DATA SHEET
METAL OXIDE VARISTORS
POWER SUPPLY
07D series
Product specification– May 08, 2021 V.2
RoHS compliant & Halogen free
Circuit Protection
Product Specification
2
13
07D
Metal Oxide Varistors (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 820V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +105℃
Storage Temperature:-40℃ ~ +125℃
Safety certification:UL、CSA、VDE
Applications
Transistor, diode, IC, thyristor or triac semiconductor protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
4
7
1
K
D
J
O
TR
Packing
No suffix: Bulk
TB: Tape & Box & P0=12.7mm
TR: Tape & Reel & P0=12.7mm
Tolerance
K: ±10%
Type
D: Disk
Varistor Voltage
180: 18V
101: 100V
Surge Series
No suffix: Standard type
J: High Surge type
Lead Shape
No suffix: Straight leads
O: Outside crimped leads
F: Y Kinked leads
Element Diameter
07
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
3
13
07D
Dimensions
D
D
T
D
H1
H1
H
T
K≤3.0
L1
L1
F
L
d1
d
K≤3.0
d
e
d
F
O Type
F Type
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H
7.5~12.0
180K
1.5~4.5
1.3
241K
2.1~4.6
2.0
H1
9.0~13.5
220K
1.6~4.6
1.4
271K
2.1~4.9
2.2
L(min.)
20.0
270K
1.6~4.7
1.6
301K
2.2~5.0
2.3
L1(min.)
15.0
330K
1.7~4.9
1.5
331K
2.2~5.1
2.3
D
7.0~9.0
390K
1.6~4.8
1.6
361K
2.4~5.2
2.5
F(±0.8)
5.0
470K
1.7~4.9
1.7
391K
2.5~5.4
2.6
T
Table 2
560K
1.8~5.0
1.9
431K
2.7~5.7
2.8
e(±0.8)
Table 2
680K
1.9~5.2
2.2
471K
2.8~6.0
3.0
d(±0.05)
0.6
820K
1.6~4.1
1.6
511K
2.9~6.2
3.2
d1(±0.4)
1.2
101K
1.9~4.3
1.8
561K
3.1~6.5
3.4
121K
1.9~4.5
2.0
621K
3.3~7.1
3.7
151K
1.7~4.8
1.6
681K
3.5~7.3
4.0
181K
1.8~4.3
1.7
751K
3.8~7.0
4.1
201K
1.9~4.4
1.8
781K
3.9~7.2
4.2
221K
2.0~4.5
1.9
821K
4.1~7.5
4.4
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
4
13
07D
Electrical Characteristics
Maximum
Allowable
Voltage
Part
Number
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
180KD07
180KD07J
11
14
18(15~21.6)
2.5
36
250
500
0.9
2.0
0.02
2800
220KD07
220KD07J
14
18
22(19.5~26)
2.5
43
250
500
1.1
2.4
0.02
2300
270KD07
270KD07J
17
22
27(24~31)
2.5
53
250
500
1.4
3.0
0.02
1800
330KD07
330KD07J
33(29.5~36.5)
2.5
65
250
500
1.7
3.5
0.02
1500
390KD07
390KD07J
25
31
39(35~43)
2.5
77
250
500
2.1
4.0
0.02
1300
470KD07
470KD07J
30
38
47(42~52)
2.5
93
250
500
2.5
5.0
0.02
1100
560KD07
560KD07J
35
45
56(50~62)
2.5
110
250
500
3.1
6.0
0.02
890
680KD07
680KD07J
40
56
68(61~75)
2.5
135
250
500
3.6
7.0
0.02
740
820KD07
820KD07J
50
65
82(74~90)
10
135
1200
1750
5
10.0
0.25
600
101KD07
101KD07J
60
85
100(90~110)
10
165
1200
1750
6.5
12.0
0.25
500
121KD07
121KD07J
75
100
120(108~132)
10
200
1200
1750
7.8
13.0
0.25
420
151KD07
151KD07J
95
125
150(135~165)
10
250
1200
1750
9.7
15.0
0.25
330
181KD07
181KD07J
115
150
180(162~198)
10
300
1200
1750
11.7
16.0
0.25
280
201KD07
201KD07J
130
170
200(180~220)
10
340
1200
1750
13.0
17.0
0.25
250
221KD07
221KD07J
140
180
220(198~242)
10
360
1200
1750
14.0
19.0
0.25
230
241KD07
241KD07J
150
200
240(216~264)
10
395
1200
1750
15.0
