222278115663
222278115663
    YAGEO(国巨)
    陶瓷电容/独石电容 1206
222278115663 数据手册
w DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS High-capacitance: Class 2, X5R/X7R (Pb Free & RoHS compliant) 6.3 V TO 25 V Product specification – June 1, 2006 V.11 56 nF to 47 µF Product specification Surface-Mount Ceramic Multilayer Capacitors SCOPE This specification describes high capacitance X5R/X7R series chip capacitors with lead-free terminations. High-Capacitance X5R/X7R 6.3 V to 25 V APPLICATIONS z PCs, hard disk, game PCs z Power supplies z DVDs, camcorders z Mobile phones, PDAs 2 17 FEATURES z Supplied in tape on reel z Nickel-barrier end termination ORDERING INFORMATION Components may be ordered by using either a Phycomp’s unique 12NC or Phycomp clear text code. PHYCOMP ORDERING CODE 12NC CODE 2 2 X X X X X X X X X X Capacitance value(1) Carrier type 22 blister 38 paper 50 blister Ur ≤ 6.3 V 54 bulk 55 paper Ur ≤ 6.3 V Tolerance 5 ±5% 6 ±10% 7 ±20% Rated voltage - Termination 20 6.3 V; NiSn 24 10 V; NiSn 78 16 V; NiSn 91 25 V; NiSn Size 7 0402 6 0603 0 0805 1 1206 2 1210 4 1812 Temperature characteristic 3 X5R 5 X7R SCM040 Packaging(2) 1 reel: ∅180 mm; 7" 5 reel: ∅330 mm; 13" 4 bulk case (1) Refer to “Conversion table of capacitance & last 2 digits of 12NC” (2) Quantity on reel depends on thickness classification; see section “Thickness classification and packing quantities for 6.3 V to 25 V”. www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors 3 17 High-Capacitance X5R/X7R 6.3 V to 25 V Conversion table of capacitance & last 2 digits of 12NC CAP. (nF) LAST 2 DIGITS OF 12NC CAP. (nF) LAST 2 DIGITS OF 12NC CAP. (nF) LAST 2 DIGITS OF 12NC CAP. (nF) LAST 2 DIGITS OF 12NC 0.10 09 1.8 26 33 43 560 59 0.12 11 2.2 27 39 44 680 61 0.15 12 2.7 28 47 45 820 62 0.18 13 3.3 29 56 46 1,000 63 0.22 14 3.9 31 68 47 1,500 65 0.27 15 4.7 32 82 48 2,200 67 0.33 16 5.6 33 100 49 3,300 69 0.39 17 6.8 34 120 51 4,700 72 0.47 18 8.2 35 150 52 6,800 74 0.56 19 10 36 180 53 10,000 76 0.68 21 12 37 220 54 22,000 81 0.82 22 15 38 270 55 47,000 85 1.0 23 18 39 330 56 100,000 89 1.2 24 22 41 390 57 1.5 25 27 42 470 58 NOTE 1. This table is applied to all X5R, X7R, Y5V, and Z5U products except Y5V 50 V products. CTC CODE Size Temp. code Char. 0402 0603 0805 1206 1210 Capacitance Tolerance Rated voltage Termination Packing 2B = X5R 225 = 2,200,000 pF; the J = ±5% 5 = 6.3 V B = NiSn 2R = X7R third digit signifies the K = ±10% 6 = 10 V multiplying factor: M = ±20% 7 = 16 V 3 = × 1,000 8 = 25 V 4 = × 10,000 1812 5 = × 100,000 2 = 180 mm; 7” paper Marking Series 0 = No marking D = BNE 3 = 330 mm; 13” paper B = 180 mm; 7” blister F = 330 mm; 13” blister P = Bulk case 6 = × 1,000,000 7 = × 10,000,000 Example: 06032B225M5B20D www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 4 17 CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION Table 1 For dimension see Table 1 TYPE W T L2 L4 L1 L3 CC0402 CC0603 CC0805 CC1206 CC1210 CC1812 L1 (mm) 1. 