CC1210KKX7RGBB106
CC1210KKX7RGBB106
    YAGEO(国巨)
    贴片电容(MLCC) 1210 10µF ±10% 35V X7R
CC1210KKX7RGBB106 数据手册
www.yageo.com High Capacitance MLCCs About Yageo Founded in 1977, the Yageo Corporation has become a world-class provider of passive component services with capabilities on a global scale, including production and sales facilities in Asia, Europe and the Americas. The corporation provides one-stop-shopping, offering its complete product portfolio of resistors, capacitors and wireless components in both commodity and specialty versions to meet the diverse requirements of customers. Yageo currently ranks as the world No.1 in chip-resistors, No. 3 in MLCCs and No. 4 in ferrite products, with a strong global presence: 21 sales offices in 15 countries, 9 production sites, 8 JIT logistic hubs, and 2 R&D centers worldwide. We support our customers with extensive literature including datasheets, brochures and application notes, which are also available electronically on our website at: www.yageo.com Functionality Electrical signals contain various noise components such as EMI or equipment-generated noise. This noise can cause many problems such as crosstalk, false-triggering, or incorrect logic levels. High capacitance MLCCs can be used to reduce these noise signals and provide a more stable operating system. High-cap MLCCs have the following functions: 1. Bypassing: Used in filtering circuits, MLCCs having low capacitance change vs. frequency work to reduce unwanted signals (high-frequency noise) of the supply voltage to ICs, transistors, or other devices. 2. Decoupling: In addition to noise reduction, the MLCC works to keep voltage levels independent of each other with the proper capacitor (low-pass) filtering the supply line. The capacitance should be large enough to absorb any load shift of a device. 3. Smoothing: When AC signals are changed to DC signals, if the voltage waveform contains too much ripple, a capacitor is used to smooth (absorb) this voltage before it is sent to other circuits. The capacitance should be large enough to absorb the ripple current. V1 Signal Coupling V2 Because capacitors pass AC but block DC signals (when charged up to the applied DC voltage), they are often used to separate the AC and DC components of a signal. It is widely used for separating and joining two circuit blocks. t t Circuit Block(2) DC V2 Circuit Block(1) DC V1 Decoupling (Bypass) A decoupling capacitor is a capacitor used to decouple one part of a circuit from another. Noise caused by other Coupling capacitor separates DC voltages of circuit elements is shunted through the capacitor, reducing circuit blocks but couples AC signal. the effect they have on the rest of the circuit. It is most commonly used between the power supply and ground. An alternative name is bypass capacitor as it is used to bypass the power supply or other high impedance component of a circuit. V V t 0 0 t IC Input Power V 0 t Product Selection Tables X7R Product Range Size(inch)Cap 0402 0603 0805 1206 1210 1812 2220 1uF 6.3V 50V 50V 100V 100V 100V 50V 2.2uF --- 16V 25V 50V 100V --- --- 4.7uF --- 6.3V 25V 50V 50V --- --- 10uF --- --- 16V 25V 50V --- --- 22uF --- --- --- 16V 25V --- --- 47uF --- --- --- --- 16V --- --- 100uF --- --- --- --- --- --- --- X5R Product Range Size(inch)Cap 0201 0402 0603 0805 1206 1210 1uF 10V 25V 50V 50V 50V 50V 2.2uF 6.3V 25V 50V 50V 50V 50V 4.7uF --- 16V 25V 50V 50V 50V 10uF --- 10V 25V 50V 50V 50V 22uF --- 6.3V 16V 10V 25V 25V 47uF --- --- 4V 10V 16V 16V 100uF --- --- --- 6.3V 6.3V 16V 220uF --- --- --- --- --- 6.3V Y5V Product Range Size(inch)Cap 0402 0603 0805 1206 1210 1uF 10V 25V 50V 50V --- 2.2uF --- 16V 25V 50V --- 4.7uF --- 10V 16V 16V --- 10uF --- --- 16V 25V 50V 22uF --- --- 10V 16V 16V 47uF --- --- --- --- --- 100uF --- --- --- --- --- Cross Reference Size Yageo Murata SEMCO TDK TaiyoYuden 0201 CC0201 GRM03 SL03 C0603 