AF0402FR-07249KL
AF0402FR-07249KL
    YAGEO(国巨)
AF0402FR-07249KL 数据手册
DATA SHEET ANTI-SULFURATED CHIP RESISTORS AUTOMOTIVE GRADE AF series 5%, 1%, 0.5% sizes 0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 Product specification – January 03, 2023 V.9 RoHS compliant & Halogen free 2 Product specification Chip Resistor Surface Mount AF 11 0100 to 2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AF0100 to AF2512 chip resistors with anti-sulfuration capabilities. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS AF XXXX X X X XX XXXX L Industrial Equipment Power Application Networking Application High-end Computer & Multimedia Electronics in high sulfur environment  Automotive electronics     GLOBAL PART NUMBER (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 (2) TOLERANCE D = ± 0.5% F = ± 1% J = ± 5% (for jumper ordering, use code of J) FEATURES  AEC-Q200 qualified for size 0201~2512  Superior resistance against sulfur containing atmosphere  Halogen free product and production  RoHS compliant  Reduces environmentally hazardous waste  High component and equipment reliability  Saving of PCB space  Moisture sensitivity level: MSL 1  50ppm available (3) PACKAGING TYPE R = Paper taping reel K = Embossed plastic tape reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point. Detailed resistance rules are displayed in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is system default code for ordering only (Note) Resistance rule of global part number Resistance coding rule Example XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω O RDERING EXAMPLE The ordering code for an AF0402 chip resistor, value 100 KΩ with ± 1% tolerance, supplied in 7-inch tape reel with 10Kpcs quantity is: AF0402FR-07100KL. NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com Jan. 03, 2023 V.9 Product specification Chip Resistor Surface Mount AF SERIES 3 11 0100 to 2512 MARKING AF0100 / AF0201 / AF0402 No marking ynsc007 Fig. 1 AF0603 / AF0805 / AF1206 / AF1210 / AF2010 / AF2512 03 Fig. 2 YNSC001 Value=10 KΩ E-24 series: 3 digits, ±5%, ≥10Ω First two digits for significant figure and 3rd digit for number of zeros AF0603 0 YNSC037 Fig. 3 Value = 24 Ω E-24 series: 3 digits, ± 1% One short bar under marking letter E-96 series: 3 digits, ± 1% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AF0805 / AF1206 / AF1210 / AF2010 / AF2512 00 YNSC004 Fig. 5 Value = 10 KΩ Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros AF1218 YNSC099-2 Fig. 6 Value = 10 KΩ YNSC103-2 Fig. 7 Value = 10 KΩ E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros NOTE For further marking information, please see special data sheet “Chip resistors marking”. Marking of AF series is the same as RC series www.yageo.com Jan. 03, 2023 V.9 Product specification Chip Resistor Surface Mount AF 4 11 0100 to 2512 SERIES CONSTRUCTION The resistors are constructed on top of a high grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a glass. The composition of the glaze is adjusted to give the approximate required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added. See fig.8 OUTLINES For dimensions see Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 DIMENSIONS Table 1 For outlines see fig. 8 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) 0.40± 0.02 0.20± 0.02 0.14± 0.02 0.10± 0.03 0.10± 0.03 AF0100 0.60± 0.03 0.30± 0.03 0.23± 0.03 0.12± 0.05 0.15± 0.05 AF0201 AF0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 AF0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 0.25± 0.15 AF0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 0.35± 0.20 AF1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 0.50± 0.20 AF1210 3.10± 0.10 2.60± 0.15 0.57± 0.10 0.45± 0.20 0.50± 0.20 AF1218 3.10± 0.10 4.60± 0.10 0.57± 0.10 0.45± 0.20 0.50± 0.20 AF2010 5.00± 0.10 2.50± 0.15 0.57± 0.10 0.55± 0.20 0.55± 0.20 AF2512 6.35± 0.10 3.20± 0.15 0.57± 0.10 0.60± 0.20 0.60± 0.20 W YNSC086 L Fig. 8 Chip resistor outlines www.yageo.com Jan. 03, 2023 V.9 Product specification Chip Resistor Surface Mount AF SERIES 5 11 0100 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE AF0100 AF0201 POWER 1/32 W Operating Temperature Range –55 °C to 125°C 1/20 W Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage 15V 25V 30V 50V Resistance Range Temperature Coefficient Jumper Criteria 30V 5% (E24) 10Ω ≤ R ≤ 1MΩ 1% (E24/E96) 10Ω ≤ R ≤ 1MΩ Jumper < 50mΩ 10Ω ≤ R < 100Ω ± 300 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 200 ppm/°C Rated Current 0.5A Max. Current 1.0A 50V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω -100/+350 ppm/°C 10Ω < R ≤ 10MΩ ± 200 ppm/°C Rated Current 0.5A Max. Current 1.0A 