DATA SHEET
SURFACE-MOUNT CERAMIC
MULTILAYER CAPACITORS
General Purpose & High Capacitance
Class 2, X7R
6.3 V TO 50 V
100 pF to 22 µF
Product Specification – October 13, 2011 V.8
RoHS compliant & Halogen Free
Product specification
Surface-Mount Ceramic Multilayer Capacitors
General Purpose & High Cap.
X7R
6.3 V to 50 V
2
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP
This specification describes X7R
series chip capacitors with leadfree terminations.
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
APPLICATIONS
PCs, Hard disk, Game PCs
DVDs, Video cameras
Mobile phones
Data processing
CTC & 12NC
YAGEO BRAND ordering code
GLOBAL PART NUMBER
CC
XXXX X X
(1)
X7R
(2) (3)
X
( PREFERRED )
BB
XXX
(4)
(5)
(1) SIZE – INCH BASED (METRIC)
0201 (0603)
FEATURES
Supplied in tape on reel
Nickel-barrier end termination
RoHS compliant
Halogen Free compliant
0402 (1005)
0603 (1608)
0805 (2012)
1206 (3216)
1210 (3225)
1812 (4532)
(2) TOLERANCE
J = ±5% (1)
K = ±10%
M = ±20%
(3) PACKING STYLE
R = Paper/PE taping reel; Reel 7 inch
K = Blister taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
F = Blister taping reel; Reel 13 inch
C = Bulk case
(4) RATED VOLTAGE
5 = 6.3 V
6 = 10 V
7 = 16 V
8 = 25 V
9 = 50 V
(5) CAPACITANCE VALUE
2 significant digits+number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 103 = 10 x 103 = 10,000 pF = 10 nF
NOTE
1. Tolerance ±5% is not available for full product range, please contact local sales force
before ordering
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
3
PHYCOMP BRAND ordering codes
GLOBAL PART NUMBER (preferred), PHYCOMP CTC (for North America) and 12NC (traditional) codes are
acceptable to order Phycomp brand products.
GLOBAL PART NUMBER
( PREFERRED )
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC
CODE
2 2 XX
XX
X
X
X
X
XX
Carrier type
38 = Paper/PE (≥ 10 V)
22 = Blister (≥ 10 V)
50 = Blister (6.3 V)
55 = Paper/PE (6.3 V)
54 = Bulk
Capacitance value(1)
Rated voltage - Termination
20 = 6.3 V
24 = 10 V
78 = 16 V
91 = 25 V
58 = 50 V
Temperature characteristic
5 = X7R
Tolerance
5 = ±5%(2)
6 = ±10%
7 = ±20%
Packaging(3)
1 = reel: ∅180 mm; 7"
5 = reel: ∅330 mm; 13"
4 = bulk case
YNM0029
Size
8 = 0201
7 = 0402
6 = 0603
0 = 0805
1 = 1206
2 = 1210
4 = 1812
(1) Please refer to "Last 2-digit of 12NC" in "CAPACITANCE RANGE & THICKNESS FOR X7R"
(2) Tolerance ±5% is not available for full product range, please contact local sales force before ordering
(3) Quantity on reel depends on thickness classification; see table 5
PHYCOMP CTC
CODE ( FOR NORTH AMERICA )
Example: 02012R102K8B20D
0201
2R
102
K
8
B
2
D
Size
code
Temp.
Char.
Capacitance
in pF
Tolerance
Voltage
Termination
Packing
Marking
Range identifier
0201
2R = X7R
0402
0603
0805
1206
1210
1812
101 = 100 pF;
J = ±5% (1)
the third digit
K = ±10%
signifies the
M = ±20%
multiplying factor:
0=×1
1 = × 10
2 = × 100
3 = × 1,000
5 = 6.3 V
6 = 10 V
7 = 16 V
8 = 25 V
9 = 50 V
B = NiSn
2 = 180 mm
7” Paper/PE
0 = no marking
D = Class 2 MLCC
3 = 330 mm
13” Paper/PE
B = 180 mm
7” Blister
F = 330 mm
13” Blister
P = Bulk case
NOTE
1. Tolerance ±5% is not available for full product range, please contact local sales force before ordering
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
4
CONSTRUCTION
The capacitor consists of a
rectangular block of ceramic
dielectric in which a number of
interleaved metal electrodes are
contained. This structure gives
rise to a high capacitance per
unit volume.
