AC0612JR-0782RL
AC0612JR-0782RL
    YAGEO(国巨)
    AC0612JR-0782RL
AC0612JR-0782RL 数据手册
DATA SHEET THICK FILM WIDE TERMINAL CHIP RESISTORS AUTOMOTIVE GRADE AC series ±5%, ±1%, ±0.5% Product specification – December 11, 2015 V.1 Sizes 0612/1020/1225 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount AC 9 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AC0612 to AC1225 chip resistors with leadfree terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS  All general purpose applications  Car electronics, industrial application FEATURES  AEC-Q200 qualified  Moisture sensitivity level: MSL 1  AC series soldering is compliant with J-STD-020D  Halogen free epoxy  RoHS compliant - Products with lead-free terminations meet RoHS requirements - Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS  Reduce environmentally hazardous waste  High component and equipment reliability  The resistors are 100% performed by automatic optical inspection prior to taping. 2 0612/1020/1225 SERIES GLOBAL PART NUMBER AC XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0612/1020/1225 (2) TOLERANCE D = ± 0.5% F = ± 1% J = ± 5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel (6) RESISTANCE VALUE 1Ω to 1 MΩ There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω 976R = 976 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω XXMX (10 MΩ) 10M = 10,000,000 Ω O RDERING EXAMPLE The ordering code for an AC0612 chip resistor, value 100 KΩ with ± 1% tolerance, supplied in 7-inch tape reel is: AC0612FR-07100KL. NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process". 2. On customized label, "LFP" or specific symbol can be printed. 3. AC series with ±0.5% tolerance is also available. For further information, please contact sales. www.yageo.com Dec. 11, 2015 V.1 Product specification Chip Resistor Surface Mount AC SERIES 3 9 0612/1020/1225 MARKING AC0612 / AC1020 / AC1225 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 1 Value=10 KΩ Fig. 2 E-24/ E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Value=10 KΩ CONSTRUCTION The resistors are constructed on top of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by the resistive glaze. The resistive glaze is covered by a leadfree glass. The composition of the glaze is adjusted to give the approximate required resistance value and laser trimming of this resistive glaze achieves the value inside tolerance. The whole element is covered by a protective overcoat. Size 0508 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added. See fig.3. OUTLINES Fig. 3 Chip resistor outlines DIMENSIONS Table 1 For outlines, please refer to Fig. 4 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AC0612 1.60± 0.20 3.20 ± 0.20 0.55± 0.10 0.18± 0.15 0.40± 0.15 AC1020 2.50 ± 0.20 5.00 ± 0.20 0.55± 0.10 0.25 ± 0.20 0.90 ± 0.20 AC1225 3.20 ± 0.20 6.40 ± 0.20 0.55± 0.10 0.45 ± 0.20 0.75 ± 0.20 For dimension, please refer to Table 1 Side view for all type Fig. 4 Chip resistor dimensions www.yageo.com Dec. 11, 2015 V.1 Product specification Chip Resistor Surface Mount AC SERIES 4 9 0612/1020/1225 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS RESISTANCE RANGE TYPE Operating Temperature Range AC0612 AC1020 5% (E24) 1Ω to 1MΩ 0.5%, 1% (E24/E96) 1Ω to 1MΩ Jumper < 50mΩ AC1225 –55 °C to +155 °C Max. Working Voltage Max. Overload Voltage Dielectric Withstanding Voltage 200V 400V 500V 200V 400V 500V 200V 400V 500V Temperature Jumper Criteria Coefficient of Resistance 1Ω≤R≤10Ω, ±200ppm/℃ Rated Current 10Ω
AC0612JR-0782RL
物料型号:AC系列,包括0612、1020、1225尺寸。
器件简介:这些电阻器采用无铅端面制作,通过厚膜工艺制造,符合汽车级标准,具有AEC-Q200认证,适用于一般用途、汽车电子和工业应用。
引脚分配:文档中未明确说明引脚分配,但通常这类电阻器为端面引脚。
参数特性:电阻值范围从1Ω至1MΩ,公差有±5%、±1%和±0.5%可选。电阻器符合RoHS标准,无卤素环氧树脂封装,具有较高的组件和设备可靠性。
功能详解:电阻器在制造过程中100%通过自动光学检测。标记方式遵循E-24、E-96系列标准,尺寸从0508及以上的电阻器在顶部标记有阻值。
应用信息:适用于一般用途、汽车电子和工业应用。
封装信息:提供7英寸和13英寸纸带卷装或浮雕卷装,具体包装风格和数量见文档中的表格。
电气特性:包括工作温度范围、最大工作电压、最大过载电压、介质耐压、电阻温度系数等。
测试和要求:包括高温暴露、耐湿性、偏置湿度、工作寿命、耐焊热性、热冲击和静电放电等测试。
法律声明:Yageo保留随时更改产品相关信息的权利,不承担因产品应用或使用引起的任何责任。
AC0612JR-0782RL 价格&库存
很抱歉,暂时无法提供与“AC0612JR-0782RL”相匹配的价格&库存,您可以联系我们找货
AC0612JR-0782RL
    • 1+1.30870
    • 100+0.85990
    • 1000+0.58300
    • 2500+0.40160
    • 5000+0.28610
    库存:4740
    AC0612JR-0782RL
    • 20+0.02160
    • 200+0.01950
    • 1000+0.01840
    • 3000+0.01730
    库存:8397
