391KD14
391KD14
    YAGEO(国巨)
    Metal Oxide Varistors
391KD14 数据手册
DATA SHEET METAL OXIDE VARISTORS POWER SUPPLY 14D series Product specification– May 08, 2021 V.2 RoHS compliant & Halogen free Circuit Protection Product Specification METAL OXIDE VARISTORS 2 16 14D Metal Oxide Varistor (MOV) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ Wide operating voltage (V1mA) range from 18V to 1800V Fast responding to transient over-voltage Large absorbing transient energy capability Low clamping ratio and no follow-on current Meets MSL level 1, per J-STD-020 Operating Temperature:-40℃ ~ +105℃ Storage Temperature:-40℃ ~ +125℃ Safety certification:UL、CSA、VDE Applications ■ ■ ■ ■ ■ Transistor, diode, IC, thyristor or triac semiconductor protection Surge protection in consumer electronics Surge protection in industrial electronics Surge protection in electronic home appliances, gas and petroleum appliances Relay and electromagnetic valve surge absorption Part Number Code 4 7 1 K D 1 4 J O TR Packing No suffix: Bulk TB: Tape & Box & P0=12.7mm TR: Tape & Reel & P0=12.7mm EB: Tape & Box & P0=15.0mm ER: Tape & Reel & P0=15.0mm Tolerance K: ±10% Type D: Disk Varistor Voltage 180: 18V 101: 100V 102: 1000V Surge Series No suffix: Standard type J: High Surge type Lead Shape No suffix: Straight leads O: Outside crimped leads F: Y Kinked leads Element Diameter 14 www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 3 16 14D Dimensions D D T D H1 H1 H T K≤3.0 L1 L1 F L d1 d K≤3.0 d e d F O Type F Type Notes: Varistor voltage≥1200V, structure diagram is F type. Table 1 Table 2 Unit: mm Unit: mm Symbol Dimension Model T e Model T e H 14.5~20.0 180K 2.0~3.9 1.5 361K 2.9~5.2 2.7 H1 17.0~21.0 220K 2.1~4.0 1.6 391K 3.0~5.4 2.8 L(min.) 20.0 270K 2.1~4.1 1.8 431K 3.2~5.6 3.0 L1(min.) 15.0 330K 2.2~4.3 1.7 471K 3.3~5.8 3.2 D 14.0~16.5 390K 2.1~4.1 1.8 511K 3.4~6.1 3.4 F(±0.8) 7.5 470K 2.2~4.3 1.9 561K 3.6~6.4 3.6 T Table 2 560K 2.3~4.6 2.1 621K 3.8~6.8 3.9 e(±0.8) Table 2 680K 2.4~4.8 2.4 681K 4.0~7.1 4.2 d(±0.05) 0.8 820K 2.1~4.1 1.8 751K 4.3~7.2 4.3 d1(±0.4) 1.4 101K 2.4~4.2 2.0 781K 4.4~7.3 4.4 121K 2.4~4.4 2.2 821K 4.6~7.5 4.6 151K 2.2~4.1 1.8 911K 4.8~7.5 5.0 181K 2.3~4.2 1.9 102K 5.4~8.0 5.0 201K 2.4~4.3 2.0 112K 5.8~8.5 5.4 221K 2.5~4.4 2.1 122K 5.9~9.0 5.8 241K 2.6~4.5 2.2 142 6.9~10.5 6.6 271K 2.6~4.6 2.4 162 7.4~11.0 7.4 301K 2.7~4.6 2.5 182 7.6~12.0 8.2 331K 2.7~5.0 2.5 www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 4 16 14D Electrical Characteristics Maximum Allowable Voltage Part Number Varistor Voltage Maximum Clamping Voltage Withstanding Surge Current Maximum Energy (10/1000μs) Rated Power Typical Capacitance (Reference) Standard