AF0201FR-0739R2L
AF0201FR-0739R2L
    YAGEO(国巨)
AF0201FR-0739R2L 数据手册
DATA SHEET ANTI-SULFURATED CHIP RESISTORS AUTOMOTIVE GRADE AF series 5%, 1%, 0.5% sizes 0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 Product specification – January 26, 2022 V.9 RoHS compliant & Halogen free 2 Product specification Chip Resistor Surface Mount AF 10 0100 to 2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AF0100 to AF2512 chip resistors with anti-sulfuration capabilities. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS AF XXXX X X X XX XXXX L Industrial Equipment Power Application Networking Application High-end Computer & Multimedia Electronics in high sulfur environment  Automotive electronics     GLOBAL PART NUMBER (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 (2) TOLERANCE D = ± 0.5% F = ± 1% J = ± 5% (for jumper ordering, use code of J) FEATURES  AEC-Q200 qualified  Superior resistance against sulfur containing atmosphere  Halogen free product and production  RoHS compliant  Reduces environmentally hazardous waste  High component and equipment reliability  Saving of PCB space  Moisture sensitivity level: MSL 1  50ppm available (3) PACKAGING TYPE R = Paper taping reel K = Embossed plastic tape reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point. Detailed resistance rules are displayed in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is system default code for ordering only (Note) Resistance rule of global part number Resistance coding rule Example XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω O RDERING EXAMPLE The ordering code for an AF0402 chip resistor, value 100 KΩ with ± 1% tolerance, supplied in 7-inch tape reel with 10Kpcs quantity is: AF0402FR-07100KL. NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com Jan. 26, 2022 V.9 Product specification Chip Resistor Surface Mount AF SERIES 3 10 0100 to 2512 MARKING AF0100 / AF0201 / AF0402 No marking ynsc007 Fig. 1 AF0603 / AF0805 / AF1206 / AF1210 / AF2010 / AF2512 03 Fig. 2 YNSC001 Value=10 KΩ E-24 series: 3 digits, ±5%, ≥10Ω First two digits for significant figure and 3rd digit for number of zeros AF0603 0 YNSC037 Fig. 3 Value = 24 Ω E-24 series: 3 digits, ± 1% One short bar under marking letter E-96 series: 3 digits, ± 1% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AF0805 / AF1206 / AF1210 / AF2010 / AF2512 00 YNSC004 Fig. 5 Value = 10 KΩ Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros AF1218 YNSC099-2 Fig. 6 Value = 10 KΩ YNSC103-2 Fig. 7 Value = 10 KΩ E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros NOTE For further marking information, please see special data sheet “Chip resistors marking”. Marking of AF series is the same as RC series www.yageo.com Jan. 26, 2022 V.9 Product specification Chip Resistor Surface Mount AF 4 10 0100 to 2512 SERIES CONSTRUCTION The resistors are constructed on top of a high grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a glass. The composition of the glaze is adjusted to give the approximate required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added. See fig.8 OUTLINES For dimensions see Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 DIMENSIONS Table 1 For outlines see fig. 8 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AF0100 0.40± 0.02 0.20± 0.02 0.14± 0.02 0.10± 0.03 0.10± 0.03 AF0201 0.60± 0.03 0.30± 0.03 0.23± 0.03 0.12± 0.05 0.15± 0.05 AF0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 AF0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 0.25± 0.15 W YNSC086 L Fig. 8 Chip resistor outlines AF0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 0.35± 0.20 AF1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 0.50± 0.20 AF1210 3.10± 0.10 2.60± 0.15 0.57± 0.10 0.45± 0.20 0.50± 0.20 AF1218 3.10± 0.10 4.60± 0.10 0.57± 0.10 0.45± 0.20 0.50± 0.20 AF2010 5.00± 0.10 2.50± 0.15 0.57± 0.10 0.55± 0.20 0.55± 0.20 AF2512 6.35± 0.10 3.20± 0.15 0.57± 0.10 0.60± 0.20 0.60± 0.20 www.yageo.com Jan. 26, 2022 V.9 Product specification Chip Resistor Surface Mount AF SERIES 5 10 0100 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE AF0100 AF0201 POWER 1/32 W Operating Temperature Range –55 °C to 125°C 1/20 W Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage 15V 25V 30V 50V Resistance Range Temperature Coefficient Jumper Criteria 30V 5% (E24) 10Ω ≤ R ≤ 1MΩ 1% (E24/E96) 10Ω ≤ R ≤ 1MΩ Jumper < 50mΩ 10Ω ≤ R < 100Ω ± 300 