MULTILAYER CERAMIC ANTENNA (LINEAR POLARIZATION MODE)
FOR 400MHz~500MHz
Product Specification1 (Preliminary)
QUICK REFERENCE DATA
__________________________________________________________________________
Working Frequency*
400~500MHz
Bandwidth
20 MHz (Min)
Gain
0.5 dBi (Max)
VSWR
3.0 max
Polarization
Linear
Azimuth
Omni-directional
Impedance
50Ω
Operating Temperature
-55~125 oC
Termination
Ni/Sn (Environmentally-Friendly Leadless)
Resistance to soldering heat 260oC, 10 sec.
* Three types of ceramic antenna are available: Type 43, Type 46, and Type 49
Special Environmental Concerns- Green Products Design: The foil making process
is using environmentally friendly aqueous solvent technology. Termination is lead free and
packing materials can be re-cycled
1. APPLICATION
1
All the technical data and information contained herein are subject to change without prior notice
Print date 04/10/06
R&D
Preliminary use only
Aug. 9, 02
Multilayer Ceramic Antenna
for 433~500MHz
Grant/Cliff
spec.doc
Oct. 14, 02
PHYCOMP Ltd.
CAN4313 121 200431B
CAN4313 121 200461B
CAN4313 121 200491B
sheet 190-1
Page 1
Oct. 14, 02
A4
60 mm
cleanness
circuits
space
BACK SIDE
back side all ground plane
(But under antenna should avoid ground plane)
TOP SIDE
RF-Module
40 mm
50 ohm transmission line
2. SOLDER LAND PATTERN FOR ANTENNA
Figure
S
C
S
Dimensions
S
L
S
R&D
F
L
7.30 ± 0.50 mm
F
2.50 ± 0.50 mm
C
0.90 ± 0.10 mm
S
2.50 ± 0.50 mm
Remark
Feed pad
Mount pad
S
Print date 04/10/06
Aug. 9, 02
for 433~500MHz
Grant/Cliff
spec.doc
Oct. 14, 02
PHYCOMP Ltd.
CAN4313 121 200431B
CAN4313 121 200461B
CAN4313 121 200491B
sheet 190-2
Page 2
Oct. 14, 02
A4
3. MECHANICAL DATA
Figure
Dimension
W
C
S
T
L
6.8±0.5mm
W
37.5±0.5mm
T
0.90±0.2mm
F
2.3±0.3mm
Feed termination
C
S1
S1
S
S1
L
S1
F
Port
0.5±0.3mm
2.3±0.3mm
1.4±0.3mm
Solder termination
Solder termination
Solder termination
S1
4. TEST BOARD DIMENSION FOR S11 (RETURN LOSS) AND
RADIATION PATTERN MEASURNMENT
60 mm
40 mm
FR-4 PCB thickness = 0.8 mm
The length of transmission line = 1.35 mm ( depends on PCB thickness)
R&D
Print date 04/10/06
Aug. 9, 02
for 433~500MHz
Grant/Cliff
spec.doc
Oct. 14, 02
PHYCOMP Ltd.
CAN4313 121 200431B
CAN4313 121 200461B
CAN4313 121 200491B
sheet 190-3
Page 3
Oct. 14, 02
A4
5. S11 RETURN LOSS (Adjustable, Example is 433MHz, 4311 121 20043)
(Adjustable, Example is 490MHz, 4311 121 20049)
R&D
Print date 04/10/06
Aug. 9, 02
for 433~500MHz
Grant/Cliff
spec.doc
Oct. 14, 02
PHYCOMP Ltd.
CAN4313 121 200431B
CAN4313 121 200461B
CAN4313 121 200491B
sheet 190-4
Page 4
Oct. 14, 02
A4
6. TYPICAL RADIATION PATTERN
90
45
-90
135
E Plane
R&D
225
90
-90
135
H Plane
180
Print date 04/10/06
-45
225
180
Aug. 9, 02
for 433~500MHz
Grant/Cliff
spec.doc
Oct. 14, 02
PHYCOMP Ltd.