0 ±0.05 1.6 ±0.10 2.0 ±0.20 3.2±0.20 3.2 ±0.20 4.5 ±0.20 W (mm) 0.5 ±0.05 0.8 ±0.07 1.25 ±0.20 1.6±0.20 2.5 ±0.20 3.2 ±0.20 T (mm) Refer to table 2 to 4 MBB211 L2/L3 (mm) Fig. 2 Surface mounted multilayer ceramic capacitor dimension L4 (mm) min. 0.15 0.20 0.25 0.25 0.25 0.25 max. 0.30 0.50 0.75 0.75 0.75 0.75 min. 0.40 0.60 0.55 1.40 1.40 2.20 www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 5 17 CAPACITANCE RANGE & THICKNESS FOR X5R/X7R 6.3 V Table 2 CAPACITANCE (µF) 6.3 V 0402 0603 0805 1206 1210 0.056 0.068 0.082 0.10 0.5 ±0.05 0.12 0.15 0.18 0.22 0.27 0.33 0.39 0.47 0.56 0.68 0.82 1.0 0.8 ±0.07 1.5 0.8 ±0.1 2.2 1.25 ±0.1 3.3 1.25 ±0.2 4.7 6.8 10 1.6 ±0.2 22 2.5 ±0.2 47 NOTE 1. Values in shaded cells indicate thickness class in mm. 2. X5R: ; X7R: ; both X5R and X7R: . www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 6 17 CAPACITANCE RANGE & THICKNESS FOR X5R/X7R 10V Table 3 CAPACITANCE (µF) 10 V 0402 0.056 0.5 ±0.05 0603 0805 1206 1210 0.068 0.082 0.10 0.5 ±0.05 0.12 0.5 ±0.05 0.15 0.18 0.22 0.27 0.8 ±0.07 0.33 0.39 0.47 0.56 0.8 ±0.07 0.68 0.82 1.0 1.25 ±0.1 1.5 0.8 ±0.1 2.2 1.25 ±0.1 3.3 1.25 ±0.2 4.7 1.6 ±0.2 6.8 1.6 ±0.2 10 1.9 ±0.2 22 2.5 ±0.2 NOTE 1. Values in shaded cells indicate thickness class in mm. 2. X5R: ; X7R: ; both X5R and X7R: . www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 7 17 CAPACITANCE RANGE & THICKNESS FOR X5R/X7R 16V TO 25V Table 4 CAPACITANCE (µF) 16V 0402 0.056 0.5 ±0.05 0603 0805 1206 1210 1812 25V 0603 1206 1210 0.068 0.082 0.10 0.12 0.8 ±0.07 0.15 0.18 0.22 0.27 0.33 0.8 ±0.07 0.39 0.47 0.56 1.25 ±0.2 0.68 0.82 1.0 1.6 ±0.2 1.5 2.2 1.15 ±0.1 3.3 1.9 ±0.2 4.7 1.6 ±0.2 6.8 1.9 ±0.2 1.9 ±0.2 2.5 ±0.2 2.5 ±0.2 10 22 2.5 ±0.2 NOTE 1. Values in shaded cells indicate thickness class in mm. 2. X5R: ; X7R: ; both X5R and X7R: . www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 8 17 THICKNESS CLASSES AND PACKING QUANTITY Table 5 DESCRIPTION SIZE THICKNESS 8 mm TAPE WIDTH/AMOUNT PER REEL 12 mm TAPE WIDTH AMOUNT CODE CLASSIFICATION PER Ø180 mm, 7” Ø330 mm, 13” /AMOUNT PER REEL (mm) BULK CASE Paper Blister Paper Blister Ø180 mm, 7” Blister 0201 0.3 ±0.03 15,000 --- 50,000 --- --- --- 0402 0.5 ±0.05 10,000 --- 50,000 --- --- 50,000 0603 0.8 ±0.07 4,000 --- 