AC1210KKX7R9BB475
AC1210KKX7R9BB475
    YAGEO(国巨)
    4.7UF ±10% 50V
AC1210KKX7R9BB475 数据手册
DATA SHEET SURFACE MOUNT MULTILAYER CERAMIC CAPACITORS Automotive grade HiCap X7R 6.3 V TO 100 V 1 µF to 10 µF Product specification – February 25, 2021 V.0 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X7R 6.3 V to 100 V 2 19 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes Automotive grade X7R series chip capacitors with lead-free terminations and used for automotive equipments. All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. GLOBAL PART NUMBER AC XXXX X X XXX X (1) APPLICATIONS All general purpose applications Entertainment applications Comfort / security applications Information applications FEATURES  AEC-Q200 qualified  MSL class: MSL 1  AC series soldering is compliant with J-STD-020D  High component and equipment reliability  The capacitors are 100% performed by automatic optical inspection prior to taping. (2) (3) (4) B (5) X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216)/ 1210 (3225) /1812 (4532) (2) TOLERANCE J = ± 5% K = ± 10% M = ± 20% Capacitance tolerance ± 5% doesn't available for X7R full product range, please contact local sales before order (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL X7R (5) RATED VOLTAGE 4=4V 5 = 6.3 V 6 = 10 V 7 = 16 V 8 = 25 V G = 35 V 9 = 50 V 0 = 100 V (6) PROCESS B = X7R (7) CAPACITANCE VALUE 2 significant digits + number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Feb. 25, 2021 V.0 3 Product specification Surface-Mount Ceramic Multilayer Capacitors X7R Automotive grade 19 6.3 V to 100 V CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (Matte Sn). The terminations are leadfree. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION Table 1 For outlines see fig. 2 OUTLINES TYPE L1 (mm) W (mm) T (MM) 0201 0.6 ± 0.03 0.3± 0.03 0402 1.0 ± 0.05 0603 0805 1206 L2 / L3 (mm) L4 (mm) min. max. min. 0.3± 0.03 0.10 0.20 0.20 0.5 ± 0.05 0.5 ± 0.05 0.15 0.35 0.40 1.6 ± 0.10 0.8 ± 0.10 0.8 ± 0.10 0.20 0.60 0.40 2.0 ± 0.10 1.25 ± 0.10 2.0 ± 0.20 1.25 ± 0.20 3.2 ± 0.15 1.6 ± 0.15 For dimension see Table 1 W T 0.6 ± 0.10 0.85 ± 0.10 1.6 ± 0.20 L4 L1 0.25 0.75 L3 MBB211 0.70 1.25 ± 0.20 Fig. 2 Surface mounted multilayer ceramic capacitor dimension 0.6 ± 0.10 0.85 ± 0.10 1.15 ± 0.10 3.2 ± 0.30 L2 1.25 ± 0.20 0.25 0.75 1.40 0.25 0.75 1.40 0.25 0.75 2.20 0.25 0.75 2.20 1.6 ± 0.20 1210 1808 3.2 ± 0.30 1.6 ± 0.30 1.6 ± 0.30 3.2 ± 0.20 2.5 ± 0.20 3.2 ± 0.30 2.5 ± 0.20 3.2 ± 0.40 2.5 ± 0.30 2.5 ± 0.20 4.5 ± 0.40 2.0 ± 0.30 1.25 ± 0.20 0.85 ± 0.10 1.25 ± 0.20 1.6 ± 0.20 2.0 ± 0.20 0.85 ± 0.10 1812 4.5 ± 0.40 3.2 ± 0.30 1.25 ± 0.20 1.6 ± 0.20 www.yageo.com Feb. 25, 2021 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR X7R Table 2 Sizes from 0603 to 0805 0603 CAP. 6.3V 10V 16 V 25 V 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 Automotive grade X7R 16 V 25 V 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.2 uF 1.25± 0.2 1.25± 0.2 1.25± 0.2 4.7 uF 1.25± 0.2 1.25± 0.2 10 uF Table 3 6.3 V 35 V 50 V 1.25± 0.2 1.25± 0.2 1.25± 0.2 Sizes 1206 1206 CAP. 6.3 V 16V 25V 50 V 100 V 1 µF 1.15± 0.10 1.15± 0.10 1.60± 0.2 1.60± 0.2 1.60± 0.2 2.2 µF 1.60± 0.2 1.60± 0.2 1.60± 0.2 1.60± 0.2 4.7 uF 4 19 0805 10 V 1 µF 6.3 V to 100 V 1.60± 0.2 10V 1.60± 0.2 1.60± 0.2 10 uF Table 4 Sizes 1210 to 1812 1210 CAP. 25 V 1812 50V 100 V 50V 100V 1 µF 1.25± 0.20 1.25± 0.20 2.0± 0.2 1.60± 0.2 1.60± 0.2 2.2 µF 4.7 µF 2.0± 0.2 2.5± 0.2 2.0± 0.2 2.5± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Feb. 25, 2021 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X7R 6.3 V to 100 V 5 19 THICKNESS CLASSES AND PACKING QUANTITY Table 5 SIZE CODE THICKNESS CLASSIFICATION PACKING CODE 7 INCH 13 INCH QUANTITY PER REEL TAPE WIDTH Ø 180 MM / 7 INCH Paper Blister Ø 330 MM / 13 INCH Paper Blister 0201 0.3 ± 0.03 mm R P 8 mm 15,000 --- 50,000 --- 0402 0.5 ± 0.05 mm R P 8 mm 10,000 --- 50,000 --- 0603 0.8 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.0/1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 