DATA SHEET
THIN FILM CHIP RESISTORS
AUTOMOTIVE GRADE
AT series
0.01% TO 1%, TC5 TO TC50
sizes 0402/0603/0805/1206
Product specification – April 15, 2021 V.6
RoHS compliant
Chip Resistor Surface Mount
AT
SERIES
2
9
0402 to 1206
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes AT0402 to
AT1206 high precision-high stability
chip resistors made by thin film
process.
Part number is identified by the series name, size, tolerance, packaging
type, temperature coefficient, taping reel and resistance value.
GLOBAL PART NUMBER
AT XXXX X X X XX XXXXX L
(1)
APPLICATIONS
Automotive electronics
Industrial and medical equipment
Test and measuring equipment
Telecommunications
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0402 / 0603 / 0805 / 1206
(2) TOLERANCE
B = ± 0.1%
C = ± 0.25%
FEATURES
D = ± 0.5%
AEC-Q200 qualified
F = ± 1%
Total lead free without RoHS
exemption
L = ± 0.01%
Halogen free epoxy
W = ± 0.05%
Superior resistance against sulfur
containing atmosphere
Moisture sensitivity level: MSL 1
Reducing environmentally
hazardous wastes
High component and equipment
reliability
Non-forbidden materials used in
products/production
P = ± 0.02%
(3) PACKAGING TYPE
R = Paper taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
A = ± 5 ppm/°C
B = ± 10 ppm/°C
C = ± 15 ppm/°C
D = ± 25 ppm/°C
E = ± 50 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value.
Letter R/K/M is decimal point
Example: 100R = 100Ω
1K = 1,000Ω
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (NOTE)
O RDERING EXAMPLE
The ordering code of a AT0402 chip resistor, TC 25 value 56Ω with ±
0.5% tolerance, supplied in 7-inch tape reel is: AT0402DRD0756RL.
NOTE
1. All our Rchip products meet RoHS compliant and Halogen Free. "LFP" of the
internal 2D reel label mentions "Lead Free Process".
2. On customized label, "LFP" or specific symbol can be printed.
www.yageo.com
Apr. 15, 2021 V6
AT
SERIES
3
9
0402 to 1206
MARKING
AT0402
No marking
ynsc007
Fig. 1
AT0603
E-96 series: including values 10/11/13/15/20/75 of E -24 series, 3 digits
Fig. 2
Value = 12.4 KΩ
ynsc003
Fig. 3
Value = 56 KΩ
E-24 series: exception values 10/11/13/15/20/75 of E -24 series, one short bar
under marking letter
AT0805 / AT1206
YNSC004
Fig. 4
Value = 10 KΩ
Both E-24 and E-96 series: 4 digits
First three digits for significant figure and 4th digit for number of zeros
NOTE
For further marking information, please see special data sheet “Chip resistors marking”.
CONSTRUCTION
A metal film layer is deposited on a high
grade ceramic body (aluminium oxide).
This resistive layer is trimmed to its
nominal value and on both ends a contact
is made which will guarantee optimum
solderability. This is achieved by applying
several layers and for ease of soldering the
outer layer consists of Ni/matte tin. The
resistive layer is covered with a protective
coating.
OUTLINES
marking layer
protective coat
resistive layer
inner electrode
H
termination (Ni / matte tin)
ceramic substrate
I2
I1
W
YNSC064
L
Fig. 5 Chip resistor outlines
www.yageo.com
Apr. 15, 2021 V6
AT
SERIES
4
9
0402 to 1206
DIMENSIONS
Table 1
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
AT0402
1.00 ± 0.10
0.50 ± 0.05
0.30 ± 0.05
0.20 ± 0.10
0.25 ± 0.10
AT0603
1.60 ± 0.10
0.80 ± 0.10
0.45 ± 0.10
0.25 ± 0.15
0.25 ± 0.15
AT0805
2.00 ± 0.10
1.25 ± 0.10
0.50 ± 0.10
0.35 ± 0.20
0.35 ± 0.20
AT1206
3.10 ± 0.10
1.60 ± 0.10
0.55 ± 0.10
0.45 ± 0.20
0.40 ± 0.20
ELECTRICAL CHARACTERISTICS
Table 2
TYPE
Operating
Temperature Power
Range Rating
AT0402
1/16W
Max.
Max.