15,000 --- --- 15,000 0805 0.6 ±0.10 4,000 --- 20,000 --- --- 10,000 0.85 ±0.1 4,000 --- 15,000 --- --- 8,000 1.25 ±0.10 --- 3,000 --- 10,000 --- 5,000 0.6 ±0.10 4,000 --- 20,000 --- --- --- 0.85 ±0.10 4,000 --- 15,000 --- --- --- 1.00 / 1.15 ±0.10 --- 3,000 --- 10,000 --- --- 1.6 ±0.15 --- 2 500 --- 10,000 --- --- 1.6 ±0.20 --- 2,000 --- 10,000 --- --- 0.6 / 0.7 ±0.10 --- 4,000 --- 15,000 --- --- 0.85 ±0.10 --- 4,000 --- 10,000 --- --- 1.15 ±0.10 --- 3,000 --- 10,000 --- --- 1.15 ±0.15 --- 3,000 --- 10,000 --- --- 1.5 ±0.10 --- 2,000 --- --- --- --- 1.6 / 1.9 ±0.20 --- 2,000 --- --- --- --- 2.5 ±0.20 --- 1,000 --- --- --- --- 1.15 ±0.15 --- --- --- --- 1 500 --- 1.35 ±0.15 --- --- --- --- 1,000 --- 1.5 ±0.10 --- --- --- --- 1,000 --- 0.6 / 0.85 ±0.10 --- --- --- --- 2,000 --- 1.15 ±0.10 --- --- --- --- 1,500 --- 1.15 ±0.15 --- --- --- --- 1,500 --- 1.35 ±0.15 --- --- --- --- 1,000 --- 1.5 ±0.1 --- --- --- --- 1,000 --- 1206 1210 Discrete capacitors 1808 1812 Low inductance Arrays 1.6 ±0.2 --- --- --- --- 1,000 --- 0306 0.5 ±0.10 4,000 --- 15,000 --- --- --- 0508 0.85 ±0.10 4,000 --- 15,000 --- --- --- 0612 0.85 ±0.10 4,000 --- 15,000 --- --- --- 0508 0.6 ±0.10 4,000 --- --- --- --- --- 0.85 ±0.10 4,000 --- --- --- --- --- 0.8 ±0.10 4,000 --- --- --- --- --- 1.2 ±0.10 --- 3,000 --- --- --- --- 0612 www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors 9 17 High-Capacitance X5R/X7R 6.3 V to 25 V ELECTRICAL CHARACTERISTICS CLASS 2 CAPACITORS; X5R/X7R DIELECTRIC; NISN TERMINATIONS Unless otherwise stated all electrical values apply at an ambient temperature of 20 ±1 °C, an atmospheric pressure of 86 to 106 kPa, and a relative humidity of 63 to 67%. Table 6 VALUE DESCRIPTION Capacitance range (1) Capacitance 56 nF to 47 µF tolerance (1) (2) Dissipation factor ±5%, ±10%, and ±20% (D.F.) (1) Insulation resistance after 1 minute at Ur (DC) See table 7 - 12 Rins ≥ 10 GΩ or Rins × C ≥ 500 seconds whichever is less Maximum capacitance change as a function of temperature (temperature characteristic/coefficient) Operating temperature range: X5R X7R ±15% –55 °C to +85 °C –55 °C to +125 °C NOTE 1. f=1 KHz for C ≤ 10 µF; measuring at voltage 1 Vrms; f=120 Hz for C > 10 µF; measuring at voltage 0.5 Vrms. 2. ±5% capacitance tolerance is on request for capacitance value < 1 uF. www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 10 17 DISSIPATION FACTOR (D.F.) FOR SIZES 0402 TO 1812 Table 7 For size 0402 (1005 metric) TC SIZE CAPACITANCE VALUE (µF) CAPACITANCE TOLERANCE (%) DC RATED VOLTAGE (V) DISSIPATION FACTORD.F. (%) THICKNESS (mm) X5R 0402 0.10 ±10; ±20 6.3 7.0 0.50 