DATA SHEET
SURFACE-MOUNT CERAMIC
MULTILAYER CAPACITORS
General purpose & High capacitance
Class 2, Y5V
6.3 V TO 50 V
10 nF to 47 µF
Product Specification – March 07, 2017 V.8
RoHS compliant & Halogen Free
Product specification
Surface-Mount Ceramic Multilayer Capacitors
General Purpose & High Cap.
Y5V
6.3 V to 50 V
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP
This specification describes Y5V
series chip capacitors with leadfree terminations.
CTC & 12NC
APPLICATIONS
Consumer electronics, for
example:
- Tuners
- Television receivers
- Video recorders
- All types of cameras
- Mobile telephones
FEATURES
Supplied in tape on reel
Nickel-barrier end termination
RoHS compliant
Halogen Free compliant
2
13
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
CC
XXXX X X
(1)
Y5V
(2) (3)
X
BB
XXX
(4)
(5)
(1) SIZE – INCH BASED (METRIC)
0201 (0603)
0402 (1005)
0603 (1608)
0805 (2012)
1206 (3216)
1210 (3225)
(2) TOLERANCE
M = ± 20%
Z = –20% to +80%
(3) PACKING STYLE
R = Paper/PE taping reel; Reel 7 inch
K = Blister taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
F = Blister taping reel; Reel 13 inch
(4) RATED VOLTAGE
5 = 6.3 V
6 = 10 V
7 = 16 V
8 = 25 V
9 = 50 V
(5) CAPACITANCE VALUE
2 significant digits+number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 103 = 10 x 103 = 10,000 pF = 10 nF
www.yageo.com
Mar. 07, 2017 V.8
Y5V
6.3 V to 50 V
3
13
CONSTRUCTION
The capacitor consists of a
rectangular block of ceramic
dielectric in which a number of
interleaved metal electrodes are
contained. This structure gives
rise to a high capacitance per
unit volume.
The inner electrodes are
connected to the two end
terminations and finally covered
with a layer of plated tin (NiSn).
The terminations are lead-free. A
cross section of the structure is
shown in Fig.1.
Fig. 1 Surface mounted multilayer ceramic capacitor construction
DIMENSION
Table 1 For outlines see fig. 2
TYPE
L1 (mm)
W (mm)
0201
0402
0603
0.6 ± 0.03
1.0 ± 0.05
0805
1206
1210
1812
OUTLINES
T (MM)
L2 / L3 (mm)
L4 (mm)
min.
max.
min.
0.3 ± 0.03
0.10
0.20
0.20
0.5 ± 0.05
0.20
0.30
0.40
1.6 ± 0.10
0.8 ± 0.10
0.20
0.60
0.40
2.0 ± 0.10 (1)
1.25 ± 0.10 (1)
2.0 ± 0.20 (2)
1.25 ± 0.20 (2)
0.25
0.75
0.70
3.2 ± 0.15 (1)
1.6 ± 0.15 (1)
3.2 ± 0.30 (2)
1.6 ± 0.20 (2)
0.25
0.75
1.40
3.2 ± 0.20 (1)
2.5 ± 0.20 (1)
3.2 ± 0.40 (2)
2.5 ± 0.30 (2)
4.5 ± 0.20 (1)
3.2 ± 0.20 (1)
4.5 ± 0.40 (2)
3.2 ± 0.40 (2)
Refer to
table 2 to 4
For dimension see Table 1
Fig. 2 Surface mounted multilayer ceramic
capacitor dimension
0.25
0.75
1.40
0.25
0.75
2.20
NOTE
1. Dimension for size 0805 to 1812, C ≤ 100 nF
2. Dimension for size 0805 to 1812, C > 100 nF
www.yageo.com
Mar. 07, 2017 V.8
Y5V
6.3 V to 50 V
4
13
CAPACITANCE RANGE & THICKNESS FOR Y5V
Table 2 Sizes from 0201 to 0402
0201
0402
CAP.
6.3 V
25 V
10 V
16 V
25 V
50 V
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.5± 0.05
22 nF
0.5± 0.05
0.5± 0.05
0.5± 0.05
47 nF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.5± 0.05
220 nF
0.5± 0.05
0.5± 0.05
0.5± 0.05
470 nF
0.5± 0.05
0.5± 0.05
0.5± 0.05
1.0 µF
0.5± 0.05
0.5± 0.05
10 nF
100 nF
6.3 V
0.3± 0.03
0.3± 0.03
2.2 µF
4.7 µF
10 µF
22 µF
47 µF
Table 3 Sizes from 0603 to 0805
CAP.
