AT0402BRD0715KL
AT0402BRD0715KL
    YAGEO(国巨)
    特性:AEC Q200 合格。完全无铅,无 RoHS 豁免。无卤环氧树脂。对含硫气氛有出色的耐受性。湿度敏感度等级:MSL I。减少对环境有害的废物。应用:汽车电子。工业和医疗设备
AT0402BRD0715KL 数据手册
DATA SHEET THIN FILM CHIP RESISTORS AUTOMOTIVE GRADE AT series 0.01% TO 1%, TC5 TO TC50 sizes 0402/0603/0805/1206 Product specification – April 15, 2021 V.6 RoHS compliant Product specification Chip Resistor Surface Mount AT SERIES 2 9 0402 to 1206 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AT0402 to AT1206 high precision-high stability chip resistors made by thin film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER AT XXXX X X X XX XXXXX L (1) APPLICATIONS ⚫ Automotive electronics ⚫ Industrial and medical equipment ⚫ Test and measuring equipment ⚫ Telecommunications (2) (3) (4) (5) (6) (7) (1) SIZE 0402 / 0603 / 0805 / 1206 (2) TOLERANCE B = ± 0.1% C = ± 0.25% FEATURES D = ± 0.5% AEC-Q200 qualified F = ± 1% Total lead free without RoHS exemption L = ± 0.01% ⚫ Halogen free epoxy W = ± 0.05% ⚫ Superior resistance against sulfur containing atmosphere ⚫ Moisture sensitivity level: MSL 1 ⚫ Reducing environmentally hazardous wastes ⚫ High component and equipment reliability ⚫ Non-forbidden materials used in products/production ⚫ ⚫ P = ± 0.02% (3) PACKAGING TYPE R = Paper taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE A = ± 5 ppm/°C B = ± 10 ppm/°C C = ± 15 ppm/°C D = ± 25 ppm/°C E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point Example: 100R = 100Ω 1K = 1,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only. (NOTE) O RDERING EXAMPLE The ordering code of a AT0402 chip resistor, TC 25 value 56Ω with ± 0.5% tolerance, supplied in 7-inch tape reel is: AT0402DRD0756RL. NOTE 1. All our Rchip products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 3 9 0402 to 1206 MARKING AT0402 No marking ynsc007 Fig. 1 AT0603 E-96 series: including values 10/11/13/15/20/75 of E -24 series, 3 digits Fig. 2 Value = 12.4 KΩ ynsc003 Fig. 3 Value = 56 KΩ E-24 series: exception values 10/11/13/15/20/75 of E -24 series, one short bar under marking letter AT0805 / AT1206 YNSC004 Fig. 4 Value = 10 KΩ Both E-24 and E-96 series: 4 digits First three digits for significant figure and 4th digit for number of zeros NOTE For further marking information, please see special data sheet “Chip resistors marking”. CONSTRUCTION A metal film layer is deposited on a high grade ceramic body (aluminium oxide). This resistive layer is trimmed to its nominal value and on both ends a contact is made which will guarantee optimum solderability. This is achieved by applying several layers and for ease of soldering the outer layer consists of Ni/matte tin. The resistive layer is covered with a protective coating. OUTLINES marking layer protective coat resistive layer inner electrode H termination (Ni / matte tin) ceramic substrate I2 I1 W YNSC064 L Fig. 5 Chip resistor outlines www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 4 9 0402 to 1206 DIMENSIONS Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AT0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 AT0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AT0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 AT1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 ELECTRICAL CHARACTERISTICS Table 2 TYPE Operating Temperature Power Range Rating AT0402 1/16W Max. Max. Working Overload Voltage Voltage 50 V 100 V Resistance Range (E-24/E-96 