103-129
103-129
    MITUTOYO(三丰)
103-129 数据手册
Mitutoyo General Catalog Micrometer Move to other products 1 SPC 2 Caliper 3 Depth gage 4 Height gage List of products Digimatic Micrometer SERIES 293 Quickmike SERIES 293, 369, 422 Digimatic Micrometers SERIES 293 Outside Micrometers SERIES 101 Outside Micrometers SERIES 102 Quick-Setting Outside Micrometers SERIES 293, 102 Outside Micrometers SERIES 103 Outside Micrometers SERIES 340, 104 Outside Micrometers SERIES 105 Outside Micrometers SERIES 406, 106 Spline Micrometers SERIES 331, 111 Point Micrometers SERIES 342, 142, 112 Crimp Height Micrometers SERIES 342, 142, 112 V-Anvil Micrometers SERIES 314, 114 Tube Micrometers SERIES 395, 295, 115 Universal Micrometers SERIES 116 "Uni-Mike" SERIES 317, 117 Sheet Metal Micrometers SERIES 389, 189, 119, 118 Blade Micrometers SERIES 422, 122 Disk Micrometers SERIES 323, 223, 123 Paper Thickness Micrometers SERIES 169 Disk Micrometers SERIES 369, 169 Screw Thread Micrometers SERIES 125 Gear Tooth Micrometers SERIES 324, 124 Screw Thread Micrometers SERIES 326, 126 Can Seam Micrometers SERIES 347, 147 Hub Micrometers SERIES 147 Wire Micrometers SERIES 147 Digit Outside Micrometers SERIES 193 Caliper Type Micrometers SERIES 343, 143 Digimatic Micrometers SERIES 227 Low Force Micrometers SERIES 227 Digimatic Bench Micrometer SERIES 121 Snap Meters SERIES 523 Dial Snap Meters SERIES 523 Indicating Micrometers SERIES 510 Outside Micrometers SERIES 107 Limit Micrometers SERIES 113 Optical Flats SERIES 158 Optical Parallels SERIES 157 Micrometer Standards SERIES 167 Standards for Screw Thread Micrometers SERIES 167 Standards for V-Anvil Micrometers SERIES 167 3-Wire Units SERIES 313 Micrometer Stands SERIES 156 Groove Micrometers SERIES 146 Depth Micrometers SERIES 329, 229, 129 Depth Micrometers SERIES 128 Micrometer 6 Inside micrometer 7 Micrometer head 8 Indicator 9 Test indicator 10 Gage head 11 Gauge Block 12 Reference gage 13 Surface plate 14 Miscellaneous 15 Linear scale 16 Digimatic scale unit 17 Profile projector 18 Microscope 19 Contracer 20 Surftest 21 Formtracer 22 Roundtest 23 Hardness tester 24 CMM 25 Flexible measuring gage 26 Vision measuring system 27 Detailed shape measuring system 28 Laser scan micrometer 29 DIY tools Digimatic Micrometer SERIES 293 — with Dust/Water Protection Conforming to IP65 Level MICROMETERS 293-330 FEATURES • IP65 protection level, enabling use in environments exposed to cutting oil, etc*. *Anti-corrosion treatment is required after use. • Measurement data output function is available with a waterresistant connection cable. • Oil-resistance materials are used in all plastic components. • ±1 µm instrumental error (75 mm/3” or less range models) • Auto power ON/OFF function. • Certificate of inspection* is included. (50mm/2” or less range models) *It is not the type used to obtain calibration certificates. 293-250 Technical Data Display: Functions: LCD Origin-Set, Zero-Setting, Data hold, Automatic power on/off, inch/mm conversion (inch/mm type only), Data output Battery: SR44 (1 pc.) (938882) Battery life: Approx. 