DATA SHEET
WIRELESS COMPONENTS
Coupler
CPL1608LL12RWHEXA
LTE
Product Specification – January 18, 2018 V.1
1608 Series
Product specification
WIRELESS COMPONENTS
FEATURES
Compact size design
RoHS compliant
ORDERING INFORMATION
APPLICATIONS
WWAN Hexa-band
PART NUMBER
LTE (0.6-2.7GHz)
2
5
Coupler
All part numbers are identified by the series, packing type, material, size,
antenna type, working frequency and packing quantity.
CPL 1608 LL 12 R WHEXA
(1)
(2)
(3)
(4)
(5)
(6)
(1) PRODUCT
CPL = Directonal Coupler
(2) SIZE
1608 = 1.6 × 0.8 mm
(3) MATERIALS
Material Code LL
(4) TYPE
12 = Type 12
(5) PACKING STYLE
R = Tape and Reel
(6) WORKING FREQUENCY
WHEX = WWAN Hexa-band, LTE (0.6-2.7GHz) application
www.yageo.com
Jan. 18, 2018 V.1
WIRELESS COMPONENTS
3
5
Coupler
SPECIFICATION
Table 1
(MHz)
689 ~ 960
0.15 max.
at 25°C
1425 ~ 2170
0.25 max.
at 25°C
1.5 max.
2300 ~ 2700
0.3 max.
at 25°C
Coupling (dB)
23 ~ 28
21.5 ~ 26.5
22.5 ~ 27.5
Isolation (dB)
42 min.
38 min.
35 min.
Insertion Loss (dB)
V.S.W.R
-40 ~ +85 °C
Operating Temperature
DIMENSIONS
Table 2 Machinical Dimension
OUTLINES
DIMENSION
L (mm)
1.60 ± 0.15
W (mm)
0.80 ±0.15
T (mm)
0.60 ±0.15
P1 (mm)
0.20 ±0.15
P2 (mm)
0.20 ±0.15
P3 (mm)
0.20 ± 0.15
P4 (mm)
0.20 ±0.15
P5 (mm)
0.20 ± 0.15
P6 (mm)
0.20 ±0.15
D1 (mm)
D2 (mm)
0.20 ± 0.15
D3 (mm)
0.15 ± 0.10
Fig. 1 Coupler outlines
0.30 ± 0.10
Table 3 Termination configuration
TERMINAL NAME
P1
P2
P3
P4
P5
P6
FUNCTION
Input
GND
Output
50-Ω Term
GND
Coupling
www.yageo.com
Jan. 18, 2018 V.1
WIRELESS COMPONENTS
4
5
Coupler
•Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness.
Fig. 2 Reference design of evaluation board
ELECTRICAL PERFORMANCES
•Measured on Agilent E5071C
Network Analyzer
•Input port : Port 1 (Return loss : S11)
•Output port : Port 2 (Insertion loss :
S21)
•Coupling port : Port 4 (Coupling S41)
•50-Ω termination port : Port 3
(Isolation S31)
Fig. 3
Frequency Characteristics
www.yageo.com
Jan. 18, 2018 V.1
WIRELESS COMPONENTS
Coupler
5
5
REVISION HISTORY
REVISION DATE
Version 0
Jul. 15, 2016
Version 1
Jan. 18, 2018
CHANGE NOTIFICATION
DESCRIPTION
- New datasheet for Coupler
- Correct Dimension L
www.yageo.com
Jan. 18, 2018 V.1
很抱歉,暂时无法提供与“CPL1608LL12RWHEXA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.89403
- 50+0.71259
- 150+0.62187
- 500+0.55383
- 2500+0.47963
- 4000+0.45242