0603
6.3 V
0805
10 V
16 V
25 V
50 V
10 nF
0.8± 0.1
22 nF
47 nF
6.3 V
10 V
16 V
25 V
50 V
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
100 nF
0.8± 0.1
0.8± 0.1
220 nF
0.8± 0.1
0.8± 0.1
0.6± 0.1 0.85± 0.1 0.85± 0.1
470 nF
0.8± 0.1
0.8± 0.1
0.85± 0.1 0.85± 0.1 0.85± 0.1
1.0 µF
0.8± 0.1
0.8± 0.1
0.8± 0.1
2.2 µF
0.8± 0.1
0.8± 0.1
0.8± 0.1
4.7 µF
0.8± 0.1
0.85± 0.1 0.85± 0.1 1.25± 0.2
0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2
10 µF
1.25± 0.2 1.25± 0.2
22 µF
1.25± 0.2 1.25± 0.2
47 µF
NOTE
1. Values in shaded cells indicate thickness class in mm
2. Capacitance value of non E-3 series is on request
www.yageo.com
Mar. 07, 2017 V.8
Table 4 Sizes from 1206 to 1210
1206
CAP.
6.3 V
10 V
16 V
50 V
10 nF
0.6± 0.1
0.6± 0.1
22 nF
0.6± 0.1
0.6± 0.1
47 nF
0.6± 0.1
0.6± 0.1
100 nF
0.6± 0.1
0.6± 0.1
220 nF
0.6± 0.1
0.6± 0.1
470 nF
0.85± 0.1
0.85± 0.1
1.0 µF
0.85± 0.1
0.85± 0.1
0.85± 0.1
4.7 µF
0.85± 0.1
0.85± 0.1
10 µF
0.85± 0.1
0.85± 0.1
1.15± 0.1
22 µF
1.6± 0.2
1.6± 0.2
1.6± 0.2
Y5V
6.3 V to 50 V
5
13
1210
25 V
2.2 µF
6.3 V
10 V
16 V
25 V
50V
1.5± 0.1
1.5± 0.1
1.5± 0.1
1.5± 0.1
1.5± 0.1
1.6± 0.2
1.6± 0.2
1.6± 0.2
0.85± 0.1
1.6± 0.2
47 µF
NOTE
www.yageo.com
Mar. 07, 2017 V.8
Y5V
6.3 V to 50 V
6
13
THICKNESS CLASSES AND PACKING QUANTITY
Table 5
SIZE
CODE
THICKNESS
CLASSIFICATION
TAPE WIDTH
QUANTITY PER REEL
0201
0.3 ± 0.03 mm
0402
0603
0805
1206
Ø 180 MM / 7 INCH
Ø 330 MM / 13 INCH
Paper
Blister
Paper
Blister
QUANTITY
PER BULK CASE
8 mm
15,000
50,000
0.5 ± 0.05 mm
8 mm
10,000
50,000
50,000
0.8 ± 0.1 mm
8 mm
4,000
15,000
15,000
0.6 ± 0.1 mm
8 mm
4,000
20,000
10,000
0.85 ± 0.1 mm
8 mm
4,000
15,000
8,000
1.25 ± 0.2 mm
8 mm
3,000
10,000
5,000
0.6 ± 0.1 mm
8 mm
4,000
20,000
0.85 ± 0.1 mm
8 mm
4,000
15,000
1.00 / 1.15 ± 0.1 mm
8 mm
3,000
10,000
1.25 ± 0.2 mm
8 mm
3,000
10,000
1.6 ± 0.15 mm
8 mm
2,500
10,000
1.6 ± 0.2 mm
8 mm
2,000
10,000
0.6 / 0.7 ± 0.1 mm
8 mm
4,000
15,000
0.85 ± 0.1 mm
8 mm
4,000
10,000
1.15 ± 0.1 mm
8 mm
3,000
10,000
1.15 ± 0.15 mm
8 mm
3,000
10,000
1.25 ± 0.2 mm
8 mm
3,000
1210
1.5 ± 0.1 mm
8 mm
2,000
1.6 / 1.9 ± 0.2 mm
8 mm
2,000
2.0 ± 0.2 mm
8 mm
2,000
1,000
2.5 ± 0.2 mm
8 mm
1,000
500
www.yageo.com
Mar. 07, 2017 V.8
Y5V
7
13
6.3 V to 50 V
ELECTRICAL CHARACTERISTICS
Y5V DIELECTRIC CAPACITORS; NISN TERMINATIONS
Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions
for testing as given in 5.3 of IEC 60068-1:
- Temperature: 15 °C to 35 °C
- Relative humidity: 25% to 75%
- Air pressure: 86 kPa to 106 kPa
Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time
sufficient to allow the entire capacitor to reach this temperature.
The period as prescribed for recovery at the end of a test is normally sufficient for this purpose.