High Surge VAC(V) VDC(V) V1mA(V) IP(A) VC(V) I (A) Standard I (A) High Surge (J) Standard (J) High Surge (W) @1KHz (pf) 180KD14 180KD14J 11 14 18(15~21.6) 10 36 1000 2000 4.0 7.0 0.1 11100 220KD14 220KD14J 14 18 22(19.5~26) 10 43 1000 2000 5.0 8.0 0.1 9100 270KD14 270KD14J 17 22 27(24~31) 10 53 1000 2000 6.0 10.0 0.1 7400 330KD14 330KD14J 20 26 33(29.5~36.5) 10 65 1000 2000 7.5 12.0 0.1 6100 390KD14 390KD14J 25 31 39(35~43) 10 77 1000 2000 8.6 13.0 0.1 5100 470KD14 470KD14J 30 38 47(42~52) 10 93 1000 2000 10.0 17.0 0.1 4300 560KD14 560KD14J 35 45 56(50~62) 10 110 1000 2000 11.0 20.0 0.1 3600 680KD14 680KD14J 40 56 68(61~75) 10 135 1000 2000 14.0 24.0 0.1 2900 820KD14 820KD14J 50 65 82(74~90) 50 135 4500 6000 22.0 27.0 0.6 2400 101KD14 101KD14J 60 85 100(90~110) 50 165 4500 6000 28.0 33.0 0.6 2000 121KD14 121KD14J 75 100 120(108~132) 50 200 4500 6000 32.0 40.0 0.6 1700 151KD14 151KD14J 95 125 150(135~165) 50 250 4500 6000 40.0 53.0 0.6 1300 181KD14 181KD14J 115 150 180(162~198) 50 300 4500 6000 50.0 60.0 0.6 1100 201KD14 201KD14J 130 170 200(180~220) 50 340 4500 6000 57.0 70.0 0.6 1000 221KD14 221KD14J 140 180 220(198~242) 50 360 4500 6000 60.0 78.0 0.6 900 241KD14 241KD14J 150 200 240(216~264) 50 395 4500 6000 63.0 84.0 0.6 830 271KD14 271KD14J 175 225 270(243~297) 50 455 4500 6000 70.0 99.0 0.6 740 301KD14 301KD14J 190 250 300(270~330) 50 500 4500 6000 77.0 108 0.6 670 331KD14 331KD14J 210 275 330(297~363) 50 550 4500 6000 85.0 115 0.6 610 361KD14 361KD14J 230 300 360(324~396) 50 595 4500 6000 93.0 130 0.6 560 391KD14 391KD14J 250 320 390(351~429) 50 650 4500 6000 100 140 0.6 510 431KD14 431KD14J 275 350 430(387~473) 50 710 4500 6000 115 155 0.6 460 471KD14 471KD14J 300 385 470(423~517) 50 775 4500 6000 118 175 0.6 430 511KD14 511KD14J 320 415 510(459~561) 50 845 4500 6000 121 180 0.6 390 561KD14 561KD14J 350 460 560(504~616) 50 925 4500 6000 125 185 0.6 360 621KD14 621KD14J 385 505 620(558~682) 50 1025 4500 6000 128 190 0.6 320 681KD14 681KD14J 420 560 680(612~748) 50 1120 4500 6000 130 200 0.6 290 751KD14 751KD14J 460 615 750(675~825) 50 1240 4500 6000 143 210 0.6 270 781KD14 781KD14J 485 640 780(702~858) 50 1290 4500 6000 148 220 0.6 260 821KD14 821KD14J 510 670 820(738~902) 50 1355 4500 6000 157 235 0.6 240 911KD14 911KD14J 550 745 910(819~1001) 50 1500 4500 6000 175 255 0.6 220 102KD14 102KD14J 625 825 1000(900~1100) 50 1650 4500 6000 190 280 0.6 200 112KD14 112KD14J 680 895 1100(990~1210) 50 1815 4500 6000 213 310 0.6 180 122KD14 122KD14J 750 990 1200(1080~1320) 50 1980 4500 6000 232 324 0.6 160 142KD14 / 880 1140 1400(1260~1540) 50 2310 4500 / 238 / 0.6 150 162KD14 / 1000 1280 1600(1440~1760) 50 2640 4500 / 243 / 0.6 140 182KD14 / 1100 1465 1800(1620~1980) 50 2970 4500 / 250 / 0.6 130 Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%; 2. Varistor voltage≥1200V, structure diagram is F type; 3. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~182K). www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 5 16 14D Maximum Surge Current Derating Curve 180KD14 to 680KD14 820KD14 to 182KD14 10000 10000 1000 1 100 2 10 1023 104 10 105 106 1000 Max. Surge Current (A) Max. Surge Current (A) 1 2 10 1 100 10 102 103 104 105 106 10 1 0.1 10 100 1000 0.1 10 10000 100 Td (μs) 10000 10000 1 2 1 1000 2 10 102 103 104 105 106 Max. Surge Current (A) Max. Surge Current (A) 100 10000 820KD14J to 122KD14J 180KD14J to 680KD14J 1000 1000 Td (μs) 10 1 0.1 10 100 10 102 103 104 105 106 10 1 100 1000 Td (μs) 10000 0.1 10 100 1000 10000 Td (μs) www.yageo.com May. 08, 2021 V.0 Circuit Protection METAL OXIDE VARISTORS Product Specification 14D 6 16 Maximum Leakage Current and Maximum Clamping Voltage Curve www.yageo.com May. 08, 2021 V.0 Circuit Protection METAL OXIDE VARISTORS Product Specification 14D 7 16 Maximum Leakage Current and Maximum Clamping Voltage Curve www.yageo.com May. 08, 2021 V.0 Circuit Protection METAL OXIDE VARISTORS Product Specification 14D 8 16 Maximum Leakage Current and Maximum Clamping Voltage Curve www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 9 16 14D Reliability Items Standard Test conditions / Methods Specifications Gradually applying the force specified and keeping the unit fixed for 10±1 sec. Tensile Strength of Terminals IEC60068-2-21 Terminal diameter (mm) 0.5<d≤0.8 0.8<d≤1.25 1.25<d Force (kg) No visible damage 1.0 2.0 4.0 |ΔV1mA/V1mA |≤5% Hold specimen and apply the force specified below to each lead. Bend the specimen to 90°, then return to the original position. Repeat the procedure in the opposite direction. Bending Strength of Terminals Vibration Solderability Resistance to Soldering Heat High Temperature Storage Low Temperature Storage Damp Heat, Steady State High Temperature Load Terminal diameter (mm) 0.5<d≤0.8 0.8<d≤1.25 1.25<d IEC60068-2-21 Force (kg) 0.5 1.0 2.0 IEC60068-2-6 Frequency range: 10~55 Hz 2 Amplitude: 0.75mm or 98m/s Direction: 3 mutually perpendicular directions, 2hrs each. IEC60068-2-20 Solder Temp: 245±5℃ Dipping Time: 2±0.5 sec No visible damage |ΔV1mA/V1mA |≤5% No visible damage |ΔV1mA/V1mA |≤5% Solder Temp: 260±5℃ Dipping Time: 10±1 sec Ambient Temp: 125±2℃ Duration: 1000±24hrs At least 95% of terminal electrode is covered by new solder No visible damage |ΔV1mA/V1mA |≤5% No visible damage |ΔV1mA/V1mA |≤5% Ambient Temp: -40±2℃ No visible damage Duration: 1000±24hrs |ΔV1mA/V1mA |≤5% IEC60068-2-78 The test is divided into two groups . a. 40±2℃ , 90~95% RH for 1344±24hrs b. 40±2℃ , 90~95% RH,at 10%VDC ,1344±24 hrs No visible damage |ΔV1mA/V1mA|≤10% Insulation Resistance≧100MΩ MIL-STD-202 Ambient Temp: 105±2℃ Method 108 Load: Max. Allowable Voltage In AC. IEC60068-2-20 IEC60068-2-2 IEC60068-2-1 Duration: 1000±24hrs |ΔV1mA/V1mA|≤10% The conditions shown below shall be repeated 5 cycles Temperature Cycle IEC60068-2-14 10/1000µS Surge Life Temperature (℃) Period (minutes) 1 -40±3 30±3 No visible damage 2 Room temperature 5±3 |ΔV1mA/V1mA |≤5% 3 125±3 30±3 4 Room temperature 5±3 8/20µS waveform,10 surge currents, unipolar, interval 8/20uS Surge Life Step IEC61051-1 30secs,amplitude corresponding to max. surge current No visible damage △Vb(1mA)≦±10% derating curves for 20µS. 10/1000µS waveform,10 surge currents, unipolar, interval IEC61051-1 2mins,amplitude corresponding to max. surge current derating No visible damage |ΔV1mA/V1mA |≤10% curves for 1000µS. Voltage Proof IEC61051-1 Metal balls method, 2500Vac 1 min. No visible damage www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 10 16 14D Soldering Recommendation Lead-free Wave Soldering Recommendation 300 Maximum Wave 265℃ Preheating Soldering Cooling Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds (max.) Soldering 1 time Recommendation Reworking Conditions with Soldering Iron Item Conditions Temperature of Soldering Iron-tip 360℃ (max.) Soldering Time 3 seconds (max.) Distance from Varistor 2mm (min.) Marking Code ① XXXKDXXX ② ③ ④ ⑤ XXX Y VDE ① Brightking Logo ② Varistor Voltage ③ CSA Accreditation Logo ⑥ ⑦ ④ UL Accreditation Logo ⑤ VDE Accreditation Logo ⑧ ⑥“J”is High Surge Code, no“J”is Standard Surge ⑦ Disk Size ⑧ Internal control code www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 11 16 14D Taping Dimensions P2 P h B W0 W H0 W2 D0 I P1 F W1 P0 t h P2 B P W0 W H0 W2 D0 I P1 P0 F W1 t Symbol Dimension (mm) P 25.4±1.0 P0 12.7±1.0 P1 8.95±0.7 P2 12.7±1.3 F 7.5±0.8 h 0±4 W 18.0±1.0 W0 12.0±1.0 W1 9.0±0.5 W2 3.0max H0 16.0±1.0 I 2.0max D0 4.0±0.2 t 0.6±0.3 B 40max Symbol Dimension (mm) P 30.0±1.0 P0 15.0±1.0 P1 3.85±0.7 P2 7.5±1.3 F 7.5±0.8 h 0±4 W 18.0±1.0 W0 12.0±1.0 W1 9.0±0.5 W2 3.0max H0 16.0±1.0 I 2.0max D0 4.0±0.2 t 0.6±0.3 B 40max www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 12 16 14D Taping Dimensions P2 h P B W0 W H0 W2 D0 I F P1 W1 P0 t h P2 B P W0 W H0 W2 D0 I P1 F P0 W1 t Symbol Dimension (mm) P 25.4±1.0 P0 12.7±1.0 P1 8.95±0.7 P2 12.7±1.3 F 7.5±0.8 h 0±4 W 18.0±1.0 W0 12.0±1.0 W1 9.0±0.5 W2 3.0max H0 16.0±1.0 I 2.0max D0 4.0±0.2 t 0.6±0.3 B 40max Symbol Dimension (mm) P 30.0±1.0 P0 15.0±1.0 P1 3.85±0.7 P2 