series)(Ω) & Tolerance(1) Dielectric Withstanding T.C.R. ±0.01% ±0.02% ±0.05% ±0.1% ±0.25% ±0.5% ±1% Voltage (ppm/°C)(2) (L) (P) (W) (B) (C) (D) (F) 100 V ± 50 (E) 10 ≤ R ≤ 100K ± 25 (D) 10 ≤ R ≤ 100K ± 15 (C) 50 ≤ R < 11K 50 ≤ R < 11K ± 10 (B) 50 ≤ R < 11K --10 ≤ R ≤ 330K ± 5 (A) ± 50 (E) 10 ≤ R ≤ 330K ± 25 (D) AT0603 1/10W 75V 150 V 100 V 50 ≤ R < 14K 50 ≤ R < 14K ± 5 (A) to ± 50 (E) +155 °C 150 V 300 V 300 V ± 15 (C) 10 ≤ R ≤ 1M 50 ≤ R < 17K 50 ≤ R < 17K ± 5 (A) 1/4W 200 V 400 V 500 V 10 ≤ R < 17K 50 ≤ R < 17K ± 10 (B) AT1206 --- 10 ≤ R ≤ 1M ± 25 (D) 1/8W 10 ≤ R < 14K 50 ≤ R < 14K ± 10 (B) –55 °C AT0805 ± 15 (C) 10 ≤ R < 11K --- ± 50 (E) 10 ≤ R ≤ 1M ± 25 (D) 10 ≤ R ≤ 1M ± 15 (C) ± 10 (B) ± 5 (A) 50 ≤ R < 20K 10 ≤ R < 20K 50 ≤ R < 20K 50 ≤ R < 20K --- NOTE : 1. Global part number (code 7) 2. Global part number (code 9) www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 5 9 0402 to 1206 FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please see th e special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PRODUCT TYPE PATKING STYLE REEL DIMENSION QUANTITY PER REEL AT0402 Paper taping reel 7" (178 mm) 10,000 Units AT0603 Paper taping reel 7" (178 mm) 5,000 Units AT0805 Paper taping reel 7" (178 mm) 5,000 Units AT1206 Paper taping reel 7" (178 mm) 5,000 Units NOTE: for paper tape and reel specification/dimensions, please see the special data sheet “packing” document. FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE Range: –55 °C to +155 °C POWER RATING Each type rated power at 70 °C: AT0402=1/16 W AT0603=1/10 W AT0805=1/8 W AT1206=1/4 W handbook, halfpage MLB206_1 P (%Prated ) 100 50 0 R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= 55 0 50 70 100 155 o Tamb ( C) Fig. 6 Maximum dissipation (P max) in percentage of rated power as a function of the operating ambient temperature (T amb) (PxR) Or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (v) P=Rated power R=Resistance value (Ω) www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 6 9 0402 to 1206 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Short Time Overload IEC60115-1 4.13 2.5 times of rated voltage or maximum ± (0.05%+0.05Ω) High Temperature Exposure AEC-Q200 Test 3 Moisture Resistance overload voltage, the less of the above, for 5 sec at room temperature 1,000 hours at Tamb = 125 °C, unpowered ± (0.1%+0.05Ω) 1,000 hours at Tamb = 155 °C, unpowered ± (0.3%+0.05Ω) AEC-Q200 Test 6 Each temperature / humidity cycle is defined at ± (0.1%+0.05Ω) MIL-STD-202 Method 106 8 hours (method 106F), 3 cycles / 24 hours for MIL-STD-202 Method 108 10d. with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered Parts mounted on test-boards, without condensation on parts Biased Humidity AEC-Q200 Test 7 1,000 hours; 85 °C / 85% RH MIL-STD-202 Method 103 10% of operating power ± (0.1%+0.05Ω) Measurement at 24± 4 hours after test conclusion Operational Life AEC-Q200 Test 8 MIL-STD-202 Method 108 Resistance to Soldering Heat AEC-Q200 Test 15 Thermal Shock AEC-Q200 Test 16 Solderability - Wetting AEC-Q200 Test 18 MIL-STD-202 Method 210 MIL-STD-202 Method 107 J-STD-002 1,000 hours at 70± 5 °C, RCWV applied for 1.5 hours on, 0.5 hour off, still air required ± (0.1%+0.05Ω) 1,000 hours at 125 °C, derated voltage applied for 1.5 hours on, 0.5 hour off, still air required ± (0.3%+0.05Ω) Condition B, no pre-heat of samples Lead-free solder, 260± 5 °C, 10± 1 seconds immersion time Procedure 2 for SMD: devices