Table 6
VALUE
DESCRIPTION
Capacitance range
10 nF to 22 µF
± 20%
Capacitance tolerance
–20% to +80%
Dissipation factor (D.F.)
≤ 6.3 V
≤ 15%
Exception: 0805 ≥ 22 µF
≤ 20%
10 V
≤ 12.5%
Exception: 0402 ≥ 680 nF; 0603 ≥ 2.2 µF;
0805 ≥ 10 µF;
16 V
1206 ≥ 10 µF
≤ 15%
≤ 20%
≤ 12.5%
Exception: 0603 ≥ 4.7 µF
≥ 25 V
≤ 15%
≤ 9%
Exception: 0201 ≥ 10 nF
Insulation resistance after 1 minute at Ur (DC)
≤ 12.5%
Rins ≥ 10 GΩ or Rins × Cr ≥ 500 seconds whichever is less
Maximum capacitance change as a function of temperature
(temperature characteristic/coefficient):
Operating temperature range:
+22% to –82%
–30 °C to +85 °C
www.yageo.com
Mar. 07, 2017 V.8
Fig. 3
Typical capacitance change as a function of
temperature
Fig. 5
Typical tan δ as a function of temperature
Fig. 4
Y5V
6.3 V to 50 V
8
13
Typical capacitance change with respect to the
capacitance at 1 V as a function of DC voltage at
20 °C
SOLDERING RECOMMENDATION
Table 7
SOLDERING
METHOD
Reflow
Reflow/Wave
SIZE
0201
0402
0603
0805
1206
≥ 1210
Reflow only
> 100 nF
> 1.0 µF
> 2.2 µF
> 2.2 µF
Reflow only
≤ 100 nF
≤ 1.0 µF
≤ 2.2 µF
≤ 2.2 µF
www.yageo.com
Mar. 07, 2017 V.8
Y5V
6.3 V to 50 V
9
13
TESTS AND REQUIREMENTS
Table 8
Test procedures and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Mounting
IEC 60384- 4.3
21/22
The capacitors may be mounted on printed-circuit boards or
ceramic substrates
No visible damage
Visual
inspection and
dimension
check
4.4
Any applicable method using × 10 magnification
In accordance with specification
Capacitance (1)
4.5.1
Class 2:
At 20 °C, 24 hrs after annealing
Within specified tolerance
f = 1 KHz for C ≤ 10 µF, rated voltage > 6.3 V, measuring at
voltage 1 Vrms at 20 °C
f = 1 KHz, for C ≤ 10 µF, rated voltage ≤ 6.3 V, measuring at
voltage 0.5 Vrms at 20 °C
f = 120 Hz for C > 10 µF, measuring at voltage 0.5 Vrms at 20 °C
Dissipation
factor (D.F.) (1)
4.5.2
Class 2:
Insulation
resistance
4.5.3
At Ur (DC) for 1 minute
Temperature
characteristic
4.6
Class 2:
Between minimum and maximum temperature
Y5V: -30 °C to +85 °C
Normal Temperature: 20 °C
∆C/C
Class 2:
Y5V: 22% to -82%
∆C/C
Class 2:
Y5V: 22% to -82%
Adhesion
4.7
A force applied for 10 seconds to the line joining the terminations Force
and in a plane parallel to the substrate
size ≥ 0603: 5N
size = 0402: 2.5N
size = 0201: 1N
NOTE:
1. For individual product specification, please contact local sales.
www.yageo.com
Mar. 07, 2017 V.8
Y5V
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Bending
IEC 6038421/22
Mounting in accordance with IEC 60384-22
paragraph 4.3
No visible damage
Conditions: bending 1 mm at a rate of 1 mm/s,
radius jig 5 mm
strength
4.8
6.3 V to 50 V
10
13
∆C/C
Class2:
Y5V: ± 10%
∆C/C
Class2:
Y5V: ± 10%
Resistance to
soldering heat
4.9
Precondition: 150 +0/–10 °C for 1 hour, then keep
for 24 ± 1 hours at room temperature
Preheating: for size ≤ 1206: 120 °C to 150 °C for 1
minute
Preheating: for size >1206: 100 °C to 120 °C for 1
minute and 170 °C to 200 °C for 1 minute
Solder bath temperature: 260 ± 5 °C
Dipping time: 10 ± 0.5 seconds
Recovery time: 24 ± 2 hours
Dissolution of the end face plating shall not
exceed 25% of the length of the edge
concerned
∆C/C
Class2:
Y5V: ± 20%
∆C/C
Class2:
Y5V: ± 20%
D.F. within initial specified value
Rins within initial specified value
Solderability
4.10
Preheated the temperature of 80 °C to 140 °C and
maintained for 30 seconds to 60 seconds.
