103-137
103-137
    MITUTOYO(三丰)
    日本三丰 外径千分尺 129 138螺旋测微仪器0-25MM 机械103-137 0-25MM
103-137 数据手册
Micrometers SERIES 103 – Economy Micrometer • Baked-enamel-finished frame. • Measuring faces: Carbide. Technical Data • Equipped with Ratchet Stop for constant measuring force. Flatness: Parallelism*: 0.6 μm / .000024" for models up to 300 mm  / 12", 1 µm  / 00004" for models over 300 mm / 12" (2+R/100) µm / [.00008+.00004 (R/4)]" * R = max. range (mm/inch) Note: Fractions rounded down B 103-137 SPECIFICATIONS Metric Code No. Range With ratchet stop 103-137 0 - 25 mm 103-129 103-138 25 - 50 mm 103-130 103-139-10 50 - 75 mm 103-140-10 75 - 100 mm 103-141-10 100 - 125 mm 103-142-10 125 - 150 mm 103-143-10 150 - 175 mm 103-144-10 175 - 200 mm 103-145-10 200 - 225 mm 103-146-10 225 - 250 mm 103-147-10 250 - 275 mm 103-148-10 275 - 300 mm 103-149 300 - 325 mm 103-150 325 - 350 mm 103-151 350 - 375 mm 103-152 375 - 400 mm 103-153 400 - 425 mm 103-154 425 - 450 mm 103-155 450 - 475 mm 103-156 475 - 500 mm 103-157 500 - 525 mm 103-158 525 - 550 mm 103-159 550 - 575 mm 103-160 575 - 600 mm 103-161 600 - 625 mm 103-162 625 - 650 mm 103-163 650 - 675 mm 103-164 675 - 700 mm 103-165 700 - 725 mm 103-166 725 - 750 mm 103-167 750 - 775 mm 103-168 775 - 800 mm 103-169 800 - 825 mm 103-170 825 - 850 mm 103-171 850 - 875 mm 103-172 875 - 900 mm 103-173 900 - 925 mm 103-174 925 - 950 mm 103-175 950 - 975 mm 103-176 975 - 1000 mm Inch Graduation Accuracy 0.01 mm 0.001 mm 0.01 mm ±2 µm 0.001 mm ±3 µm ±4 µm ±5 µm ±6 µm ±7 µm ±8 µm 0.01 mm ±9 µm ±10 µm ±11 µm ±12 µm ±13 µm ±14 µm ±15 µm Price £40.40 £46.40 £54.20 £60.20 £71.40 £80.10 £87.30 £97.70 £107.00 £122.00 £133.00 £136.00 £144.00 £158.00 £196.00 £207.00 £218.00 £236.00 £242.00 £250.00 £268.00 £278.00 £296.00 £311.00 £333.00 £355.00 £520.00 £540.00 £570.00 £600.00 £630.00 £650.00 £680.00 £700.00 £730.00 £750.00 £780.00 £800.00 £830.00 £860.00 £890.00 £910.00 Code No. Range With ratchet stop 103-177 0 - 1" 103-131 103-178 1 - 2" 103-132 103-179 2 - 3" 103-180 3 - 4" 103-181 4 - 5" 103-182 5 - 6" 103-183 6 - 7" 103-184 7 - 8" 103-185 8 - 9" 103-186 9 - 10" 103-187 10 - 11" 103-188 11 - 12" 103-189 12 - 13" 103-190 13 - 14" 103-191 14 - 15" 103-192 15 - 16" 103-193 16 - 17" 103-194 17 - 18" 103-195 18 - 19" 103-196 19 - 20" 103-197 20 - 21" 103-198 21 - 22" 103-199 22 - 23" 103-200 23 - 24" 103-201 24 - 25" 103-202 25 - 26" 103-203 26 - 27" 103-204 27 - 28" 103-205 28 - 29" 103-206 29 - 30" 103-207 30 - 31" 103-208 31 - 32" 103-209 32 - 33" 103-210 33 - 34" 103-211 34 - 35" 103-212 35 - 36" 103-213 36 - 37" 103-214 37 - 38" 103-215 38 - 39" 103-216 39 - 40" With friction thimble 103-135 0 - 1" 103-136 1 - 2" Graduation Accuracy .001" .0001" .001" .0001" ±.0001" ±.00015" ±.0002" ±.00025" ±.0003" ±.00035" ±.0004" .001" ±.00045" ±.0005" ±.00055" ±.0006" ±.00065" ±.0007" ±.00075" .001"* ±.0001" Price £40.40 £46.40 £54.20 £60.20 £71.40 £80.10 £87.30 £97.70 £107.00 £122.00 £133.00 £136.00 £144.00 £158.00 £196.00 £207.00 £218.00 £236.00 £242.00 £250.00 £268.00 £278.00 £296.00 £311.00 £333.00 £355.00 £520.00 £540.00 £570.00 £590.00 £610.00 £620.00 £640.00 £660.00 £680.00 £700.00 £730.00 £760.00 £790.00 £810.00 £830.00 £850.00 £55.00 £80.00 *.0001 reading is obtained with vernier, B-17 Mitutoyo operates a policy of continuous improvement that aims to provide the customer with the benefit of the latest technological advances. Therefore the company reserves the right to change any or all aspects of any product specification without notice. SET SPECIFICATIONS Metric Code No. 103-927-10 Range 0 - 75 mm (3 pcs./set) 103-913-50 0 - 150 mm (6 pcs./set) Price £203.00 Models included 103-137, 103-138, 103-139-10, 2 micrometer setting standards 103-137, 103-138, 103-139-10, 103-140-10, 103-141-10, 103-142-10, 5 micrometer setting standards 103-143-10, 103-144-10, 103-145-10, 103-146-10, 103-147-10, 103-148-10, 6 micrometer setting standards All micrometers in 103-913-50 and 103-915-10 in one set, 11 micrometer setting standards 103-915-10 150 - 300 mm (6 pcs./set) 103-914-50 0 - 300 mm (12 pcs./set) £480.00 £977.00 B £1390.00 Inch Code No. 103-929 Range 0 - 3" (3 pcs./set) 103-904-10 0 - 6" (6 pcs./set) 103-906 6 - 12" (6 pcs./set) 103-905-10 0 - 12" (12 pcs./set) Price £203.00 Models included 103-177, 103-178, 103-179, 2 micrometer setting standards 103-177, 103-178, 103-179, 103-180, 103-181, 103-182, 5 micrometer setting standards 103-183, 103-184, 103-185, 103-186, 103-187, 103-188, 6 micrometer setting standards All micrometers in 103-904-10 and 103-906 in one set, 11 micrometer setting standards £480.00 £977.00 £1390.00 DIMENSIONS 775 825 875 925 975 1025 L 14.5 3 17 ø18 ø6.35 c Models 75 to 300 mm 17 b L 14.5 3 a 47 b 17 27.5 ø12 47 L ø6.35 ø18 a c 5 c 40 15 40 15 40 15 40 15 40 15 40 15 40 15 40 15 40 15 40 15 47 27.5 a d L 18 b 307 332 355 382 405 28 430 Models over 300 mm measuring range L b 28 35 a 455 480 5 505 530 Mitutoyo operates a policy of continuous improvement that aims to provide the customer with the benefit of the latest technological advances. Therefore the company reserves the right to change any or all aspects of any product specification without notice. B-18 3 50 ø21 725 6.5 Unit: mm Models up to 75 mm measuring range ø8 675 5.3 5.7 6.1 6.3 6.7 5.5 c 28 38 46 57 76 90 102 115 127 139 152 18 166 187 199 212 14.52243 28 236 27.5 248 261 273 c 625 2.5 b 9 10 12 14 16.7 18.8 19.1 18.2 16.8 18 ø12 575 a ø18 L 30 55 80 105 132.8 158.2 183.6 208.8 234.2 258 284 309 353 378 403 428 a 453 478 503 528 c Range 0 - 25 mm 25 - 50 mm 50 - 75 mm 75 - 100 mm 100 - 125 mm 125 - 150 mm 150 - 175 mm 175 - 200 mm 200 - 225 mm 225 - 250 mm 250 - 275 mm 275 - 300 mm 300 - 325 mm 325 - 350 mm 350 - 375 mm 375 - 400 mmb 400 - 425 mm 425 - 450 mm 450 - 475 mm 475 - 500 mm 500 - 525 mm 525 - 550 mm 550 - 575 mm 575 - 600 mm 600 - 625 mm 625 - 650 mm 650 - 675 mm 675 - 700 mm 700 - 725 mm 725 - 750 mm 750 - 775 mm 775 - 800 mm 800 - 825 mm 825 - 850 mm 850 - 875 mm 875 - 900 mm 900 - 925 mm 925 - 950 mm 950 - 975 mm 975 - 1000 mm 17
103-137 价格&库存
很抱歉,暂时无法提供与“103-137”相匹配的价格&库存,您可以联系我们找货