The inner electrodes are
connected to the two end
terminations and finally covered
with a layer of plated tin (NiSn).
The terminations are lead-free. A
cross section of the structure is
shown in Fig.1.
terminations
electrodes
MLB457
ceramic material
Fig. 1 Surface mounted multilayer ceramic capacitor construction
DIMENSION
Table 1 For outlines see fig. 2
TYPE
0201
0402
0603
0805
1206
1210
1812
L1 (mm)
W (mm)
0.6 ±0.03
T (MM)
L2 / L3 (mm)
L4 (mm)
min.
max.
min.
0.3 ±0.03
0.10
0.20
0.20
1.0 ±0.05
0.5 ±0.05
0.15
0.30
0.40
1.6 ±0.10 (1)
0.8 ±0.10 (1)
1.6 ±0.15 (2)
0.8 ±0.15 (2)
0.20
0.60
0.40
2.0 ±0.10 (1)
1.25 ±0.10 (1)
2.0 ±0.20 (2)
1.25 ±0.20 (2)
0.25
0.75
0.55
3.2 ±0.15 (1)
1.6 ±0.15 (1)
(2)
1.6 ±0.20 (2)
0.25
0.75
1.40
3.2 ±0.20 (1)
2.5 ±0.20 (1)
3.2 ±0.40 (2)
2.5 ±0.30 (2)
0.25
0.75
1.40
4.5 ±0.20 (1)
3.2 ±0.20 (1)
4.5 ±0.40 (2)
3.2 ±0.40 (2)
0.25
0.75
2.20
3.2 ±0.30
Refer to
table 2 to 4
OUTLINES
For dimension see Table 1
W
T
L2
L4
L1
L3
MBB211
Fig. 2 Surface mounted multilayer
ceramic capacitor dimension
NOTE
1. Dimension for size 0603, C < 10 µF; 0805 to 1812, C ≤ 100nF
2. Dimension for size 0603, C ≥ 10 µF; 0805 to 1812, C > 100 nF
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
5
Table 2 Sizes from 0201 to 0402
CAP.
Last 2-digit of
0201
12NC
6.3 V
100 pF
09
150 pF
12
220 pF
14
330 pF
16
470 pF
18
680 pF
21
1.0 nF
23
1.5 nF
25
2.2 nF
27
3.3 nF
29
4.7 nF
32
6.8 nF
34
10 nF
36
15 nF
38
22 nF
41
33 nF
43
47 nF
45
68 nF
47
100 nF
49
150 nF
52
220 nF
54
330 nF
56
470 nF
58
680 nF
61
1.0 µF
63
2.2 µF
67
4.7 µF
72
10 µF
76
22 µF
81
0402
10 V
16 V
25 V
50 V
6.3 V
10 V
16 V
25 V
50 V
0.3±0.03
0.3±0.03
0.3±0.03 0.3±0.03 0.3±0.03
0.5±0.05
0.5±0.05 0.5±0.05 0.5±0.05 0.5±0.05
0.5±0.05
NOTE
1. Values in shaded cells indicate thickness class in mm
2. Capacitance value of non E-6 series is on request
3. For product with 5% tolerance, please contact local sales force before ordering
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
6
Table 3 Sizes from 0603 to 0805
CAP.
Last 2-digit of
0603
12NC
6.3 V
100 pF
09
150 pF
12
220 pF
14
330 pF
16
470 pF
18
680 pF
21
1.0 nF
23
1.5 nF
25
2.2 nF
27
3.3 nF
29
4.7 nF
32
6.8 nF
34
10 nF
36
15 nF
38
22 nF
41
33 nF
43
47 nF
45
68 nF
47
100 nF
49
150 nF
52
220 nF
54
330 nF
56
470 nF
58
680 nF
61
1.0 µF
63
2.2 µF
67
4.7 µF
72
10 µF
76
22 µF
81
0805
10 V
16 V
25 V
50 V
6.3 V
10 V
16 V
25 V
50 V
0.6±0.1
0.6±0.1
0.8±0.1
0.8±0.1
0.8±0.1
0.8±0.1
0.8±0.1
0.85±0.1 0.85±0.1 0.85±0.1 0.85±0.1
0.85±0.1
1.25±0.2
1.25±0.2 1.25±0.2
1.25±0.2 1.25±0.2
NOTE
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
7
Table 4 Size 1206
CAP.