MK063 0402 CC0402 GRM15 SL05 C1005 MK105 0603 CC0603 GRM18 SL10 C1608 MK107 0805 CC0805 GRM21 SL21 C2012 MK212 1206 CC1206 GRM31 SL31 C3216 MK316 1210 CC1210 GRM32 SL32 C3225 MK325 1812 CC1812 GRM43 SL43 C4532 --- Product Portfolio Electrical Characteristics TC Operating Temp range Capacitace range Voltage range Tolerance CC0201 X5R -55°C to 85°C 1uF ~ 2.2uF 6.3V ~ 10V ±20% X5R -55°C to 85°C 1uF ~ 22uF 6.3V ~ 25 V ±10%, ±20% X7R -55°C to 125°C 1uF 6.3V ±10% Y5V -30°C to 85°C 1uF 6.3V ~ 10V +80% ~ -20% X5R -55°C to 85°C 1uF ~ 47uF 6.3V ~ 50 V ±10%, ±20% X7R -55°C to 125°C 1uF ~ 4.7uF 6.3V ~ 50 V ±10% Y5V -30°C to 85°C 1uF ~ 4.7uF 10V ~ 16V +80% ~ -20% X5R -55°C to 85°C 1uF ~ 100uF 6.3V ~ 50 V ±10%, ±20% Y5V -30°C to 85°C 1uF ~ 22uF 6.3V ~ 50V +80% ~ -20% X7R -55°C to 125°C 1uF ~ 10uF 6.3V ~ 50 V ±10% X5R -55°C to 85°C 1uF ~ 100uF 6.3V ~ 50 V ±10%, ±20% X7R -55°C to 125°C 1uF ~ 22uF 6.3V ~ 100V ±10% Y5V -30°C to 85°C 1uF ~ 22uF 10V ~ 50V +80% ~ -20% X5R -55°C to 85°C 1uF ~ 220uF 6.3V ~ 50 V ±10%, ±20% X7R -55°C to 125°C 1uF ~ 47uF 6.3V ~ 100 V ±10% Y5V -30°C to 85°C 10uF ~ 22uF 6.3V ~ 25V +80% ~ -20% CC1812 X7R -55°C to 125°C 1uF 50V ±10% CC2220 X7R -55°C to 125°C 1uF 50V ±10% CC0402 CC0603 CC0805 CC1206 CC1210 Dimensions M L2 L4 L1 L3 Inch-based Metric L1 (mm) W (mm) 0201 0603M 0.6 ±0.03 0402 1005M 0603 L2 / L3 (mm) L4 (mm) min. max. min. 0.3 ±0.03 0.1 0.2 0.2 1.0 ±0.05 0.5 ±0.05 0.15 0.3 0.4 1608M 1.6 ±0.10 0.8 ±0.10 0.2 0.6 0.4 0805 2012M 2.0 ±0.10 1.25 ±0.10 0.25 0.75 0.55 1206 3216M 3.2 ±0.15 1.6 ±0.15 0.25 0.75 1.4 1210 3225M 3.2 ±0.20 2.5 ±0.20 0.25 0.75 1.4 1812 4532M 4.5 ±0.20 3.2 ±0.20 0.25 0.75 2.2 2220 5750M 5.7 ±0.40 5.0 ±0.30 0.25 0.75 3.4 Note : Actual product specifications, please refer to datasheet High Capacitance MLCCs Type Noise Filter and Snubbers L C Vin Low Freq. Signal Vin Vout L High Freq. Signal C Vout Gain Similarly, in smaller scale circuits, the spark may not be enough to damage the switch but will still radiate undesirable radio frequency interference (RFI), which a filter capacitor absorbs. Snubber capacitors are usually employed with a low-value resistor in series, to dissipate energy and minimize RFI. Such resistor-capacitor combinations are available in a single package. Low-Freq. Signal Pass High-Freq. Signal Pass Gain When an inductive circuit is opened, the current through the inductance collapses quickly, creating a large voltage across the open circuit of the switch or relay. A snubber capacitor across the newly opened circuit creates a path for this impulse to bypass the contact points, thereby preserving their life; these are commonly found in contact breaker ignition systems. (a) Frequency (b) Frequency Filtering functions of capacitor coupled with inductor (a) High Pass Filter (b) Low Pass Filter Applications Consumer, industrial and communications applications, which often have very different mounting and soldering processes, and different substrates, are exposed to a wide range of application conditions. It is therefore necessary to relate their characteristics to typical applications and to consider the application limitations. Surfacemount technology is at a dynamic stage of development in its search for new components, quest for further miniaturization, improved processing, and so on. - Automation - SMPS - Safety devices - Smart grid meters - DC/DC converters Industrial Power Management - Lighting - Computing systems - Entertainment - Peripherals - Home appliances Consumer Electronics Computers & Peripherals - Infrastructure - Electrical grids - Mobile solutions - Solar & wind energy - Networking Telecom Alternative Energy Introduction High Performance and High Reliability The four cornerstones of technology required to manufacture high performance and high reliability high-cap MLCCs are: material technology, thin-film processing technology, production technology and base metal