293-185
293-185
    MITUTOYO(三丰)
293-185 数据手册
Small Tool Instruments and Data Management Coolant Proof Micrometer QuantuMike Pioneering design, means taking the lead Bulletin No. 1930 Rapid measurement is achieved thanks to 2 mm* of spindle feed for every thimble revolution! * l Patent registered (in USA) l Patent pending (in Japan, Europe, and China) Coolant proof micrometer Debut of next-generation micrometer delivering thanks to integration of cutting-edge technology Coolant proof micrometer Mitutoyo is proud to have reached its leading position in the micrometer market through a spirit of innovation, imagination and creating added value. The QuantuMike brand of micrometer, inspired by this Mitutoyo Spirit, provides users with an excellent measuring experience with higher speed, quality and stability than ever before owing to the integration of sophisticated manufacturing and processing technologies. The name QuantuMike is from Quantum and Micrometer, reflecting our belief this tool represents a quantum leap in micrometer ergonomics. The new global standard ······ QuantuMike Evolution since the innovation by James Watt in 17 History of micrometer advancement  1772 1937 Micrometer invented by James Watt (UK) Mitutoyo success in manufacturing micrometers performance far beyond users’ expectations y Rapid measurement Faster measurement is achieved by using a coarser thread which feeds the spindle by 2mm per revolution of the thimble instead of the standard 0.5mm. This increase in thread lead has been made possible thanks to new high precision thread-cutting and test techniques. Trials show that a reduction in positioning times of 60% and measuring times of 35%* can be obtained, compared with a conventional micrometer. * According to Mitutoyo's comparison test data for measuring time on typical workpieces. Spindle feed per revolution 1 revolution of thimble Conventional model (MDC) QuantuMike Comparison of measuring time on a stepped workpiece 0.5mm 2.0mm n Significant reduction in positioning time Time needed to measure a multi-stepped cylindrical workpiece (with one hand) Time [s] 60 The time needed to measure 6 diameters on a workpiece, from the smallest to the largest with the micrometer held in one hand, was recorded for a conventional digital micrometer and for the QuantuMike 53 sec. 50 ■ ■ Positioning time ■ ■ Measuring time 40 41 sec. 30 22 sec. 20 10 sec. 10 12 sec. 12 sec. Conventional model QuantuMike 0 772 1971 1979 2003 Starting production of digital outside micrometers Starting production of Digimatic micrometers Development of coolant proof micrometers with IP65 protection  2007 Useful application of measured data Repeatable measurement* The patented ratchet thimble mechanism* helps ensure repeatable results by transmitting microvibrations along the spindle to the contact face to provide a constant measuring force and encourage good contact with the workpiece. The ratchet works from the thimble as well as the speeder so it is always easy to use - even when making measurements one-handed. The sound of the ratchet provides the user with a sense of confidence and the speeder enables the rapid spindle feed needed when measuring widely different dimensions. A statistical process control system and a measurement network system can be established to share quality information with a model equipped for data output. Dust/water resistance with IP65 protection level Excellent resistance against oil, water and dust enables this product to be used in machining situations that include splashing coolant fluid. *• Patent registered (in USA) Category Protection against human contact and foreign bodies Protection against water • Patent pending (in Japan, Europe, and China) Ratchet on thimble Ratchet on speeder Ratchet-induced microvibrations along the spindle help ensure repeatable measurements スピーダ部 ラチェット QuantuMike is equipped with a function lock feature to prevent the origin point being moved by mistake during measurement. Function lock ±1μm/±.00005” accuracy Measurements are made to an accuracy* of ±1um/.00005” throughout the range. *Quantization error of ±1 count excluded Graduated sleeve provides confidence check A graduated scale is provided on the sleeve for use with a reference mark on the thimble so that every millimeter displacement can be checked to provide