Last 2-digit of
1206
12NC
6.3 V
100 pF
09
150 pF
12
220 pF
14
330 pF
16
470 pF
18
680 pF
21
1.0 nF
23
1.5 nF
25
2.2 nF
27
3.3 nF
29
4.7 nF
32
6.8 nF
34
10 nF
36
15 nF
38
22 nF
41
33 nF
43
47 nF
45
68 nF
47
100 nF
49
150 nF
52
220 nF
54
330 nF
56
470 nF
58
680 nF
61
1.0 µF
63
2.2 µF
67
4.7 µF
72
10 µF
76
22 µF
81
47 µF
85
10 V
16 V
25 V
50 V
0.85±0.1
0.85±0.1
1.15±0.1
0.85±0.1
1.0±0.1
1.15±0.1
1.6±0.2
1.15±0.1
1.6±0.2
1.15±0.1
1.15±0.1
1.6±0.2
1.6±0.2
1.6±0.2
NOTE
4. Please contact local sales force for special ordering code before ordering
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
8
Table 5 Sizes from 1210 to 1812
CAP.
Last 2-digit of
1210
12NC
6.3 V
100 pF
09
150 pF
12
220 pF
14
330 pF
16
470 pF
18
680 pF
21
1.0 nF
23
1.5 nF
25
2.2 nF
27
3.3 nF
29
4.7 nF
32
6.8 nF
34
10 nF
36
15 nF
38
22 nF
41
33 nF
43
47 nF
45
68 nF
47
100 nF
49
150 nF
52
220 nF
54
330 nF
56
470 nF
58
680 nF
61
1.0 µF
63
2.2 µF
67
4.7 µF
72
10 µF
76
22 µF
81
47 µF
85
1812
10 V
16 V
25 V
50 V
0.85±0.1
0.85±0.1
1.15±0.1
1.15±0.1
1.25±0.2
1.25±0.2
1.9±0.2
2.5±0.2
1.9±0.2
1.9±0.2
1.9±0.2
50 V
0.85±0.1
1.15±0.1
1.6±0.2
1.9±0.2
2.5±0.2
NOTE
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
9
THICKNESS CLASSES AND PACKING QUANTITY
Table 6
SIZE
CODE
THICKNESS
CLASSIFICATION
TAPE WIDTH
QUANTITY PER REEL
0201
0.3 ±0.03 mm
0402
0603
0805
1206
Ø180 MM / 7 INCH
Ø330 MM / 13 INCH
Paper
Blister
Paper
Blister
QUANTITY
PER BULK CASE
8 mm
15,000
50,000
0.5 ±0.05 mm
8 mm
10,000
50,000
50,000
0.8 ±0.1 mm
8 mm
4,000
15,000
15,000
0.6 ±0.1 mm
8 mm
4,000
20,000
10,000
0.85 ±0.1 mm
8 mm
4,000
15,000
8,000
1.25 ±0.2 mm
8 mm
3,000
10,000
5,000
0.6 ±0.1 mm
8 mm
4,000
20,000
0.85 ±0.1 mm
8 mm
4,000
15,000
1.00 / 1.15 ±0.1 mm
8 mm
3,000
10,000
1.25 ±0.2 mm
8 mm
3,000
10,000
1.6 ±0.15 mm
8 mm
2,500
10,000
1.6 ±0.2 mm
8 mm
2,000
10,000
1210
0.6 / 0.7 ±0.1 mm
8 mm
4,000
15,000
0.85 ±0.1 mm
8 mm
4,000
10,000
1.15 ±0.1 mm
8 mm
3,000
10,000
1.15 ±0.15 mm
8 mm
3,000
10,000
1.25 ±0.2 mm
8 mm
3,000
1.5 ±0.1 mm
8 mm
2,000
1.6 / 1.9 ±0.2 mm
8 mm
2,000
2.0 ±0.2 mm
8 mm
2,000
1,000
2.5 ±0.2 mm
8 mm
1,000
500
1.15 ±0.15 mm
12 mm
3,000
1.25 ±0.2 mm
12 mm
3,000
1.35 ±0.15 mm
12 mm
2,000
1.5 ±0.1 mm
12 mm
2,000
1.6 ±0.2 mm
12 mm
2,000
8,000
2.0 ±0.2 mm
12 mm
2,000
0.6 / 0.85 ±0.1 mm
12 mm
2,000
1.15 ±0.1 mm
12 mm
1,000
1.25 ±0.2 mm
12 mm
1,000
1.5 ±0.1 mm
12 mm
1,000
1.6 ±0.2 mm
12 mm
1,000
2.0 ±0.2 mm
12 mm
1,000
2.5 ±0.2 mm
12 mm
500
1808
1812
www.yageo.com
Oct 13, 2011 V.8
X7R
10
6.3 V to 50 V
ELECTRICAL CHARACTERISTICS
X7R DIELECTRIC CAPACITORS; NISN TERMINATIONS
Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions
for testing as given in 5.3 of IEC 60068-1:
Temperature: 15 °C to 35 °C
- Relative humidity: 25% to 75%
- Air pressure: 86 kPa to 106 kPa
Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time
sufficient to allow the entire capacitor to reach this temperature.