technology. Being vertically-integrated from material processing to production technology, Yageo is able to manufacture high-performance and high-reliability, high-cap MLCCs, controlling the production process from beginning to end. Thanks to unique material technology, Yageo offers many types of Multi-Layer Ceramic Capacitors (MLCCs), including commodity, high-capacitance, high voltage, soft termination, and high frequency. The dielectric material of Yageo’s CC series ranges through NP0, X5R, X7R and Y5V, with standard EIA chip sizes available, a wide-range of capacitances for various circuit needs, rugged terminations (lead-free), and the capability to be used in both reflow and wave soldering systems. Yageo MLCCs provide outstanding performance, reliability and cost advantages for circuit designers.The capacitors are for both paper- and plastic- embossed, tape-and-reel packaging for automatic SMD placement. High capacitance MLCCs are high-end products in terms of capacitance to accomodate trends in the electronic industry towards convergence, multi-functionality, and miniaturization. In this subcategory, we cover 1μF - 220μF, depending on the case size. The available capacitance range is expanding year by year, and is particularly focused on the smaller MLCCs, with continuous R&D of the core technologies for thinner layers. Main Features of Yageo’s High Capacitance MLCCs • • • • • Materials: X5R, X7R and Y5V Wide selection of sizes: from 0201 to 2220 Capacitance range from 1μF to 220μF Working voltage rated from 6.3V - 100V Highly-reliable tolerance and high-speed automatic chip placement on PCBs • Highly-resistant termination metal • Tape & reel for surface mount assembly Terminations Electrode Ceramic Material Surface mount multilayer ceramic capacitor construction YAGEO - A GLOBAL COMPANY HQ Taipei, Taiwa n Tel. +886 2 6629 9999 Fax. +886 2 6628 8886 EUROPE China and ASIA Suzhou, China Tokyo, Japa n Shanghai, China Seongnam, Korea Dongguan, China Singapor e Tel. +86 512 6825 5568 Fax. +86 512 6825 5386 Tel. +86 21 64858697 Tel. +86 769 8772 0275 Fax. +86 769 8791 0053 Munich, Germany Tel. +81 3 6809 3972 Fax. +81 3 6809 3982 Tel. +49 8990 7784 380 Fax. +49 8990 7784 379 Milan, Ital y Tel. +82 31 712 4797 Fax. +82 31 712 5866 Tel. +39 02 6129 1017 Fax. +39 02 6601 7490 Tel. +60 4 3973049 Fax. +60 4 3973050 Mexico Tel. +52 33 31330631 Fax. +1 408 240 6201 Tel. +31 475 385 555 Fax. +31 475 385 589 Kuala Lumpur, Malaysi a Penang, Malaysi a San Jose, U.S.A. Tel. +1 408 240 6200 Fax. +1 408 240 6201 Roermond, Benelu x Tel. +65 6244 7800 Fax. +65 6244 4943 Tel. +60 3 8063 8864 Fax. +60 3 8063 7376 NORTH AMERICA Szombathely, Hungary Tel. +36 94 517 702 Fax. +36 94 517 701 Moscow, Russian Federation Tel. +7 965 408 18 11 Fax. +7 498 610 07 07 For a complete listing of all Yageo sales offices, distributors, and representatives, please visit "contact us" at www.yageo.com © YAGEO Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent or other industrial or intellectual property rights. Printed in Taiwan Document order number: YL 100 00159 Date of release: February 2016
CC1210KKX7RGBB106 价格&库存
很抱歉,暂时无法提供与“CC1210KKX7RGBB106”相匹配的价格&库存,您可以联系我们找货
CC1210KKX7RGBB106
  • 1+8.94280
  • 10+7.35390
  • 50+6.19320
  • 150+5.74020
  • 500+5.36310
  • 1000+5.03240
库存:919
CC1210KKX7RGBB106
  • 1+7.19400
  • 10+5.99500
  • 500+5.76400
库存:680
CC1210KKX7RGBB106
  • 500+2.70309500+0.35015
  • 1000+2.528361000+0.32752
  • 1500+2.440891500+0.31618
  • 2500+2.343932500+0.30362
  • 3500+2.287253500+0.29628
  • 5000+2.232745000+0.28922
库存:6134
CC1210KKX7RGBB106
  • 1+7.412891+0.96023
  • 10+4.6919910+0.60778
  • 50+3.6040550+0.46685
  • 100+3.26882100+0.42343
库存:6134
CC1210KKX7RGBB106
    CC1210KKX7RGBB106
    • 1+6.923301+0.89680
    • 10+3.4856010+0.45150
    • 100+3.16220100+0.40970
    • 500+2.73100500+0.35380
    • 1000+2.539301000+0.32900
    库存:5031