extra confidence. Reference mark mm 5: Protection against water Description Protection against ingress of dust, complete protection against contact Water jets*1 directed at the enclosure from any direction must not have any harmful effects. *1: A jet nozzle with an inside diameter of 6.3 mm directs a volume flow of 12.5 liters per minute from a distance of approximately 3 meters onto the enclosure. The test time is 3 minutes or more. Function lock helps prevent error シンブル部 ラチェット Level 6: Sealed against dust Reference mark inch/mm  n Certificate of inspection attached • A Certificate of Inspection is supplied with each instrument shipped that guarantees the quality of the product. Please note that this certificate cannot be used to obtain a Certificate of Calibration because the purchase date cannot be specified. • Please let us know if a Certificate of Calibration is required when ordering a micrometer. This certificate is supplied, for a fee, and certifies the traceability of the purchased instrument and of the standard that was used to calibrate that instrument. • Certificates of inspection and calibration are issued after processing each instrument by special measuring equipment, developed using Mitutoyo’s advanced measuring technologies, which feature very small uncertainties of measurement. SPC Data Output 293-140 (mm) SPC Data Output 293-141 (mm) SPC Data Output 293-180 (inch/mm) SPC Data Output 293-181 (inch/mm)  n Common specifications Functions n Functions Origin point setting (ABS length measurement system) Zero setting (INC length measurement system) Hold Function lock Auto power ON/OFF Data output *1 Error alarm IP65 (IEC60529)*2 7-12N Degree of protection Measuring force Power supply Position detection system Battery life Standard accessories Origin point setting (ABS length measurement system) Zero setting (INC length measurement system) Hold Button type silver oxide battery (SR44), 1 piece Electromagnetic rotary sensor *3 Approx. 3 years under normal conditions Reference bar, 1 piece (not for 0-25mm models) Button type silver oxide battery (SR44, No. 938882), 1 piece Spanner (No. 301336), 1 piece Function lock Auto power ON/OFF *1: Applicable only to 293-140/293-141/293-180/293-181 *2: This product is not waterproof. Rustproofing shall be applied after use. *3: Patent registered (in USA), Patent pending (in Japan, Europe, and China) Data output n Dimensions 27 48.5 3 37.5 23.1 A brief press on the ZERO/ABS button sets display to zero at the current spindle position and switches to the incremental (INC) measuring mode. A longer press resets to the ABS measuring mode. Pressing the HOLD button freezes the current value in the display. This function is useful for preserving a measurement in situations of poor visibility when the instrument must be moved away from the workpiece before the reading can be recorded. A second press unfreezes the display ready for another measurement. This function allows the ORIGIN (origin point setting) function and the ZERO (zero setting) function to be locked to prevent these points being reset accidentally. The reading on the LCD disappears after this instrument is idle for approx. 20 minutes, but the origin point is retained. Turning the spindle causes the reading on the LCD to reappear. Models equipped with this function have an output port for transferring measurement data to a Statistical Process Control (SPC) system. In case of an overflow on the LCD or a computing error, an error message appears on the LCD, and the measuring function stops. This prevents an instrument from giving an erroneous reading. Also, when the battery voltage drops to a certain level the low-battery-voltage alarm annunciator appears well before the micrometer becomes unusable. 