The period as prescribed for recovery at the end of a test is normally sufficient for this purpose.
Table 7
VALUE
DESCRIPTION
Capacitance range
100 pF to 22 µF
Capacitance tolerance
±5%, ±10%, ±20%
Dissipation factor (D.F.)
≤ 10 V
≤ 5%
Exception: 0201 ≥ 12 nF;
0603 ≥ 2.2 µF;
0805 ≥ 4.7 µF;
≤ 10%
1210 ≥ 4.7 µF
0805 ≥ 10 µF;
1206 ≥ 10 µF
≤ 15%
16 V
≤ 3.5%
Exception: 0201 ≥ 1.5 nF;
0402 ≥ 27 nF;
0603 ≥ 220 nF;
0805 ≥ 680 nF;
1206 ≥ 2.2 µF;
1210 ≥ 10 µF
1206 ≥ 10 µF;
1210 ≥ 22 µF
≤ 5%
≤ 10%
25 V
≤ 2.5%
Exception: 0402 ≥ 10 nF;
0603 ≥ 47 nF;
0805 ≥ 220 nF;
1206 ≥ 1 µF;
1210 ≥ 4.7 µF
0201 ≥ 560 pF;
0402 ≥ 56 nF;
0603 ≥ 1 µF;
0805 ≥ 680 nF;
1206 ≥ 2.2 µF;
1210 ≥ 10 µF
1206 ≥ 4.7 µF
≤ 3.5%
≤ 5%
≤ 10%
≥ 50 V
≤ 2.5%
Exception: 0201 ≥ 47 pF;
1206 ≥ 1 µF
0603 ≥ 47 nF
Insulation resistance after 1 minute at Ur (DC)
≤ 3.5%
≤ 3.0%
Rins ≥ 10 GΩ or Rins × Cr ≥ 500 seconds whichever is less
Maximum capacitance change as a function of temperature
(temperature characteristic/coefficient):
Operating temperature range:
±15%
–55 °C to +125 °C
NOTE
Capacitance tolerance ±5% is not available for full product range, please contact local sales force before ordering
www.yageo.com
Oct 13, 2011 V.8
ΔC
C
X7R
6.3 V to 50 V
11
YNM0013
15
10
5
−5
−10
−15
−55
Fig. 3
−25
5
40
65
95
125
T (oC)
Typical capacitance change as a function of
temperature
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
12
Size 0201 10 nF / 16 V
Solid lines: Impedance / Dotted lines: ESR
YNM0043
100.00
Z
(Ω)
10.00
1.00
0.10
0.01
0.00
0.01
0.10
1.00
10.00
f (MHz)
100.00
Fig. 4 Impedance ESR vs. frequency characteristics for multilayer chip capacitors
Size 0402 100 nF / 16 V
YNM0044
100.00
Z
(Ω)
10.00
1.00
0.10
0.01
0.00
0.01
0.10
1.00
10.00
f (MHz)
100.00
Fig. 5 Impedance ESR vs. frequency characteristics for multilayer chip capacitors
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
13
Size 0603 1 µF / 16 V
YNM0045
100.00
Z
(Ω)
10.00
1.00
0.10
0.01
0.00
0.01
0.10
1.00
10.00
f (MHz)
100.00
Fig. 6 Impedance ESR vs. frequency characteristics for multilayer chip capacitors
Size 0805 1 µF / 16 V
YNM0046
100.00
Z
(Ω)
10.00
1.00
0.10
0.01
0.00
0.01
0.10
1.00
10.00
f (MHz)
100.00
Fig. 7 Impedance ESR vs. frequency characteristics for multilayer chip capacitors
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
14
Size 1206 1 µF / 25 V
YNM0048
100.00
Z
(Ω)
10.00
1.00
0.10
0.01
0.00
0.01
Fig. 8
0.10
1.00
10.00
f (MHz)
100.00
Size 1206 10 µF / 10 V
YNM0044
100.00
Z
(Ω)
10.00
1.00
0.10
0.01
0.00
0.01
Fig. 9
0.10
1.00
10.00
f (MHz)
100.00
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
15
SOLDERING RECOMMENDATION
Table 8
SOLDERING
METHOD
SIZE
0402
0603
0805
1206
≥ 1210
Reflow
≥ 0.1 µF
≥ 1.0 µF
≥ 2.2 µF
≥ 4.7 µF
Reflow only
Reflow/Wave
< 0.1 µF
< 1.0 µF
< 2.2 µF
< 4.7 µF
TESTS AND REQUIREMENTS
Table 9 Test procedures and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Mounting
IEC 6038421/22
4.3
The capacitors may be mounted on printed-circuit boards or
ceramic substrates
No visible damage
Visual Inspection
and Dimension
Check
4.4
Any applicable method using × 10 magnification
In accordance with
specification
Capacitance (1)
4.5.1
Class 2:
At 20 °C, 24 hrs after annealing
Within specified tolerance
f = 1 KHz for C ≤ 10 µF, rated voltage > 6.3 V, measuring at
