DATA SHEET
THICK FILM WIDE TERMINAL CHIP RESISTORS
AUTOMOTIVE GRADE
AC series
±5%, ±1%, ±0.5%
Product specification – December 11, 2015 V.1
Sizes 0612/1020/1225
RoHS compliant & Halogen free
Chip Resistor Surface Mount
AC
9
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes AC0612
to AC1225 chip resistors with leadfree terminations made by thick film
process.
Part number is identified by the series name, size, tolerance, packaging
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
All general purpose applications
Car electronics, industrial
application
FEATURES
AEC-Q200 qualified
Moisture sensitivity level: MSL 1
AC series soldering is compliant
with J-STD-020D
Halogen free epoxy
RoHS compliant
- Products with lead-free
terminations meet RoHS
requirements
- Pb-glass contained in electrodes,
resistor element and glass are
exempted by RoHS
Reduce environmentally
hazardous waste
High component and equipment
reliability
The resistors are 100% performed
by automatic optical inspection
prior to taping.
2
0612/1020/1225
SERIES
GLOBAL PART NUMBER
AC XXXX X X X XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0612/1020/1225
(2) TOLERANCE
D = ± 0.5%
F = ± 1%
J = ± 5% (for Jumper ordering, use code of J)
(3) PACKAGING TYPE
R = Paper taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Base on spec
(5) TAPING REEL
07 = 7 inch dia. Reel
13 = 13 inch dia. Reel
(6) RESISTANCE VALUE
1Ω to 1 MΩ
There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no
need to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed coding rules of resistance are shown in the table of “Resistance rule of
global part number”.
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Resistance rule of global part
number
Resistance coding
Example
rule
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
976R = 976 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
XXMX
(10 MΩ)
10M = 10,000,000 Ω
O RDERING EXAMPLE
The ordering code for an AC0612
chip resistor, value 100 KΩ with
± 1% tolerance, supplied in 7-inch
tape reel is: AC0612FR-07100KL.
NOTE
1. All our R-Chip products are RoHS
compliant and Halogen free. "LFP" of the
internal 2D reel label states "Lead-Free
Process".
2. On customized label, "LFP" or specific
symbol can be printed.
3. AC series with ±0.5% tolerance is also
available. For further information, please
contact sales.
www.yageo.com
Dec. 11, 2015 V.1
AC
SERIES
3
9
0612/1020/1225
MARKING
AC0612 / AC1020 / AC1225
E-24 series: 3 digits, ± 5%
First two digits for significant figure and 3rd digit for number of zeros
Fig. 1 Value=10 KΩ
Fig. 2
E-24/ E-96 series: 4 digits, ± 1% & ± 0.5%
First three digits for significant figure and 4th digit for number of zeros
Value=10 KΩ
CONSTRUCTION
The resistors are constructed on top of a high-grade
ceramic body. Internal metal electrodes are added at each
end and connected by the resistive glaze. The resistive
glaze is covered by a leadfree glass. The composition of
the glaze is adjusted to give the approximate required
resistance value and laser trimming of this resistive glaze
achieves the value inside tolerance. The whole element is
covered by a protective overcoat. Size 0508 and bigger is
marked with the resistance value on top. Finally, the two
external terminations (Ni / matte tin) are added. See fig.3.
OUTLINES
Fig. 3 Chip resistor outlines
DIMENSIONS
Table 1 For outlines, please refer to Fig. 4
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
AC0612
1.60± 0.20
3.20 ± 0.20
0.55± 0.10
0.18± 0.15
0.40± 0.15
AC1020
2.50 ± 0.20
5.00 ± 0.20
0.55± 0.10
0.25 ± 0.20
0.90 ± 0.20
AC1225
3.20 ± 0.20
6.40 ± 0.20
0.55± 0.10
0.45 ± 0.20
0.75 ± 0.20
For dimension, please refer to Table 1
Side view for all type
Fig. 4 Chip resistor dimensions
www.yageo.com
Dec. 11, 2015 V.1
AC
SERIES
4
9
0612/1020/1225
ELECTRICAL CHARACTERISTICS
Table 2
CHARACTERISTICS
RESISTANCE
RANGE
TYPE
Operating
Temperature
Range
AC0612
AC1020
5% (E24) 1Ω to 1MΩ
0.5%, 1% (E24/E96) 1Ω to
1MΩ
Jumper < 50mΩ
AC1225
–55 °C to +155 °C
Max.
Working
Voltage
Max.
Overload
Voltage
Dielectric
Withstanding
Voltage
200V
400V
500V
200V
400V
500V
200V
400V
500V
Temperature Jumper Criteria
Coefficient
of Resistance
1Ω≤R≤10Ω,
±200ppm/℃ Rated Current
10Ω
很抱歉,暂时无法提供与“AC1225JK-0716RL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.78070
- 100+1.14850
- 1000+0.81810
- 2000+0.60730
- 4000+0.45240
- 国内价格
- 1+2.62273
- 100+1.51591
- 1000+0.92774
- 2000+0.62898
- 4000+0.45243