1.2 years under normal use Maximum response speed: Unlimited Dust/Water protection level: Conforming to IP65 Alarm: Low voltage, counting value composition error Operating temperature: 0°C to 40°C 293-230 293-231 293-233 SPC cable with data switch 293-232 05CZA662: 1m 05CZA663: 2m OPTIONAL ACCESSORIES Order No. 05CZA662 05CZA663 (See page 130.) (See page 276.) Certificate of inspection 88 Description SPC cable with data switch (1m) SPC cable with data switch (2m) Micrometer stands Gauge block set for micrometer isnpection 2.3 3 ø18 b Unit: mm L b 14.5 a 47.2 2.3 3 43 17 5 0 ø6.35 C ø18 27.5 45 4.2 44 17 43 Unit: mm Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm L 0 25 50 75 132.8 158.2 183.6 208.8 234.2 258 284 309 a 9 9.8 12.6 14 5.3 5.7 6.1 6.3 6.7 5.5 6.5 6.5 b 25 32 47 60 16.7 18.8 19.1 18.2 16.8 18 18 18 c (59.8) (70.3) (91.6) (112.9) (76.5) (91) (103.1) (115.3) (126.8) (139.8) (152.3) (166) SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Metric Range 0 - 25mm Inch/Metric With ratchet stop Order No. 293-230 / 293-240* 293-231 / 293-241* 293-232 / 293-242* 293-233 / 293-243* 293-250 293-251 293-252 293-253 293-254 293-255 293-256 293-257 Resolution 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±1µm ±1µm ±1µm ±2µm ±2µm ±2µm ±3µm ±3µm ±3µm ±4µm ±4µm ±4µm Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" 4" - 5" 5" - 6" 6" - 7" 7" - 8" 8" - 9" 9" - 10" 10" - 11" 11" - 12" Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±1µm ±1µm ±1µm ±2µm Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Resolution 0.001mm Accuracy ±1µm Range 0 - 1" 1" - 2" *without SPC data output Accuracy ±.00005" ±.00005" ±.00005" ±.0001" ±.0001" ±.0001" ±.00015" ±.00015" ±.00015" ±.0002" ±.0002" ±.0002" Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.00005" ±.00005" ±.00005" ±.0001" With friction thimble Order No. 293-335 / 293-348* 293-336 *without SPC data output 89 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm With ratchet thimble Order No. 293-334 / 293-344* 293-345* 293-346* 293-347* Inch/Metric With friction thimble Order No. 293-238 / 293-248* Order No. 293-330 / 293-340* 293-331 / 293-341* 293-332 / 293-342* 293-333 / 293-343* 293-350 293-351 293-352 293-353 293-354 293-355 293-356 293-357 Inch/Metric With ratchet thimble Order No. 293-234 / 293-244* 293-235 / 293-245* 293-236 / 293-246* 293-237 / 293-247* With ratchet stop Resolution .00005"/0.001mm .00005"/0.001mm Accuracy ±.00005" ±.00005" MICROMETERS 42.5 ø18 30.7 c L 2.8 ø6.35 a Dimensions Quickmike SERIES 293, 369, 422 — IP-54 Absolute Digimatic Micrometers 293-667 MICROMETERS 369-666 293-668 293-669 FEATURES The Quickmake provides a speedy spindle feed of 10mm per thimble rotation as compared to the conventional micrometer with 0.5mm per rotation. Its wide 30mm measuring range allows various workpieces with different shapes to be measured quickly. • Large LCD digits of 7.5mm height for error-free reading. • Non-rotating spindle and the new ratchet friction thimble. • With absolute linear scale. • IP54 level water resistance protection (when not connected with data output cable). • Stainless steel spindle. • With SPC data output. • With a standard bar to set the origin point (for models with a range over 30mm). SPECIFICATION Metric Range 0 - 30mm 25 - 55mm 50 - 80mm 75 - 105mm Order No. 293-666 293-661-10* 293-667 293-668 293-669 Resolution 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm *Without SPC data output Accuracy ±2µm ±2µm ±2µm ±3µm ±3µm Mass 275g 275g 355g 525g 625g Absolute scale with origin point Detector Scale Excluding quantizing error Inch/Metric Range 0 - 1.2" 1" - 2.2" 2" - 3.2" 3" - 4.2" Order No. 293-676 293-677 293-678 293-679 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.00008" ±.00008" ±.00012" ±.00012" Mass .61 lbs. .78 lbs. 1.16 lbs. 1.38 lbs. Excluding