X5R 0402 0.12 ±10; ±20 6.3 7.0 0.50 X5R 0402 0.15 ±10; ±20 6.3 7.0 0.50 X5R 0402 0.18 ±10; ±20 6.3 7.0 0.50 X5R 0402 0.22 ±10; ±20 6.3 7.0 0.50 X5R 0402 0.27 ±10; ±20 6.3 10.0 0.50 X5R 0402 0.33 ±10; ±20 6.3 10.0 0.50 X5R 0402 0.39 ±10; ±20 6.3 10.0 0.50 X5R 0402 0.47 ±10; ±20 6.3 10.0 0.50 X5R 0402 0.56 ±10; ±20 6.3 10.0 0.50 X5R 0402 0.68 ±10; ±20 6.3 10.0 0.50 X5R 0402 0.82 ±10; ±20 6.3 10.0 0.50 X5R 0402 1.00 ±10; ±20 6.3 10.0 0.50 X7R 0402 0.056 ±10; ±20 10 5.0 0.50 X7R 0402 0.068 ±10; ±20 10 5.0 0.50 X7R 0402 0.082 ±10; ±20 10 5.0 0.50 X5R 0402 0.10 ±10; ±20 10 5.0 0.50 X7R 0402 0.10 ±10; ±20 10 5.0 0.50 X5R 0402 0.12 ±10; ±20 10 7.0 0.50 X5R 0402 0.15 ±10; ±20 10 7.0 0.50 X5R 0402 0.18 ±10; ±20 10 7.0 0.50 X5R 0402 0.22 ±10; ±20 10 7.0 0.50 X5R 0402 0.056 ±10; ±20 16 5.0 0.50 X7R 0402 0.056 ±10; ±20 16 5.0 0.50 X5R 0402 0.068 ±10; ±20 16 5.0 0.50 X7R 0402 0.068 ±10; ±20 16 5.0 0.50 X5R 0402 0.082 ±10; ±20 16 5.0 0.50 X7R 0402 0.082 ±10; ±20 16 5.0 0.50 X5R 0402 0.10 ±10; ±20 16 5.0 0.50 X7R 0402 0.10 ±10; ±20 16 5.0 0.50 www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 11 17 Table 8 For size 0603 (1608 metric) TC SIZE CAPACITANCE VALUE (µF) CAPACITANCE TOLERANCE (%) DC RATED VOLTAGE (V) DISSIPATION FACTORD.F. (%) THICKNESS (mm) X5R 0603 1.00 ±10; ±20 6.3 7.0 0.80 X5R 0603 1.50 ±10; ±20 6.3 10.0 0.80 X5R 0603 2.20 ±10; ±20 6.3 10.0 0.80 X5R 0603 3.30 ±10; ±20 6.3 10.0 0.80 X5R 0603 4.70 ±10; ±20 6.3 10.0 0.80 X7R 0603 0.27 ±10; ±20 10 5.0 0.80 X7R 0603 0.33 ±10; ±20 10 5.0 0.80 X7R 0603 0.39 ±10; ±20 10 5.0 0.80 X7R 0603 0.47 ±10; ±20 10 5.0 0.80 X5R 0603 0.56 ±10; ±20 10 7.0 0.80 X5R 0603 0.68 ±10; ±20 10 7.0 0.80 X5R 0603 0.82 ±10; ±20 10 7.0 0.80 X5R 0603 1.00 ±10; ±20 10 7.0 0.80 X5R 0603 1.50 ±10; ±20 10 7.0 0.80 X5R 0603 2.20 ±10; ±20 10 10.0 0.80 X7R 0603 0.12 ±10; ±20 16 5.0 0.80 X7R 0603 0.15 ±10; ±20 16 5.0 0.80 X7R 0603 0.18 ±10; ±20 16 5.0 0.80 X7R 0603 0.22 ±10; ±20 16 5.0 0.80 X7R 0603 0.27 ±10; ±20 16 5.0 0.80 X7R 0603 0.33 ±10; ±20 16 5.0 0.80 X7R 0603 0.39 ±10; ±20 16 5.0 0.80 X7R 0603 0.47 ±10; ±20 16 5.0 0.80 X5R 0603 0.33 ±10; ±20 25 5.0 0.80 X5R 0603 0.39 ±10; ±20 25 5.0 0.80 X5R 0603 0.47 ±10; ±20 25 5.0 0.80 www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 12 17 Table 9 For size 0805 (2012 metric) TC SIZE CAPACITANCE VALUE (µF) CAPACITANCE TOLERANCE (%) DC RATED VOLTAGE (V) DISSIPATION FACTORD.F. (%) THICKNESS (mm) X5R 0805 2.20 ±10; ±20 6.3 7.0 1.25 X7R 0805 2.20 ±10; ±20 6.3 7.0 1.25 X5R 0805 3.30 ±10; ±20 6.3 7.0 1.25 X5R 0805 4.70 ±10; ±20 6.3 7.0 1.25 X5R 0805 6.80 ±10; ±20 6.3 10.0 1.25 X5R 0805 10.00 ±10; ±20 6.3 