293-344-30
293-344-30
    MITUTOYO(三丰)
    1 RAT THIM MICROMETER (W/O SPC)
293-344-30 数据手册
Coolant Proof Micrometers MDC-MX Series Twice as Long Battery Life and Drastic Improvement in Measurement Efficiency Small Tool Instruments and Data Management Bulletin No. 2145 Coolant Proof Micrometers MDC-MX Series Twice as Long Battery Life as before and Drastic Improvement in Measurement Efficiency View the MDC C Proof Micrometer www.mitutoyo.co • Approximately 2.4-year span of battery life • Newly-improved nonslip surface with raised dots • Ratchet thimble type* * Refer to the "SPECIFICATIONS" section on page 4. • Oilproof material employed for plastic parts • Compatibility with statistical process control and measurement systems 1 Coolant r in Action Digital micrometer standard type Ratchet Thimble type that has improved operability with one hand om/mdc Plain Function, Simple design 2 Coolant Proof Micrometers Digital micrometer standard type 293-333-30 293-331-30 293-330-30 • Approximately 2.4-year span of battery life has been achieved, thus reducing the inconvenience of replacing the battery. • A nonslip surface with raised dots is employed for the frame cover and surface panel to achieve stable handhold measurement. • The ratchet thimble mechanism helps to ensure repeatable results by transmitting microvibrations along the spindle to the contact face to provide a constant measuring force and encourage good contact with the workpiece. The ratchet works from the thimble as well as the speeder so it is always easy to use – even when making measurements onehanded. The sound of the ratchet provides the user with a sense of confidence and the speeder enables the rapid spindle feed needed when measuring widely different dimensions. • Oilproof materials are used in all plastic components. • Two types of constant-force devices are available: Ratchet Stop and Ratchet Thimble. 3 293-332-30 Employed nonslip surface with raised dots Ratchet Thimble type that has improved operability with one hand 293-335-30 Ratchet Thimble Ratchet thimble Improved operability with one hand Speeder シンブ ル ラチェ 部 ット SPECIFICATIONS スピー ダ ラチェ 部 ット Metric With SPC data output Without SPC data output Order No. 293-230-30 293-231-30 293-232-30 293-233-30 293-234-30 293-235-30 293-236-30 293-237-30 293-240-30 293-241-30 293-242-30 293-243-30 293-244-30 293-245-30 293-246-30 293-247-30 Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 0 - 25mm 25 - 50mm 50-75mm 75-100mm 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 0 - 25mm 25 - 50mm 50-75mm 75-100mm Micrometer Set Metric Range Order No. 0-50mm (2pcs. Set) 293-966-30 0-75mm (3pcs. Set) 293-962-30 0-100mm (4pcs. Set) 293-963-30 Accuracy ±1μm ±2μm ±1μm ±2μm ±1μm ±2μm ±1μm ±2μm Parallelism Measuring force constant-force device 5 - 10N With ratchet stop 7 - 12N* With ratchet thimble 5 - 10N With ratchet stop 7 - 12N* With ratchet thimble 1μm 2μm 1μm 2μm 1μm 2μm 1μm 2μm Mass 270g 330g 470g 625g 280g 340g 480g 635g 270g 330g 470g 625g 280g 340g 480g 635g www.tuv.com ID 0000040191 Included in set 293-230-30, 293-231-30, 25mm CERA block, plastic case 293-230-30, 293-231-30, 293-232-30, 2 standard bars, plastic case 293-230-30, 293-231-30, 293-232-30, 293-233-30, 3 standard bars, wooden box These marks indicate that a product has successfully passed IP65-level testing, which is carried out by the independent German certification organization TUV Rheinland. Inch/Metric Order No. Range Accuracy Parallelism Measuring force constant-force device 293-330-30 0-1" .00004" 293-331-30 1-2" ±.00005" 5-10N With ratchet stop 293-332-30 2-3" With SPC .00008" 293-333-30 3-4" ±.0001" data output 293-334-30 0-1" 7-12N* With ratchet thimble 293-335-30 0-1" ±.00005" .00004" 5-10N With friction thimble 293-336-30 1-2" 293-340-30 0-1" .00004" 293-341-30 1-2" ±.00005" 5-10N With ratchet stop 293-342-30 2-3" .00008" 293-343-30 3-4" ±.0001" Without SPC 293-344-30 0-1" .00004" 293-345-30 1-2" ±.00005" data output 7-12N* With ratchet thimble 293-346-30 2-3" .00008" 293-347-30 3-4" ±.0001" 293-348-30 ±.00005" 5 - 10N With friction thimble 0-1" .00004" 293-349-30 ±.0001" 7 - 12N* With ratchet thimble * Measuring force in the case of using the Speeder ratchet Prior to measurement, apply a measuring force in the same condition to align the index line with the thimble zero line. Inch/Metric An inspection certificate is supplied as standard. (50mm/2" or less range model) Mass 270g 330g 470g 625g 280g 275g 335g 270g 330g 470g 625g 280g 340g 480g 635g 275g 280g Micrometer Set .00005" / 0.001mm graduation model Range Order No. Included in set 0 - 3” / 0 - 76.2mm (3 pcs. set) 293-960-30 293-330-30, 293-331-30, 293-332-30, 2 standard bars, plastic case 0 - 4" / 0 -101.6mm (4 pcs. set) 293-961-30 293-330-30, 293-331-30, 293-332-30, 293-333-30, 3 standard bars, wooden box 4 IP Codes Level 6: Dust-proof. No ingress of dust allowed. Level 5: Protected against water jets. Water projected in jets against the enclosure from any direction shall have no harmful effects. Technical Data • Resolution: .00005"/0.001mm • Quantizing error: ±1 is not included. • Flatness: .000012"/ 0.3 μm • Dust/water protection level: IP65 (IEC60529) *2 • Measuring system: Electromagnetic induction type rotary sensor • Battery: SR44 (1 pc), 938882, for initial operational checks (standard accessory) • Battery life: Approx. 