ONLINE CATALOG
SWITCHCRAFT, INC. 5555 N. Elston Ave.
Chicago, IL 60630 • 773 792-2700 • FAX: 773 792-2129
www.switchcraft.com
Q-G® CORD PLUG CONNECTORS AND RECEPTACLES
m
T(*)F AND T(*)FM CORD PLUG WITH ON-OFF SWITCH
m
po
ne
nt
s.
co
T(*)F Straight female cord plug with DPDT (2-C) locking
on-off switch; standard latchlock.
T(*)FM Straight female cord plug with SPDT (1-C)
momentary on-off switch; standard latchlock.
Slide switches rated 500 mA, 125V (AC or DC). Mounting
screws are supplied.
on
lin
e
co
D(*)M, D(*)F AND D(*)FD RECEPTACLES
Studio quality black and gold Q-G ® receptacle with black
housing and gold contacts is designed for low/stable contact
resistance and withstands corrosion where highest quality is
required for recording and broadcast studio equipment,
consoles, and other applications.
D(*)M SERIES - Male receptacle for panel or chassis
mounting. Special rectangular flange permits close spacing on
crowded panels, has two .136 inch (3.45mm) diameter
countersunk holes for #5-40 flat head mounting screws (not
supplied). Mounts from front of panel or chassis in .766 inch
(19.45) diameter hole. Satin nickel finish (Series D*M) or black
finish (Series D*MB, or D*MBAU).
D(*)F SERIES - Female receptacle for panel or chassis
mounting. Flange has two .136-inch (3.45 mm) diameter
supplied). Mounts from front of panel or chassis in .953-inch
(24.21 mm) diameter hole. Series D(*)F has standard latchlock;
Series D(*)FD has FAS-DISCONNECT detent. Satin nickel finish
(Series D*F and D*FD) and “Black-Velvet” finish (Series
D*FBAU).
DIMENSIONS ARE FOR REFERENCE ONLY
Inch
(mm)
NOTE: Contact your Switchcraft Representative for price and delivery.
很抱歉,暂时无法提供与“D3FPKG”相匹配的价格&库存,您可以联系我们找货
