DATA SHEET
METAL OXIDE VARISTORS
POWER SUPPLY
14D series
Product specification– February 12, 2019 V.0
RoHS compliant & Halogen free
Circuit Protection
Product Specification
2
13
14D
Metal Oxide Varistor (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 1800V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +105℃
Storage Temperature:-40℃ ~ +125℃
Safety certification: UL: E327997
CSA: 246579
VDE: 40027827
Applications
Transistor, diode, IC, thyristor or triac semiconductor protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
Pitch
No suffix: 7.5mm
P10: 10mm
Tolerance
K: ±10%
Type
D: Disk
Varistor Voltage
180: 18V
101: 100V
102: 1000V
Surge Series
No suffix: Standard type
J: High Surge type
Packing
No suffix: Bulk
TB: Tape & Box
TR: Tape & Reel
Lead Shape
No suffix: Straight leads
O: Outside crimped leads
F: Y Kinked leads
Element Diameter
14=14mm
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
3
13
14D
Dimensions
D
D
T
H1
K≤3.0
F
d1
L1
e
d
L1
L
K≤3.0
d
T
H1
H
D
d
F
O Type
F Type
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H
14.5~20.0
180K
2.0~3.9
1.5
361K
2.9~5.2
2.7
H1
17.0~21.0
220K
2.1~4.0
1.6
391K
3.0~5.4
2.8
L(min.)
20.0
270K
2.1~4.1
1.8
431K
3.2~5.6
3.0
L1(min.)
15.0
330K
2.2~4.3
1.7
471K
3.3~5.8
3.2
D
14.0~16.5
390K
2.1~4.1
1.8
511K
3.4~6.1
3.4
F
7.5± 0.8/10.0± 1.0
470K
2.2~4.3
1.9
561K
3.6~6.4
3.6
T
Table 2
560K
2.3~4.6
2.1
621K
3.8~6.8
3.9
e(±0.8)
Table 2
680K
2.4~4.8
2.4
681K
4.0~7.1
4.2
d(±0.05)
0.8
820K
2.1~4.1
1.8
751K
4.3~7.2
4.3
d1(±0.4)
1.4
101K
2.4~4.2
2.0
781K
4.4~7.3
4.4
121K
2.4~4.4
2.2
821K
4.6~7.5
4.6
151K
2.2~4.1
1.8
911K
4.8~7.5
5.0
181K
2.3~4.2
1.9
102K
5.4~8.0
5.0
201K
2.4~4.3
2.0
112K
5.8~8.5
5.4
221K
2.5~4.4
2.1
122K
5.9~9.0
5.8
241K
2.6~4.5
2.2
142K
6.9~10.5
6.6
271K
2.6~4.6
2.4
162K
7.4~11.0
7.4
301K
2.7~4.6
2.5
182K
7.6~12.0
8.2
331K
2.7~5.0
2.5
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
4
13
14D
Electrical Characteristics
Part
Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
180KD14
180KD14J
11
14
18(15~21.6)
10
36
1000
2000
4.0
7.0
0.1
11100
220KD14
220KD14J
14
18
22(19.5~26)
10
43
1000
2000
5.0
8.0
0.1
9100
270KD14
270KD14J
17
22
27(24~31)
10
53
1000
2000
6.0
10.0
0.1
7400
330KD14
330KD14J
33(29.5~36.5)
10
65
1000
2000
7.5
12.0
0.1
6100
390KD14
390KD14J
25
31
39(35~43)
10
77
1000
2000
8.6
13.0
0.1
5100
470KD14
470KD14J
30
38
47(42~52)
10
93
1000
2000
10.0
17.0
0.1
4300
560KD14
560KD14J
35
45
56(50~62)
10
110
1000
2000
11.0
20.0
0.1
3600
680KD14
680KD14J
40
56
68(61~75)
10
135
1000
2000
14.0
24.0
0.1
2900
820KD14
820KD14J
50
65
82(74~90)
50
135
4500
6000
22.0
27.0
0.6
2400
101KD14
101KD14J
60
85
100(90~110)
50
165
4500
6000
28.0
33.0
0.6
2000
121KD14
121KD14J
75
100
120(108~132)
50
200
4500
6000
32.0
40.0
0.6
1700
151KD14
151KD14J
95
125
150(135~165)
50
250
4500
6000
40.0
53.0
0.6
1300
181KD14
181KD14J
115
150
180(162~198)
50
300
4500
6000
50.0
60.0
0.6
1100
201KD14
201KD14J
130
170
200(180~220)
50
340
4500
6000
57.0
70.0
0.6
1000
221KD14
221KD14J
140
180
220(198~242)
50
360
4500
6000
60.0
78.0
0.6
900
241KD14
241KD14J
150
200
240(216~264)
50
395
4500
6000
63.0
84.0
0.6
830
271KD14
271KD14J
175
225
270(243~297)
50
455
4500
6000
70.0
99.0
0.6
740
301KD14
301KD14J
190
250
300(270~330)
50
500
4500
6000
77.0
108
0.6
670
331KD14
331KD14J
210
275
330(297~363)
50
550
4500
6000
85.0
115
0.6