10.0 1.25 X7R 0805 1.00 ±10; ±20 10 5.0 1.25 X7R 0805 1.50 ±10; ±20 10 7.0 1.25 X5R 0805 2.20 ±10; ±20 10 7.0 1.25 X7R 0805 2.20 ±10; ±20 10 7.0 1.25 X5R 0805 3.30 ±10; ±20 10 7.0 1.25 X5R 0805 4.70 ±10; ±20 10 7.0 1.25 X5R 0805 6.80 ±10; ±20 10 10.0 1.25 X5R 0805 10.00 ±10; ±20 10 10.0 1.25 X7R 0805 0.56 ±10; ±20 16 5.0 1.25 X7R 0805 0.68 ±10; ±20 16 5.0 1.25 X7R 0805 0.82 ±10; ±20 16 5.0 1.25 X7R 0805 1.00 ±10; ±20 16 5.0 1.25 Table 10 For size 1206 (3216 metric) TC SIZE CAPACITANCE VALUE (µF) CAPACITANCE TOLERANCE (%) DC RATED VOLTAGE (V) DISSIPATION FACTORD.F. (%) THICKNESS (mm) X5R 1206 10.00 ±10; ±20 6.3 7.5 1.60 X5R 1206 22.00 ±10; ±20 6.3 10.0 1.60 X5R 1206 4.70 ±10; ±20 10 5.0 1.60 X7R 1206 4.70 ±10; ±20 10 5.0 1.60 X5R 1206 6.80 ±10; ±20 10 7.5 1.60 X5R 1206 10.00 ±10; ±20 10 7.5 1.60 X7R 1206 2.20 ±10; ±20 16 5.0 1.15 X5R 1206 4.70 ±10; ±20 16 5.0 1.60 X7R 1206 1.00 ±10; ±20 25 7.5 1.60 www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 13 17 Table 11 For size 1210 (3225 metric) TC SIZE CAPACITANCE VALUE (µF) CAPACITANCE TOLERANCE (%) DC RATED VOLTAGE (V) DISSIPATION FACTORD.F. (%) THICKNESS (mm) X5R 1210 22.00 ±20 6.3 2.5 2.50 X5R 1210 47.00 ±20 6.3 10.0 2.50 X5R 1210 10.00 ±10; ±20 10 3.5 1.90 X5R 1210 22.00 ±20 10 7.0 2.50 X5R 1210 3.30 ±10; ±20 16 3.5 1.90 X5R 1210 4.70 ±10; ±20 16 3.5 1.90 X7R 1210 4.70 ±10; ±20 16 3.5 1.90 X5R 1210 6.80 ±10; ±20 16 3.5 2.50 X5R 1210 10.00 ±10; ±20 16 3.5 2.50 X5R 1210 3.30 ±10; ±20 25 3.5 1.90 X5R 1210 4.70 ±10; ±20 25 3.5 1.90 X5R 1210 6.80 ±10; ±20 25 2.5 2.50 X5R 1210 10.00 ±10; ±20 25 2.5 2.50 Table 12 For size 1812 (4532 metric) TC SIZE CAPACITANCE VALUE (µF) CAPACITANCE TOLERANCE (%) DC RATED VOLTAGE (V) DISSIPATION FACTORD.F. (%) THICKNESS (mm) X5R 1812 22.00 ±10; ±20 16 3.5 2.50 www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors 14 17 High-Capacitance X5R/X7R 6.3 V to 25 V SOLDERING RECOMMENDATION Table 13 SOLDERING METHOD SIZE 0402 0603 0805 1206 ≥ 1210 Reflow ≥ 0.1 µF ≥ 1.0 µF ≥ 2.2 µF ≥ 4.7 µF Reflow only Reflow/Wave < 0.1 µF < 1.0 µF < 2.2 µF < 4.7 µF --- TESTS AND REQUIREMENTS Table 14 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Mounting IEC 60384-22 4.3 The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage Visual inspection and dimension check 4.4 Any applicable method using × 10 magnification In accordance with specification 4.5.1 Precondition: 150 +0/–10 °C for 1 hour, then keep for 48 ±1 hours at room temperature Within specified tolerance Capacitance f = 1 kHz for C ≤10 µF: measuring voltage 1 Vrms at 20 °C f = 120 Hz for C >10 µF: measuring voltage 0.5 Vrms at 20 °C