DATA SHEET
GAS DISCHARGE TUBES
TELEPHONE INTERFACE
2R-8x6(S) series
Product specification– November 05, 2018 V.0
RoHS compliant & Halogen free
Circuit Protection
Product Specification
GAS DISCHARGE TUBS
2
6
2R-8x6(S)
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
■ Stable breakdown voltage.
■ High insulation resistance.
■ Low capacitance (≤1.5pF)
■ High holdover voltage
■ Large absorbing transient current capability.
■ Micro-Gap Design
■ Size: 8.0mm*6.0mm
■ Storage and operating temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: E244458 & E327997
Applications
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment
Part Number Code
2
M
R
Electrical
Characteristics
M: 10KA
P: 20KA
Electrode Numbers
2R: 2 Electrodes
DC
Spark-over
Voltage
Lead Type
M: SMD
8
S
Square electrode
Dimensions
8: 8.0mm×6.0mm
Marking
: BrightKing Logo
2RM090-8 : Device Marking Code
YXXX
: Date Code
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
3
6
2R-8x6(S)
Dimensions
Dimension (mm)
Symbol
B
Spec.
Tolerance
A
8.00
±0.20
B
0.50
±0.10
D
8.30
±0.20
T
6.00
±0.25
S
9.00
±0.40
A
D
9.0
5.6
1.2
S
T
Recommended Pad Size
Electrical Characteristics
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Single
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
10/350μs
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(KA)
(A)
(times)
DC(V)
2RM075M-8-S
75±20%
600
10
2.5
10
500
25
1.0
1.5
2RM075-8
2RM090M-8-S
90±20%
600
10
2.5
10
500
50
1.0
1.5
2RM090-8
2RM150M-8-S
150±20%
600
10
2.5
10
500
100
1.0
1.5
2RM150-8
2RM230M-8-S
230±20%
700
10
2.5
10
500
100
1.0
1.5
2RM230-8
2RM250M-8-S
250±20%
700
10
2.5
10
500
100
1.0
1.5
2RM250-8
2RM300M-8-S
300±20%
900
10
2.5
10
500
100
1.0
1.5
2RM300-8
2RM350M-8-S
350±20%
900
10
2.5
10
500
100
1.0
1.5
2RM350-8
2RM420M-8-S
420±20%
1000
10
2.5
10
500
100
1.0
1.5
2RM420-8
2RM470M-8-S
470±20%
1000
10
2.5
10
500
250
1.0
1.5
2RM470-8
2RM600M-8-S
600±20%
1200
10
2.5
10
500
250
1.0
1.5
2RM600-8
2RM800M-8-S
800±20%
1400
10
2.5
10
500
250
1.0
1.5
2RM800-8
2RM1000M-8-S
1000±20%
1700
10
2.5
10
500
250
1.0
1.5
2RM1000-8
2RP075M-8-S
75±20%
600
25
1.0
1.5
2RP075-8
2RP090M-8-S
90±20%
600
50
1.0
1.5
2RP090-8
2RP150M-8-S
150±20%
600
100
1.0
1.5
2RP150-8
2RP230M-8-S
230±20%
700
100
1.0
1.5
2RP230-8
2RP250M-8-S
250±20%
700
100
1.0
1.5
2RP250-8
2RP300M-8-S
300±20%
900
100
1.0
1.5
2RP300-8
2RP350M-8-S
350±20%
900
100
1.0
1.5
2RP350-8
2RP420M-8-S
420±20%
1000
100
1.0
1.5
2RP420-8
2RP470M-8-S
470±20%
1000
250
1.0
1.5
2RP470-8
2RP600M-8-S
600±20%
1200
250
1.0
1.5
2RP600-8
2RP800M-8-S
800±20%
1400
250
1.0
1.5
2RP800-8
2RP1000M-8-S
1000±20%
1700
250
1.0
1.5
2RP1000-8
Part
Number
Minimum
Insulation
Resistance
(GΩ)
Maximum
Capacitance
1MHz
Device
Marking
Code
(pF)
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
4
6
2R-8x6(S)
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval
time.
Crest value
Impulse
Discharge Current
Current (%)
100
90
50
20µs
10
To meet
the specified
value
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min.
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
5
6
2R-8x6(S)
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
6℃/second max.
8 minutes max.
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
6
6
2R-8x6(S)
Packaging
Tape
Dimension (mm)
Symbol
Reel
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
6.35
±0.10
K0
6.55
±0.10
B0
8.65
±0.10
t0
0.50
±0.10
D
330.00
±1.00
d
13.00
±0.50
L
20.00
±0.50
t
2.00
±0.20
t
D
d
L
Quantity: 600pcs
www.yageo.com
Nov. 05, 2018 V.0
很抱歉,暂时无法提供与“2RM090M-8/S”相匹配的价格&库存,您可以联系我们找货
