223886915689
223886915689
    YAGEO(国巨)
    陶瓷电容/独石电容 0402
223886915689 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS Class 1, NP0 Product Specification – Jul 06, 2004 V.10 50 V TO 500 V Phycomp Product specification Surface-mount ceramic multilayer capacitors FEATURES Class 1, NP0 50 V to 500V QUICK REFERENCE DATA DESCRIPTION • Six standard sizes • High capacitance per unit volume Rated voltage Ur (DC) • Supplied in tape on reel or in bulk case (case sizes 0402, 0603 and 0805 only) Capacitance range (E12 series); note 1: VALUE 50 V, 100 V, 200 V and 500 V (IEC) 50 V; note 2 0.47 pF to 22 nF • For high frequency applications 100 V 10 pF to 22 nF • NiSn terminations. 200 V 10 pF to 5.6 nF 500 V 10 pF to 3.3 nF APPLICATIONS Tolerance on capacitance: • Consumer electronics • Telecommunications • Automotive C ≥ 10 pF ±5%; ±2%; ±1% C < 10 pF ±0.5 pF; ±0.25 pF; ±0.1 pF Test voltage (DC) for 1 minute: • Data processing. 50 V and 100 V 2.5 × Ur 200 V 3 × Ur DESCRIPTION 500 V 2 × Ur The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved precious metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two terminations, silver dipped with a barrier layer of plated nickel and finally covered with a layer of plated tin (NiSn). A cross section of the structure is shown in Fig.1. Sectional specifications IEC 60384-10 second edition 1989-04; also based on CECC 32 100 Detailed specification based on CECC 32 101-801 Climatic category (IEC 60068) 55/125/56 Notes 1. Other values below 10 pF and non E12 series are available on request. 2. Also applicable for applications up to 63 V. terminations electrodes MLB457 ceramic material Fig.1 2004 Jul 06 Rev.10 Construction of a ceramic multilayer capacitor. 2 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V MECHANICAL DATA W T L2 L4 L3 MBB211 L1 For dimensions see Table 1. Fig.2. Component outline. Physical dimensions Table 1 Capacitor dimensions L1 CASE SIZE W L2 and L3 T MIN. MAX. MIN. MAX. L4 MIN. 0.45 0.55 0.20 0.30 0.40 Dimensions in millimetres 0402 1.0 ±0.05 0.5 ±0.05 0603 1.6 ±0.10 0.8 ±0.07 0.73 0.87 0.25 0.65 0.40 0805 2.0 ±0.10 1.25 ±0.10 0.50 1.35 0.25 0.75 0.55 1206 3.2 ±0.15 1.6 ±0.15 0.50 1.25 0.25 0.75 1.40 1210 3.2 ±0.20 2.5 ±0.20 0.50 1.75 0.25 0.75 1.40 1812 4.5 ±0.20 3.2 ±0.20 0.50 1.30 0.25 0.75 2.20 Dimensions in inches 0402 0.040 ±0.002 0.020 ±0.002 0.018 0.022 0.008 0.012 0.016 0603 0.063 ±0.004 0.032 ±0.003 0.029 0.035 0.010 0.026 0.016 0805 0.079 ±0.004 0.049 ±0.004 0.020 0.053 0.010 0.030 0.022 1206 0.126 ±0.006 0.063 ±0.006 0.020 0.049 0.010 0.030 0.056 1210 0.126 ±0.008 0.098 ±0.008 0.020 0.069 0.010 0.030 0.056 1812 0.177 ±0.008 0.126 ±0.008 0.020 0.051 0.010 0.030 0.088 2004 Jul 06 Rev.10 3 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V SELECTION CHART FOR 50 V C (pF) LAST THREE DIGITS OF 12NC 0.47 477 0.56 567 0.68 687 0.82 827 1.0 108 1.2 128 1.5 158 1.8 188 2.2 228 2.7 278 3.3 338 3.9 398 4.7 478 5.6 568 6.8 688 8.2 828 10 109 12 129 15 159 18 189 22 229 27 279 33 339 39 399 47 479 56 569 68 689 82 829 50 V 0402 0603 0805 1206 0.5 ±0.05 0.8 ±0.07 0.6 ±0.1 0.6 ±0.1 1210 1812 0.5 to 1.0 Note 1. Values in shaded cells indicate thickness class. 