500-182-30
500-182-30
    MITUTOYO(三丰)
    MITUTOYO - 500-182-30 - Digital Caliper, ABSOLUTE, LCD, 200mm, 0.01mm Resolution, 0.01mm Graduation
500-182-30 数据手册
Digital ABS AOS Caliper 0-200mm Article number: 500-182-30 Description These Digimatic calipers allow you to take reliable measurements and oᴀ洅er you the following beneᴀ밄ts: Now equipped with the same AOS (Advanced Onsite Sensor) induction type encoder used in top-of-the-line ABS coolant-proof calipers. Thanks to the adoption of the electromagnetic induction type ABS encoder, this caliper can be used without concern for contamination on the scale face during measurement. Detection signal is not aᴀ洅ected by dirt (water, oil, etc.) on surface of a scale (except 300mm type). The slider provides smooth, stable and comfortable operation. Character height: 9mm (alleviation of fatigue with the high-contrast LCD) The ABS (ABSOLUTE) scale requires no origin setting after power-on and also has no limit to response speed. Extraordinary battery life Features Range: 0 - 200 mm Depth bar: ᴀ밄at Mass: 194 g Accuracy: ≤ 200 mm : ±0,02 mm /> 200 mm : ±0,03 mm (excluding quantizing error) Digital step: 0,01 mm Max. response speed: Unlimited Battery life: approx. 18000 hours Display: LCD, Character Height 9 mm Delivered: In a case, including 1 battery ORIGIN (ABS-Zero): Yes ZERO/ABS: Yes ON/OFF: Yes Low voltage alarm: Yes Digital/Analog: Digital Functions: Without thumb roller Inch-Metric: Metric Dimensions L: 290 mm a: 50 mm b: 24.5 mm c: 20 mm d: 16 mm Accessories Optional accessories: Product Price Digimatic Cable, Straight, Data Button, 1m 959149 List price: £34.60 Digimatic Cable, Straight, Data Button, 2m 959150 List price: £39.40 U-WAVE T Connection Cable C Straight, with Data Button 02AZD790C List price: £52.20 USB Input Tool Direct (Digimatic USB) cable, with Data Button, 2m Straight, with Data Button 06ADV380C List price: £90.80 Depth Base Attachment for Caliper 75mm width, for 100, 150, 200mm range 050083-10 List price: £35.00 Depth Base Attachment for Caliper 100mm width, for 100, 150, 200mm range 050084-10 List price: £40.00 Depth Base Attachment for Caliper 125mm width, for 300mm range 050085-10 List price: £45.00 Consumable spares: Product Price Battery SR44 1.5V 938882 List price: £3.50
500-182-30 价格&库存
很抱歉,暂时无法提供与“500-182-30”相匹配的价格&库存,您可以联系我们找货
