CC1206KKNPOCBN221
CC1206KKNPOCBN221
    YAGEO(国巨)
    CC1206KKNPOCBN221
CC1206KKNPOCBN221 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS High-Voltage NP0/X7R 500 V TO 3 KV Product Specification – December 15, 2021V.15 0.47 pF to 33 nF Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP This specification describes HighVoltage NP0/X7R series chip capacitors with lead-free terminations. CTC & 12NC APPLICATIONS All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) PCs, Hard disk, Game PCs Power supplies LCD panel ADSL, Modem CC FEATURES (2) TOLERANCE RoHS compliant Halogen Free compliant MSL class MSL I Soldering is compliant with J-STD-020D XXXX X X XXX X X X XXX (1) (2) (3) (4) (5) (6) (7) (8) (1) SIZE – INCH BASED (METRIC) 0805 (2012) / 1206 (3216) / 1210 (3225) / 1808 (4520) / 1812 (4532) / 2220 (5750) C = ± 0.25 pF D = ± 0.5 pF G = ± 2% J = ± 5% K = ± 10% M = ± 20% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL NPO = NP0 X7R = X7R (5) RATED VOLTAGE B = 500V D = 2 KV Z = 630V S = 2.5KV C = 1KV E = 3 KV (6) CONTROL CODE A: Anti-arc coating B: Standard Type (7) PROCESS N = NP0 B = X7R (8) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION OUTLINES Table 1 For outlines see fig.2 TYPE 0805 1206 L1 (mm) W (mm) 2.0 ± 0.10 1.25 ± 0.10 2.0 ± 0.20 1.25 ± 0.20 1.25 ± 0.20 3.2 ± 0.15 1.60 ± 0.15 0.60 ± 0.10 T (MM) 1.60 ± 0.20 L4 (mm) min. max. min. 0.25 0.75 0.70 0.25 0.75 1.40 0.85 ± 0.10 1.25 ± 0.20 0.25 0.75 1.40 0.25 0.75 2.20 0.25 0.75 2.20 0.25 0.75 3.40 1.60 ± 0.20 3.2 ± 0.20 2.50 ± 0.20 1210 3.2 ± 0.30 2.50 ± 0.20 For dimension see Table 1 0.60 ± 0.10 0.85 ± 0.10 3.2 ± 0.30 L2 / L3 (mm) Fig. 2 Surface mounted multilayer ceramic capacitor dimension 0.85 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 1.25 ± 0.20 1808 4.5 ± 0.40 2.00 ± 0.30 1.35 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 0.85 ± 0.10 1.25 ± 0.20 1812 4.5 ± 0.40 3.20 ± 0.20 1.35 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 2220 5.7 ± 0.40 5.0 ± 0.3. 2.00 ± 0.20 www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR NP0 Table 2 Sizes from 0805 to 1210 CAP. 0805 1206 1210 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.2 pF 2.7 pF 0.85± 0.1 3.3 pF 3.9 pF 4.7 pF 5.6 pF 6.8 pF 8.2 pF 0.85± 0.1 1.25± 0.2 10 pF 12 pF 15 pF 18 pF 22 pF 0.85± 0.1 1.25± 0.2 27 pF 33 pF 39 pF 0.6± 0.1 1.25± 0.2 47 pF 1.25± 0.2 1.25± 0.2 56 pF 68 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 82 pF 100 pF 1.25± 0.2 120 pF 150 pF 180 pF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR NP0 Table 3 Sizes from 0805 to 1210 (continued) CAP. 0805 1206 1210 220 pF 1.25± 0.2 1.25± 0.2 270 pF 330 pF 0.85± 0.1 0.85± 0.1 390 pF 0.6± 0.1 470 pF 1.25± 0.2 560 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 pF 820 pF 1.25± 0.2 1.25± 0.2 1.0 nF 1.2 nF 0.85± 0.1 1.5 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR NP0 Table 4 Sizes from 1808 to 1812 1808 CAP. 1812 0.47 pF 0.56 pF 0.68 pF 0.82 pF 