2.4 years under normal use • Standard accessories: Reference bar, 1 pc (except for 0-25mm (0-1”) models) Spanner (301336), 1 pc *2 Rustproofing shall be applied after use. Coolant Proof Micrometers Optional accessories Functions (Only for models with data output function) • Origin point setting (ABS measurement system) Resets the ABS origin at the current spindle position to the minimum value of the measuring range and switches to ABS mode. • Zero-setting (INC measurement system) A brief press on the ZERO/ABS button sets display to zero at the current spindle position and switches to the incremental (INC) measuring mode. A longer press resets to the ABS measuring mode. • Hold: Printer Digimatic mini-processor DP1-VR Connecting cables with output switch 05CZA662 SPC cable w/data switch 40"(1m) 05CZA663 SPC cable w/data switch 80"(2m) Pressing the HOLD button freezes the current value in the display. This function is useful for preserving a measurement in situations of poor visibility where the instrument must be moved away from the workpiece before the reading can be recorded. • Data output*4: Models equipped with this function have an output port for transferring measurement data to a Statistical Process Control (SPC) system. *4: Only models with the data output function • Auto power ON/OFF: The reading on the LCD disappears after this instrument is idle for about 20 minutes, but the reading and measurement mode are retained. Turning the spindle causes the reading to reappear. • Error alarm: In case of an overflow on the LCD or a computing error, an error message appears on the LCD, and the measuring function stops. This prevents an instrument from giving an erroneous reading. Also, when the battery voltage drops to a certain level, the low-battery-voltage alarm annunciator appears well before the micrometer becomes unusable. • Function lock*5: This function allows the ORIGIN (origin point setting) function and the ZERO (zero-setting ) function to be locked to prevent these points being reset accidentally. *5: All-digit preset type only USB Input Tool Direct USB-ITN-B: 06ADV380B (2m) Wireless interface: 02AZD730D U-WAVE transmitter IP67 type 02AZD880D U-WAVE transmitter buzzer type 02AZD810D U-WAVE receiver 02AZD790B U-WAVE connecting cable 02AZE140B Connecting cable for footswitch DIMENSIONS a a e 25 32 47 60 f 9 9.8 12.6 14 e 25 32 47 60 f 9 9.8 12.6 14 e ø6.35 e a Ratchet stop Range 0-25mm 25-50mm 50-75mm 75-100mm L 0 25 50 75 2.5 48.5 62.9 62.9 Ratchet thimble type 63.6 63.6 Range 0-25mm 25-50mm 50-75mm 75-100mm L 0 25 50 75 a 2.5 ø19.3 Ratchet thimble 5 Unit: mm 10.8 2 48.5 10.8 25 2 ø18 L 25 ø19.3 f L ø18 Ratchet stop type f ø6.35 Digimatic outside micrometers Plain Function, Simple design SPECIFICATIONS • Approximately 2.4-year span of battery life has been achieved, thus reducing the inconvenience of replacing the battery. • Simple design, such as not incorporating data output, achieves low cost. • Provided only with an origin-set button for easy origin setting. • Two types of constant-force devices are available: Ratchet Stop and Friction Thimble. Metric Order No. 293-821-30 Range 0-25mm Resolution Accuracy constant-force device With ratchet thimble 270g Range Resolution Accuracy 0-1" .00005"/0.001mm ±.0001" constant-force device With ratchet thimble With friction thimble Mass 270g 275g 0.001mm ±2μm Mass Inch/Metric Order No. 293-831-30 293-832-30 Technical Data • Measuring force: 5 -10N • Quantizing error: ±1 is not included. • Measuring system: Electromagnetic induction type rotary sensor • Battery: SR44 (1 pc), 938882, for initial operational checks (standard accessory) • Battery life: Approx. 2.4 years under normal use 293-832-30 An inspection certificate is supplied as standard. DIMENSIONS Unit: mm 25 2 48.5 63 ø18 2.5 ø6.35 26 9 6 10.8 Ratchet stop type Coolant Proof Micrometers MDC-MX Series One Number to Serve You Better 1-888-MITUTOYO (1-888-648-8869) Aurora, Illinois (Corporate Headquarters) Note: All information regarding our products, and in particular the illustrations, drawings, dimensional and performance data contained in this printed matter as well as other technical data are to be regarded as approximate average values. We therefore reserve the right to make changes to the corresponding designs. The stated standards, similar technical regulations, descriptions and illustrations of the products were valid at the time of printing. In addition, the latest applicable version of our General Trading Conditions will apply. Only quotations submitted by ourselves may be regarded as definitive. Mitutoyo products are subject to US Export Administration Regulations (EAR). Re-export or relocation of our products may require prior approval by an appropriate governing authority. Trademarks and Registrations Designations used by companies to distinguish their products are often claimed as trademarks. In all instances where Mitutoyo America Corporation is aware of a claim, the product names appear in initial capital or all capital letters. The appropriate companies should be contacted for more complete trademark and registration information. © 2014 Mitutoyo America Corporation, Aurora IL 2M 0514-04 Printed in USA, August 2014 Westford, Massachusetts Huntersville, North Carolina Mason, Ohio Plymouth, Michigan City of Industry, California Birmingham, Alabama Renton, Washington Houston, Texas
293-344-30 价格&库存
很抱歉,暂时无法提供与“293-344-30”相匹配的价格&库存,您可以联系我们找货