610
361KD14
361KD14J
230
300
360(324~396)
50
595
4500
6000
93.0
130
0.6
560
391KD14
391KD14J
250
320
390(351~429)
50
650
4500
6000
100
140
0.6
510
431KD14
431KD14J
275
350
430(387~473)
50
710
4500
6000
115
155
0.6
460
471KD14
471KD14J
300
385
470(423~517)
50
775
4500
6000
118
175
0.6
430
511KD14
511KD14J
320
415
510(459~561)
50
845
4500
6000
121
180
0.6
390
561KD14
561KD14J
350
460
560(504~616)
50
925
4500
6000
125
185
0.6
360
621KD14
621KD14J
385
505
620(558~682)
50
1025
4500
6000
128
190
0.6
320
681KD14
681KD14J
420
560
680(612~748)
50
1120
4500
6000
130
200
0.6
290
751KD14
751KD14J
460
615
750(675~825)
50
1240
4500
6000
143
210
0.6
270
781KD14
781KD14J
485
640
780(702~858)
50
1290
4500
6000
148
220
0.6
260
821KD14
821KD14J
510
670
820(738~902)
50
1355
4500
6000
157
235
0.6
240
911KD14
911KD14J
550
745
910(819~1001)
50
1500
4500
6000
175
255
0.6
220
102KD14
102KD14J
625
825
1000(900~1100)
50
1650
4500
6000
190
280
0.6
200
112KD14
112KD14J
680
895
1100(990~1210)
50
1815
4500
6000
213
310
0.6
180
122KD14
122KD14J
750
990
1200(1080~1320)
50
1980
4500
6000
232
324
0.6
160
142KD14
142KD14J
880
1140
1400(1260~1540)
50
2310
4500
6000
238
327
0.6
150
162KD14
162KD14J
1000
1280
1600(1440~1760)
50
2640
4500
6000
243
331
0.6
140
182KD14
182KD14J
1100
1465
1800(1620~1980)
50
2970
4500
5000
250
335
0.6
130
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Varistor voltage≥1200V, structure diagram is F type.
3. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~182K)
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
5
13
14D
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Crest value
Maximum Clamping
Voltage
Current (%)
100
90
To meet the
Specified value
50
20µs
10
8µs
Time
Impulse Width
Rated Wattage
The maximum average power that can be applied within the
specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
V1mA@85℃-V1mA@25℃
Varistor Voltage
Temp. Coefficient
V1mA@25℃
1
× 100%(%/℃)
60
≤0.05%/℃
V1mA@-40℃-V1mA@25℃
V1mA@25℃
1
× 100%(%/℃)
65
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
14Φ series
180K to 680K
75A (8/20μs)
820K to 182K
150A (8/20μs)
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
6
13
14D
Soldering Recommendation
Wave Lead Free Soldering Recommendation
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
7
13
14D
Mechanical Characteristics
Items
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
Terminal diameter (mm)
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
1.0
2.0
4.0
No visible damage
| V1mA/V1mA |≤5%
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
Bending Strength
of Terminals
Vibration
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
0.5
1.0
2.0
Frequency range: 10~55 Hz
Amplitude: 0.75mm or 98m/s2
Direction: 3 mutually perpendicular directions, 2hrs each.
No visible damage
| V1mA/V1mA |≤5%
No visible damage
| V1mA/V1mA |≤5%
Solder ability
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
At least 95% of terminal
electrode is covered by
new solder
Resistance to
Soldering Heat
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
No visible damage
| V1mA/V1mA |≤10%
Reliability
Items
Specifications
High Temperature
Storage
Ambient Temp: 125±2℃
Duration: 1000hrs
| V1mA/V1mA |≤5%
Low Temperature
Storage
Ambient Temp: -40±2℃
Duration: 1000hrs
| V1mA/V1mA |≤5%
Ambient Temp: 40±2℃, 90~95% R.H.