7.5±1.3 F 7.5±0.8 h 0±4 W 18.0±1.0 W0 12.0±1.0 W1 9.0±0.5 W2 3.0max H0 16.0±1.0 I 2.0max D0 4.0±0.2 t 0.6±0.3 B 40max www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 13 16 14D Taping Dimensions P h B P2 W0 W H2 W2 D0 I F P1 W1 P0 t h P2 B P W0 W H2 W2 D0 I P1 F P0 W1 t Symbol Dimension (mm) P 25.4±1.0 P0 12.7±1.0 P1 8.95±0.7 P2 12.7±1.3 F 7.5±0.8 h 0±4 W 18.0±1.0 W0 12.0±1.0 W1 9.0±0.5 W2 3.0max H2 20.0±2.0 I 2.0max D0 4.0±0.2 t 0.6±0.3 B 40max Symbol Dimension (mm) P 30.0±1.0 P0 15.0±1.0 P1 3.85±0.7 P2 7.5±1.3 F 7.5±0.8 h 0±4 W 18.0±1.0 W0 12.0±1.0 W1 9.0±0.5 W2 3.0max H2 20.0±2.0 I 2.0max D0 4.0±0.2 t 0.6±0.3 B 40max www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 14 16 14D Quantity Packaging Dimensions (Unit: mm) Quantity In bulk for Terminals Untrimmed Products 400pcs/bag 4bags/box (180K~331K) ax . 300pcs/bag 4bags/box (361K~621K) 5M 250pcs/bag 4bags/box (681K~112K) 16 130 Max. 250 Max. 150pcs/bag 4bags/box (122K~182K) In bulk for Terminals Trimmed Products 400pcs/bag 4bags/box (180K~331K) 5M ax . 300pcs/bag 4bags/box (361K~621K) 250pcs/bag 4bags/box (681K~112K) 16 66 Max. 252 Max. 150pcs/bag 4bags/box (122K~182K) Packaging Dimensions (Unit: mm) Quantity Tape & Box & P0=12.7mm 750pcs/ box (180K~241K) 0M ax . 600pcs/ box (271K~331K) 25 60 Max. 500pcs/ box (361K~621K) 340 Max. 400pcs/ box (681K~751K) 350pcs/ box (781K~112K) www.yageo.com May. 08, 2021 V.0 Circuit Protection Product Specification METAL OXIDE VARISTORS 15 16 14D Quantity Packaging Dimensions (Unit: mm) Quantity Tape & Reel & P0=12.7mm 750pcs/reel (361K~621K) 5M ax . 1000pcs/reel (180K~331K) 36 60 Max. 500pcs/reel (681K~751K) 365 Max. 55 Max. 30±1 Φ365 Max. 400pcs/reel (781K~112K) Packaging Dimensions (Unit: mm) Quantity Tape & Box & P0=15.0mm ax . 500pcs/ box (180K~331K) 0M 400pcs/ box (361K~751K) 25 60 Max. 340 Max. 300pcs/ box (781K~112K) Tape & Reel & P0=15.0mm 5M ax . 750pcs/reel (180K~331K) 36 60 Max. 600pcs/reel (361K~751K) 365 Max. 55 Max. 30±1 Φ365 Max. 500pcs/reel (781K~112K) www.yageo.com May. 08, 2021 V.0 Circuit Protection METAL OXIDE VARISTORS Product Specification 14D 16 16 Storage Condition of Products (I) Storage Conditions : 1.Storage Temperature : -10℃ ~ +40℃ 2.Relative Humidity : ≦80%RH 3.Keep away from corrosive atmosphere and sunlight. (II) Period of Storage : 1 year www.yageo.com May. 08, 2021 V.0
391KD14
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出电路。
3. 引脚分配:共有6个引脚,分别为1脚发光二极管阳极,2脚发光二极管阴极,3脚光电晶体管集电极,4脚光电晶体管发射极,5脚光电晶体管基极,6脚Vcc。
4. 参数特性:工作温度范围为-40℃至+85℃,输入电流为10mA,输出电流为10mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、医疗设备、通信设备等领域。
7. 封装信息:采用DIP-6封装形式。
391KD14 价格&库存
很抱歉,暂时无法提供与“391KD14”相匹配的价格&库存,您可以联系我们找货