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 200 ppm/°C Rated Current 0.5A Max. Current 1.0A 50V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω -100/+350 ppm/°C 10Ω < R ≤ 10MΩ ± 200 ppm/°C Rated Current 0.5A Max. Current 1.0A 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 50 ppm/°C Rated Current 1A Max. Current 2A 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 1/16 W 50V 100V 100V 1/8W 75V 100V 100V AF0402 1/10 W 75V 150V 150V 75V 150V 150V AF0603 1/5 W –55 °C to 155 °C 1/8 W 150V 300V 300V 1/4 W 150V 300V 300V AF0805 1/4 W 200V 400V 500V 1/2 W 200V 400V 500V AF1206 Rated Current 1A Max. Current 2A Rated Current 2A Max. Current 5A Rated Current 2A Max. Current 10A www.yageo.com Jan. 26, 2022 V.9 Product specification Chip Resistor Surface Mount AF SERIES 6 10 0100 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE AF1210 POWER Operating Temperature Range 1/2 W AF1218 Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage 200V 1W 200V 500V 500V 500V 500V –55 °C to 155 °C AF2010 3/4 W AF2512 1W 200V 200V 500V 500V 500V 500V Resistance Range Temperature Coefficient Jumper Criteria 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A 5% (E24) 1Ω ≤ R ≤ 1MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 1MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 1MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 2.2MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A www.yageo.com Jan. 26, 2022 V.9 Product specification Chip Resistor Surface Mount AF SERIES 7 10 0100 to 2512 FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles of AF -series is the same as RC-series. Please see the special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE Paper taping reel (R) Embossed taping reel (K) REEL DIMENSION AF0100 AF0201 AF0402 AF0603 AF0805 AF1206 AF1210 AF1218 AF2010 AF2512 7" (178 mm) 20,000 10,000/20,000 10,000/20,000 5,000 5,000 -- 13" (330 mm) -- 50,000 50,000 20,000 20,000 -- 7" (178 mm) -- -- -- -- -- 4,000 NOTE 1. For paper/embossed tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE RANGE FUNCTIONAL DESCRIPTION PT040 O PERATING TEMPERATUR100 E RmΩ ANto GE910 mΩ 2 ± 200 ppm/°C AF0100 Range: -55°C to + 125°C PT060 - AF2512 Range: -55°C to + 155°C AF0201 ± 200 ppm/°C 3 PT080 P OWER RATING P (%Prated) MLB206_9-1 100 0201 to 2512 ± 200 ppm/°C 5 Each type power at 70°C: 100rated MΩ TO 910 MΩ PT120 AF0100=1/32W (0.03125W) 100 mΩ 6 AF0201=1/20W (0.05W) PT201 AF0402=1/16 W (0.0625W); ±1/8W (0.125W) 100 ppm/°C 0 AF0603=1/10 W (0.1W); 1/5W (0.2W) PT251 AF0805=1/8 W (0.125W); 1/4W ± 100(0.25W) ppm/°C 2 AF1206=1/4 W (0.25W); 1/2W (0.5W) 50 0100 > 100 mΩ 0 55 0 ± 75 ppm/°C 50 70 100 125 155 o Tamb ( C) Fig. 9 Maximum dissipation (P max) in percentage of rated power as ± 75 ppm/°C a function of the operating ambient temperature (T amb) AF1210=1/2W (0.5W) AF1218=1W AF2010=3/4W (0.75W) AF2512=1W R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V = √(P X R) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com Jan. 26, 2022 V.9 Product specification Chip Resistor Surface Mount AF SERIES 8 10 0100 to 2512 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE Temperature Coefficient of Resistance (T.C.R.) IEC 60115-1 4.8 MIL-STD-202 Method 304 At +25/–55°C and +25/+125°C REQUIREMENTS Refer to table 2 Formula: R2–R1 T.C.R= ------------------------× 106 (ppm/°C) R1(t2–t1) Where t1=+25°C or specified room temperature t2=–55°C or +125°C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Life/Endurance IEC 60115-1 4.25 MIL-STD-202 Method 108 At 70± 2°C for 1,000 hours, RCWV applied for 1.5 hours on, 0.5 hour off, still-air required 0100: ± (3.0%+0.05 Ω) Others: ± (1.0%+0.05 Ω)
AF0201FR-0739R2L
物料型号:AF系列,尺寸从0100到2512,包括5%、1%、0.5%的容差。
器件简介:这是一系列自表面贴装的片式电阻,具有抗硫化能力,符合汽车级标准。
引脚分配:文档中没有明确提到引脚分配,但通常这类电阻为两个端子的简单结构。
参数特性: - 工作温度范围:-55°C 至 +155°C - 最大工作电压和最大过载电压根据型号有所不同 - 电阻范围和温度系数也有不同规格 - 额定电流和最大电流根据型号有所变化
功能详解: - 这些电阻具有优越的抗硫化气氛能力,无卤产品和生产过程 - 符合RoHS标准,减少环境有害废物 - 高组件和设备可靠性,节省PCB空间 - 湿度敏感性等级为MSL 1
应用信息:适用于工业设备、电力应用、网络应用以及在高硫环境中的高端计算机和多媒体电子。
封装信息:提供0100/0201/0402/0603/0805/1206/1210/1218/2010/2512等尺寸,封装类型包括纸带卷装(R)和塑料膜带卷装(K)。
AF0201FR-0739R2L 价格&库存
很抱歉,暂时无法提供与“AF0201FR-0739R2L”相匹配的价格&库存,您可以联系我们找货
AF0201FR-0739R2L
    • 1+0.06370
    • 100+0.04100
    • 1000+0.02930
    • 5000+0.02170
    • 10000+0.01620
    库存:18850
    AF0201FR-0739R2L
      • 100+0.03110
      • 1000+0.02486
      • 3000+0.02139
      库存:99