quantizing error 90 Quick feeding mechanism Lead screw 10mm/rev. 369-411 Metric 422-411 Metric Disk type Range 0 - 30mm 25 - 55mm Order No. 369-411 369-412 Resolution 0.001mm 0.001mm Accuracy ±4µm ±4µm Mass 360g 490g Range 0 - 30mm 25 - 55mm Blade type Order No. 422-411 422-412 Resolution 0.001mm 0.001mm Excluding quantizing error Inch/Metric Range 0 - 1.2" 1" - 2.2" Inch/Metric Resolution .00005"/0.001mm .00005"/0.001mm Accuracy ±.00016" ±.00016" Mass .79 lbs. 1.08 lbs. Range 0 - 1.2" 1" - 2.2" Mass 350g 490g Blade type Order No. 422-421 422-422 Resolution .00005"/0.001mm .00005"/0.001mm Accuracy ±.00012" ±.00012" Mass .77 lbs. 1.08 lbs. Excluding quantizing error Excluding quantizing error Metric Accuracy ±3µm ±3µm Excluding quantizing error Disk type Order No. 369-421 369-422 MICROMETERS 342-451 Crimp height type Range 0 - 15mm Order No. 342-451 Resolution 0.001mm Accuracy ±3µm Mass 275g Excluding quantizing error Dimensions a 32 69.6 ø24.9 0.75 Series 369 0.75 LCD Origin-Set, Zero-Set, power on/off, inch/mm conversion (inch/ mm type only), SPC data output*, data hold *Not provided for 293-661-10 model Battery: SR44 (1 pc.) (938882) Battery life: Approx. 3 years (293-666, 293-661-10 and 293-676)/Approx. 1 year Measuring force: 5 - 10N (500 - 1000gf) Measuring faces: Carbide-tipped (293 series only) Alarm: Low battery voltage, scale contamination Dust/Water protection level: Conforming to IP54 b ø6.35 0.75 ø20 ø20 0.7 Display: Functions: 50.4 Minimum measuring range 0.7 Technical Data Unit: mm 6.5 Series 422 45° Range 0 - 30mma 25 - 55mm 50 - 80mm 75 - 105mm a 9 11.3 13.1 13.5 d 25 36 47 60 OPTIONAL ACCESSORIES Order No. 937387 965013 Unit: mm ø0.5 (flat) Series 342: Crimp height type 91 Description SPC cable (1m) SPC cable (2m) Digimatic Micrometers SERIES 293 Ratchet Stop MICROMETERS 293-805 Friction Thimble 293-816 FEATURES SPECIFICATIONS • The world's lightest digital micrometer 215g in mass. • Simply measures 0 through 25mm (1") with resolution to 0.001mm. • Measuring faces carbide tipped. • Provided only with a zero-set key for easy origin setting. (No spindle clamp, no data output, no auto-sleep function) • A ratchet stop or friction thimble for a constant measuring force. • Measurement readout with large characters on the LCD screen. • Battery: SR44 (938882) x 1pc. for 1.2 years • Slim construction for easy access to the stepped feature like the one shown. Metric Range 0 - 25mm With ratchet stop Order No. 293-805 Resolution 0.001mm Accuracy ±2µm Mass 215g Excluding quantizing error Inch/Metric Range 0 - 1" With ratchet stop Order No. 293-815 Resolution .00005"/0.001mm Accuracy ±.0001" Mass .47 lbs. Excluding quantizing error Inch/Metric Range 0 - 1" With friction thimble Order No. 293-816 Resolution .00005"/0.001mm Accuracy ±.0001" Mass .47 lbs. Excluding quantizing error Dimensions Unit: mm 56.3 8.8 155.3 Ratchet stop 143.2 Friction thimble 92 Outside Micrometers SERIES 101 101-105 MICROMETERS 101-109 FEATURES • Satin-chrome-finished frame, tapered (on the anvil side) for hard-to-reach places. Measuring faces • Carbide-tipped measuring faces. • Designed to be operated efficiently with one hand. • Provided with a standard except for 1" model. • Flatness: .000024" • Parallelism: .00005" for .5" model .00008" for models up to 3" .00012" for 3" - 4" model SPECIFICATIONS Dimensions 1" - 2" 2" - 3" 3" - 4" Graduation .0001" .001" .0001" .001" .0001" .0001" .0001" 1.08 a Accuracy ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.00015" .67 ø.71 Order No. 101-230 101-105 101-113 101-106 101-114 101-119 101-120 1.85 ød Range 0 - .5" 0 - 1" .57 .12 L b With ratchet stop c Inch Unit: inch Note: .0001" reading is obtained with vernier. Inch Range 0 - 1" 1" - 2" Range 1 - 1" 1 - 2" 2 - 3" 3 - 4" With friction thimble Order No. 101-109 101-117 101-110 101-118 Graduation .001" .0001" .001" .0001" Accuracy ±.0001" ±.0001" ±.0001" ±.0001" L 1.19 2.18 3.16 4.15 a .11 .11 .11 .11 b .20 .30 .37 .38 c 1.10 1.28 1.77 2.28 d .25 .25 .25 .25 Note: The shape of the thimble changes on the model with friction thimble. Note: .0001" reading is obtained with vernier. 93 Outside Micrometers SERIES 102 102-307 MICROMETERS 102-309 FEATURES • Heat-insulated frame, tapered (on the anvil side) for hard-toreach places. • Carbide-tipped measuring faces. • Provided with a standard except for 25mm (1") model. Measuring faces • Flatness: 0.6µm (.000024") for models of 0.01mm (.001") reading 0.3µm (.000012") for models of 0.001mm (.0001") reading • Parallelism: 1µm (.00004") for 25mm (1") model 2µm (.00008") for models up to 100mm (4") SPECIFICATIONS 50 - 75mm 75 - 100mm Inch Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Graduation 0.01mm 0.001mm 0.01mm 0.001mm 0.01mm 0.01mm Accuracy ±2µm ±2µm ±2µm ±2µm ±2µm ±3µm Metric Micrometer set Range 0 - 100mm (4 mikes/set) Order No. 102-911 Assortment of micrometers • 102-301 102-302 102-303 102-304 • 3 micrometer standards With ratchet stop Order No. 102-321 102-327 102-322 102-328 102-323 102-324 Graduation .001" .0001" .001" .0001" .001" .001" Accuracy ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.00015" Dimensions b 14.5 3 L a 47 27.5 17 ø18 25 - 50mm With ratchet stop Order No. 102-301 102-307 102-302 102-308 102-303 102-304 ød Metric Range 0 - 25mm c Note: 0.001mm (.0001") reading is obtained with vernier. Metric Range 0 - 25mm 25 - 50mm Inch Range 0 - 1" 1" - 2" With ratchet thimble Order No. 102-305 102-309 102-306 Graduation 0.01mm 0.001mm 0.01mm Unit: mm Accuracy ±2µm ±2µm ±2µm Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm With ratchet thimble Order No. 102-325 102-329 102-326 102-330 Graduation .001" .0001" .001" .0001" Accuracy ±.0001" ±.0001" ±.0001" ±.0001" L 30.3 55.3 80.3 105.3 a 2.8 2.8 2.8 2.8 b 5 8 9 10 c 26 32 45 58 d 6.35 6.35 6.35 6.35 Note: The shape of the thimble changes on the model with ratchet thimble. Note: 0.001mm (.0001") reading is obtained with vernier. 94 Quick-Setting Outside Micrometers SERIES 293, 102 293-151-30 MICROMETERS 102-450 102-650 Measuring faces FEATURES • Flatness: • Parallelism: • 1mm spindle thread pitch for quick setting. • The measurement can be read directly from the thimble due to the 100 step graduation. • Carbide-tipped measuring faces. • With Ratchet Thimble for constant force. (Ratchet Stop is also available for the 102 series.) • Provided with a standard except for 25mm (1") model. • The 293 series is provided with SPC output. Dimensions b 16 49.5 5 13 c ø30.7 ød 27.5 100 divisions Digital model with ratchet stop Order No. 293-151-30 293-152-30 293-153-30 293-154-30 Graduation 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±1µm ±1µm ±1µm ±2µm Unit: mm 16 3 50 17 ø21 Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm L a SPECIFICATIONS Metric 0.6µm 2µm Excluding quantizing error Metric Range 0 - 25mm 25 - 50mm Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm With ratchet stop Order No. 102-450 102-451 