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.2 pF 2.7 pF 3.3 pF 3.9 pF 4.7 pF 5.6 pF 6.8 pF 8.2 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 1.6± 0.2 39 pF 1.25± 0.2 47 pF 1.25± 0.2 1.25± 0.2 56 pF 68 pF 82 pF 1.25± 0.2 1.25± 0.2 100 pF 1.25± 0.2 1.25± 0.2 120 pF 150 pF 180 pF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR NP0 Table 5 Sizes from 1808 to 1812 (continued) 1812 CAP. 220 pF 1.25± 0.2 270 pF 330 pF 390 pF 1.25± 0.2 1.25± 0.2 470 pF 560 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR X7R Table 6 Sizes from 0805 to 1210 0805 CAP. 1206 1210 100 pF 150 pF 220 pF 330 pF 0.85± 0.1 470 pF 1.25± 0.2 1.25± 0.2 680 pF 1.0 nF 0.85± 0.1 0.85± 0.1 1.6± 0.2 1.5 nF 2.2 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.60± 0.2 3.3 nF 4.7 nF 6.8 nF 10 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 15 nF 1.25± 0.2 22 nF 33 nF 1.60± 0.2 1.6± 0.2 1.60± 0.2 2.0± 0.2 47 nF 68 nF 100 nF 1.6± 0.2 2.0± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For products with 5% tolerance, please contact local sales force before ordering www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR X7R Table 7 Sizes from 1808 to 1812 1808 CAP. 1812 2020 100 pF 150 pF 220 pF 330 pF 1.6± 0.2 470 pF 680 pF 1.35± 0.15 1.0 nF 1.5 nF 1.35± 0.15 2.2 nF 1.6± 0.2 2.0± 0.2 1.6± 0.2 1.35± 0.15 3.3 nF 4.7 nF 6.8 nF 10 nF 1.35± 0.2 1.6± 0.2 1.35± 0.15 1.25± 0.2 15 nF 22 nF 33 nF 1.6± 0.2 47 nF 68 nF 100 nF 1.6± 0.2 1.6± 0.2 2.0± 0.2 150 nF 220 nF 2.0± 0.2 330 nF 470 nF 680 nF 1 µF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For products with 5% tolerance, please contact local sales force before ordering www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV THICKNESS CLASSES AND PACKING QUANTITY Table 8 Ø 180 MM / SIZE CODE 0805 1206 THICKNESS CLASSIFICATION QUANTITY 7 INCH 13 INCH PER BULK CAS Paper Blister Paper Blister E 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 10,000 R P 8 mm 4,000 --- 15,000 --- 8,000 1.00 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 5,000 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- --- 1.00 / 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 --- 1.6 ± 0.2 mm K F 8 mm --- 2,000 --- 8,000 --- 0.85 ± 0.1 mm K F 8 mm --- 4,000 --- 10,000 --- 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 --- 1.15 ± 0.15 mm K F 8 mm --- 3,000 --- 10,000 --- 1.25 ± 0.2 mm K 8 mm --- 3,000 --- --- --- 1.5 ± 0.1 mm K 8 mm --- 2,000 --- --- --- 1.6± 0.2 mm K 8 mm --- 2,000 --- --- --- 8 mm --- 2,000 1,000 --- --- --- 8 mm --- 1,000 500 --- --- --- 2.0 ± 0.2 mm 2.5 ± 0.2 mm 1812 7 INCH 13 INCH TAPE WIDTH QUANTITY PER REEL 0.85 ± 0.1 mm 1210 1808 PACKING CODE. Ø 330 MM / K K 1.15 ± 0.15 mm K 12 mm --- 3,000 --- --- --- 1.25 ± 0.2 mm K 12 mm --- 3,000 --- --- --- 1.35 ± 0.15 mm K 12 mm --- 2,000 --- --- --- 1.5 ± 0.1 mm K 12 mm --- 2,000 --- --- --- 1.6 ± 0.2 mm K 12 mm --- 2,000 --- --- --- 2.0 ± 0.2 mm K 12 mm --- 2,000 --- --- --- 0.6 / 0.85 ± 0.1 mm