2109S-10
2109S-10
    MITUTOYO(三丰)
2109S-10 数据手册
Bulletin No. 1635-2G Dial Gage 2109S-10 Indicator (JIS/ISO Standard) New Dial Indicator The new workhorse of dial indicators is now available, with increased enviromental resistance, increased resistance to shock and a more rigid spindle. Mitutoyo’s Dial Gage 2109S-10 now offers users more stability and longer life, thanks to advances to the inner workings of the rack and pinion gear system. Shock resistance is increased with a more robust gear train, while contamination resistance has been dramatically increased over other indicators of this type with a tighter seal around the bezel and frame, and the elimination of a lifting lever screw. A long slot in the lifting lever makes the contact point for the lift a straight line, creating a smoother lifting action and leading to longer operational life. A flat crystal allows easier reading, and jeweled bearings inside provide longer, more accurate life. The contact point becomes a straight line for smoother operation. Specifications Order No. Graduation Total Range Range Per Rev. Dial Reading Accuracy Measuring Face 2109S-10 0.001mm 1mm 0.2mm 0-100-0 ±0.005mm 1.5N or less Distributed By: www.mitutoyo.com Mitutoyo America Corporation Regional Offices © 2003 Mitutoyo America Corporation, Aurora IL Michigan Phone: (734) 459-2810 Illinois Phone: (630) 978-5385 California Phone: (626) 961-9661 Massachusetts Phone: (978) 692-8765 Indiana Phone: (317) 577-6070 North Carolina Phone: (704) 875-8332 We reserve the right to change specifications and prices without notice. 2B-10 • Printed in USA • March 2003
2109S-10 价格&库存
很抱歉,暂时无法提供与“2109S-10”相匹配的价格&库存,您可以联系我们找货
