ANT1204F007R0870A
ANT1204F007R0870A
    YAGEO(国巨)
    ANT1204F007R0870A
ANT1204F007R0870A 数据手册
DATA SHEET WIRELESS COMPONENTS FR4 Chip Antenna ANT1204F007R0870A UHF (870MHZ) Preliminary Product Specification – September 12, 2013 V.0 1204 Series Product specification WIRELESS COMPONENTS FEATURES Compact size Omni-directional Radiation Tape & reel automatic mounting Reflow process compatible RoHS compliant APPLICATIONS Smart meter Industrial remote control Chip Antenna 2 6 1204 Series ORDERING INFORMATION All part numbers are identified by the series, packing type, material, size, antenna type, working frequency and packing quantity. PART NUMBER ANT (1) 1204 F (2) (3) 007 (4) (5) R 0870 A (6) (1) PRODUCT ANT = Antenna (2) SIZE 1204=12 × 4 mm (3) ANTENNA TYPE L, F, A=Chip antenna (4) SERIAL NO. 007 (5) PACKING STYLE R = Tape and Reel (6) WORKING FREQUENCY 0870 = UHF 870MHz PHYCOMP CTC CAN4311059070871K 12NC 431105907087 www.yageo.com Sep. 12, 2013 V.0 Product specification WIRELESS COMPONENTS Chip Antenna 3 6 1204 Series SPECIFICATION Table 1 VALUE DESCRIPTION Centre Frequency 870MHz Bandwidth 30 MHz (Typ.) Return Loss 10 dB min Polarization Linear Azimuth Beamwidth Omni-directional Peak Gain 1.67 dBi (Typ.) 50Ω Impedance - 40~85 ℃ Operating Temperature Maximum Power 1W Termination Cu / Au (Environmentally-Friendly Leadless) 260°C / 10 sec Resistance to Soldering Heats NOTE The specification is defined on Yageo evaluation board DIMENSION S Table 2 Machinical Dimension DIMENSION L (mm) W (mm) T (mm) OUTLINES 12.20±0.20 4.00±0.20 1.60±0.20 YAGEO8707 Table 3 Termination configuration TERMINAL NAME S1 S2 Function Fig. 1 Antenna outlines Feeding Point Soldering Point www.yageo.com Sep. 12, 2013 V.0 Product specification WIRELESS COMPONENTS Chip Antenna 1204 Series 4 6 REFERENCE DESIGN OF EVALUATION BOARD Unit: mm Fig. 2 Outlook and dimension of evaluation board Fig. 3 Details of soldering Pad www.yageo.com Sep. 12, 2013 V.0 Product specification WIRELESS COMPONENTS Chip Antenna 1204 Series 5 6 ELECTRLCAL PERFORMANCE ELECTRLCAL PERFORMANCES Return loss (dB) 50 30 10 -10 3 1 -30 2 -50 770 790 810 830 850 870 890 910 930 950 970 f(MHz) Marker data 1.856MHz,-10dB 2.870MHz,-34dB 3.914MHz,-10dB Fig. 4 Return loss Fig. 5 Radiation pattern www.yageo.com Sep. 12, 2013 V.0 Product specification WIRELESS COMPONENTS Chip Antenna 6 6 1204 Series REVISION HISTORY REVISION DATE Preliminary Sept. 11, 2013 CHANGE NOTIFICATION DESCRIPTION - New data sheet antenna, 870MHz application, 1204 series www.yageo.com Sep. 12, 2013 V.0
ANT1204F007R0870A
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85摄氏度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装。
ANT1204F007R0870A 价格&库存
很抱歉,暂时无法提供与“ANT1204F007R0870A”相匹配的价格&库存,您可以联系我们找货