Graduation 0.01mm 0.01mm Accuracy ±2µm ±2µm Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm With ratchet thimble Order No. 102-650 102-651 102-652 102-653 Graduation 0.01mm 0.01mm 0.01mm 0.01mm L 30 55 80 105 a 2.5 2.5 2.5 2.5 b 5 8 9 9 c 26 32.5 45 58 d 8 8 8 8 Note: The shape of the thimble changes on the digital model. Accuracy ±2µm ±2µm ±2µm ±2µm 95 Outside Micrometers SERIES 103 103-139 MICROMETERS 103-137 FEATURES • • • • • • Hammertone-green, baked-enamel-finished frame. Carbide-tipped measuring faces. Clear graduations on satin-chrome finish. Positive locking clamp. Ratchet Stop or Friction Thimble for exact repetitive readings. Provided with a standard except for 25mm (1") model. Inch Range 0 - 1" Order No. Graduation 103-177 .001" 103-131 .0001" 1" - 2" 103-178 .001" 103-132 .0001" 2" - 3" 103-179 .001" 3" - 4" 103-180 .001" 4" - 5" 103-181 .001" 5" - 6" 103-182 .001" 6" - 7" 103-183 .001" 7" - 8" 103-184 .001" 8" - 9" 103-185 .001" 9" - 10" 103-186 .001" 10" - 11" 103-187 .001" 11" - 12" 103-188 .001" 12" - 13" 103-189 .001" 13" - 14" 103-190 .001" 14" - 15" 103-191 .001" 15" - 16" 103-192 .001" 16" - 17" 103-193 .001" 17" - 18" 103-194 .001" 18" - 19" 103-195 .001" 19" - 20" 103-196 .001" (Models with a range up to 40" are available.) SPECIFICATIONS Metric Range 0 - 25mm With ratchet stop Order No. Graduation 103-137 0.01mm 103-129 0.001mm 25 - 50mm 103-138 0.01mm 103-130 0.001mm 50 - 75mm 103-139-10 0.01mm 75 - 100mm 103-140-10 0.01mm 100 - 125mm 103-141-10 0.01mm 125 - 150mm 103-142-10 0.01mm 150 - 175mm 103-143-10 0.01mm 175 - 200mm 103-144-10 0.01mm 200 - 225mm 103-145-10 0.01mm 225 - 250mm 103-146-10 0.01mm 250 - 275mm 103-147-10 0.01mm 275 - 300mm 103-148-10 0.01mm 300 - 325mm 103-149 0.01mm 325 - 350mm 103-150 0.01mm 350 - 375mm 103-151 0.01mm 375 - 400mm 293-152 0.01mm 400 - 425mm 103-153 0.01mm 425 - 450mm 103-154 0.01mm 450 - 475mm 103-155 0.01mm 475 - 500mm 103-156 0.01mm (Models with a range up to 1000mm are available.) With ratchet stop Accuracy ±2µm ±2µm ±2µm ±2µm ±2µm ±3µm ±3µm ±3µm ±4µm ±4µm ±4µm ±5µm ±5µm ±5µm ±6µm ±6µm ±6µm ±7µm ±7µm ±7µm ±8µm ±8µm Accuracy ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.00015" ±.00015" ±.00015" ±.0002" ±.0002" ±.0002" ±.00025" ±.00025" ±.00025" ±.0003" ±.0003" ±.0003" ±.00035" ±.00035" ±.00035" ±.0004" ±.0004" Note: 0.001mm (.0001") reading is obtained with vernier. Metric Range 0 - 25mm 25 - 50mm Measuring faces Inch • Flatness: 0.6µm (.000024") for models up to 300mm (12") 1µm (.00004") for models over 300mm (12") • Parallelism: (2+L/100)µm [(.00008+.00004 (L/4))"]* *L=Maximum measuring length (mm) [(inch)], Fraction rounded down Range 0 - 1" 1" - 2" With friction thimble Order No. 103-125 103-133 103-126 Graduation 0.01mm 0.001mm 0.01mm With friction thimble Order No. 103-127 103-135T 103-128 103-136T Graduation .001" .0001" .001" .0001" Note: 0.001mm (.0001") reading is obtained with vernier. 96 Accuracy ±2µm ±2µm ±2µm Accuracy ±.0001" ±.0001" ±.0001" ±.0001" MICROMETERS 103-913 Metric Inch Micrometer set Range 0 - 75mm (3 mikes/set) 0 - 150mm (6 mikes/set) Order No. 103-927-10 150 - 300mm (6 mikes/set) 103-915-10 0 - 300mm (12 mikes/set) 103-914-30 103-913-30 Assortment of micrometers • 103-137, 103-138, 103-139 • 2 micrometer standards • 103-137, 103-138, 103-139-10, 103-140-10, 103-141-10, 103-142-10 • 5 micrometer standards • 103-143, 103-144, 103-145, 103-146, 103-147, 103-148 • 6 micrometer standards • All micrometers