Dissipation factor (D.F.) 4.5.2 Insulation resistance 4.5.3 At Ur (DC) for 1 minute In accordance with specification Voltage proof 4.5.4.2 2.5 × Ur for 1 minute No breakdown or flashover Temperature characteristic 4.6 Between minimum and maximum temperature In accordance with specification 4.15 A force applied for 10 seconds to the line joining the terminations and in a plane parallel to the substrate for size ≥ 0603: a force of 5 N applied for size 0402: a force of 2.5 N applied No visible damage 4.8 Mounting in accordance with IEC 60384-22 paragraph 4.3 No visible damage Conditions: bending 1 mm at a rate of 1 mm/s, radius jig 340 mm X5R/X7R: lΔC/Cl: ≤ 10% Adhesion Bond strength of plating on end face f = 1 kHz for C ≤10 µF: measuring voltage 1 Vrms at 20 °C f = 120 Hz for C >10 µF: measuring voltage 0.5 Vrms at 20 °C In accordance with specification Y5V: lΔC/Cl: ≤ 20% www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 15 17 Table 14 Test condition, procedure and requirements (continued) TEST Resistance to soldering heat TEST METHOD 4.9 PROCEDURE REQUIREMENTS Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ±1 hours at room temperature The termination shall be well tinned Preheating: for size ≤ 1206: 120 to 150 °C for 1 minute X5R/X7R: lΔC/Cl: ≤ 10% Preheating: for size >1206: 100 to 120 °C for 1 minute and 170 to 200 °C for 1 minute Y5V: lΔC/Cl: ≤ 20% Solder bath temperature: 260 ±5 °C Rins: within initial specified value D.F.: within initial specified value Dipping time: 10 ±0.5 seconds Recovery time: 24 ±2 hours. Solderability 4.10 Unmounted chips completely immersed in a solder bath at 235 ±5 °C The termination shall be well tinned. Dipping time: size ≤ 1206 for 2 ±0.5 seconds; size > 1206 for 4 ±0.5 seconds Rapid change of temperature IEC 60384-22 4.11 Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ±1 hours at room temperature No visual damage 5 cycles with following detail: 30 minutes at lower category temperature; 30 minutes at upper category temperature D.F.: within initial specified value X5R/X7R: ≤ 15% Y5V: ≤ 20% Rins: within initial specified value Recovery time 24 ±2 hours. Damp heat steady state 4.13 Initial measurements; after 150 +0/-10 °C for 1 hour, then keep for 24 ±1 hours at room temperature X5R/X7R: lΔC/Cl: ±20% Duration and conditions: 500 ±12 hours at 40 ±2 °C; 90 to 95% RH D.F.: 2 × initial value max. Final measurement: perform a heat treatment at 150 +0/– 10 °C for 1 hour, final measurements shall be carried out 24 ±1 hours after recovery at room temperature without load. Endurance 4.14 Preconditioning; Initial measurements; after 