2004 Jul 06 Rev.10 4 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V SELECTION CHART FOR 50 V (CONTINUED) C (pF) LAST THREE DIGITS OF 12NC 100 101 120 121 150 151 180 181 220 221 270 271 330 331 390 391 470 471 560 561 680 681 820 821 1,000 102 1,200 122 1,500 152 1,800 182 2,200 222 2,700 272 3,300 332 3,900 392 4,700 472 5,600 562 6,800 682 8,200 822 10,000 103 12,000 123 15,000 153 18,000 183 22,000 223 50 V 0402 0603 0805 1206 1210 1812 0.5 ±0.05 0.8 ±0.07 0.6 ±0.1 0.6 ±0.1 0.5 to 1.0 0.85 ±0.1 1.25 ±0.1 0.5 to 1.0 0.85 ±0.1 1.15 ±0.1 0.9 to 1.3 Note 1. Values in shaded cells indicate thickness class. 2004 Jul 06 Rev.10 5 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V Thickness classification and packing quantities THICKNESS CLASSIFICATION (mm) 12 mm TAPE WIDTH QUANTITY PER REEL 8 mm TAPE WIDTH QUANTITY PER REEL ∅180 mm; 7" PAPER BLISTER ∅330 mm; 13" QUANTITY PER BULK CASE ∅180 mm; 7" BLISTER PAPER BLISTER 1812 0402 0603 0805 − − 0.5 ±0.05 10,000 − 50,000 − − 50,000 0.6 ±0.1 4,000 − 20,000 − − − − 10,000 0.8 ±0.07 4,000 − 15,000 − − − 15,000 − 0.85 ±0.1 4,000 − 15,000 − − − − 8,000 0.5 to 1.0 − 4,000 − 10,000 2,000 − − − 0.9 to 1.3 − 3,000 − 10,000 1 500 − − − 1.15 ±0.1 − 3,000 − 10,000 − − − − 1.25 ±0.1 − 3,000 − 10,000 − − − 5,000 2004 Jul 06 Rev.10 6 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V ORDERING INFORMATION FOR 50 V Components may be ordered by using either a Phycomp’s unique 12NC or simple 15-digit clear text code. Ordering code 12NC (preferred) 2 2 X X X X X X X X X X Capacitance value see selection chart Carrier type 22 blister 38 paper 54 bulk Tolerance 4 ±0.25 pF for 5 pF ≤ C < 10 pF ±2% for C ≥ 10 pF 5 ±0.25 pF for C < 5 pF ±0.5 pF for 5 pF ≤ C < 10 pF ±5% for C ≥ 10 pF Voltage 86 50 V Size 9 7 1 3 2 5 8 0402 (1) 0603 (1) 0805 (1) 1206 (1) 1210 1812 RYA014_a ±0.1 pF for 5 pF ≤ C < 10 pF (1) ±1% for C ≥ 10 pF Packing 1 180 mm / 7" reel 7 330 mm / 13" reel 4 bulk case Note 1. ±1 % only available in 0402, 0603, 0805, and 1206. Clear text code Example: 0805CG102J9B200 Size Code Temp. Char. 0402 (1) CG = NP0 0603 (1) 0805 (1) 1206 (1) 1210 1812 Capacitance 102 = 1000 pF; the third digit signifies the multiplying factor: 8 = × 0.01 9 = × 0.1 0=×1 1 = × 10 2 = × 100 3 = × 1000 Tol. Vol. Termination B = ±0.1 pF 9 = 50 V B = NiSn C = ±0.25 pF D = ±0.5 pF F = ±1 % G = ±2% J = ±5% Packing Marking Series 2 = 180 mm; 7" paper 0 = no marking 0 = conv. ceramic 3 = 330 mm; 13" paper B = 180 mm; 7" blister F = 330 mm; 13" blister P = bulk case Note 1. ±1 % only available in 0402, 0603, 0805, and 1206. 2004 Jul 06 Rev.10 7 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V SELECTION CHART FOR 100 V C (pF) LAST TWO DIGITS OF 12NC 10 23 12 24 15 25 18 26 22 27 27 28 33 29 39 31 47 32 56 33 68 34 82 35 100 36 120 37 150 38 180 39 220 41 270 42 330 43 390 44 470 45 560 46 680 47 820 48 100 V 0603 0805 1206 0.8 ±0.07 0.6 ±0.1 0.6 ±0.1 1210 1812 Note 1. Values in shaded cells indicate thickness class. 