CS0805KFX7R9BB474
CS0805KFX7R9BB474
    YAGEO(国巨)
    CS0805KFX7R9BB474
CS0805KFX7R9BB474 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS Soft termination NPO and X7R 16V TO 3KV 0.47pF to 2.2 uF Product Specification – March 25, 2021 V.8 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 16V to 3KV 2 19 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes X7R series chip capacitors with Flexible leadfree terminations. All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. YAGEO ordering code APPLICATIONS High flexure stress circuit boards Switch power supplies Telecom base station GLOBAL PART NUMBER (PREFERRED ) CS XXXX X X (1) X7R (2) (3) X BX XXX (4) (5) (6) (1) SIZE – INCH BASED (METRIC) FEATURES  Supplied in tape on reel  Flexible termination system  Leaded-free termination meet RoHS requirements  Improved resistance to thermal stresses  Increased mechanical performance 0402 (1005) 1206 (3216) 0603 (1608) 1210 (3225) 0805 (2012) 1808 (4520) 1812 (4532) (2) TOLERANCE G = ± 2% (1) J = ± 5% (2) K = ± 10% M = ± 20% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) RATED VOLTAGE 7 = 16 V Y = 250 V 8 = 25 V B = 500 V 9 = 50 V Z = 630 V 0 = 100 V C = 1 kV D = 2 kV A = 200 V E = 3 kV (5) PROCESS N = NP0 B = Class 2 MLCC (6) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 103 = 10 x 103 = 10,000 pF = 10 nF NOTE 1. Tolerance ±2% doesn't available for full NPO product range, please contact local sales force before order. 2. Tolerance ±5% doesn't available for full X7R product range, please contact local sales force before order. www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 3 19 16V to 3KV CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end flexible terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1 and Fig.2. terminations Copper Soft electrode (Stress relaxation) electrodes Ni Plating Sn Plating YNM0049 MLB457 Fig. 2 Concept of soft termination ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION Table 1 For outlines see fig. 3 TYPE L1 (mm) W (mm) 0402 1.0 ± 0.15 1.6 ± 0.20 1.6 ± 0.25 0.5 ± 0.15 0.8 ± 0.15 0.8 ± 0.25 0603 0805 2.0 ± 0.3 1.25 ± 0.2 1.25 ± 0.25 1206 3.2 ± 0.4 1.6 ± 0.2 1.6 ± 0.3 1210 3.2 ± 0.5 2.5 ± 0.3 3.2 ± 0.3 1808 4.5+0.6/-0.4 2.0 ± 0.4 1812 4.5+0.6/-0.4 3.2 ± 0.4 OUTLINES T (mm) 0.50 ± 0.80 ± 0.80 ± 0.60 ± 0.85 ± 1.25 ± 1.25 ± 0.60 ± 0.85 ± 1.15 ± 1.25 ± 1.60 ± 1.60 ± 0.85 ± 1.15 ± 1.25 ± 1.25 ± 1.60 ± 2.00 ± 2.5 ± 2.5 ± 1.25 ± 1.35 ± 1.60 ± 1.60 ± 2.00 ± 0.85 ± 1.15 ± 1.25 ± 1.25 ± 1.35 ± 1.60 ± 0.15 0.15 0.25 0.15 0.15 0.20 0.25 0.15 0.15 0.20 0.20 0.20 0.30 0.20 0.30 0.20 0.30 0.30 0.30 0.3 0.2 0.20 0.40 0.20 0.40 0.40 0.30 0.40 0.20 0.40 0.40 0.40 L2/L3(mm) L2/L3(mm) min max L4(mm) min Dimension code CA DA DB EA EB EC ED FA FB FC FD FE FF GA GB GC GD GE GF GG GH HA HB HC HD HE IA IB IC ID IE IF 0.10 0.20 0.20 0.35 0.65 0.85 0.30 0.50 0.20 0.25 0.75 0.70 0.25 0.85 0.50 0.25 0.85 1.50 0.25 1.00 1.20 0.25 0.85 1.40 0.25 0.45 1.0 0.75 1.2 1.5 