DATA SHEET
WIRELESS COMPONENTS
Ceramic Chip Antenna
ANT2012LL00R2400A
2.4 – 2.5 GHZ
Product Specification – February 22, 2013 V.0
2012 Series
Product specification
WIRELESS COMPONENTS
2
2
FEATURES
Compact size
Omni-directional Radiation
Tape & reel automatic
mounting
Reflow process compatible
RoHS compliant
ORDERING INFORMATION
APPLICATIONS
2.4GHz
WiFi device
Bluetooth gadget
Zigbee device
ISM band equipment
(1) PRODUCT
All part numbers are identified by the series, packing type, material, size,
antenna type, working frequency and packing quantity.
PART NUMBER
ANT 2012 L L00 R 2400A
(1)
(2)
(3) (4)
(5)
(6)
ANT = Antenna
(2) SIZE
2012 = 2.0 ×1.2 mm
(3) ANTENNA TYPE
L,F,A = Chip Antenna
(4) SERIAL NO.
L00
(5) PACKING STYLE
R = Tape and Reel
(6) WORKING FREQUENCY
2400 = 2.4GHz
PHYCOMP CTC
CAN4311714002454K
12NC
431171400245
www.yageo.com
Feb. 22, 2013 V1
WIRELESS COMPONENTS
3
3
SPECIFICATION
Table 1
VALUE
DESCRIPTION
Centre Frequency
2.45 GHz
Bandwidth
370 MHz (Typ.)
Return Loss
10 dBi min
Polarization
Linear
Azimuth Beamwidth
Omni-directional
Peak Gain
3.77 dBi (Typ.)
Impedance
50 Ω
- 40~105 ℃
Operating Temperature
Maximum Power
1W
Termination
Ni / Sn (Environmentally-Friendly Leadless)
Resistance to Soldering Heats
260℃ , 10sec.
NOTE
1. The specification is defined on Yageo evaluation board
DIMENSIONS
Table 2 Machinical Dimension
DIMENSION
L (mm)
2.00 ±0.20
W (mm)
1.25 ±0.20
T (mm)
1.10 ±0.10
A (mm)
0.15 ±0.10
OUTLINES
Top View
Side View
L
T
S2
W S1
Table 3 Termination configuration
TERMINAL NAME
FUNCTION
S1
Feeding Point
S2
Soldering Point
Bottom View
A
YNH0033
Fig. 1 Antenna outlines
www.yageo.com
Feb. 22, 2013 V1
WIRELESS COMPONENTS
4
4
REFERENCE DESIGN OF EVALUATION BOARD
7
45
10
Fig. 3 Outlook and dimension of evaluation board
Matching Circuit
Unit : mm
1.0
3.0
Top Layer
0.40
Bottom Layer
1.40
1.70
Unit : mm
YNH0034
Fig. 4 Details of soldering Pad
www.yageo.com
Feb. 22, 2013 V1
WIRELESS COMPONENTS
5
5
ELECTRICAL PERFORMANCES
Return loss
(dB)
YNH0004
50
30
10
−10
1
3
−30
2
−50
2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 3.0
f (GHz)
Marker data
1. 2.21GHz, -10dB
2. 2.45GHz, -28.5dB
3. 2.58GHz, -10dB
Fig. 5 Return loss
Gain (dBi)
5.00 −
Z axle
0.00 −
X
Y
− 5.00 −
− 10.00 −
Z
− 15.00 −
− 20.00 −
− 25.00 −
X axle
Y axle
− 30.00 −
Evaluation board and XYZ direction
− 35.00 −
YNH0035
Frequency = 2.45 GHz
Max gain = 3.77 dBi, at (90,240)
MEG (mean effective gain)= -193 dBi
Directivity (dB) = 4.61
Efficiency = -0.84 dB, 82.93 %
Fig. 6 Radiation pattern
www.yageo.com
Feb. 22, 2013 V1
WIRELESS COMPONENTS
6
6
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 0
- New data sheet for SMD type antenna, 2.45GHz application,
2012 series
Feb. 22, 2013
www.yageo.com
Feb. 22, 2013 V1
很抱歉,暂时无法提供与“ANT2012LL00R2400A”相匹配的价格&库存,您可以联系我们找货