Duration: 1000hrs
| V1mA/V1mA |≤5%
Humidity
The conditions shown below shall be repeated 5 cycles
Temperature Cycle
Step
Temperature (℃)
Period (minutes)
1
-40±3
30±3
2
Room temperature
15±3
3
125±3
30±3
4
Room temperature
15±3
No visible damage
| V1mA/V1mA |≤5%
High Temperature
Load
Ambient Temp: 105±2℃
Duration: 1000hrs
Load: Max. Allowable Voltage In AC eara.
| V1mA/V1mA|≤10%
Damp Heat Load
Duration: 1000hrs
No visible damage
| V1mA/V1mA |≤10%
Metal balls method, 2500Vac 1 min.
No visible damage
Voltage Proof
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
8
13
14D
Maximum Surge Current Derating Curve
820KD14 to 182KD14
180KD14 to 680KD14
10000
10000
1000
1
100
2
10
1023
104
10
105
106
1000
Max. Surge Current (A)
1
2
10
1
100
10
102
103
104
105
106
10
1
0.1
10
100
1000
0.1
10
10000
Td (μs)
100
180KD14J to 680KD14J
10000
1
2
1
2
1000
10
102
103
104
105
106
100
10000
820KD14J to 182KD14J
10000
1000
1000
Td (μs)
10
1
0.1
10
100
10
102
103
104
105
106
10
1
100
1000
Td (μs)
10000
0.1
10
100
1000
10000
Td (μs)
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
14D
9
13
Maximum Leakage Current and Maximum Clamping Voltage Curve
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
14D
10
13
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
14D
11
13
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
12
13
14D
Marking Code
① Brightking Logo
② Varistor Voltage
③ UL Accreditation Logo
①
④ CSA Accreditation Logo
XXXKDXXX
②
③
④
⑤
XXX Y
VDE
⑥
⑦
⑤ VDE Accreditation Logo
⑧
⑨
⑥“J”is High Surge Code, no“J”is Standard Surge
⑦ Disk Size
⑧Product Line Code (“Y”may be A(a) thru Z(z))
⑨ Date Code
Taping Dimensions
P2
P
Symbol
Dimensions (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H
20.0±2.0
D0
4.0±0.2
t
0.6±0.3
B
40max
h
B
W2
W0
W
H
D0
P1
P0
F
W1
t
www.yageo.com
Feb. 12, 2019 V.0
Circuit Protection
13
13
14D
Quantity
Packaging Dimensions (Unit: mm)
Quantity
Exposure in bulk
400pcs/bag
4bags/box
(180K~331K)
300pcs/bag
4bags/box
(361K~621K)
5M
ax
250pcs/bag
4bags/box
(681K~112K)
16
125 Max.
150pcs/bag
4bags/box
(122K~182K)
250 Max.
Cut the feet in bulk
400pcs/bag
4bags/box
(180K~331K)
5M
ax
300pcs/bag
4bags/box
(361K~621K)
250pcs/bag
4bags/box
(681K~112K)
18
65 Max.
245 Max.
150pcs/bag
4bags/box
(122K~182K)
Tape & Box
750pcs/box
(180K~331K)
0M
ax
500pcs/box
(361K~621K)
25
60 Max.
400pcs/box
(681K~751K)
340 Max.
Tape & Reel
5M
ax
1000pcs/reel
(180K~331K)
36
60 Max.
750pcs/reel
(361K~621K)
365 Max.
55 Max.
30±1
Φ365 Max.
500pcs/reel
(681K~751K)
www.yageo.com
Feb. 12, 2019 V.0
很抱歉,暂时无法提供与“431KD14-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 750+1.09212750+0.14193
- 1500+1.046841500+0.13604
- 2250+1.024212250+0.13310
- 3750+0.999093750+0.12984
- 5250+0.984415250+0.12793
- 7500+0.970297500+0.12610
- 国内价格 香港价格
- 1+2.467991+0.32072
- 10+1.6978110+0.22064
- 25+1.4990925+0.19481
- 100+1.28697100+0.16725
- 250+1.18442250+0.15392