2004 Jul 06 Rev.10 8 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V SELECTION CHART FOR 100 V (CONTINUED) C (pF) LAST TWO DIGITS OF 12NC 1,000 49 1,200 51 1,500 52 1,800 53 2,200 54 2,700 55 3,300 56 3,900 57 4,700 58 5,600 59 6,800 61 8,200 62 10,000 63 12,000 64 15,000 65 18,000 66 22,000 67 100 V 0603 0805 1206 1210 1812 0.6 ±0.1 0.85 ±0.1 0.6 ±0.1 1.25 ±0.1 0.85 ±0.1 1.15 ±0.1 0.5 to 1.0 0.5 to 1.0 0.9 to 1.3 Note 1. Values in shaded cells indicate thickness class. 2004 Jul 06 Rev.10 9 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V SELECTION CHART FOR 200 V AND 250 V C (pF) LAST TWO DIGITS OF 12NC 10 23 12 24 15 25 18 26 22 27 27 28 33 29 39 31 47 32 56 33 68 34 82 35 100 36 120 37 150 38 180 39 220 41 270 42 330 43 390 44 470 45 560 46 680 47 820 48 1,000 49 1,200 51 1,500 52 1,800 53 2,200 54 2,700 55 3,300 56 3,900 57 0.8 to 1.0 0.8 to 1.0 4,700 58 0.9 to 1.3 0.9 to 1.3 5,600 59 200 V 0805 1206 0.6 ±0.1 0.6 ±0.1 250 V 1210 1812 0.85 ±0.1 0805 1206 0.6 ±0.1 0.6 ±0.1 1210 1812 0.85 ±0.1 0.85 ±0.1 0.85 ±0.1 1.25 ±0.1 1.25 ±0.1 1.15 ±0.1 1.15 ±0.1 0.8 to 1.0 0.8 to 1.0 0.9 to 1.3 0.9 to 1.3 Note 1. Values in shaded cells indicate thickness class. 2004 Jul 06 Rev.10 10 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V SELECTION CHART FOR 500 V C (pF) LAST TWO DIGITS OF 12NC 10 23 12 24 15 25 18 26 22 27 27 28 33 29 39 31 47 32 56 33 68 34 82 35 100 36 120 37 150 38 180 39 220 41 270 42 330 43 390 44 470 45 560 46 680 47 820 48 1,000 49 1,200 51 1,500 52 1,800 53 2,200 54 2,700 55 3,300 56 3,900 57 4,700 58 5,600 59 500 V 1206 1210 1812 0.6 ±0.1 0.8 to 1.0 0.85 ±0.1 1.15 ±0.1 0.9 to 1.3 1.2 to 1.75 0.9 to 1.3 Note 1. Values in shaded cells indicate thickness class. 2004 Jul 06 Rev.10 11 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V Thickness classification and packing quantities THICKNESS CLASSIFICATION (mm) 8 mm TAPE WIDTH QUANTITY PER REEL ∅180 mm; 7" PAPER BLISTER 12 mm TAPE WIDTH QUANTITY PER REEL ∅330 mm; 13" ∅180 mm; 7" BLISTER PAPER BLISTER 1812 QUANTITY PER BULK CASE 0603 0805 0.6 ±0.1 4,000 − 20,000 − − − 10,000 0.8 ±0.07 4,000 − 15,000 − − 15,000 − 0.85 ±0.1 4,000 − 15,000 − − − 8,000 0.8 to 1.0 − 4,000 − 10,000 2,000 − − 0.9 to 1.3 − 3,000 − 10,000 1 500 − − 1.15 ±0.1 − 3,000 − 10,000 − − − 1.25 ±0.1 − 3,000 − 10,000 − − 5,000 1.2 to 1.75 − 2 500 − 10,000 1 200 − − 2004 Jul 06 Rev.10 12 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V ORDERING INFORMATION FOR 100 V TO 500 V Components may be ordered by using either a Phycomp’s unique 12NC or simple 15-digit clear text code. Ordering code 12NC (preferred) 2 2 X X X X X X 1 X X X Carrier type 22 blister 38 paper 54 bulk Capacitance value see selection chart Voltage 60 100 V 93 200 V 83 250 V 97 500 V Tolerance 4 ±2% 5 ±5% Size 6 0 1 2 4 Packing 1 180 mm / 7" reel 5 330 mm / 13" reel 4 bulk case 0603 0805 1206 1210 1812 RYA016_a Clear text code Example: 