CRS110FK-ZB-100RAA
CRS110FK-ZB-100RAA
    VITROHM
    VITROHM - CRS110FK-ZB-100RAA - SMD Chip Resistor, 100 ohm, ± 1%, 1.1 W, SMD, Wirewound, Precision
CRS110FK-ZB-100RAA 数据手册
CRS Series Datasheet Precision Wirewound Resistors | Axial and SMD Version Ceramic core | Flame retardant coating New SAP Part Nr.: CRS 300 J T - 73- 150R AA Serie * Power rating Tol. Pack-Code TCR Forming type R Value Special F = ±1% G = ±2% J = ±5% T = Tape (ammo pack) - Base on spec. 52- Inner Taping dimension or 73- Inner Taping dimension ZB- Z version Consumer & Electronics Industrial Computer & Peripherals AA = Standard Historical VTM Part Nr.: CR254 – 0 5 T 150R Type Tol. Pack-Code R Value RZC4 6720 Type Size T = Tape (ammo pack) J K - 13 150R Tol. K = Blister tape reel TC Reel diam. R Value CRS110 CRS200 CRS250 CRS300 CRS350 CRS400 CRS500 CRS550 CRS720 AXIAL SMD CR251-0 RZC1 CR252-0 RZC2 CR253-0 RZC3 CR254-0 RZC4 CR255-0 ----- CR256-0 RZC6 CR257-0 ----- CR258-0 ----- CR259-0 ----- [W] 1,1 1,0 2,0 1,8 2,5 2,3 5,0 4,5 5,5 5,0 7,2 6,5 0R01 … 220R 0R016 … 470R 0R01 … 750R 0R027 … 5K1 0R033 … 6K8 0R047 … 8K2 56 43 Type Historical Part Number Nominal Power Rating * P40 P70 Resistance Range [Ω] E-Series (preferred) Tolerances Temperature Coefficient Working Temperature Range E24 (Other upon request) ±[%] Depends on the value, please check the table below [ºC] [KW-1] Max. Working Voltage [V]RMS IEC115-1 clause 4.7 (1[min]) 1(F); 2(G); 5(J) ±[10-6*K-1] Thermal Resistance Dielectric Withstanding Voltage 3,0 3,5 4,0 2,7 3,2 3,6 0R01 … 0R015 … 0R02 … 1K8 1K 1K5 (Other values upon request) -55 … +350 280 155 122 104 93 [V]RMS 78 62 500 Type CRS110 CRS200 CRS250 CRS300 CRS350 CRS400 CRS500 CRS550 CRS720 Historical P/N: CR251 - 0 CR252 - 0 CR253 - 0 CR254 - 0 CR255 - 0 CR256 - 0 CR257 - 0 CR258 - 0 CR259 - 0 *R 95% coverage) IEC60068-2-20 (245±5[ºC] 3±0,5[s]) Marking Printed in clear IEC60062 Temperature Coefficient ( -20ºC to 120ºC ) Historical P/N: CRS110 CR251-0 ------ ------ ≥ 0R01 CRS200 CR252-0 ≥ 0R016 ≤ 0R02 CRS250 CR253-0 ≥ 0R01 CRS300 CR254-0 CRS350 700 ± 200 ppm/K 400 ± 50 ppm/K appr. +180 ppm/K -20 ± 60 ppm/K 0 ± 10 ppm/K ≤ 0R024 ≥ 0R027 ≤ 0R091 ≥ 0R1 ≤ 15R ≥ 16R ≤ 220R ≥ 0R027 ≤ 0R091 ------ ------ ≥ 0R1 ≥ 68R ≥ 75R ≤ 470R ≤ 0R02 ≥ 0R022 ≤ 0R047 ≥ 0R051 ≤ 0R091 ≥ 0R1 ≤ 47R ≥ 51R ≤ 750R ≥ 0R01 ≤ 0R027 ≥ 0R03 ≤ 0R075 ≥ 0R082 ≤ 0R091 ≥ 0R1 ≤ 47R ≥ 51R ≤ 1K8 CR255-0 ≥ 0R015 ≤ 0R024 ≥ 0R027 ≤ 0R062 ≥ 0R068 ≤ 0R091 ≥ 0R1 ≤ 68R ≥ 75R ≤ 1K0 CRS400 CR256-0 ≥ 0R02 ≤ 0R03 ≥ 0R033 ≤ 0R062 ≥ 0R068 ≤ 0R091 ≥ 0R1 ≤ 130R ≥ 150R ≤ 1K5 CRS500 CR257-0 ≥ 0R027 ≤ 0R047 ≥ 0R051 ≤ 0R082 ≥ 0R091 ≤ 0R13 ≥ 0R15 ≤ 150R ≥ 160R ≤ 5K1 CRS550 CR258-0 ≥ 0R033 ≤ 0R062 ≥ 0R068 ≤ 0R13 ≥ 0R15 ≤ 0R16 ≥ 0R18 ≤ 160R ≥ 180R ≤ 6K8 CRS720 CR259-0 ≥ 0R047 ≤ 0R075 ≥ 0R082 ≤ 0R15 ≥ 0R16 ≤ 0R24 ≥ 0R27 ≤ 180R ≥ 200R ≤ 8K2 File Nr. 3200.18-450.108.14 | Revision: 202201 New P/Nr. Type 2 1 CRS Series Datasheet The standard packaging for CRS in axial type is taped, dimensions below. New P/N Type CRS110 CRS200 CRS250 CRS300 CRS350 CRS400 CRS500 CRS550 CRS720 Historical P/N: CR251-0 CR252-0 CR253-0 CR254-0 CR255-0 CR256-0 CR257-0 CR258-0 CR259-0 Pack Code Pieces T = Taped Ammo pack 1000 1000 1000 1000 500 1000 500 500 500 Forming Type A C S 52 52 73 73 73 73 73 73 73 65 65 85 85 85 85 85 85 85 5 5 10 10 10 10 10 10 10 (Inner Taping dim.) 52- 73- New P/N Type CRS110 CRS200 CRS250 CRS300 CRS400 Type CRS110 CRS200 CRS250 CRS300 CRS400 A0 5,0 Historical P/N Size RZC1 5315 RZC2 5315 RZC3 6720 RZC4 6720 RZC6 8424 B0 13,7 W 24 2,0 20,9±1,0 P T2 8 7,2 24 2,0 8 7,6 6,0 21,4 32 2,0 12 8,1 Tol. J = ±5% max. ∅ D max ∅ d ±0,05 3,0 4,0 4,5 6,0 6,0 0,65 0,80 0,65 0,80 0,80 9,0 9,7 14,5 12,6 17,0 17,0±1,0 16,7 * Power rating L1 13,4±0,5 5,7 Ordering Code for SMD: CRS 300 J Serie D1 L Type CRS110 CRS200 CRS250 CRS300 CRS400 W1 25,4 33,4 W2 29,5 37,4 N 90 100 K - ZB- 150R AA Pack-Code TCR Forming type R Value Special K = Blister Tape Reel - Base on spec. ZB- Z version AA = Standard E 5,0±0,5 Z max I 7,0 10 7,5 14 8,0 16 a b 10 10 A Type Packaging 330 CRS110 CRS200 CRS250 CRS300 13(inch) Blister tape CRS400 15(inch) Blister tape 380 Pieces 1000 File Nr. 3200.18-450.108.14 | Revision: 202201 SOLDAR PAD 3 1 CRS Series Datasheet This type CRS is also available in a different pre-forming, as shown below, other’s upon request. THOUGH HOLE VERSION Axial Goal Post Kink (AK-) Radial (RD-) Radial 2 Kink (RK-) File Nr. 3200.18-450.108.14 | Revision: 202201 Axial Goal Post (AG-) 4 1
CRS110FK-ZB-100RAA 价格&库存
很抱歉,暂时无法提供与“CRS110FK-ZB-100RAA”相匹配的价格&库存,您可以联系我们找货
