Yageo corporation ELECTROLYTIC CAPACITORS
Surface Mount
Aluminum Electrolytic
CA [ For General ]
ELECTRICAL CHARACTERISTICS
Operation Temperature Range -40 to +85°C
Rated Voltage Range
4 to 100VDC
Rated Capacitance Range
0.1 ~ 1000μF
Capacitance Tolerance
±20% at 120Hz, 20°C
Leakage Current (Max. 20°C)
I ≤ 0.01CV (μA) or 3μA whichever is greater.
(After 2 Minutes Application of DC Rated Voltage at 20°C)
feature
I = Leakage Current (μA), C = Rated Capacitance (μF), V = Rated Voltage (V)
For General Purpose Series with 85°C 2000 Hours
Low Temperature Stability
Suitable for AV (TV, Video, Audio) Monitor / Computer,
Home appliance, OA / HA / Communication
marking
Impedance Ratio at 120Hz (Max.)
W V (V)
4
6.3
10
16
25
35
50
63
100
Z (-25°C)
7
4
3
2
2
2
2
2
3
Z (-40°C)
15
8
6
4
4
3
3
3
2
After the rated voltage has been applied at 85°C for 2000 hours, the
Endurance
capacitors shall meet the following requirements.
1 0
(a) Capacitance Change: Within ±20% of the Initial Value
(b) Dissipation Factor: Not Exceeding 200% of Specified Value
(c) Leakage Current: Not Exceeding the Specified Value
Capacitance (F)
16G
Rated Voltage (VDC)
793
Date Code
Shelf Life
After having been placed at 85°C without voltage applied for 1000 hours,
the capacitors shall meet the same requirements as Endurance.
dimensions
Unit: mm
SIZE
CODE
Dø
L
A
H
I
W
P
K
B
4.0
5.4
4.3
5.5 Max.
1.8
0.65 ± 0.1 1.0±0.2
0.35 --- 0.20
C
5.0
5.4
5.3
6.5 Max.
2.2
0.65 ± 0.1 1.5±0.2
0.35 --- 0.20
D
6.3
5.4
6.6
7.8 Max.
2.6
0.65 ± 0.1 1.8±0.2
0.35 --- 0.20
E
8.0
6.5
8.3
9.5 Max.
3.4
0.65 ± 0.1 2.2±0.2
0.35 --- 0.20
F
8.0
10.5
8.3
10.0 Max. 3.4
0.90 ± 0.2 3.1±0.2
0.70 ± 0.20
G
10.0
10.5
10.3
12.0 Max. 3.5
0.90 ± 0.2 4.6±0.2
0.70 ± 0.20
H
6.3
7.7
6.6
7.8 Max.
0.65 ± 0.1 1.8±0.2
0.35 --- 0.20
K
0.3Max.
H
(I)
(P)
øD ± 0.5
(I)
A ± 0.2
W
( ) Reference Size
L ± 0.3
D ≥ ø8 = L ± 0.5
2.6
+ 0.15
+ 0.15
+ 0.15
+ 0.15
+ 0.15
125
CASE SIZE & PERMISSIBLE RIPPLE CURRENT OF STANDARD PRODUCTS
D x L: mm
CAP. RATED VOLTAGE W V (SURGE VOLTAGE W V)
(μF)
4 (5)
SIZE
6.3 (8)
10 (13)
16 (20)
RIPPLE
DISSIPATION SIZE
RIPPLE
DISSIPATION SIZE
RIPPLE
DISSIPATION SIZE
RIPPLE
DISSIPATION
CURRENT FACTOR
CURRENT FACTOR
CURRENT FACTOR
CURRENT FACTOR
4.7
10
22
33
47
100
220
330
470
1000
1500
4 x 5.4
4 x 5.4
4 x 5.4
5 x 5.4
19
26
34
61
6.3 x 5.4 82
0.35
0.35
0.35
0.35
0.35
4 x 5.4
5 x 5.4
0.26
0.26
4 x 5.4
4 x 5.4
14
0.30
4 x 5.4
