Through-hole resistors
Professional &
Flame-Proof Type
Metal Film Resistors
Miniature Style [ FM0 Series ]
FEATURES
INTRODUCTION
Power Rating
0.4W, 0.6W
Resistance Tolerance
±1%, ±5%
T.C.R.
±50ppm/°C, ±100ppm/°C
Flameproof Multi-layer Coating Meets
UL-94V-0
Flameproof Feature Meets Overload Test
UL-1412
DERATING CURVE
The FM0 Series Metal Film Professional &
Flame-Proof Resistors are manufactured using
a vacuum sputtering system to deposit multiple
layers of mixed metal alloys and passivative
materials onto a carefully treated high grade
ceramic substrate. After a helical groove has
been cut in the resistive layer, tinned connecting
leads of electrolytic copper are welded to the
end-caps. The resistors are coated with layers
of light green color lacquer.
For resistors operated in ambient temperatures above 70°C, power rating must be derated
in accordance with the curve below.
70
Rated Load (%)
155 °C
100
80
60
40
60
80
Ambient Temperature (°C)
100 120 140 160
DIMENSIONS
Unit: mm
ød
H
L
øD
STYLE
DIMENSION
Miniature
L
øD
H
ød
FM0204
3.4±0.3
1.9±0.2
28±2.0
0.45±0.05
FM0207
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
13
Note:
ELECTRICAL CHARACTERISTICS
STYLE
FM0204
FM0207
Power Rating at 70°C
0.4W
0.6W
Maximum Working Voltage
200V
300V
Maximum Overload Voltage
400V
600V
Voltage Proof on Insulation
300V
500V
Resistance Range
1Ω - 4M7Ω & 0Ω for E24 & E96 series value
Operating Temp. Range
-55°C to +155°C
Temperature Coefficient
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage)
±0.25%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -55°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>1,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±1.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±1.5%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±1.5%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±0.75%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±0.25%+0.05Ω
Accidental Overload Test
IEC 60115-1 4.26
4 times RCWV for 1 Min.
No evidence of flaming
or arcing
Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“FM0204JT-52-27K”相匹配的价格&库存,您可以联系我们找货