CAN4313 121 200431B
CAN4313 121 200461B
CAN4313 121 200491B
sheet 190-5
Page 5
Oct. 14, 02
A4
RELIABILITY DATA (Reference to IEC Specification)
IEC
IEC
384-10/
CECC 32
100
CLAUSE
6006868-2
TEST
METHOD
TEST
4.4
Mounting
4.5
4.6.1
Visual inspection
and dimension
check
Antenna
4.8
Adhesion
The antenna can be
mounted on printedcircuit boards or
ceramic substrates by
applying wave
soldering, reflow
soldering (including
vapour phase soldering)
or conductive adhesive
Any applicable method
using × 10
magnification
Central Frequency
at 20 oC
REQUIREMENTS
No visible damage
In accordance with
specification (no chip
off 3 mm)
Standard test board
in page 3
A force of 5 N applied
No visible damage
for 10 s to the line
joining the terminations
and in a plane parallel to
the substrate
Bond strength of
Mounted in accordance No visible damage
plating on end face with CECC 32 100,
paragraph 4.4
4.9
4.10
PROCEDURE
Tb
Resistance to
soldering heat
Conditions: bending
No visible damage
0.25 mm at a rate of
1mm/s, radius jig. 340
mm, 1 mm warp on FR4
board of 90 mm length
260 ± 5 °C for 10 ± 0.5 s The terminations
shall be well tinned
in a static solder bath
after recovery and
Central Freq. Change
± 6%
R&D
Print date 04/10/06
Aug. 9, 02
for 433~500MHz
Grant/Cliff
spec.doc
Oct. 14, 02
PHYCOMP Ltd.
CAN4313 121 200431B
CAN4313 121 200461B
CAN4313 121 200491B
sheet 190-6
Page 6
Oct. 14, 02
A4
IEC
IEC
384-10/
CECC 32
100
CLAUSE
6006868-2
TEST
METHOD
TEST
Resistance to
leaching
4.11
Ta
Solderability
4.12
Na
Rapid change of
temperature
4.14
Ca
Damp heat
PROCEDURE
REQUIREMENTS
260 ± 5 °C for 30 ± 1 s
Using visual
enlargement of × 10,
dissolution of the
termination shall not
exceed 10%
Zero hour test, and test
The termination must
after storage (20 to 24
be well tinned, at
months) in original
least 75% is well
atmosphere; un-mounted tinned at termination
chips completely
immersed for 2 ± 0.5 s
in 235 ± 5°C.
No visible damage
-55 °C (30 minutes) to
+125 °C (30 minutes); 5 Central Freq. Change
± 6%
cycles
500 ± 12 hours at 60 °C; No visible damage
2 hours recovery
90 to 95 % RH
± 6%
4.15
500 ± 12 hours at 125
°C;
Endurance
No visible damage
2 hours recovery
± 6%
R&D
Print date 04/10/06
Aug. 9, 02
for 433~500MHz
Grant/Cliff
spec.doc
Oct. 14, 02
PHYCOMP Ltd.
CAN4313 121 200431B
CAN4313 121 200461B
CAN4313 121 200491B
sheet 190-7
Page 7
Oct. 14, 02
A4
ORDERING INFORMATION: 12NC Ordering Code
The antennas may be ordered by using the Yageo ordering code. These code numbers can be
determined by the following rules:
CAN 43 13 1 21 20 043 1B
CAN = Yageo Part No. for Antenna
F. Family Code
43 = Antenna
C. Packing Type Code
13 = Bulk, 1000 pcs
M. Materials Code
1 = High Frequency Material
S. Size Code
21 = 6.5 * 38.0 * 0.9 mm
T. Tolerance
20 = 20 MHz Bandwidth, VSWR
很抱歉,暂时无法提供与“CAN4313121200431B”相匹配的价格&库存,您可以联系我们找货
