CRF Series Datasheet
Precision Fusible Safety Wirewound Resistors | Axial and SMD Version
Ceramic core | Flame retardant coating | UL1412 Recognized (file E330640)
New SAP Part Nr.:
CRF
300
J
T
73-
150R
UL
Serie
* Power rating
Tol.
Pack-Code
TCR
Forming type
R Value
Special
J = ±5%
T = Tape
(ammo pack)
- Base on
spec.
52- Inner Taping
dimension or
73- Inner Taping
dimension
ZB- Z version
UL = UL Version
YY = Standard
Industrial
Consumer &
Electronics
Power & Energy
Computer &
Peripherals
Automotive
Historical VTM Part Nr.:
CRF254 – 8
5
T
150R
Type
Tol.
Pack-Code
R Value
RZS4 6720
Type
Size
T = Tape (ammo pack)
J
K
13
150R
Tol.
K = Blister tape reel
TC
Reel diam.
R Value
Type
AXIAL
Historical Part Number
Nominal Power Rating
Standard
UL
SMD
* P40
P70
Resistance Range
[W]
[Ω]
CRF110
CRF200
CRF250
CRF300
CRF400
CRF500
CRF251-4
CRF251-8
RZS1
CRF252-4
CRF252-8
RZS2
CRF253-4
CRF253-8
RZS3
CRF254-4
CRF254-8
RZS4
CRF256-4
CRF256-8
RZS6
CRF257-4
CRF257-8
1,1
1,0
1R … 100R
2,0
1,8
1R … 240R
2,5
2,3
1R … 330R
3,0
2,7
1R … 470R
4,0
3,6
1R … 330R
(Other values upon request, for CRF UL approval check the ohmic value range below page 2)
E-Series (preferred)
Tolerances
Temperature Coefficient
Working Temperature Range
E24 (Other upon request)
-6* -1
120 ±50
[ºC]
-1
[KW ]
Max. Working Voltage
[V]RMS
IEC115-1 clause 4.7 (1[min])
J = 5%
±[10 K ]
Thermal Resistance
Dielectric Withstanding Voltage
5,0
4,5
1R … 330R
-55 … +350
280
155
122
104
[V]RMS
78
62
500
Type
CRF110
CRF200
CRF250
CRF300
CRF400
CRF500
Historical P/N:
CRF251-4 / -8
CRF252-4 / -8
CRF253-4 / -8
CRF254-4 / -8
CRF256-4 / -8
CRF257-4 / -8
L max.
9,0
9,7
14,5
12,6
17,0
18,0
Ø
D max. *
3,0
4,0
4,5
6,0
6,0
8,5
Ø
File Nr. 3200.18-450.121.14 | Revision: 202104
±5% = J
Precision Type
“Z” preforming ; Other preforming available
UL approval, file E330640
High pulse load up to 6[KV]
240[V] fusing application
RoHs Compliant
d ±0,05
0,65
0,80
0,65
0,80
0,80
0,80
*R 95% coverage)
IEC60068-2-20
(245±5[ºC] 3±0,5[s])
Marking
Printed in clear
CRF110
CRF200
CRF250
CRF300
CRF400
CRF500
Axial
CRF251-8
CRF252-8
CRF253-8
CRF254-8
CRF256-8
CRF257-8
SMD
RZS1
RZS2
New P/Nr. For UL
Historical P/N
Resistance Range
230[V]
375[V]
120[V]
170[V]
1R … 100R
1R … 240R
1R … 100R
1R … 240R
RZS3
RZS4
RZS6
10R … 330R
10R … 330R
10R … 330R
10R … 90R
10R … 90R
10R … 90R
1R … 330R
1R … 330R
New P/Nr. For Standard
CRF110
CRF200
CRF250
CRF300
CRF400
CRF500
Historical P/N
CRF251-4
CRF252-4
CRF253-4
CRF254-4
CRF256-4
CRF257-4
*1R … 100R
*1R … 240R
*1R … 330R
*1R … 470R
*1R … 330R
*1R … 330R
Resistance Range
Axial
Note: The special construction off resistance values >10R results in an immediate interruption (
很抱歉,暂时无法提供与“CRF400JK-ZB-10RUL”相匹配的价格&库存,您可以联系我们找货