Working Overload
Voltage Voltage
50 V
100 V
Resistance Range (E-24/E-96 series)(Ω) & Tolerance(1)
Dielectric
Withstanding
T.C.R.
±0.01% ±0.02% ±0.05% ±0.1% ±0.25% ±0.5% ±1%
Voltage (ppm/°C)(2)
(L)
(P)
(W)
(B)
(C)
(D)
(F)
100 V
± 50 (E)
10 ≤ R ≤ 100K
± 25 (D)
10 ≤ R ≤ 100K
± 15 (C)
50 ≤ R < 11K
50 ≤ R < 11K
± 10 (B)
50 ≤ R < 11K
--10 ≤ R ≤ 330K
± 5 (A)
± 50 (E)
10 ≤ R ≤ 330K
± 25 (D)
AT0603
1/10W
75V
150 V
100 V
50 ≤ R < 14K
50 ≤ R < 14K
± 5 (A)
to
± 50 (E)
+155 °C
150 V
300 V
300 V
± 15 (C)
10 ≤ R ≤ 1M
50 ≤ R < 17K
50 ≤ R < 17K
± 5 (A)
1/4W
200 V
400 V
500 V
10 ≤ R < 17K
50 ≤ R < 17K
± 10 (B)
AT1206
10 ≤ R ≤ 1M
± 25 (D)
1/8W
10 ≤ R < 14K
50 ≤ R < 14K
± 10 (B)
–55 °C
AT0805
± 15 (C)
10 ≤ R < 11K
± 50 (E)
10 ≤ R ≤ 1M
± 25 (D)
10 ≤ R ≤ 1M
± 15 (C)
± 10 (B)
± 5 (A)
50 ≤ R < 20K
10 ≤ R < 20K
50 ≤ R < 20K
50 ≤ R < 20K
NOTE : 1. Global part number (code 7)
2. Global part number (code 9)
www.yageo.com
Apr. 15, 2021 V6
AT
SERIES
5
9
0402 to 1206
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please see th e special data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PRODUCT TYPE
PATKING STYLE
REEL DIMENSION
QUANTITY PER REEL
AT0402
Paper taping reel
7" (178 mm)
10,000 Units
AT0603
Paper taping reel
7" (178 mm)
5,000 Units
AT0805
Paper taping reel
7" (178 mm)
5,000 Units
AT1206
Paper taping reel
7" (178 mm)
5,000 Units
NOTE: for paper tape and reel specification/dimensions, please see the special data sheet “packing” document.
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
Range: –55 °C to +155 °C
POWER RATING
Each type rated power at 70 °C:
AT0402=1/16 W
AT0603=1/10 W
AT0805=1/8 W
AT1206=1/4 W
handbook, halfpage
MLB206_1
P
(%Prated )
100
50
R ATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=
55
70
100
155
o
Tamb ( C)
Fig. 6 Maximum dissipation (P max) in percentage of rated power
as a function of the operating ambient temperature (T amb)
(PxR)
Or max. working voltage whichever is less
Where
V=Continuous rated DC
or AC (rms) working voltage (v)
P=Rated power
R=Resistance value (Ω)
www.yageo.com
Apr. 15, 2021 V6
AT
SERIES
6
9
0402 to 1206
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Short Time
Overload
IEC60115-1 4.13
2.5 times of rated voltage or maximum
± (0.05%+0.05Ω)
High
Temperature
Exposure
AEC-Q200 Test 3
Moisture
Resistance
overload voltage, the less of the above, for 5 sec
at room temperature
1,000 hours at Tamb = 125 °C, unpowered
± (0.1%+0.05Ω)
1,000 hours at Tamb = 155 °C, unpowered
± (0.3%+0.05Ω)
AEC-Q200 Test 6
Each temperature / humidity cycle is defined at
± (0.1%+0.05Ω)
MIL-STD-202 Method 106
8 hours (method 106F), 3 cycles / 24 hours for
MIL-STD-202 Method 108
10d. with 25 °C / 65 °C 95% R.H, without steps
7a & 7b, unpowered
Parts mounted on test-boards, without
condensation on parts
Biased
Humidity
AEC-Q200 Test 7
1,000 hours; 85 °C / 85% RH
MIL-STD-202 Method 103
10% of operating power
± (0.1%+0.05Ω)
Measurement at 24± 4 hours after test conclusion
Operational
Life
AEC-Q200 Test 8
Resistance to
Soldering
Heat
AEC-Q200 Test 15
Thermal
Shock
AEC-Q200 Test 16
Solderability
- Wetting
AEC-Q200 Test 18
MIL-STD-202 Method 210
MIL-STD-202 Method 107
J-STD-002
1,000 hours at 70± 5 °C, RCWV applied for 1.5
hours on, 0.5 hour off, still air required
± (0.1%+0.05Ω)
1,000 hours at 125 °C, derated voltage applied for
1.5 hours on, 0.5 hour off, still air required
± (0.3%+0.05Ω)
Condition B, no pre-heat of samples
Lead-free solder, 260± 5 °C, 10± 1 seconds
immersion time
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
± (0.05%+0.05Ω)
-55/+125 °C
Number of cycles is 300. Devices mounted
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air – Air
± (0.1%+0.05Ω)
Electrical Test not required Magnification 50X
SMD conditions:
(a) Method B, aging 4 hours at 155 °C dry heat,
dipping at 235± 3 °C for 5± 0.5 seconds.