19.3 6.35 L 2.8 b a Error alarm Pressing the ORIGIN button resets the ABS origin at the current spindle position. Unit: mm 0-25mm (0-1”) range model 0-25mm (0-1”) 25-50mm (1-2”)* L 0 25 (25.4)* a 9 9.8 b 25 32 n Selective specifications Order No. SPC data output Without SPC data output SPC data output Without SPC data output 293-140 293-141 Measuring range 0-25mm 25-50mm 293-145 293-146 293-180 293-181 293-185 293-186 0-25mm 25-50mm 0-1”/0-25mm 1-2”/25-50mm 0-1”/0-25mm 1-2”/25-50mm Resolution Instrumental error* 0.001mm Flatness of measuring faces Parallelism of measuring faces 265g 325g ±1μm 0.3μm or less .00005”/0.001mm *Quantization error of ±1 count excluded  ±.00005”/±1µm Weight 1μm or less 265g 325g 265g 325g 265g 325g n Optional accessories (Only for models with SPC data output function) • Input tool (signal conversion) • Connection cable with output switch No.05CZA662=1m No.05CZA663=2m No. 264-005 (Keyboard) No. 264-012-10 (USB) • Digimatic mini processor, DP-1VR No.264-504-5A (Data processor for quality control) MIG-4A MIG-2B 982-548-10A Front view n Optional accessories • Color speeder sleeve Color speeder sleeves in black, red, yellow, green, blue, and gray are available for measuring management. Color Black Red Yellow Green Blue Product No. No.04GAA899* No.04GAA900 No.04GAA901 No.04GAA902 Gray No.04AAB208 No. 264-007 (RS-232C) No.04GAA903 * Standard  982-547-10A Front view Coordinate Measuring Machines Vision Measuring Systems Our products are classified as regulated items under JapaneseForm ForeignMeasurement Exchange and Foreign Trade Law. Please consult us in advance if you wish to export our Optical products to any Measuring other country. If the purchased product is exported, even though it is not a regulated item (Catch-All item), the customer service Sensorcontrols Systems available for that product may be affected. If you have any questions, consult your local Mitutoyo sales Test please Equipment and office. Seismometers Digital Scale and DRO Systems Small Tool Instruments and Data Management Coordinate Measuring Machines Vision Measuring Systems Form Measurement Mitutoyo America Corporation www.mitutoyo.com Optical Measuring One Number to Serve You Better 1-888-MITUTOYO (1-888-648-8869) Sensor Systems Test Equipment and M3 Solution Centers Seismometers Digital Scale and DRO Systems Small Tool Instruments and Data Management Note: All information regarding our products, and in particular the illustrations, drawings, dimensional and performance data contained in this printed matter as well as other technical data are to be regarded as approximate average values. We therefore reserve the right to make changes to the corresponding designs. The stated standards, similar technical regulations, descriptions and illustrations of the products were valid at the time of printing. In addition, the latest applicable version of our General Trading Conditions will apply. Only quotations submitted by ourselves may be regarded as definitive. Mitutoyo products are subject to US Export Administration Regulations (EAR). Re-export or relocation of Mitutoyo products may require prior approval by an appropriate governing authority. Trademarks and Registrations Designations used by companies to distinguish their products are often claimed as trademarks. In all instances where Mitutoyo America Corporation is aware of a claim, the product names appear in initial capital or all capital letters. The appropriate companies should be contacted for more complete trademark and registration information. Note: All information regarding our products, and in particular the illustrations, drawings, dimensional and performance data contained in this pamphlet, as well as other We reserve the right to change specifications and prices without notice. technical data are to be regarded as approximate average values. We therefore reserve the right to make changes to the corresponding designs, dimensions and weights. The stated standards, similar technical regulations, descriptions and illustrations of the products were valid at the time of printing. Only quotations submitted by ourselves may be regarded as definitive. Our products are classified as regulated items under Japanese consult usPrinted in advance if you wish © 2008 Mitutoyo America Corporation, Aurora IL Foreign Exchange and Foreign Trade Law. Please 0108-05 in USA, Jan. to export our products to any other country. If the purchased product is exported, even though it is not a regulated item (Catch-All controls item), the customer service available for that product may be affected. If you have any questions, please consult your local Mitutoyo sales office. Mitutoyo Corporation 20-1, Sakado 1-Chome, Takatsu-ku, Kawasaki-shi, Kanagawa 213-8533, Japan T +81 (0) 44 813-8230 F +81 (0) 44 813-8231 http://www.mitutoyo.co.jp 2008 Precision is our Profession
293-185 价格&库存
很抱歉,暂时无法提供与“293-185”相匹配的价格&库存,您可以联系我们找货