voltage 1 Vrms at 20 °C
f = 1 KHz, for C ≤ 10 µF, rated voltage ≤ 6.3 V, measuring at
voltage 0.5 Vrms at 20 °C
f = 120 Hz for C > 10 µF, measuring at voltage 0.5 Vrms at 20 °C
Dissipation
Factor (D.F.) (1)
4.5.2
Class 2:
In accordance with
specification
Insulation
Resistance
4.5.3
At Ur (DC) for 1 minute
In accordance with
specification
NOTE:
1. For individual product specification, please contact local sales.
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Temperature
Characteristic
IEC 6038421/22
Class 2:
Between minimum and maximum temperature
X7R: -55 °C to +125 °C
Normal Temperature: 20 °C
4.6
16
∆C/C
Class 2:
X7R: ±15%
∆C/C
Class 2:
X7R: ±15%
Adhesion
4.7
A force applied for 10 seconds to the line joining the
terminations and in a plane parallel to the substrate
Force
size ≥ 0603: 5N
size = 0402: 2.5N
size = 0201: 1N
Bond Strength
of Plating on
End Face
4.8
Mounting in accordance with IEC 60384-22 paragraph
4.3
No visible damage
Conditions: bending 1 mm at a rate of 1 mm/s, radius jig
340 mm
∆C/C
Class2:
X7R: ±10%
∆C/C
Class2:
X7R: ±10%
Resistance to
Soldering Heat
4.9
Precondition: 150 +0/–10 °C for 1 hour, then keep for
24 ±1 hours at room temperature
Preheating: for size ≤ 1206: 120 °C to 150 °C for 1
minute
Preheating: for size >1206: 100 °C to 120 °C for 1
minute and 170 °C to 200 °C for 1 minute
Dissolution of the end face plating shall
not exceed 25% of the length of the
edge concerned
Dipping time: 10 ±0.5 seconds
∆C/C
Class2:
X7R: ±10%
Recovery time: 24 ±2 hours
Solder bath temperature: 260 ±5 °C
∆C/C
Class2:
X7R: ±10%
D.F. within initial specified value
Rins within initial specified value
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
17
TEST
TEST METHOD PROCEDURE
REQUIREMENTS
Solderability
IEC 60384- 4.10
21/22
The solder should cover over 95% of the
critical area of each termination
Preheated to a temperature of 80 °C to 140 °C and
maintained for 30 seconds to 60 seconds.
Test conditions for lead containing solder alloy
Temperature: 235 ±5 °C
Dipping time: 2 ±0.2 seconds
Depth of immersion: 10 mm
Alloy Composition: 60/40 Sn/Pb
Number of immersions: 1
Test conditions for lead-free containing solder alloy
Temperature: 245 ±5 °C
Dipping time: 3 ±0.3 seconds
Alloy Composition: SAC305
Rapid Change of
Temperature
4.11
Preconditioning;
5 cycles with following detail:
30 minutes at lower category temperature
30 minutes at upper category temperature
Recovery time 24 ±2 hours
No visual damage
∆C/C
Class2:
X7R: ±15%
∆C/C
Class2:
X7R: ±15%
D.F. meet initial specified value
Rins meet initial specified value
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Damp Heat
with Ur Load
IEC 6038421/22
1. Preconditioning, class 2 only:
150 +0/-10 °C /1 hour, then keep for
24 ±1 hour at room temp
No visual damage after recovery
2. Initial measure:
Spec: refer to initial spec C, D, IR
∆C/C
4.13
3. Damp heat test:
500 ±12 hours at 40 ±2 °C;
90 to 95% R.H. 1.0 Ur applied
4. Recovery:
Class 2: 24 ±2 hours
5. Final measure: C, D, IR
P.S. If the capacitance value is less than the
minimum value permitted, then after the other
measurements have been made the capacitor
shall be preconditioned according to “IEC 60384
4.1” and then the requirement shall be met.