K 12 mm --- 2,000 --- --- --- 1.15 ± 0.1 mm K 12 mm --- 1,000 --- --- --- 1.15 ± 0.15 mm K 12 mm --- 1,000 --- --- --- 1.25 ± 0.2 mm K 12 mm --- 1,000 --- --- --- 1.35 ± 0.15 mm K 12 mm --- 1,000 --- --- --- 1.5 ± 0.1 mm K 12 mm --- 1,000 --- --- --- 1.6 ± 0.2 mm K 12 mm --- 1,000 --- --- --- 2.0 ± 0.2 mm K 12 mm --- 1,000 --- --- --- 2.5 ± 0.2 mm K 12 mm --- 500 --- --- --- 2.0 ± 0.2 mm K 12 mm --- 1000 --- --- --- 2220 www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV PAPER/PE TAPE SPECIFICATION Fig. 3 Paper/PE tape Table 9 Dimensions of paper/PE tape for relevant chip size; see Fig.3 SIZE Unit: mm SYMBOL CODE A0 B0 W E F P0 (1) P1 P2 Ø D0 K0 T 0201 0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.55 ± 0.03 0.38 ± 0.05 (0.47 / 0.55)±0.10 0402 0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.50 +0.1 /-0 (0.75 / 0.60)±0.10 (0.85 / 0.70)±0.10 0603 1.05 ± 0.14 1.86 ± 0.13 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 0805 1.50 ± 0.15 2.26 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 1206 1.90 ± 0.15 3.50 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (0.95 / 0.75)±0.10 (1.05 / 0.85)± 0.10 NOTE 1. P0 pitch tolerance over any 10 pitches is 0.2 mm www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV BLISTER TAPE SPECIFICATION K0: so chosen that the orientation of the component cannot change For W = 8 mm: T2 = 3.5 mm max. For W = 12 mm: T2 = 6.5 mm max. Fig. 4 Blister tape Table 10 Dimensions of blister tape for relevant chip size; see Fig.4 SYMBOL SIZE A0 B0 CODE Unit: mm K0 W E F Min. Max. Min. Max. Min. Max. Ø D0 Ø D1 P0 (2) P1 P2 T2 Min. Min. Max. 0805 1.29 1.65 2.09 2.60 1.25 1.62 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.30 1.67 1206 1.65 2.12 3.30 3.75 1.22 2.15 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.27 2.20 1210 2.55 3.02 3.31 3.88 0.97 2.92 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.02 2.97 1808 2.05 2.55 4.80 5.45 1.30 2.45 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.35 2.50 1812 3.35 3.75 4.70 5.33 0.70 2.40 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 0.75 2.45 2220 5.12 5.32 5.84 6.04 1.28 1.48 12.0 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 1.33 1.53 NOTE 1. Typical capacitor displacement in pocket 2. P0 pitch tolerance over any 10 pitches is ±0.2 mm www.yageo.com Dec. 15, 2021 V.15 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV REEL SPECIFICATION Fig. 5 Reel Table11 Reel dimensions; see Fig.5 TAPE WIDTH SYMBOL Unit: mm A N C W1 W2max. 8 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 9.4 ± 1.5 14.4 8 (Ø 330 mm/13") 330 ± 1.0 100 ± 1.0 13 +0.50/-0.20 9.0 ± 0.2 14.4 12 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 13.4 ± 1.5 18.4 P ROPERTIES OF REEL Material: polystyrene Surface resistance:
CC1206KKNPOCBN221 价格&库存
很抱歉,暂时无法提供与“CC1206KKNPOCBN221”相匹配的价格&库存,您可以联系我们找货
CC1206KKNPOCBN221
    • 1+1.94540
    • 100+1.25480
    • 1500+0.84700
    • 3000+0.60300
    库存:80
