Sign In Search
About
Products
Applications
Resources
Contact
Home > Industrial Products > Connectors > DIN > DIN Panel Mount
3 to 8 pin DIN connectors which mount to PC boards. Plugs connect at right-angle to mounting surface. Shielded version
has metal flange surrounding face of insert to provide through-grounding between plug and receptacle and to potential
panel/chassis for common grounding. Male version features interlocking flanges for side-by-side row mounting.
Questions? Contact Switchcraft Customer Support at 1-773-792-2700
Product
57GB3FX
57GB5FX
Description
DIN Panel Mount Connector, 3 contacts at 180°
Downloads:
Specification Sheet
DIN Panel Mount Connector, 5 contacts at 180°
Associated Products:
57HB3FX
57HB5FX
DIN Panel Mount Connector, Female receptacle with ground contact,
5 contacts at 210°, flared solder terminals
3 contacts at 180°, flared solder terminals
Mini DIN Dual Right Angle
57NC5FX
60GB4FX
60HA4FX
DIN Panel Mount Connector, 5 contacts at 180°, PC terminals
Receptacles, DMD Series
DIN Panel Mount Connector, 4 contacts at 210°
4 contacts at 210°
Locking DIN Cable Mount
60NC4FX
61GB5FX
61GB6FX
61HA5FX
61NC5FX
62GB7FX
62GB8FX
DIN Panel Mount Connector, 4 contacts at 210°, PC terminals
DIN Panel Mount Connector, 5 contacts at 240°
DIN Panel Mount Connector, 6 contacts at 240°
5 contacts at 240°
DIN Panel Mount Connector, 5 contacts at 240°, PC terminals
DIN Panel Mount Connector, 7 contacts at 270°
DIN Panel Mount Connector, 8 contacts at 270°
DIN Cable Mount
62HB7FX
62HB8FX
62NC7FX
62NC8FX
contact,7 contacts at 270°, flared solder terminals
8 contacts at 270°, flared solder terminals
DIN Panel Mount Connector, 7 contacts at 270°, PC terminals
DIN Panel Mount Connector, 8 contacts at 270°, PC terminals
Switchcraft : 773-792-2700
Conxall : 630-834-7504
Home
Support
Contact Us
Login
很抱歉,暂时无法提供与“60NC4FX”相匹配的价格&库存,您可以联系我们找货