28
0.16
4 x 5.4
28
0.30
4 x 5.4
27
0.26
5 x 5.4
39
0.16
4 x 5.4
29
0.30
5 x 5.4
45
0.26
5 x 5.4
43
0.20
6.3 x 5.4 66
0.16
4 x 5.4
38
0.26
5 x 5.4
43
0.30
6.3 x 5.4 70
0.16
5 x 5.4
46
0.26
6.3 x 5.4 46
0.30
6.3 x 7.7 75
0.18
6.3 x 5.4 71
0.26
5 x 5.4
60
0.30
6.3 x 5.4 70
0.20
6.3 x 5.4 70
0.26
6.3 x 7.7 85
0.20
8 x 6.5
0.20
86
6.3 x 5.4 190
0.26
6.3 x 7.7 105
0.26
6.3 x 7.7 105
0.20
6.3 x 7.7 235
0.35
8 x 6.5
250
0.26
8 x 10.5 280
0.20
8 x 6.5
250
0.35
6.3 x 7.7 280
0.35
8 x 10.5 330
0.26
8 x 10.5 316
0.20
8 x 6.5
300
0.35
10 x 10.5 380
0.20
8 x 10.5 340
0.35
8 x 10.5 380
0.35
8 x 10.5 580
0.35
10 x 10.5 700
0.35
10 x 10.5 1000
0.35
Note: 1. Ripple Current: (mA/rms) 85°C, 120Hz
2. Dissipation Factor: 20°C, 120Hz
8 x 10.5 330
0.26
8 x 10.5 350
0.20
10 x 10.5 400
0.26
10 x 10.5 420
0.20
10 x 10.5 580
0.26
126
CAP. (μF)
D x L: mm
25 (32)
SIZE
RIPPLE
CURRENT
35 (44)
DISSIPATION SIZE
FACTOR
RIPPLE
CURRENT
50 (63)
DISSIPATION SIZE
FACTOR
RIPPLE
CURRENT
DISSIPATION
FACTOR
0.10
4 x 5.4
1
0.12
0.22
4 x 5.4
2
0.12
0.33
4 x 5.4
3
0.12
0.47
4 x 5.4
5
0.12
1.0
4 x 5.4
10
0.12
2.2
4 x 5.4
8
0.12
4 x 5.4
16
0.12
3.3
4 x 5.4
10
0.12
4 x 5.4
16
0.12
4.7
4 x 5.4
22
0.14
4 x 5.4
22
0.12
5 x 5.4
23
0.12
10
4 x 5.4
24
0.20
4 x 5.4
24
0.16
5 x 5.4
28
0.12
5 x 5.4
28
0.14
5 x 5.4
30
0.12
6.3 x 5.4
35
0.12
5 x 5.4
45
0.14
5 x 5.4
49
0.23
6.3 x 5.4
70
0.12
6.3 x 5.4
55
0.14
6.3 x 5.4
60
0.12
6.3 x 7.7
90
0.12
8 x 6.5
110
0.12
22
33
47
100
220
330
470
5 x 5.4
53
0.14
6.3 x 5.4
100
0.14
6.3 x 7.7
90
0.12
6.3 x 5.4
65
0.14
8 x 6.5
130
0.14
8 x 10.5
120
0.12
6.3 x 5.4
70
0.20
6.3 x 7.7
150
0.14
6.3 x 7.7
63
0.12
8 x 6.5
96
0.16
8 x 6.5
165
0.14
8 x 10.5
100
0.12
10 x 10.5
130
0.12
6.3 x 7.7
115
0.16
6.3 x 7.7
140
0.14
8 x 10.5
160
0.12
8 x 6.5
140
0.16
8 x 6.5
170
0.14
10 x 10.5
190
0.12
8 x 10.5
180
0.16
10 x 10.5
210
0.14
8 x 6.5
210
0.16
8 x 10.5
250
0.14
10 x 10.5
310
0.12
8 x 10.5
260
0.16
10 x 10.5
310
0.14
10 x 10.5
310
0.16
8 x 10.5
350
0.16
10 x 10.5
400
0.14
10 x 10.5
430
0.16
10 x 10.5
480
0.16
127
CAP. (μF)
D x L: mm
63 (79)
SIZE
RIPPLE
CURRENT
DISSIPATION
FACTOR
3.3
100 (125)
SIZE
RIPPLE
CURRENT
DISSIPATION
FACTOR
8 x 10.5
30
0.18
4.7
6.3 x 5.4
8 x 10.5
50
0.18
10
6.3 x 5.4
8 x 10.5
55
0.18
22
8 x 10.5
30
0.18
10 x 10.5
60
0.18
33
8 x 10.5
30
0.18
10 x 10.5
65
0.18
47
8 x 10.5
30
0.18
100
10 x 10.5
60
0.18
很抱歉,暂时无法提供与“CA035M0047RED-0605”相匹配的价格&库存,您可以联系我们找货