18
Class2:
X7R: ±15%
D.F.
Class2:
X7R: ≤ 16V: ≤ 7%
≥ 25V: ≤ 5%
Rins
Class2:
X7R: ≥ 500 MΩ or Rins x Cr ≥ 25s
whichever is less
∆C/C
Class2:
X7R: ±20%
D.F.
Class2:
X7R: 2 x initial value max
Rins
Class2:
X7R: 500 MΩ or Rins x Cr ≥ 25s
whichever is less
www.yageo.com
Oct 13, 2011 V.8
X7R
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Endurance
IEC 6038421/22
No visual damage
2. Initial measure:
∆C/C
4.14
3. Endurance test:
Temperature: X7R: 125 °C
Specified stress voltage applied for 1,000 hours:
Applied 2.0 x Ur for general products
Applied 1.5 x Ur for high cap. products
4. Recovery time: 24 ±2 hours
P.S. If the capacitance value is less than the minimum
value permitted, then after the other measurements
have been made the capacitor shall be preconditioned
according to “IEC 60384 4.1” and then the
6.3 V to 50 V
19
Class2:
X7R: ±15%
D.F.
Class2:
X7R: ≤ 16V: ≤ 7%
≥ 25V: ≤ 5%
Rins
Class2:
X7R: ≥ 1,000 MΩ or Rins x Cr ≥ 50s
whichever is less
∆C/C
Class 2:
X7R: ±20%
D.F.
Class 2:
Rins
Class 2:
X7R: 1,000 MΩ or Rins x Cr ≥ 50s
whichever is less
Voltage Proof
IEC 603841
4.6
Specified stress voltage applied for 1 minute
Ur ≤ 100 V: series applied 2.5 Ur
100 V < Ur ≤ 200 V series applied (1.5 Ur + 100)
200 V < Ur ≤ 500 V series applied (1.3 Ur + 100)
Ur > 500 V: 1.3 Ur
I: 7.5 mA
No breakdown or flashover
www.yageo.com
Oct 13, 2011 V.8
X7R
6.3 V to 50 V
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 8
Oct 13, 2011
- Dimension updated
Version 7
Jan 13, 2011
- Dimension updated
Version 6
Oct 13, 2010
- Rated voltage of 0201 extend to 50 V
- Capacitance range of 0201 X7R 6.3V to 16V extend to 100 pF
- Capacitance range of 0805 X7R 10V extend to 10 µF
- Capacitance range of 0805 X7R 50V extend to 1 µF
- Capacitance range of 1210 X7R 10V extend to 22 µF
- Figures of impedance ESR updated
Version 5
Jul 27, 2010
- Dimension on 0603 and 1206 case size updated
Version 4
Apr 21, 2010
- The statement of "Halogen Free" on the cover added
- Dimension updated
Version 3
Oct 26, 2009
- Capacitance range of 0402 X7R 25 V extend to 100 nF
Version 2
May 11, 2009
- Product range updated
Version 1
Apr 24, 2009
- Ordering code updated
Version 0
Apr 15, 2009
- New datasheet for general purpose and high capacitance X7R series with
RoHS compliant
- Replace the "6.3V to 50V" part of pdf files: X7R_10V_9, X7R_16V-to100V_9, X7R_16-to-500V_9, UP-X5R_X7R_HighCaps_6.3-to-25V_11,
UY-X5R_X7R_HighCaps_6.3-to-25V_11
- Combine 0201 from pdf files: UP-NP0X5RX7RY5V_0201_6.3-to-50V_2
and UY-NPOX5RX7RY5V_0201_6.3-to-50V_2
- Define global part number
- Description of "Halogen Free compliant" added
- Test method and procedure updated
www.yageo.com
Oct 13, 2011 V.8
