AT0603BRD0733RL
AT0603BRD0733RL
    YAGEO(国巨)
AT0603BRD0733RL 数据手册
DATA SHEET THIN FILM CHIP RESISTORS AUTOMOTIVE GRADE AT series 0.01% TO 1%, TC5 TO TC50 sizes 0402/0603/0805/1206 Product specification – April 15, 2021 V.6 RoHS compliant Product specification Chip Resistor Surface Mount AT SERIES 2 9 0402 to 1206 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AT0402 to AT1206 high precision-high stability chip resistors made by thin film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER AT XXXX X X X XX XXXXX L APPLICATIONS  Automotive electronics  Industrial and medical equipment  Test and measuring equipment  Telecommunications (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0402 / 0603 / 0805 / 1206 (2) TOLERANCE B = ± 0.1% C = ± 0.25% FEATURES  AEC-Q200 qualified D = ± 0.5% F = ± 1% Total lead free without RoHS exemption L = ± 0.01%  Halogen free epoxy W = ± 0.05%  Superior resistance against sulfur containing atmosphere  Moisture sensitivity level: MSL 1  Reducing environmentally hazardous wastes    P = ± 0.02% (3) PACKAGING TYPE R = Paper taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE A = ± 5 ppm/°C High component and equipment reliability B = ± 10 ppm/°C Non-forbidden materials used in products/production D = ± 25 ppm/°C C = ± 15 ppm/°C E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point Example: 100R = 100Ω 1K = 1,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only. (NOTE) ORDERING EXAMPLE The ordering code of a AT0402 chip resistor, TC 25 value 56Ω with ± 0.5% tolerance, supplied in 7-inch tape reel is: AT0402DRD0756RL. NOTE 1. All our Rchip products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT 3 9 0402 to 1206 SERIES MARKING AT0402 No marking ynsc007 Fig. 1 AT0603 E-96 series: including values 10/11/13/15/20/75 of E-24 series, 3 digits Fig. 2 Value = 12.4 Ω 563 ynsc003 Fig. 3 Value = 56 KΩ E-24 series: exception values 10/11/13/15/20/75 of E-24 series, one short bar under marking letter AT0805 / AT1206 00 YNSC004 Fig. 4 Value = 10 KΩ Both E-24 and E-96 series: 4 digits First three digits for significant figure and 3rd digit for number of zeros NOTE For further marking information, please see special data sheet “Chip resistors marking”. CONSTRUCTION A metal film layer is deposited on a high grade ceramic body (aluminium oxide). This resistive layer is trimmed to its nominal value and on both ends a contact is made which will guarantee optimum solderability. This is achieved by applying several layers and for ease of soldering the outer layer consists of Ni/matte tin. The resistive layer is covered with a protective coating. OUTLINES marking layer protective coat resistive layer inner electrode H termination (Ni / matte tin) ceramic substrate I2 I1 W YNSC064 L Fig. 5 Chip resistor outlines www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 4 9 0402 to 1206 DIMENSIONS Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AT0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 AT0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AT0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 AT1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 ELECTRICAL CHARACTERISTICS Table 2 TYPE Operating Temperature Power Range Rating AT0402 1/16W Max. Max. Working Overload Voltage Voltage 50 V 100 V Resistance Range (E-24/E-96 series)(Ω ) & Tolerance (1) Dielectric T.C.R. ±0.01% ±0.02% ±0.05% ±0.1% ±0.25% ±0.5% ±1% Withstanding (2) (L) (P) (W) Voltage (ppm/°C) (B) (C) (D) (F) 100 V ±50 (E) 10 ≤ R ≤ 100K ±25 (D) 10 ≤ R ≤ 100K ± 15 (C) 50 ≤ R < 11K 50 ≤ R < 11K --10 ≤ R ≤ 330K ±5 (A) ±50 (E) 10 ≤ R ≤ 330K ±25 (D) AT0603 1/10W 75V 150 V 100 V ± 15 (C) 50 ≤ R < 14K AT0805 50 ≤ R < 14K ±5 (A) 1/8W 150 V 300 V 300 V 10 ≤ R ≤ 1M ±25 (D) 10 ≤ R ≤ 1M ± 15 (C) 50 ≤ R < 17K 200 V 400 V 500 V 10 ≤ R < 17K 50 ≤ R < 17K 50 ≤ R < 17K ±5 (A) 1/4W --- ±50 (E) ± 10 (B) AT1206 10 ≤ R < 14K 50 ≤ R < 14K ± 10 (B) –55 °C to +155 °C 10 ≤ R < 11K 50 ≤ R < 11K ± 10 (B) --- ±50 (E) 10 ≤ R ≤ 1M ±25 (D) 10 ≤ R ≤ 1M ± 15 (C) ± 10 (B) ±5 (A) 50 ≤ R < 20K 10 ≤ R < 20K 50 ≤ R < 20K 50 ≤ R < 20K --- NOTE : 1. Global part number (code 7) 2. Global part number (code 9) www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 5 9 0402 to 1206 FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors moun ting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity REEL DIMENSION QUANTITY PER REEL Paper taping reel 7" (178 mm) 10,000 Units AT0603 Paper taping reel 7" (178 mm) 5,000 Units AT0805 Paper taping reel 7" (178 mm) 5,000 Units AT1206 Paper taping reel 7" (178 mm) 5,000 Units PRODUCT TYPE PATKING STYLE AT0402 NOTE: for paper tape and reel specification/dimensions, please see the special data COEFFICIENT sheet “packing” document. TEMPERATURE