0.25 0.85 2.20 0.25 0.85 2.20 For dimension see Table 1 W T L2 L4 L1 L3 MBB211 Fig. 3 Surface mounted multilayer ceramic capacitor dimension www.yageo.com Mar. 25, 2021 V.8 4 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 16V to 3KV 19 CAPACITANCE RANGE & THICKNESS Table 2 NPO / 0402 to 0805 CAP. 0402 0603 0805 50V 100V 50V 100V 250V 50V 100V 250V 500V 630V 1000V 0.47 pF CA CA DA DA DA EA EA EA EA 0.56 pF CA CA DA DA DA EA EA EA EA 0.68 pF CA CA DA DA DA EA EA EA EA 0.82 pF CA CA DA DA DA EA EA EA EA 1 pF CA CA DA DA DA EA EA EA EA 1.2 pF CA CA DA DA DA EA EA EA EA 1.5 pF CA CA DA DA DA EA EA EA EA 1.8 pF CA CA DA DA DA EA EA EA EA 2.2 pF CA CA DA DA DA EA EA EA EA 2.7 pF CA CA DA DA DA EA EA EA EA 3.3 pF CA CA DA DA DA EA EA EA EA 3.9 pF CA CA DA DA DA EA EA EA EA 4.7 pF CA CA DA DA DA EA EA EA EA 5.6 pF CA CA DA DA DA EA EA EA EA 6.8 pF CA CA DA DA DA EA EA EA EA 8.2 pF CA CA DA DA DA EA EA EA EA 10 pF CA CA DA DA DA EA EA EA EA EA EB 12 pF CA CA DA DA DA EA EA EA EA EA EB 15 pF CA CA DA DA DA EA EA EA EA EA EB 18 pF CA CA DA DA DA EA EA EA EA EA EB 22 pF CA CA DA DA DA EA EA EA EA EA EB 27 pF CA CA DA DA DA EA EA EA EA EA EB 33 pF CA CA DA DA DA EA EA EA EA EA EB 39 pF CA CA DA DA DA EA EA EA EA EA EB 47 pF CA CA DA DA DA EA EA EA EA EA EB 56 pF CA CA DA DA DA EA EA EA EA EA EC 68 pF CA CA DA DA DA EA EA EA EA EA EC 82 pF CA CA DA DA DA EA EA EA EA EA EC 100 pF CA CA DA DA DA EA EA EA EA EA Tape width 8 mm NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request 3. For product with 2% tolerance, please contact local sales force before ordering www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 16V to 3KV 5 19 CAPACITANCE RANGE & THICKNESS Table 3 NPO / 0402 to 0805 CAP. 0402 0603 0805 50V 100V 50V 100V 250V 50V 100V 250V 500V 630V 120 pF CA CA DA DA DA EA EA EA EA EA 150 pF CA CA DA DA DA EA EA EA EA EA 180 pF CA DA DA DA EA EA EA EA EA 220 pF CA DA DA DA EA EA EB EB EB 270 pF CA DA DA DA EA EA EB EB EB 330 pF CA DA DA DA EA EA EB EB EB 390 pF CA DA DA DA EA EA EB EB EB 470 pF CA DA DA DA EA EA EB EB EB 560 pF DA DA DA EA EA EB EC EC 680 pF DA DA DA EA EA EB EC EC 820 pF DA DA EA EA EB EC EC 1.0 nF DA DA EA EA EB EC EC 1.2 nF DA EB EB EC 1.5 nF DA EB EB EC 1.8 nF DA EB EB EC 2.2 nF DA EC EC EC 2.7 nF DA EC EC EC 3.3 nF DA EC EC EC 3.9 nF EC EC EC 4.7 nF EC EC EC 5.6 nF EC EC 6.8 nF EC EC 8.2 nF EC EC 10 nF EC EC Tape width 1000V 8 mm NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request 3. For product with 2% tolerance, please contact local sales force before ordering www.yageo.com Mar. 25, 2021 V.8 6 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 16V to 3KV 19 CAPACITANCE RANGE & THICKNESS Table 4 NPO / 1206 to 1210 CAP. 1206 1210 50V 100V 250V 500V 630V 1000V 2000V 3000V 50V 100V 250V 500V 630V 1000V 2000V 0.47 pF FA FA FA 0.56 pF FA FA FA 0.68 pF FA FA FA 0.82 pF FA FA FA 1 pF FA FA FA 1.2 pF FA FA FA 1.5 pF FA FA FA 1.8 pF FA FA FA 2.2 pF FA FA FA FA 2.7 pF FA FA FA FA 3.3 