21.0
0.25
210
271KD07
271KD07J
175
225
270(243~297)
10
455
1200
1750
18.0
24.0
0.25
185
301KD07
301KD07J
190
250
300(270~330)
10
500
1200
1750
20.0
26.0
0.25
165
331KD07
331KD07J
210
275
330(297~363)
10
550
1200
1750
23.0
28.0
0.25
150
361KD07
361KD07J
230
300
360(324~396)
10
595
1200
1750
24.0
32.0
0.25
140
391KD07
391KD07J
250
320
390(351~429)
10
650
1200
1750
26.0
35.0
0.25
130
431KD07
431KD07J
275
350
430(387~473)
10
710
1200
1750
28.0
40.0
0.25
115
471KD07
471KD07J
300
385
470(423~517)
10
775
1200
1750
29.0
42.0
0.25
105
511KD07
511KD07J
320
415
510(459~561)
10
845
1200
1750
31.0
45.0
0.25
100
561KD07
561KD07J
350
460
560(504~616)
10
925
1200
1750
35.0
49.0
0.25
90
621KD07
621KD07J
385
505
620(558~682)
10
1025
1200
1750
38.0
55.0
0.25
80
681KD07
681KD07J
420
560
680(612~748)
10
1120
1200
1750
42.0
60.0
0.25
75
751KD07
751KD07J
460
615
750(675~825)
10
1240
1200
1750
45.0
64.0
0.25
70
781KD07
781KD07J
485
640
780(702~858)
10
1290
1200
1750
48.0
69.0
0.25
65
821KD07
821KD07J
510
670
820(738~902)
10
1355
1200
1750
52.0
73.0
0.25
60
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K)
IR≤25μA (820K~821K)
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
5
13
07D
Maximum Surge Current Derating Curve
820KD07 to 821KD07
10000
10000
1000
1000
Max. Surge Current (A)
180KD07 to 680KD07
1
100
10
2
10
102
1034
105
106
10
1
100
1000
100
10
1000
Td (μs)
180KD07J to 680KD07J
820KD07J to 821KD07J
10000
1000
1000
1
2
10
102
103
104
105
106
10000
1
2
10
102
100
103
104
105
106
10
1
1
0.1
10
100
Td (μs)
10000
10
103
1045
106
10
0.1
10
10000
102
1
0.1
10
100
1
2
10
100
1000
Td (μs)
10000
0.1
10
100
1000
10000
Td (μs)
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
6
13
07D
Maximum Leakage Current and Maximum Clamping Voltage Curve
820KD07 to 821KD07
10000
10000
1000
1000
180KD07 to 680KD07
1
100
10
2
10
102
1034
105
106
10
1
100
1000
100
10
1000
Td (μs)
10000
1000
1000
1
2
10
102
103
104
105
106
10000
1
2
10
102
100
103
104
105
106
10
1
1
0.1
10
100
Td (μs)
10000
10
103
1045
106
10
0.1
10
10000
102
1
0.1
10
100
1
2
10
100
1000
Td (μs)
10000
0.1
10
100
1000
10000
Td (μs)
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
07D
7
13
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
07D
8
13
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
9
13
07D
Reliability
Items
Standard
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
IEC60068-2-21
Terminal diameter (mm)
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
No visible damage
1.0
2.0
4.0
|ΔV1mA/V1mA |≤5%
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
Bending Strength
of Terminals
Vibration
Solderability
Resistance to
Soldering Heat
High Temperature
Storage
Low Temperature
Storage
Damp Heat,
Steady State
High Temperature
Load
0.5<d≤0.8
0.8<d≤1.25
1.25<d
IEC60068-2-21
Force (kg)
0.5
1.0
2.0
IEC60068-2-6
Frequency range: 10~55 Hz
2
Amplitude: 0.75mm or 98m/s
Direction: 3 mutually perpendicular directions, 2hrs each.