fluxed and cleaned with isopropanol ± (0.05%+0.05Ω) -55/+125 °C Number of cycles is 300. Devices mounted Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air ± (0.1%+0.05Ω) Electrical Test not required Magnification 50X SMD conditions: (a) Method B, aging 4 hours at 155 °C dry heat, dipping at 235± 3 °C for 5± 0.5 seconds. (b) Method B, steam aging 8 hours, dipping at 215± 3 °C for 5± 0.5 seconds. (c) Method D, steam aging 8 hours, dipping at 260± 3 °C for 7± 0.5 seconds Well tinned No visible damage (>95% covered) No visible damage www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount TEST AT SERIES TEST METHOD PROCEDURE REQUIREMENTS Board Flex / Bending AEC-Q200 Test 21 Chips mounted on a 90mm glass epoxy resin PCB (FR4) Bending for 0402: 5 mm 0603/0805: 3 mm 1206: 2mm Holding time: minimum 60 second ± (0.1%+0.05Ω) Temperature Coefficient of Resistance (T.C.R.) IEC 60115-1 4.8 At +25/–55 °C and +25/+125°C Formula: Refer to table 2 AEC-Q200-005 T.C.R= 7 9 0402 to 1206 R2 - R1 × 106(ppm/°C) R1(t 2 − t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Flower of Sulfur ASTM-B-809-95* Sulfur 750 hours, 105°C, unpowered. ± (4.0%+0.05Ω) * Modified www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 0402 to 1206 8 9 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 6 Apr. 15, 2021 - - Add tol. ± 0.01%, 0.02%, 0.05% ; TCR 5ppm & 10ppm Version 5 Oct. 24, 2017 - - Add resistance range for ± 15 ppm/°C Version 4 Mar. 16, 2016 - - Remove FOS 90°C test Version 3 Dec. 11, 2015 - - Modify Outline Version 2 May 11, 2015 - - Modify FOS test Version 1 Jun. 18, 2014 - - Modify FOS test Version 0 May 07, 2014 - - First issue of this specification www.yageo.com Apr. 15, 2021 V6 Product specification Chip Resistor Surface Mount AT SERIES 0402 to 1206 9 9 LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its produ cts for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular pur pose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such s tatements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of r eliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life -saving, or life-sustaining devices or for any other application or use in which the failure of Yageo product s could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above -mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unch anged. Any product change will be announced by PCN. www.yageo.com Apr. 15, 2021 V6
AT0402BRD0715KL
物料型号:文档描述的是YAGEO品牌的AT系列贴片电阻,型号从AT0402到AT1206。
器件简介:这些电阻采用薄膜工艺制造,具有高精度和高稳定性,适用于汽车电子、工业和医疗设备、测试和测量设备以及通信设备。
引脚分配:文档中没有明确提到引脚分配,但通常贴片电阻为两个端子。
参数特性:电阻的公差范围从±0.01%到±1%,温度系数从±5ppm/°C到±50ppm/°C。电阻值由2到4位数字表示,例如100R表示100Ω,1K表示1000Ω。
功能详解:电阻具有AEC-Q200认证,无铅且符合RoHS标准,无卤素环氧树脂,对含硫气氛有优越的抵抗力。
应用信息:适用于汽车电子、工业和医疗设备、测试和测量设备、通信设备等。
封装信息:提供0402、0603、0805、1206等尺寸,包装类型为纸质胶带卷,卷径为7英寸。
电气特性:包括工作温度范围、功率范围、最大工作过载、最大电压、电阻范围和公差等。
测试和要求:包括短时间过载、高温暴露、湿度、偏置湿度、操作寿命、耐焊接热、热冲击和焊接性测试。
AT0402BRD0715KL 价格&库存
很抱歉,暂时无法提供与“AT0402BRD0715KL”相匹配的价格&库存,您可以联系我们找货
AT0402BRD0715KL
  • 10000+0.8664710000+0.11260
  • 30000+0.8171630000+0.10620
库存:3686
AT0402BRD0715KL
    AT0402BRD0715KL
    • 1+1.760651+0.22880
    • 10+1.4554710+0.18915
    • 50+1.2742850+0.16560
    • 100+1.20364100+0.15642
    • 500+1.05959500+0.13770
    库存:3686
    AT0402BRD0715KL
      AT0402BRD0715KL
        • 1+2.17810
        • 100+1.43110
        • 1000+0.97030
        • 5000+0.66850
        • 10000+0.47600
        库存:85
        AT0402BRD0715KL