pF FA FA FA FA 3.9 pF FA FA FA FA 4.7 pF FA FA FA FA 5.6 pF FA FA FA FA 6.8 pF FA FA FA FA 8.2 pF FA FA FA FA 10 pF FA FA FA FA FD FD FD FD 12 pF FA FA FA FA FD FD FD FD 15 pF FA FA FA FA FD FD FD FD 18 pF FA FA FA FA FD FD FD FD 22 pF FA FA FA FA FD FD FD FD 27 pF FA FA FA FA FD FD FD FD 33 pF FA FA FA FA FD FD FD FD GC GC GC 39 pF FA FA FA FA FD FD FD FD GC GC GC 47 pF FA FA FA FA FD FD FD FD 56 pF FA FA FA FA FD FD 68 pF FA FA FA FA FD 82 pF FA FA FA FA 100 pF FA FA FA FA GC GC GC GC GC GC GC FD GC GC GC GC GC GC GC FD FD GC GC GC GC GC GC GC FD FD FD GC GC GC GC GC GC GC FD FD FD GC GC GC GC GC GC GC Tape width www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 16V to 3KV 7 19 CAPACITANCE RANGE & THICKNESS Table 5 NPO / 1206 to 1210 CAP. 1206 1210 50V 100V 250V 500V 630V 1000V 2000V 50V 100V 250V 500V 630V 1000V 2000V 120 pF FA FA FA FA FD FD FD GC GC GC GC GC GC GC 150 pF FA FA FA FA FD FD FD GC GC GC GC GC GC GC 180 pF FA FA FA FA FD FD FD GC GC GC GC GC GC GC 220 pF FA FA FA FA FD FD FD GC GC GC GC GC GC GC 270 pF FA FA FA FA FD FD GC GC GC GC GC GC 330 pF FA FA FA FA FD FD GC GC GC GC GC GC 390 pF FA FA FA FA FD FD GC GC GC GC GC GC 470 pF FA FA FA FA FD FD GC GC GC GC GC GC 560 pF FA FA FA FA FD FD GC GC GC GC GC GC 680 pF FA FA FA FA FD FD GC GC GC GC GC GC 820 pF FA FA FB FB FD FD GC GC GC GC GC GC 1.0 nF FA FA FB FB FD FD GC GC GC GC GC GC 1.2 nF FA FA FB FB FD GC GC GC GC 1.5 nF FA FA FB FB FD GC GC GC GC 1.8 nF FA FA FD FD FD GC GC GC GC 2.2 nF FA FA FD FD FD GC GC GC GC 2.7 nF FA FA FD GC GC GC GC 3.3 nF FB FB FD GC GC GC GC 3.9 nF FB FB FD GC GC GC GC 4.7 nF FB FB GC GC GC GC 5.6 nF FB FB GC GC 6.8 nF FB FB GC GC 8.2 nF FD FD GC GC 10 nF FD FD GC GC Tape width 8 mm www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 8 19 16V to 3KV CAPACITANCE RANGE & THICKNESS Table 6 NPO / 1808 to 1812 CAP. 1808 1000V 1812 2000V 3000V 100V 250V 500V 630V 1000V 2000V 3000V 10 pF HC IC IC IC 12 pF HC IC IC IC 15 pF HC IC IC IC 18 pF HC IC IC IC 22 pF HC IC IC IC 27 pF HC IC IC IC 33 pF HA HA HC IC IC IC 39 pF HA HA HC IC IC IC 47 pF HA HA HC IC IC IC 56 pF HA HA HC IC IC IC IC IC IC IC 68 pF HA HA HC IC IC IC IC IC IC IC 82 pF HA HA HC IC IC IC IC IC IC IC 100 pF HA HA HC IC IC IC IC IC IC IC 120 pF HA HA IC IC IC IC IC IC IC 150 pF HA HA IC IC IC IC IC IC IC 180 pF HA HA IC IC IC IC IC IC IC 220 pF HA HA IC IC IC IC IC IC IC 270 pF HA HA IC IC IC IC IC IC 330 pF HA HA IC IC IC IC IC IC 390 pF HA HA IC IC IC IC IC IC 470 pF HA HA IC IC IC IC IC 560 pF HA HA IC IC IC IC IC 680 pF IC IC IC IC IC 820 pF IC IC IC IC IC 1.0 nF IC IC IC IC IC 1.2 nF IC IC IC IC IC 1.5 nF IC IC IC IC IC 1.8 nF IC IC IC 2.2 nF IC IC IC 2.7 nF IC IC IC 3.3 nF IC IC IC 3.9 nF IC IC IC 4.7 nF IC IC IC 5.6 nF IC 6.8 nF IC 8.2 nF IC 10 nF IC 12 nF IC 15 nF IC 18 nF IC 22 nF IC 27 nF 33 nF Tape Width 12 mm NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request 3. For product with 2% tolerance, please contact local sales