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 50 ppm/°C Rated Current 1A Max. Current 2A 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 1/16 W 50V 100V 100V 1/8W 75V 100V 100V AF0402 1/10 W 75V 150V 150V 75V 150V 150V AF0603 1/5 W –55 °C to 155 °C 1/8 W 150V 300V 300V 1/4 W 150V 300V 300V AF0805 1/4 W 200V 400V 500V 1/2 W 200V 400V 500V AF1206 Rated Current 1A Max. Current 2A Rated Current 2A Max. Current 5A Rated Current 2A Max. Current 10A www.yageo.com Jan. 03, 2023 V.9 Product specification Chip Resistor Surface Mount AF SERIES 6 11 0100 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE POWER Operating Temperature Range Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage Resistance Range Temperature Coefficient Jumper Criteria 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A 1/2 W 200V 500V 500V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1W 200V 500V 500V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 1MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 2.2MΩ ± 50 ppm/°C AF1210 1W 200V 500V 500V 5% (E24) 1Ω ≤ R ≤ 1MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 1MΩ Jumper < 50mΩ 200V 500V 500V 5% (E24) 1Ω ≤ R ≤ 1MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 1MΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 1MΩ ± 100 ppm/°C 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C AF1218 1.5 W –55 °C to 155 °C 3/4 W 200V 500V 500V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1.25W 200V 500V 500V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 500V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 500V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω≤ R ≤ 10MΩ 1Ω ≤ R < 10Ω ± 200 ppm/°C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/°C AF2010 1W 200V 500V AF2512 2W 200V 500V Rated Current 2A Max. Current 10A Rated Current 2A Max. Current 10A Rated Current 2A Max. Current 10A www.yageo.com Jan. 03, 2023 V.9 Product specification Chip Resistor Surface Mount AF SERIES 7 11 0100 to 2512 FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles of AF -series is the same as RC-series. Please see the special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE Paper taping reel (R) Embossed taping reel (K) REEL DIMENSION AF0100 AF0201 AF0402 AF0603 AF0805 AF1206 AF1210 AF1218 AF2010 AF2512 7" (178 mm) 20,000 10,000/20,000 10,000/20,000 5,000 5,000 -- 13" (330 mm) -- 50,000 50,000 20,000 20,000 -- 7" (178 mm) -- -- -- -- -- 4,000 NOTE 1. For paper/embossed tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE RANGE FUNCTIONAL DESCRIPTION toE910 m PT040 O PERATING TEMPERATUR100 E Rm ANG 2 ± 200 ppm/°C AF0100 Range: -55°C to + 125°C PT060 - AF2512 Range: -55°C to + 155°C AF0201 ± 200 ppm/°C 3 P (%Prated) MLB206_9-1 100 0201 to 2512 PT080 P OWER RATING ± 200 ppm/°C 5 Each type power at 70°C: 100rated MΩ TO 910 MΩ PT120 AF0100=1/32W (0.03125W) 100 mΩ 6 AF0201=1/20W (0.05W) PT201 AF0402=1/16 W (0.0625W); ±1/8W (0.125W) 100 ppm/°C 0 AF0603=1/10 W (0.1W); 1/5W (0.2W) PT251 AF0805=1/8 W (0.125W); 1/4W ± 100(0.25W) ppm/°C 2 AF1206=1/4 W (0.25W); 1/2W (0.5W) 50 0100 > 100 mΩ 0 55 0 ± 75 ppm/°C 50 70 100 125 155 o Tamb ( C) Fig. 9 Maximum dissipation (P max) in percentage of rated power as ± 75 ppm/°C a function of the operating ambient temperature (T amb) AF1210=1/2W (0.5W); 1W AF1218=1W; 1.5W AF2010=3/4W (0.75W); 1.25W AF2512=1W, 2W R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V = √(P X R) or max. working voltage whichever is less Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value ( ) www.yageo.com Jan. 03, 2023 V.9 Product specification Chip Resistor Surface Mount AF SERIES 8 11 0100 to 2512 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS High Temperature Exposure AEC-Q200 Test 3 0100: 1,000 hours at 125 °C MIL-STD-202 Method 108 Others: 1,000 hours at 155± 3 °C unpowered 0100: ± (2.0%+0.05Ω)
AF0402FR-07249KL
物料型号:文档描述的是YAGEO公司的AF系列贴片电阻,型号范围从AF0100到AF2512。
器件简介:AF系列贴片电阻具备抗硫化特性,符合汽车级标准,无卤素且符合RoHS指令,能够在含硫环境中提供优越的电阻性能。
引脚分配:文档中没有明确指出具体的引脚分配,但通常贴片电阻为两个端点的简单结构。
参数特性:电阻值范围从50ppm到22MΩ,温度系数从±50ppm/°C到±200ppm/°C不等,额定功率从1/32W到2W,最大工作电压和过载电压也根据不同型号有所差异。
功能详解:这些电阻设计用于工业设备、电力应用、网络应用、高端计算机和多媒体电子设备,尤其是在高硫环境中的汽车电子。
应用信息:适用于高硫环境的高端电子设备,如汽车电子,以及需要高可靠性和节省PCB空间的应用。
封装信息:提供了不同尺寸的封装信息,包括AF0100至AF2512的尺寸参数,以及标记方式和电气特性表。
AF0402FR-07249KL 价格&库存
很抱歉,暂时无法提供与“AF0402FR-07249KL”相匹配的价格&库存,您可以联系我们找货
AF0402FR-07249KL
    • 10000+0.0139810000+0.00175
    • 40000+0.0139240000+0.00174
    • 150000+0.01391150000+0.00174
    • 400000+0.01391400000+0.00174
    • 1000000+0.013911000000+0.00174
    库存:10000
    AF0402FR-07249KL
      • 1610+0.01720
      • 5000+0.01160
      • 10000+0.00830
      库存:40000