IEC60068-2-20
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
Ambient Temp: 125±2℃
Duration: 1000±24hrs
At least 95% of terminal
electrode is covered by
new solder
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Ambient Temp: -40±2℃
No visible damage
|ΔV1mA/V1mA |≤5%
IEC60068-2-78
The test is divided into two groups .
a. 40±2℃ , 90~95% RH for 1344±24hrs
b. 40±2℃ , 90~95% RH,at 10%VDC ,1344±24 hrs
No visible damage
|ΔV1mA/V1mA|≤10%
Insulation
Resistance≧100MΩ
MIL-STD-202
Ambient Temp: 105±2℃
Method 108
Load: Max. Allowable Voltage In AC.
IEC60068-2-20
IEC60068-2-2
IEC60068-2-1
|ΔV1mA/V1mA|≤10%
The conditions shown below shall be repeated 5 cycles
Temperature Cycle
IEC60068-2-14
10/1000µS
Surge Life
Temperature (℃)
Period (minutes)
1
-40±3
30±3
No visible damage
2
Room temperature
5±3
|ΔV1mA/V1mA |≤5%
3
125±3
30±3
4
Room temperature
5±3
8/20µS waveform,10 surge currents, unipolar, interval
8/20uS
Surge Life
Step
IEC61051-1
30secs,amplitude corresponding to max. surge current
No visible damage
△Vb(1mA)≦±10%
derating curves for 20µS.
10/1000µS waveform,10 surge currents, unipolar, interval
IEC61051-1
2mins,amplitude corresponding to max. surge current derating
No visible damage
|ΔV1mA/V1mA |≤10%
curves for 1000µS.
Voltage Proof
IEC61051-1
Metal balls method, 2500Vac 1 min.
No visible damage
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
10
13
07D
Soldering Recommendation
Lead-free Wave Soldering Recommendation
300
Maximum Wave 265℃
Preheating
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Marking Code
① Brightking Logo
② Varistor Voltage
①
③ UL Accreditation Logo
XXXKDXXX
②
③
④
XXX Y
VDE
⑤
⑥
⑦
④ VDE Accreditation Logo
⑤“J”is High Surge Code, no“J”is Standard Surge
⑥ Disk Size
⑦ Internal control code
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
11
13
07D
Taping Dimensions
P
P2
h
B
W0
W
H0
W2
D0
I
F
P1
P0
W1
t
P2
h
P
B
W0
W
H0
W2
D0
I
F
P1
P0
W1
t
Symbol
Dimension (mm)
P
12.7±1.0
P0
12.7±0.3
P1
3.85±0.7
P2
6.35±1.3
F
5.0±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
32max
Symbol
Dimension (mm)
P
12.7±1.0
P0
12.7±0.3
P1
3.85±0.7
P2
6.35±1.3
F
5.0±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
32max
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
12
13
07D
Taping Dimensions
P2
P
h
B
W0
W
H2
W2
D0
I
F
P1
P0
W1
t
Symbol
Dimension (mm)
P
12.7±1.0
P0
12.7±0.3
P1
3.85±0.7
P2
6.35±1.3
F
5.0±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H2
20.0±2.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
32max
Quantity
Packaging Dimensions (Unit: mm)
Quantity
In bulk for Terminals Untrimmed Products
5M
ax
1000pcs/bag
4bags/box
(180K~821K)
16
130 Max.
250 Max.
5M
ax
In bulk for Terminals Trimmed Products
16
66 Max.
1000pcs/bag
4bags/box
(180K~821K)
252 Max.
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
13
13
07D
Quantity
Quantity
1500pcs/box
(180K~391K)
0M
ax
1000pcs/box
(431K~681K)
25
60 Max.
340 Max.
750pcs/box
(751K~821K)
5M
ax
2000pcs/reel
(180K~331K)
36
60 Max.
365 Max.
55 Max.
30±1
Φ365 Max.
1500pcs/reel
(361K~821K)
Storage Condition of Products
(I) Storage Conditions :
1.Storage Temperature : -10℃ ~ +40℃
2.Relative Humidity : ≦80%RH
3.Keep away from corrosive atmosphere and sunlight.
(II) Period of Storage : 1 year
www.yageo.com
May. 08, 2021 V.0
很抱歉,暂时无法提供与“561KD07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.970741+0.12566