force before ordering www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 9 19 16V to 3KV CAPACITANCE RANGE & THICKNESS Table 7 X7R / 0402 to 0805 CAP. 0402 0603 0805 16V 25V 50V 100V 16V 25V 50V 100V 250V 16V 25V 50V 100V 250V 500V 100 pF CA CA CA CA DA DA DA DA DA 150 pF CA CA CA CA DA DA DA DA 220 pF CA CA CA CA DA DA DA 330 pF CA CA CA CA DA DA 470 pF CA CA CA CA DA 680 pF CA CA CA CA 1.0 nF CA CA CA 1.5 nF CA CA 2.2 nF CA 3.3 nF DA EA EA EA EA EB EB EB EB DA DA EA EA EA EA EB EB EB EB DA DA DA EA EA EA EA EB EB EB EB DA DA DA DA EA EA EA EA EB EB EB EB DA DA DA DA DA EA EA EA EA EB EB EB EB CA DA DA DA DA DA EA EA EA EA EB EB EB EB CA CA DA DA DA DA DA EA EA EA EA EB EB EB CA CA CA DA DA DA DA DA EA EA EA EA EB EB EB CA CA CA CA DA DA DA DA EA EA EA EA EB EB EB 4.7 nF CA CA CA CA DA DA DA DA EA EA EA EA EB EB EB 6.8 nF CA CA CA CA DA DA DA DA EA EA EA EA EC EB EB 10 nF CA CA CA CA DA DA DA DA EA EA EA EA EC EC EC 15 nF CA CA CA DA DA DA DA EA EA EA EB EC EC 22 nF CA CA CA DA DA DA DA EA EA EA EB EC EC 33 nF CA CA CA DA DA DA DA EB EB EB EC 47 nF CA CA CA DA DA DA DA EB EB EB EC 68 nF CA CA DA DA DA DA EB EB EB EC 100 nF CA CA DA DA DA DA EB EB EB EC 150 nF DA DA DA EC EC EC 220 nF DA DA DA EC EC EC 330 nF DA DA EC EC EC 470 nF DA DA EC EC EC 680 nF DA EC EC EC 1000 nF DA EC EC EC 2.2 µF EC ED 4.7 µF ED Tape width DA 630V 1000V 8 mm NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For product with 5% tolerance, please contact local sales force before ordering www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 10 19 16V to 3KV CAPACITANCE RANGE & THICKNESS Table 8 X7R / 1206 to 1210 CAP. 1206 1210 16V 25V 50V 100V 200/250V 500V 630V 1000V 2000V 16V 25V 50V 100V 250V 500V 630V 1000V 2000V 220 pF FB FB FB FB FB FD FD FD FD 330 pF FB FB FB FB FB FD FD FD FD 470 pF FB FB FB FB FB FD FD FD FD GD GD 680 pF FB FB FB FB FB FD FD FD FD GD GD 1.0 nF FB FB FB FB FB FD FD FD FD GD GD 1.5 nF FB FB FB FB FB FD FD FD FD GD GD 2.2 nF FB FB FB FB FB FD FD FD GA GA GA GA GA GD GE 3.3 nF FB FB FB FB FB FD FD FD GA GA GA GA GA GD GD GD 4.7 nF FB FB FB FB FB FD FD FD GA GA GA GA GA GD GD GD 6.8 nF FB FB FB FB FB FD FD FD GA GA GA GA GA GD GD GD 10 nF FB FB FB FB FB FD FD FD GA GA GA GA GA GD GD GD 15 nF FB FB FB FB FB FD FD GA GA GA GA GA GD GD GD 22 nF FB FB FB FB FD FE FE GA GA GA GA GD GD GE GE 33 nF FB FB FB FB FD FE FE GA GA GA GA GD GD 47 nF FB FB FB FB FD GA GA GA GA GD GD 68 nF FB FB FB FD FD GA GA GA GA GD 100 nF FB FB FB FD FE GA GA GA GA GD 150 nF FB FB FC FD GA GA GB GD GD 220 nF FB FB FC FD GA GA GB GD GD 330 nF FE FE FE FE GA GA GB GD 470 nF FE FE FE FE GB GB GD GD 680 nF FC FC FF FF GB GB GD GF 1000 nF FC FC FF FF GD GD GD GF 2.2 µF FC FC FF FF GG GG GG GH 4.7 µF FF FF GG GG GG 10 µF FF FF GG GG GG 100 pF 150 pF Tape width 8 mm NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For product with 5% tolerance, please contact local sales force before ordering www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors NPO & X7R Soft Termination 11 19 16V to 3KV CAPACITANCE RANGE & THICKNESS Table 9 X7R / 1808 to 1812 CAP. 1808 1812 1000V 2000V 3000V 50V 100V 250V 500V 630V 1000V 2000V 330 pF HB HB HD 470 pF HB HB HD 680 pF HB HB HD 1.0 nF HB HB HE 1.5 nF HB HB HE 2.2 nF HB HD IA IA IA ID IE IE IE 3.3 nF HB IA IA IA ID IE IE IE 4.7 nF HB IA IA IA ID IE IE IE 6.8 nF HD IA IA IA ID IE IE 10 nF HD IA IA IA ID IE IE 15 nF IA IA IA ID IE IE 22 nF IA IA IA ID IE IE 33 nF IA IA IA ID IF IF 47 nF IA IA ID ID 68 nF IA IA ID ID 100 nF IB ID ID IF 150 nF IB ID ID 220 nF IB ID IF 330 nF IB ID IF 470 nF IB IF IF 680 nF IF IF 1000 nF IF IF 100 pF 150 pF 220 pF 2.2 µF Tape width 12 mm NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For product with 5% tolerance, please contact local sales force before ordering www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 12 19 16V to 3KV THICKNESS CLASSES AND PACKING QUANTITY Table 10 SIZE CODE THICKNESS CLASSIFICATION TAPE WIDTH QUANTITY PER REEL 0402 0.50 ± 0.15 0603 0.80 ± 0.15 0805 1206 1210 1808 1812 Ø 180 MM / 13 INCH Ø 180 MM / 7 INCH PAPER BLISTER PAPER BLISTER 8mm 10,000 -- 50,000 -- 8mm 4,000 -- 15,000 -- 0.60 ± 0.15 8mm 4,000 -- 20,000 -- 0.85 ± 0.15 8mm 4,000 -- 15,000 -- 1.25 ± 0.20 8mm -- 3,000 -- 10,000 0.60 ± 0.15 8mm 4,000 -- 20,000 -- 0.85 ± 0.15 8mm 4,000 -- 15,000 -- 1.15 ± 0.20 8mm -- 3,000 -- 10,000 1.25 ± 0.20 8mm -- 3,000 -- 10,000 1.60 ± 0.20 8mm -- 2,000 -- 8,000 1.60 ± 0.30 8mm -- 2,000 -- 8,000 0.85 ± 0.20 8mm -- 4,000 -- 10,000 1.15 ± 0.30 8mm -- 3,000 -- 10,000 1.25 ± 0.20 8mm -- 3,000 -- 10,000 1.25 ± 0.30 8mm -- 3,000 -- 10,000 1.60 ± 0.30 8mm -- 2,000 -- 5,000 2.00 ± 0.30 8mm -- 2,000 -- -- 2.50 ± 0.20 8mm -- 1,000 -- -- 1.25 ± 0.20 12mm -- 2,000 -- -- 1.35 ± 0.40 12mm -- 2,000 -- -- 1.60 ± 0.20 12mm -- 2,000 -- -- 1.60 ± 0.40 12mm -- 2,000 -- -- 2.00 ± 0.40 12mm -- 2,000 -- -- 0.85 ± 0.30 12mm -- 2,000 -- -- 1.15 ± 0.40 12mm -- 1,000 -- -- 1.25 ± 0.20 12mm -- 1,000 -- -- 1.25 ± 0.40 12mm -- 1,000 -- -- 1.35 ± 0.40 12mm -- 1,000 -- -- 1.60 ± 0.40 12mm -- 1,000 -- -- ELECTRICAL CHARACTERISTICS X7R DIELECTRIC CAPACITORS; NISN TERMINATIONS Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions for testing as given in 5.3 of IEC 60068-1: - Temperature: 15 °C to 35 °C Relative humidity: 25% to 75% Air pressure: 86 kPa to 106 kPa Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time sufficient to allow the entire capacitor to reach this temperature. The period as prescribed for recovery at the end of a test is normally sufficient for this purpose. www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 13 19 16V to 3KV Table 11 DESCRIPTION VALUE Capacitance range 100 pF to 2.2µF Dissipation factor (D.F.) NPO X7R 16V 25V 50V C < 30 pF ≤ 1 / (400 + 20C ) C ≥ 30 pF ≤ 0.1 % 0402 0603 0805 1206 1210 1808 1812 100pF to 22nF 100pF to 220nF 150pF to 470nF 220pF to 1µF 2.2nF to 1µF 27nF to 100nF 470nF 680 nF to 2.2µF 2.2µF 4.7µF 4.7µF to 10µF 