0.85 ± 0.1 mm K F 8 mm --- 4,000 --- 10,000 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 2.0 ± 0.2 mm K 8 mm --- 2,000 --- --- 2.5 ± 0.2 mm K 8 mm --- 1,000 --- --- 0.6 / 0.85± 0.1 mm K 12 mm --- 2,000 --- --- 1.15± 0.1 mm K 12 mm --- 1,000 --- --- 1.25± 0.2 mm K 12 mm --- 1,000 --- --- 1.6 ± 0.2 mm K 12 mm --- 2,000 --- --- 0805 1206 1210 1812 www.yageo.com Feb. 25, 2021 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X7R 6 19 6.3 V to 100 V PAPER/PE TAPE SPECIFICATION P0 D0 T P2 E F cover tape W B0 K0 A0 P1 MBG251-1 Fig. 3 Paper/PE tape Table 6 Dimensions of paper/PE tape for relevant chip size; see Fig.3 SIZE Unit: mm SYMBOL CODE A0 B0 W E F P0 (1) P1 P2 Ø D0 K0 T 0.38 ± 0.05 (0.47 / 0.55)±0.10 0201 0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.55 ± 0.03 0402 0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.50 +0.1 /-0 (0.75 / 0.60)±0.10 (0.85 / 0.70)±0.10 0603 1.05 ± 0.14 1.86 ± 0.13 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 0805 1.50 ± 0.15 2.26 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 1206 1.90 ± 0.15 3.50 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (0.95 / 0.75)±0.10 (1.05 / 0.85)± 0.10 NOTE 1. P0 pitch tolerance over any 10 pitches is 0.2 mm www.yageo.com Feb. 25, 2021 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade X7R 7 19 6.3 V to 100 V BLISTER TAPE SPECIFICATION P0 D0 K0 P2 E F cover tape W B0 A0 T2 SCM015 D1 P1 K0: so chosen that the orientation of the component cannot change For W = 8 mm: T2 = 3.5 mm max. For W = 12 mm: T2 = 6.5 mm max. direction of unreeling Fig. 4 Blister tape Table 7 Dimensions of blister tape for relevant chip size; see Fig.4 SYMBOL SIZE A0 B0 CODE Unit: mm K0 W E F Min. Max. Min. Max. Min. Max. Ø D0 Ø D1 P0 (2) P1 P2 T2 Min. Min. Max. 0805 1.29 1.65 2.09 2.60 1.25 1.62 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.30 1.67 1206 1.65 2.12 3.30 3.75 1.22 2.15 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.27 2.20 1210 2.55 3.02 3.31 3.88 0.97 2.92 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.02 2.97 1808 2.05 2.55 4.80 5.45 1.30 2.45 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.35 2.50 1812 3.35 3.75 4.70 5.33 0.70 2.40 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 0.75 2.45 NOTE 1. Typical capacitor displacement in pocket 2. P0 pitch tolerance over any 10 pitches is ±0.2 mm www.yageo.com Feb. 25, 2021 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors X7R Automotive grade 6.3 V to 100 V 8 19 REEL SPECIFICATION W2 C N A HBK039 W1 Fig. 5 Reel Table 8 Reel dimensions; see Fig.5 TAPE WIDTH SYMBOL Unit: mm A N C W1 W2max. 8 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 9.4 ± 1.5 14.4 8 (Ø 330 mm/13") 330 ± 1.0 100 ± 1.0 13 +0.50/-0.20 9.0 ± 0.2 14.4 12 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 13.4 ± 1.5 18.4 P ROPERTIES OF REEL Material: polystyrene Surface resistance:
AC1210KKX7R9BB475 价格&库存
很抱歉,暂时无法提供与“AC1210KKX7R9BB475”相匹配的价格&库存,您可以联系我们找货
AC1210KKX7R9BB475
    库存:20000
    AC1210KKX7R9BB475
      库存:2860
      AC1210KKX7R9BB475
      • 1+4.300101+0.55890
      • 10+1.9524010+0.25380
      • 100+1.74880100+0.22730
      • 500+1.40140500+0.18220
      • 1000+1.293601000+0.16820
      • 2000+1.157102000+0.15040
      库存:780
      AC1210KKX7R9BB475
        库存:2000
        AC1210KKX7R9BB475
          • 190+6.03770
          • 1000+3.30000
          库存:100030
          AC1210KKX7R9BB475
          • 1+5.379561+0.69922
          • 10+3.2480210+0.42217
          • 50+2.4203850+0.31459
          • 100+2.16698100+0.28166
          • 500+1.73833500+0.22594
          库存:1595
          AC1210KKX7R9BB475
            库存:750
            AC1210KKX7R9BB475
            • 1000+2.359521000+0.30668
            库存:10000
            AC1210KKX7R9BB475
              AC1210KKX7R9BB475
              • 1+8.38856
              • 50+3.82053
              • 100+3.41712
              • 250+3.08490
              • 500+2.74082
              库存:720