1206CG102GBB200 Size Code 0805 1206 1210 1812 Temp. Char. Capacitance Tol. CG = NP0 102 = 1000 pF; G = ±2% J = ±5% the third digit signifies the multiplying factor: Vol. 0 = 100 V B = 200 V C = 250 V D = 500 V Termination B = NiSn 0=×1 1 = × 10 2 = × 100 3 = × 1000 2004 Jul 06 Rev.10 13 Packing Marking Series 0 = no marking 0 = conv. 2 = 180 mm; 7" paper ceramic 3 = 330 mm; 13" paper B = 180 mm; 7" blister F = 330 mm; 13" blister P = bulk case www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V ELECTRICAL CHARACTERISTICS Class 1 capacitors; NP0 dielectric; NiSn terminations Unless otherwise stated all electrical values apply at an ambient temperature of 20 ±1 °C, an atmospheric pressure of 86 to 106 kPa, and a relative humidity of 63 to 67%. DESCRIPTION VALUE Capacitance range (E12 series); note 1 50 V 0.47 pF to 22 nF 100 V 10 pF to 22 nF 200 V 10 pF to 5.6 nF 500 V 10 pF to 3.3 nF Tolerance on capacitance after 1,000 hours C ≥ 10 pF ±5%; ±2% 5 pF ≤ C < 10 pF ±0.5 pF, ±0.25 pF C < 5 pF ±0.25 pF Tan δ; note 1 C < 10pF  3 ≤10  + 0.7  C  C ≥ 10 pF ≤10 × 10−4 Insulation resistance after 1 minute at Ur (DC) × 10−4 or 30 × 10−4, whichever is smallest Rins > 10 GΩ Temperature coefficient: C < 10 pF (0 ±150) × 10−6/K; note 2 C ≥ 10 pF (0 ±30) × 10−6/K; note 2 Ageing not applicable Notes 1. Measured at 1 V, 1 MHz for C ≤ 1000 pF and 1 V, 1 kHz for C > 1,000 pF, using a four-gauge method. 2. For sizes 0402 and 0603 all capacitance values from 0.47 pF to 150 pF have a temperature coefficient of (0 ±30) × 10−6/K. 2004 Jul 06 Rev.10 14 www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V MEA607 MEA608 10 tan δ (x 10 – 4) 40 TC (x10 6/K) 7.5 20 5 0 20 2.5 40 0 40 0 40 80 – 40 120 T ( C) o 0 40 80 120 T ( oC) Sample limits (broken lines). Requirement levels (dotted lines). Fig.3 Typical temperature coefficient as a function of temperature. MEA614 15 ∆C C (%) 10 Typical tan δ as a function of temperature. Fig.4 MGA457 - 1 1 ∆C C (%) 0.5 5 0 0 Ð5 −0.5 Ð 10 Ð 15 0 10 20 30 −1 40 50 V DC (V) 0 250 500 VDC (V) High voltage series. Fig.5 Fig.6 Typical capacitance change with respect to the capacitance at 1 V as a function of DC voltage. 2004 Jul 06 Rev.10 15 Typical capacitance change with respect to the capacitance at 1 V as a function of DC voltage. www.yageo.com Phycomp Product specification Surface-mount ceramic multilayer capacitors Class 1, NP0 50 V to 500V REVISION HISTORY Revision Date Change Notification Description Rev.6 2001 Jul 16 − - Converted to Phycomp brand - Highest value in 50 V range reduced from 47 nF to 33 nF - Various thickness classes corrected - Products in 2020 case size removed - AgPd finishing for terminations no longer supported Rev.7 2003 Mar 21 - - Updated company logo Rev.8 2003 Jul 24 - - Cover page revised Rev.9 2004 Apr 27 - - "Silver palladium (AgPd)" in the description on page 2 deleted Rev.10 2004 Jul 06 - - Insulation resistance updated!! 2004 Jul 06 Rev.10 16 www.yageo.com
223886915689 价格&库存
很抱歉,暂时无法提供与“223886915689”相匹配的价格&库存,您可以联系我们找货
