CA016M0100RED-0605
CA016M0100RED-0605
    YAGEO(国巨)
    SMD
    铝电解电容器 SMD
CA016M0100RED-0605 数据手册
Yageo corporation ELECTROLYTIC CAPACITORS Surface Mount Aluminum Electrolytic CA [ For General ] ELECTRICAL CHARACTERISTICS Operation Temperature Range -40 to +85°C Rated Voltage Range 4 to 100VDC Rated Capacitance Range 0.1 ~ 1000μF Capacitance Tolerance ±20% at 120Hz, 20°C Leakage Current (Max. 20°C) I ≤ 0.01CV (μA) or 3μA whichever is greater. (After 2 Minutes Application of DC Rated Voltage at 20°C) feature I = Leakage Current (μA), C = Rated Capacitance (μF), V = Rated Voltage (V) For General Purpose Series with 85°C 2000 Hours Low Temperature Stability Suitable for AV (TV, Video, Audio) Monitor / Computer, Home appliance, OA / HA / Communication marking Impedance Ratio at 120Hz (Max.) W V (V) 4 6.3 10 16 25 35 50 63 100 Z (-25°C) 7 4 3 2 2 2 2 2 3 Z (-40°C) 15 8 6 4 4 3 3 3 2 After the rated voltage has been applied at 85°C for 2000 hours, the Endurance capacitors shall meet the following requirements. 1 0 (a) Capacitance Change: Within ±20% of the Initial Value (b) Dissipation Factor: Not Exceeding 200% of Specified Value (c) Leakage Current: Not Exceeding the Specified Value Capacitance (F) 16G Rated Voltage (VDC) 793 Date Code Shelf Life After having been placed at 85°C without voltage applied for 1000 hours, the capacitors shall meet the same requirements as Endurance. dimensions Unit: mm SIZE CODE Dø L A H I W P K B 4.0 5.4 4.3 5.5 Max. 1.8 0.65 ± 0.1 1.0±0.2 0.35 --- 0.20 C 5.0 5.4 5.3 6.5 Max. 2.2 0.65 ± 0.1 1.5±0.2 0.35 --- 0.20 D 6.3 5.4 6.6 7.8 Max. 2.6 0.65 ± 0.1 1.8±0.2 0.35 --- 0.20 E 8.0 6.5 8.3 9.5 Max. 3.4 0.65 ± 0.1 2.2±0.2 0.35 --- 0.20 F 8.0 10.5 8.3 10.0 Max. 3.4 0.90 ± 0.2 3.1±0.2 0.70 ± 0.20 G 10.0 10.5 10.3 12.0 Max. 3.5 0.90 ± 0.2 4.6±0.2 0.70 ± 0.20 H 6.3 7.7 6.6 7.8 Max. 0.65 ± 0.1 1.8±0.2 0.35 --- 0.20 K 0.3Max. H (I) (P) øD ± 0.5 (I) A ± 0.2 W ( ) Reference Size L ± 0.3 D ≥ ø8 = L ± 0.5 2.6 + 0.15 + 0.15 + 0.15 + 0.15 + 0.15 125 CASE SIZE & PERMISSIBLE RIPPLE CURRENT OF STANDARD PRODUCTS D x L: mm CAP. RATED VOLTAGE W V (SURGE VOLTAGE W V) (μF) 4 (5) SIZE 6.3 (8) 10 (13) 16 (20) RIPPLE DISSIPATION SIZE RIPPLE DISSIPATION SIZE RIPPLE DISSIPATION SIZE RIPPLE DISSIPATION CURRENT FACTOR CURRENT FACTOR CURRENT FACTOR CURRENT FACTOR 4.7 10 22 33 47 100 220 330 470 1000 1500 4 x 5.4 4 x 5.4 4 x 5.4 5 x 5.4 19 26 34 61 6.3 x 5.4 82 0.35 0.35 0.35 0.35 0.35 4 x 5.4 5 x 5.4 20 22 0.26 0.26 4 x 5.4 20 0.16 4 x 5.4 14 0.30 4 x 5.4 28 0.16 4 x 5.4 28 0.30 4 x 5.4 27 0.26 5 x 5.4 39 0.16 4 x 5.4 29 0.30 5 x 5.4 45 0.26 5 x 5.4 43 0.20 6.3 x 5.4 66 0.16 4 x 5.4 38 0.26 5 x 