(b) Method B, steam aging 8 hours, dipping at
215± 3 °C for 5± 0.5 seconds.
(c) Method D, steam aging 8 hours, dipping at
260± 3 °C for 7± 0.5 seconds
Well tinned
No visible damage
(>95% covered)
No visible damage
www.yageo.com
Apr. 15, 2021 V6
TEST
AT
SERIES
TEST METHOD
PROCEDURE
REQUIREMENTS
Board Flex /
Bending
AEC-Q200 Test 21
Chips mounted on a 90mm glass epoxy resin
PCB (FR4)
Bending for 0402: 5 mm
0603/0805: 3 mm
1206: 2mm
Holding time: minimum 60 second
± (0.1%+0.05Ω)
Temperature
Coefficient of
Resistance
(T.C.R.)
IEC 60115-1 4.8
At +25/–55 °C and
+25/+125°C Formula:
Refer to table 2
AEC-Q200-005
T.C.R=
7
9
0402 to 1206
R2 - R1
× 106(ppm/°C)
R1(t 2 − t1)
Where
t1=+25 °C or specified room temperature
t2=–55 °C or +125 °C test temperature
R1=resistance at reference temperature in ohms
R2=resistance at test temperature in ohms
Flower of
Sulfur
ASTM-B-809-95*
Sulfur 750 hours, 105°C, unpowered.
± (4.0%+0.05Ω)
* Modified
www.yageo.com
Apr. 15, 2021 V6
AT
SERIES
0402 to 1206
8
9
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 6
Apr. 15, 2021
- Add tol. ± 0.01%, 0.02%, 0.05% ; TCR 5ppm & 10ppm
Version 5
Oct. 24, 2017
- Add resistance range for ± 15 ppm/°C
Version 4
Mar. 16, 2016
- Remove FOS 90°C test
Version 3
Dec. 11, 2015
- Modify Outline
Version 2
May 11, 2015
- Modify FOS test
Version 1
Jun. 18, 2014
- Modify FOS test
Version 0
May 07, 2014
- First issue of this specification
www.yageo.com
Apr. 15, 2021 V6
AT
SERIES
0402 to 1206
9
9
LEGAL DISCLAIMER
Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors,
inaccuracies or incompleteness contained in any product related information, including but not limited to
product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or
improvements to product related information at any time and without notice.
Yageo makes no representation, warranty, and/or guarantee about the fitness of its produ cts for any particular
purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo
disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all
liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied
warranties, including warranties of fitness for a particular pur pose, non-infringement and merchantability.
Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s
knowledge of typical operating conditions for such types of applications in a generic nature. Such s tatements
are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a
specific customer application or use. They are intended for use only by customers with requisite knowledge and
experience for determining whether Yageo products are the correct products for their application or use. In
addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or
use of Yageo products which requires higher degree of r eliability or safety, shall employ additional protective
safeguard measures to ensure that product failure would not result in personal injury or property damage.
Yageo products are not designed for application or use in medical, life -saving, or life-sustaining devices or for
any other application or use in which the failure of Yageo product s could result in personal injury or death.
Customers using or selling Yageo products not expressly indicated for above -mentioned purposes shall do so at
their own risk and agree to fully indemnify Yageo and hold Yageo harmless.
Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for
revising this content without further notification, as long as products are unch anged. Any product change will
be announced by PCN.
www.yageo.com
Apr. 15, 2021 V6
