CRP200JT-52-2R2AA
CRP200JT-52-2R2AA
    VITROHM
    VITROHM - CRP200JT-52-2R2AA - Through Hole Resistor, 2.2 ohm, CRP, 2 W, ± 5%, Axial Leaded
CRP200JT-52-2R2AA 数据手册
CRP Series Datasheet Precision Wirewound Resistors | Axial and SMD Version Ceramic core | Pulse Version | Flame retardant coating Automotive New SAP Part Nr.: CRP 300 J T - 73- 150R AA Serie * Power rating Tol. Pack-Code TCR Forming type R Value Special F = ±1% G = ±2% J = ±5% T = Tape (ammo pack) - Base on spec. 52- Inner Taping dimension or 73- Inner Taping dimension ZB- Z version Industrial Power & Energy AA = Standard Historical VTM Part Nr.: CR254 – 1 5 T 150R Type Tol. Pack-Code R Value T = Tape (ammo pack) RZI4 6720 J K - 13 150R Type Size Tol. K = Blister tape reel TC Reel diam. R Value Type Historical Part Number Nominal Power Rating * P40 P70 Resistance Range CRP110 CRP200 CRP300 CRP400 CRP500 CRP720 AXIAL SMD CRP251-1 RZI1 CRP252-1 RZI2 CRP254-1 RZI4 CRP256-1 RZI6 CRP257-1 ----- CRP259-1 ----- [W] 1,1 1,0 2,0 1,8 3,0 2,7 4,0 3,6 5,0 4,5 0R1 … 220R R051,0R1 … 470R 0R1 … 1K8 0R1 … 1K5 0R1 … 5K1 [Ω] (under development) (Other values upon request) E-Series (preferred) Tolerances Temperature Coefficient Working Temperature Range E24 (Other upon request) ±[%] 1(F); 2(G); 5(J) ±[10-6*K-1] 120 ±50 [ºC] Thermal Resistance [KW-1] Max. Working Voltage [V]RMS Dielectric Withstanding Voltage [V]RMS IEC115-1 clause 4.7 (1[min]) 7,2 6,5 1R … 22R 24R … 470R -55 … +350 280 155 104 78 62 43 500 Type CRP110 CRP200 CRP300 CRP400 CRP500 CRP720 Historical P/N: CRP251 - 1 CRP252 - 1 CRP254 - 1 CRP256 - 1 CRP257 - 1 CRP259 - 1 *R 95% coverage) IEC60068-2-20 (245±5[ºC] 3±0,5[s]) Color code Marking ((5th band (green) for pulse version)) (Values
CRP200JT-52-2R2AA 价格&库存
很抱歉,暂时无法提供与“CRP200JT-52-2R2AA”相匹配的价格&库存,您可以联系我们找货