5.4 43 0.30 6.3 x 5.4 70 0.16 5 x 5.4 46 0.26 6.3 x 5.4 46 0.30 6.3 x 7.7 75 0.18 6.3 x 5.4 71 0.26 5 x 5.4 60 0.30 6.3 x 5.4 70 0.20 6.3 x 5.4 70 0.26 6.3 x 7.7 85 0.20 8 x 6.5 0.20 86 6.3 x 5.4 190 0.26 6.3 x 7.7 105 0.26 6.3 x 7.7 105 0.20 6.3 x 7.7 235 0.35 8 x 6.5 250 0.26 8 x 10.5 280 0.20 8 x 6.5 250 0.35 6.3 x 7.7 280 0.35 8 x 10.5 330 0.26 8 x 10.5 316 0.20 8 x 6.5 300 0.35 10 x 10.5 380 0.20 8 x 10.5 340 0.35 8 x 10.5 380 0.35 8 x 10.5 580 0.35 10 x 10.5 700 0.35 10 x 10.5 1000 0.35 Note: 1. Ripple Current: (mA/rms) 85°C, 120Hz 2. Dissipation Factor: 20°C, 120Hz 8 x 10.5 330 0.26 8 x 10.5 350 0.20 10 x 10.5 400 0.26 10 x 10.5 420 0.20 10 x 10.5 580 0.26 126 CASE SIZE & PERMISSIBLE RIPPLE CURRENT OF STANDARD PRODUCTS CAP. (μF) D x L: mm RATED VOLTAGE W V (SURGE VOLTAGE W V) 25 (32) SIZE RIPPLE CURRENT 35 (44) DISSIPATION SIZE FACTOR RIPPLE CURRENT 50 (63) DISSIPATION SIZE FACTOR RIPPLE CURRENT DISSIPATION FACTOR 0.10 4 x 5.4 1 0.12 0.22 4 x 5.4 2 0.12 0.33 4 x 5.4 3 0.12 0.47 4 x 5.4 5 0.12 1.0 4 x 5.4 10 0.12 2.2 4 x 5.4 8 0.12 4 x 5.4 16 0.12 3.3 4 x 5.4 10 0.12 4 x 5.4 16 0.12 4.7 4 x 5.4 22 0.14 4 x 5.4 22 0.12 5 x 5.4 23 0.12 10 4 x 5.4 24 0.20 4 x 5.4 24 0.16 5 x 5.4 28 0.12 5 x 5.4 28 0.14 5 x 5.4 30 0.12 6.3 x 5.4 35 0.12 5 x 5.4 45 0.14 5 x 5.4 49 0.23 6.3 x 5.4 70 0.12 6.3 x 5.4 55 0.14 6.3 x 5.4 60 0.12 6.3 x 7.7 90 0.12 8 x 6.5 110 0.12 22 33 47 100 220 330 470 5 x 5.4 53 0.14 6.3 x 5.4 100 0.14 6.3 x 7.7 90 0.12 6.3 x 5.4 65 0.14 8 x 6.5 130 0.14 8 x 10.5 120 0.12 6.3 x 5.4 70 0.20 6.3 x 7.7 150 0.14 6.3 x 7.7 63 0.12 8 x 6.5 96 0.16 8 x 6.5 165 0.14 8 x 10.5 100 0.12 10 x 10.5 130 0.12 6.3 x 7.7 115 0.16 6.3 x 7.7 140 0.14 8 x 10.5 160 0.12 8 x 6.5 140 0.16 8 x 6.5 170 0.14 10 x 10.5 190 0.12 8 x 10.5 180 0.16 10 x 10.5 210 0.14 8 x 6.5 210 0.16 8 x 10.5 250 0.14 10 x 10.5 310 0.12 8 x 10.5 260 0.16 10 x 10.5 310 0.14 10 x 10.5 310 0.16 8 x 10.5 350 0.16 10 x 10.5 400 0.14 10 x 10.5 430 0.16 10 x 10.5 480 0.16 Note: 1. Ripple Current: (mA/rms) 85°C, 120Hz 2. Dissipation Factor: 20°C, 120Hz 127 CASE SIZE & PERMISSIBLE RIPPLE CURRENT OF STANDARD PRODUCTS CAP. (μF) D x L: mm RATED VOLTAGE W V (SURGE VOLTAGE W V) 63 (79) SIZE RIPPLE CURRENT DISSIPATION FACTOR 3.3 100 (125) SIZE RIPPLE CURRENT DISSIPATION FACTOR 8 x 10.5 30 0.18 4.7 6.3 x 5.4 20 0.18 8 x 10.5 50 0.18 10 6.3 x 5.4 20 0.18 8 x 10.5 55 0.18 22 8 x 10.5 30 0.18 10 x 10.5 60 0.18 33 8 x 10.5 30 0.18 10 x 10.5 65 0.18 47 8 x 10.5 30 0.18 100 10 x 10.5 60 0.18 Note: 1. Ripple Current: (mA/rms) 85°C, 120Hz 2. Dissipation Factor: 20°C, 120Hz
CA016M0100RED-0605 价格&库存
很抱歉,暂时无法提供与“CA016M0100RED-0605”相匹配的价格&库存,您可以联系我们找货