2.2µF to 10µF ≤ 10% 2.2nF to 1µF ≤ 2.5% ≤ 5% 100pF to 10nF 100pF to 39nF 150pF to 180nF 220pF to 680nF 12 nF to 47nF 47nF to 220nF 220nF to 470nF 1µF 680nF to 1µF 2.2µF 330nF to 1µF 2.2µF 4.7µF to 10µF 2.2µF to 10µF 100pF to 10nF 100pF to 39nF 150pF to 180nF 220pF to 470nF 2.2nF to 1µF 12 nF to 47nF 47nF to 220nF 220nF to 470nF 680nF to 1µF 680nF 2.2µF 56nF to 100nF ≤ 3.5% ≤ 5% 100pF to 10nF All 100V 12nF to 100nF 250V to 3KV All All ≤ 10% 2.2nF to 1µF ≤ 2.5% ≤ 3.5% ≤ 5% 1µF All ≤ 3.5% 2.2µF to 10µF ≤ 10% 220pF to 680nF 2.2nF to 680nF 1µF 1µF 2.2µF 2.2µF All All All ≤ 2.5% ≤ 3.5% ≤ 5% All All ≤ 2.5% I.R. ≥ 10 GΩ or R × C ≥ 500 seconds whichever is less R × C ≥ 100 seconds : X7R/0603/1uF/16V to 25V Insulation resistance after 1 minute at Ur (DC) X7R/0805/2.2µF/25V X7R/0805/4.7µF/16V X7R/1206/4.7µF to 10µF/16V to 25V X7R/1210/2.2µF to 10µF/16V to 50V, X7R/1210/2.2µF/100V Maximum capacitance change as a function of temperature NPO: ± 30ppm (temperature characteristic/coefficient): X7R: ± 15% Operating temperature range: –55 °C to +125 °C Table 12 SOLDERING RECOMMENDATION SOLDERING METHOD Reflow Reflow/Wave SIZE 0402 Reflow only 0603 0805 1206 ≥ 1210 > 1.0 µF > 2.2 µF > 2.2 µF Reflow only ≤ 1.0 µF ≤ 2.2 µF ≤ 2.2 µF --- www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 16V to 3KV 14 19 TESTS AND REQUIREMENTS Table 13 Test procedures and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Mounting IEC 6038421/22 4.3 The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage Visual Inspection and Dimension Check 4.4 Any applicable method using × 10 magnification In accordance with specification Capacitance 4.5.1 Class 1: Within specified tolerance f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Class II: At 20 °C, 24 hrs after annealing f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C f = 120Hz for C >10 µF, measuring at voltage 0.5 Vrms at 20 °C Dissipation Factor (D.F.) 4.5.2 Class 1: f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C In accordance with specification f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Class II: At 20 °C, 24 hrs after annealing f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C f = 120Hz for C > 10 µF, measuring at voltage 0.5 Vrms at 20 °C Insulation Resistance 4.5.3 Ur ≤ 500 V: At Ur for 1 minute Ur > 500 V: At 500 V for 1 minute In accordance with specification www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 16V to 3KV TEST TEST METHOD PROCEDURE REQUIREMENTS Temperature Characteristic IEC 6038421/22 Capacitance shall be measured by the steps shown in the following table. Class I: C/C: ± 30ppm The capacitance change should be measured after 5 min at each specified temperature stage. Class II: X7R: C/C: ±15% 4.6 Step Temperature(˚C) a 25± 2 b Lower temperature± 3˚C c 25± 2 d Upper Temperature± 2˚C e 25± 2 15 19 (1) Class I Temperature Coefficient shall be calculated from the formula as below Temp, Coefficient = C2-C1 C1 x106 [ppm/˚C] C1: Capacitance at step c C2: Capacitance at 125˚C T: 100˚C (=125˚C-25˚C) (2) Class II Capacitance Change shall be calculated from the formula as below C= C2-C1 C1 x 100% C1: Capacitance at step c C2: Capacitance at step b or d www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Adhesion Bending Strength TEST METHOD Soft Termination NPO & X7R 16V to 3KV PROCEDURE REQUIREMENTS 4.7 A force applied for 10 seconds to the line joining the terminations and in a plane parallel to the substrate Force size ≥ 0603: 5N size = 0402: 2.5N size = 0201: 1N 4.8 Mounting in accordance with IEC 60384-22 paragraph 4.3 No visible damage Conditions: bending at a rate of 1 mm/s, radius jig 5 mm C/C Class I: NPO: 5 mm X7R/0402 to 0603: 5 mm X7R/0805 to 1812: 3 mm 16 19 NP0: within ± 1% or 0.5 pF, whichever is greater Class II: X7R: ± 10% Resistance to Soldering Heat 4.9 Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute Preheating: for size >1206: 100 °C to 120 °C for 1 minute and 170 °C to 200 °C for 1 minute Solder bath temperature: 260 ± 5 °C Dipping time: 10 ± 0.5 seconds Recovery time: 24 ± 2 hours Dissolution of the end face plating shall not exceed 25% of the length of the edge concerned ΔC/C Class 1: NP0: within ± 0.5% or 0.5 pF, whichever is greater Class II: X7R: ± 10% D.F. within initial specified value I.R. within initial specified value Solderability IEC 60384- 4.10 21/22 Preheated the temperature of 80 °C to 140 °C and maintained for 30 seconds to 60 seconds. The solder should cover over 95% of the critical area of each termination Test conditions for lead containing solder alloy Temperature: 235 ± 5 °C Dipping time: 2 ± 0.2 seconds Depth of immersion: 10 mm Alloy Composition: 60/40 Sn/Pb Number of immersions: 1 Test conditions for leadfree containing solder alloy Temperature: 245 ± 5 °C Dipping time: 3 ± 0.3 seconds Depth of immersion: 10 mm Alloy Composition: SAC305 Number of immersions: 1 www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST TEST METHOD Rapid Change of 4.11 Temperature NPO & X7R Soft Termination PROCEDURE REQUIREMENTS Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature No visual damage 5 cycles with following detail: 30 minutes at lower category temperature 30 minutes at upper category temperature Recovery time 24 ± 2 hours 16V to 3KV 17 19 ΔC/C Class 1: NP0: within ± 1% or 1 pF, whichever is greater Class II: X7R: ± 15% D.F. meet initial specified value I.R. meet initial specified value Damp Heat with Ur Load IEC 6038421/22 4.13 1. Preconditioning, class II only: 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp No visual damage after recovery 2. Initial measure: Spec: refer initial spec C, D, I.R. Class 1: 3. Damp heat test: 500 ± 12 hours at 40 ± 2 °C; 90 to 95% R.H. 1.0 Ur applied Class II: 4. Recovery: Class 2: 24 ± 2 hours D.F. 5. Final measure: C, D, I.R. NP0: ≤ 2 x specified value P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to “IEC 60384 4.1” and then the requirement