grommet Code –
Cable O.D. Range:
Connector Type:
3 - Cable End
4 - Panel Mount
5 - Cable to Cable
15 18 Back Shell
21 Style
24 3 or 5
28 30 -
Contact Size:
1 - #12 (2-4 Contacts)
2 - #20 (4-9 Contacts)
3 - #16 (4-6 Contacts)
.15 - .17 (3.8-4.3)
.18 - .20 (4.6-5.1)
.21 - .23 (5.3-5.8)
.24 - .27 (6.1-6.8)
.24 - .28 (7.1-7.4)
.30 - .32 (7.6-8.1)
Back Shell Style:
Weathertight grommet
grip/seal & (1) interfacial
“O”ring.
3DC - Daisy chain grommet with 3
I.D.s (.125, .188 & .250)
5
Mechanical screw-down
cable clamp with grommet
seal.
3
Contact Style:
80 81 82 91 92 -
Crimp (Supplied loose)
P/C Tail .187" (4.7) (Supplied assembled)
Solder Cup (Supplied assembled)
P/C Tail .280" (7.1) (Supplied assembled)*
P/C Tail .335" (8.5) (Supplied assembled)*
Number of Contacts:
2, 3, 4, 5, 6, 7, 8 & 9
300 - Panel mount with hex nut &
gasket.
3ES - 300 with Epoxy (Panel
Mount Only)
Type of Contact:
P - Pin
S - Socket
Contact Plating:
G - Gold over Nickel (Standard)
EMI/RFI shielded assemblies available - consult factory.
*Available in #20 size contact only.
Consult factory for optional threaded coupling.
Consult factory for your custom design cable assemblies and connectors. (See pages 3 & 26)
Contact Arrangements
1
1
2
2
1
4
4
5
1
6
1
5
3
2-#12
4
1
1
3-#12
4-#12*
1
1
4-#16
6
1
7
5-#20
6-#16*
1
1
7
9
7
8
5
4-#20
5-#16*
6-#20
7-#20
8-#20
9-#20
Contact arrangements shown are wiring view of cable end pins/sockets.
Key/keyway shown for orientation only.
*Available in connector types: cable end socket, panel mount pin, and cable to cable pin styles only.
16
Specifications
Typical Specifications
Manufacturers Identifications
Description
Rating
Conductor Size
Configuration
Certification
Multi-Con-X®
Field Installable Connector & Custom Cable Assemblies
1.95 thru 23.0A, 600V
#12 Contacts, 12 thru 14 AWG
#16 Contacts, 16 thru 18 AWG
#20 Contacts, 20 thru 24 AWG
2 thru 4 #12 Contacts
4 thru 6 #16 Contacts
4 thru 9 #20 Contacts
UL Recognized File #E150822 - 250V
CSA Certified File #LR89277 - 600V
Material Specifications
Cable Pin/Socket
Backshell (Threaded)
Grommet
Coupling Ring
Contacts
Connector Body
O-Ring
Sleeve
Nylon, UL Recognized, Black (Style #3)
Santoprene Rubber, Black
Brass, Gold over Nickel
Nitrile Rubber, Black
Cable to Cable
Grommet
Contacts
Connector Body
Santoprene, Rubber, Black
Optional
Long Backshell (Threaded)
Mechanical Backshell (Threaded)
– Strap
– Screws
Nylon, UL Recognized, Black (Style #3 with solder contacts)
Nylon, UL Recognized, Black (W/4482)
Nylon, UL Recognized, Black (Style #5)
Cadmium Plated
Panel Mount
Contacts
Panel Body
Gasket
Hex Nut
Optional
Dust Cap
Square Flange Adapter
Square Flange Adapter Gasket
Santoprene Rubber, Black (Part No. 4295)
Nylon, UL Recognized, Black (Part No. 4296)
Nitrile Rubber, Black (Part No. 4297)
Mechanical Specifications
Durability
Vibration
Minimum 300 mate/unmate cycles without mechanical or electrical failure
Coupling rings have overriding locking feature to prevent loosening or
separation of connector
All series hex nut to withstand 10-12 inch/lb tightening torque
Hex Nut Torque
Electrical Specifications
Voltage
Current
600 V
See Electrical Current Rating Chart (Page 27)
Environmental Specifications
Temperature Rating
Corrosion
Weathertight
-55°C to +125°C (-67°F to +257°F)
300 Hr salt spray contacts
Consult factory with specific application
(See Pages 3 & 26)
Watertight
NEMA 6P, 13: IEC IP67
17