OF RESISTANCE RESISTANCE RANGE DESCRIPTION FUNCTIONAL PT040 toE910 mΩ OPERATING TEMPERATUR100 E RmΩ ANG 2 ± 200 ppm/°C Range: –55 °C to +155 °C PT060 ± 200 ppm/°C 3POWER RATING Each PT080type rated power at 70 °C: ± 200 ppm/°C AT0402=1/16 W 5 AT0603=1/10 WTO 910 MΩ 100 MΩ PT120 AT0805=1/8 W 100 mΩ 6AT1206=1/4 W PT201 0RATED VOLTAGE ± 100 ppm/°C PT251 The DC or AT (rms) continuous working voltage ± 100 ppm/°C 2corresponding to the rated power is determined by the following formula: V= handbook, halfpage MLB206_1 P (%Prated) 100 50 > 100 mΩ 0 ±5575 ppm/°C0 50 70 100 155 o Tamb ( C) ± 75 dissipation ppm/°C (P max ) in percentage of rated power Fig. 6 Maximum as a function of the operating ambient temperature (T amb ) (P xR) Or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (v) P=Rated power R=Resistance value (Ω) www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 6 9 0402 to 1206 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST Short Time Overload TEST METHOD PROCEDURE REQUIREMENTS IEC60115-1 4.13 2.5 times of rated voltage or maximum ± (0.05%+0.05Ω) overload voltage, the less of the above, for 5 sec at room temperature High Temperature Exposure AEC-Q200 Test 3 Moisture Resistance 1,000 hours at Tamb = 125 °C, unpowered ± (0.1%+0.05Ω) 1,000 hours at Tamb = 155 °C, unpowered ± (0.3%+0.05Ω) AEC-Q200 Test 6 Each temperature / humidity cycle is defined at ± (0.1%+0.05Ω) MIL-STD-202 Method 106 8 hours (method 106F), 3 cycles / 24 hours for MIL-STD-202 Method 108 10d. with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered Parts mounted on test-boards, without condensation on parts Biased Humidity AEC-Q200 Test 7 1,000 hours; 85 °C / 85% RH MIL-STD-202 Method 103 10% of operating power ± (0.1%+0.05Ω) Measurement at 24± 4 hours after test conclusion Operational Life AEC-Q200 Test 8 MIL-STD-202 Method 108 Resistance to Soldering Heat AEC-Q200 Test 15 Thermal Shock AEC-Q200 Test 16 Solderability - Wetting AEC-Q200 Test 18 MIL-STD-202 Method 210 MIL-STD-202 Method 107 J-STD-002 1,000 hours at 70± 5 °C, RCWV applied for 1.5 hours on, 0.5 hour off, still air required ± (0.1%+0.05Ω) 1,000 hours at 125 °C, derated voltage applied for 1.5 hours on, 0.5 hour off, still air required ± (0.3%+0.05Ω) Condition B, no pre-heat of samples Lead-free solder, 260± 5 °C, 10± 1 seconds immersion time Procedure 2 for SMD: devices fluxed and cleaned with isopropanol ± (0.05%+0.05Ω) -55/+125 °C Number of cycles is 300. Devices mounted Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air ± (0.1%+0.05Ω) Electrical Test not required Magnification 50X SMD conditions: (a) Method B, aging 4 hours at 155 °C dry heat, dipping at 235± 3 °C for 5± 0.5 seconds. (b) Method B, steam aging 8 hours, dipping at 215± 3 °C for 5± 0.5 seconds. (c) Method D, steam aging 8 hours, dipping at 260± 3 °C for 7± 0.5 seconds Well tinned No visible damage (>95% covered) No visible damage www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount TEST AT SERIES TEST METHOD PROCEDURE REQUIREMENTS Board Flex / Bending AEC-Q200 Test 21 Chips mounted on a 90mm glass epoxy resin PCB (FR4) Bending for 0402: 5 mm 0603/0805: 3 mm 1206: 2mm Holding time: minimum 60 second ± (0.1%+0.05Ω) Temperature Coefficient of Resistance (T.C.R.) IEC 60115-1 4.8 At +25/–55 °C and +25/+125°C Formula: Refer to table 2 AEC-Q200-005 T.C.R= 7 9 0402 to 1206 R2 - R1 × 106(ppm/°C) R1(t 2  t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Flower of Sulfur ASTM-B-809-95* Sulfur 750 hours, 105°C, unpowered. ± (4.0%+0.05Ω) * Modified www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 0402 to 1206 8 9 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 6 Apr. 15, 2021 - - Add tol. ± 0.01%, 0.02%, 0.05% ; TCR 5ppm & 10ppm Version 5 Oct. 24, 2017 - - Add resistance range for ± 15 ppm/°C Version 4 Mar. 16, 2016 - - Remove FOS 90°C test Version 3 Dec. 11, 2015 - - Modify Outline Version 2 May 11, 2015 - - Modify FOS test Version 1 Jun. 18, 2014 - - Modify FOS test Version 0 May 07, 2014 - - First issue of this specification www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 0402 to 1206 9 9 LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particu lar purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. Yageo statements regarding the suitability of products for cer tain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the sui tability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life -saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in p ersonal injury or death. Customers using or selling Yageo products not expressly indicated for above -mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Apr. 15, 2021 V6
AT0603BRD0733RL 价格&库存
很抱歉,暂时无法提供与“AT0603BRD0733RL”相匹配的价格&库存,您可以联系我们找货