shall be met. ΔC/C NP0: within ± 2% or 1 pF, whichever is greater X7R: ± 15% Class 1: Class II: X7R: ≤ 2 x specified value I.R. Class 1: NP0: ≥ 2,500 MΩ or R x C ≥ 25Ω.F whichever is less Class II: X7R: ≥ 500 MΩ or R x C ≥ 25Ω.F whichever is less X7R/0603/1uF/16V to 25V ΔC/C X7R/0805/4.7µF/16V ± 20% X7R/1206/10µF/16V to 25V D.F. X7R/1210/2.2µF to 10µF/16V to 50V X7R/1210/2.2µF/100V ≤2 specified value I.R. R C ≥ 5 Ω.F www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Endurance TEST METHOD IEC 6038421/22 4.14 Soft Termination PROCEDURE NPO & X7R 16V to 3KV 18 19 REQUIREMENTS 1. Preconditioning, class II only: 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec: refer initial spec C, D, I.R. 3. Endurance test: Temperature: NP0/X7R: 125 °C Specified stress voltage applied for 1,000 hours: 4. High voltage series follows with below stress condition: No visual damage ΔC/C Class1: NP0: within ± 2% or 1 pF, whichever is greater Class II: X7R: ± 15% Voltage NPO X7R ≤ 100V 2.0 x Ur 2.0 x Ur 200/250V 1.5 x Ur 1.5 x Ur D.F. Class1: 500/630V 1.3 x Ur 1.2 x Ur NP0: ≤ 2 x specified value ≥ 1KV 1.2 x Ur 1.1 x Ur Class II: 5. Recovery time: 24 ± 2 hours X7R: ≤ 2 x specified value 6. Final measure: C, D, I.R. P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to “IEC 60384 4.1” and then the requirement shall be met. I.R. Class1: NP0: ≥ 4,000 MΩ or R x C ≥ 40Ω.F whichever is less Class II: X7R: ≥ 1,000 MΩ or R x C ≥ 50Ω.F whichever is less * Apply 1.5 x Ur for below items X7R/0603/1uF/16V to 25V X7R/0805/4.7µF/16V X7R/1206/10µF/16V to 25V X7R/1210/2.2µF to 10µF/16V to 50V X7R/1210/2.2µF/100V Voltage Proof IEC 60384-1 4.6 Specified stress voltage applied for 1~5 seconds Ur ≤ 100 V: series applied 2.5 Ur 100 V < Ur ≤ 200 V series applied (1.5 Ur + 100) 200 V < Ur ≤ 500 V series applied (1.3 Ur + 100) Ur > 500 V: 1.3 Ur Ur ≧ 1000 V: 1.2 Ur Charge/Discharge current is less than 50 mA ΔC/C ± 20% D.F. ≤ 2 specified value I.R. R x C ≥ 10 Ω.F No breakdown or flashover www.yageo.com Mar. 25, 2021 V.8 Product specification Surface-Mount Ceramic Multilayer Capacitors Soft Termination NPO & X7R 16V to 3KV 19 19 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 8 Mar. 25, 2021 - - Modify X7R, 1206, 330nF to 470nF, 100V thickness to 1.6+/-0.2mm Version 7 Oct. 05, 2020 - - Add X7R, 0603, 1uF, 25V and modify X7R, 1210, 2.2uF, 100V thickness to 2.5mm Version 6 Feb. 18, 2020 Version 5 May 23, 2019 - - Product range changed Version 4 Jun.19, 2017 - - Product range updated Version 3 Jan. 26, 2017 - - Global part number coding rule update Version 2 Dec. 30, 2016 - - Dimension updated Version 1 Dec. 16, 2016 - - Product range updated Version 0 May 20, 2016 - - New datasheet for soft termination NPO & X7R series with RoHS compliant - Modify X7R, 1206, 22nF, 500V thickness to 1.6mm www.yageo.com Mar. 25, 2021 V.8
CS0805KFX7R9BB474 价格&库存
很抱歉,暂时无法提供与“CS0805KFX7R9BB474”相匹配的价格&库存,您可以联系我们找货
CS0805KFX7R9BB474
  • 10000+0.3922010000+0.05035