150 +0/-10 °C for 1 hour, then keep for 24 ±1 hours at room temperature Duration and conditions: 1,000 ±12 hours at upper category temperature with 1.5 × Ur voltage applied Final measurement: perform a heat treatment at 150 +0/– 10 °C for 1 hour, final measurements shall be carried out 24 ±1 hours after recovery at room temperature without load. Y5V: lΔC/Cl: ±30% Rins: 1,000 MΩ or Rins × Cr ≥ 50 seconds, whichever is less X5R/X7R: lΔC/Cl: ±20% Y5V: lΔC/Cl: ±30% D.F.: 2 × initial value max. Rins: 1,000 MΩ or Rins × Cr ≥ 50 seconds, whichever is less www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 16 17 Table 14 Test condition, procedure and requirements (continued) TEST TEST METHOD PROCEDURE REQUIREMENTS Resistance to leaching IEC 60384-10 4.10 Solder bath temperature: 260 ±5 °C Using visual enlargement of × 10, dissolution of the termination shall not exceed 10% Damp heat, with Ur load 4.14 Dipping time 30 ±0.5 seconds Initial measurements; after 150 +0/-10 °C for 1 hour, then keep for 24 ±1 hours at room temperature X5R/X7R: lΔC/Cl: ±20% Duration and conditions: 500 ±12 hours at 40 ±2 °C; 90 to 95% RH; Ur applied D.F.: 2 × initial value max. Final measurement: perform a heat treatment at 150 +0/– 10 °C for 1 hour, final measurements shall be carried out 24 ±1 hours after recovery at room temperature without load. Y5V: lΔC/Cl: ±30% Rins: 500 MΩ or Rins × Cr ≥ 25 seconds, whichever is less www.yageo.com June 1, 2006 V.11 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Capacitance X5R/X7R 6.3 V to 25 V 17 17 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 11 June 1, 2006 - - X5R 0603 4.7 µF tolerance extension Version 10 Feb 18, 2005 - - Capacitance range extended Version 9 Nov 17, 2004 - - Extended capacitance 0.68 µF and 2.2 µF of X5R 0603 10 V Version 8 Sep 29, 2004 - - Revised 12NC ordering code of table 7-9 Version 7 Sep 20, 2004 - - Rated voltage 6.3 V added to 0402/1210 and 25 V added to 1206 - Extend capacitance range: 4.7µF of 0603, 22µF of 1206, and 22µF of 1210 Version 6 Aug 13, 2004 - - 0603 10 V 0.47 µF extended material with X5R Version 5 Jul 06, 2004 - - Revise the dimensions of 0603 and 0805 Version 4 May 10, 2004 - - Extended capacitance 4.7 µF and 10 µF of X5R 0805 10 V - Revised 12NC ordering code and Phycomp clear text code of table 2 & 3 Version 3 Mar 02, 2004 - - Test and requirement revised. Version 2 Feb 25, 2004 - - Test and requirement revised. Version 1 Sep 16, 2003 - - Updated company logos Version 0 Aug 16, 2002 - - www.yageo.com June 1, 2006 V.11
222278115663 价格&库存
很抱歉,暂时无法提供与“222278115663”相匹配的价格&库存,您可以联系我们找货