The solder should cover over 95% of the
critical area of each termination
1. Temperature: 235± 5°C / Dipping time: 2 ± 0.5 s
2. Temperature: 245± 5°C / Dipping time: 3 ± 0.5 s
(lead free)
Depth of immersion: 10mm
www.yageo.com
Mar. 07, 2017 V.8
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Rapid change
of
temperature
IEC 6038421/22
Preconditioning;
150 +0/–10 °C for 1 hour, then keep for
No visual damage
4.11
Y5V
6.3 V to 50 V
11
13
∆C/C
5 cycles with following detail:
30 minutes at lower category temperature
30 minutes at upper category temperature
Class2:
Y5V: ± 20%
Recovery time 24 ± 2 hours
∆C/C
Class2:
Y5V: ± 20%
D.F. meet initial specified value
Rins meet initial specified value
Damp heat
with Ur load
4.13
1. Preconditioning, class 2 only:
150 +0/-10 °C /1 hour, then keep for
24 ± 1 hour at room temp
2. Initial measure:
Spec: refer initial spec C, D, IR
3. Damp heat test:
500 ± 12 hours at 40 ± 2 °C;
90 to 95% R.H. 1.0 Ur applied
4. Recovery:
Class 2: 24 ± 2 hours
5. Final measure: C, D, IR
P.S. If the capacitance value is less than the
minimum value permitted, then after the other
measurements have been made the capacitor shall
be precondition according to “IEC 60384 4.1” and
then the requirement shall be met.
No visual damage after recovery
∆C/C
Class2:
Y5V: ± 30%
D.F.
Class2:
Y5V: ≤ 15%
Rins
Class2:
Y5V: ≥ 500 MΩ or Rins x Cr ≥ 25s
whichever is less
∆C/C
Class2:
Y5V: ± 30%
D.F.
Class2:
Y5V: 2 x initial value max
Rins
Class2:
Y5V: 500 MΩ or Rins x Cr ≥ 25s
whichever is less
www.yageo.com
Mar. 07, 2017 V.8
Y5V
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Endurance
IEC 6038421/22
No visual damage
4.14
2. Initial measure:
3. Endurance test:
Temperature: Y5V: 85 °C
Specified stress voltage applied for 1,000 hours:
Applied 2.0 x Ur for general product.
Applied 1.5 x Ur for high cap. product.
4. Recovery time: 24 ± 2 hours
P.S. If the capacitance value is less than the minimum
value permitted, then after the other measurements
have been made the capacitor shall be precondition
according to “IEC 60384 4.1” and then the
6.3 V to 50 V
12
13
∆C/C
Class2:
Y5V: ± 30%
D.F.
Class2:
Y5V: ≤ 15%
Rins
Class2:
Y5V: ≥ 1,000 MΩ or Rins x Cr ≥ 50s
whichever is less
∆C/C
Class 2:
Y5V: ± 30%
D.F.
Class 2:
Rins
Class 2:
Y5V: 1,000 MΩ or Rins x Cr ≥ 50s
whichever is less
Voltage proof
IEC 60384-1 4.6
Specified stress voltage applied for 1~5 seconds
No breakdown or flashover
Ur ≤ 100 V: series applied 2.5 Ur
Charge/Discharge current is less than 50 mA
www.yageo.com
Mar. 07, 2017 V.8
Y5V
6.3 V to 50 V
13
13
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 8
Mar. 7, 2017
- 0805 L4 spec updated
Version 7
Dec. 9, 2016
- Soldering recommendation update
Version 6
Jan. 12, 2016
- Update capacitance range & thickness
Version 5
Jul 29, 2010
- Modify the last 2-digit of 12NC
Version 4
Jun 24, 2010
- Dimension on 1206 case size updated
Version 3
Apr 22, 2010
- Dimension updated
Version 2
Feb 04, 2010
- The statement of "Halogen Free" on the cover added
Version 1
Nov 04, 2009
- Ordering code updated
- Dimension updated
Version 0
Apr 15, 2009
- New datasheet for general purpose and high capacitance Y5V series with
RoHS compliant
- Replace the "6.3V to 50V" part of pdf files: Y5V_6.3V_10V_9_Preliminary,
Y5V_10V-to-50V_10_Preliminary, Y5V_16V_25V_50V_11
- Combine 0201 from pdf files: UP-NP0X5RX7RY5V_0201_6.3-to-50V_2
and UY-NPOX5RX7RY5V_0201_6.3-to-50V_2
- Define global part number
- Description of "Halogen Free compliant" added
- Test method and procedure updated
www.yageo.com
Mar. 07, 2017 V.8