of 103-913-30 and 103-915-10 in one set • 11 micrometer standards 97 Range 0 - 3" (3 mikes/set) 0 - 4" (4 mikes/set) 0 - 6" (6 mikes/set) Order No. 103-929 6" - 12" (6 mikes/set) 103-906 0 - 12" (12 mikes/set) 103-905 103-930 103-904 Assortment of micrometers • 103-177, 103-178, 103-179 • 2 micrometer standards • 103-177, 103-178, 103-179, 103-180 • 3 micrometer standards • 101-105, 101-106, 103-179, 103-180, 103-181, 103-182 • 5 micrometer standards • 103-183, 103-184, 103-185, 103-186, 103-187, 103-188 • 6 micrometer standards • All micrometers of 103-904 and 103-906 in one set • 11 micrometer standards Outside Micrometers SERIES 340, 104 — with Interchangeable Anvils MICROMETERS 340-251 104-136 FEATURES Metric • IP65 water/dust protection level (340 series*). Range 0 - 50mm 0 - 100mm 0 - 150mm 100 - 200mm 150 - 300mm 200 - 300mm 300 - 400mm 400 - 500mm 500 - 600mm 600 - 700mm 700 - 800mm 800 - 900mm 900 - 1000mm *Models with a range up to 300mm (12"). • • • • • Wide measuring range with interchangeable anvils. Carbide-tipped spindle face. Provided with a Ratchet Stop for constant force. Supplied with zero-setting standards for each range. The 340 series (LCD readout type) is provided with SPC output. SPECIFICATIONS Metric Range 0 - 150mm 150 - 300mm 300 - 400mm 400 - 500mm 500 - 600mm 600 - 700mm 700 - 800mm 800 - 900mm 900 - 1000mm Digital model Order No. 340-251 340-252 340-513 340-514 340-515 340-516 340-517 340-518 340-519 Inch/Metric Range 0 - 6" 6" - 12" 12" - 18" 18" - 24" 24" - 30" 30" - 36" Resolution 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm Interchangeable anvils 0, 25, 50, 75, 100, 125mm 0, 25, 50, 75, 100, 125mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm Resolution .00005"/0.001mm .0001"/0.001mm .0001"/0.001mm .0001"/0.001mm .0001"/0.001mm .0001"/0.001mm Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Interchangeable anvils 0, 25mm 0, 25, 50, 75mm 0, 25, 50, 75, 100, 125mm 0, 25, 50, 75mm 0, 25, 50, 75, 100, 125mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm 0, 25, 50, 75mm Graduation .001" .0001" .001" .001" .001" .001" .001" .001" .001" .001" Interchangeable anvils 0, 1" 0, 1" 0, 1", 2", 3" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" *The frame in a heat insulating cover Inch Range 0 - 2" 0 - 4" 0 - 6" 6" - 12" 12" - 18" 18" - 24" 24" - 30" 30" - 36" 36" - 42" Digital model Order No. 340-351 340-352 340-713 340-714 340-715 340-716 Order No. 104-171* 104-139A 104-135A 104-140A 104-136A 104-141A 104-142A 104-143A 104-144A 104-145A 104-146A 104-147A 104-148A Interchangeable anvils 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" 0, 1", 2", 3", 4", 5" Order No. 104-166 104-165 104-149 104-137 104-138 104-201 104-202 104-203 104-204 104-205 Note: .0001" reading is obtained with vernier. Measuring faces • Flatness: 0.6µm (.000024") for models up to 300mm (12") 1µm (.00004") for models over 300mm (12") • Parallelism: (2+L/100)µm [(.00008+.00004 (L/4))"]** **L=Maximum measuring length (mm) [(inch)], Fraction rounded up Accuracy • ±(4+L/75)µm [±(.0002+.00005 (L/3))"]* *L=Maximum measuring length (mm) [(inch)], Fraction rounded up, Excluding quantizing error (340 series) 98 Outside Micrometers MICROMETERS SERIES 105 — with Extension Anvil Collars 105-106 105-408 SPECIFICATIONS Metric Range 500 - 600mm 600 - 700mm 700 - 800mm 800 - 900mm 900 - 1000mm 1000 - 1100mm 1100 - 1200mm 1000 - 1200mm 1200 - 1300mm 1300 - 1400mm 1200 - 1400mm 1400 - 1500mm 1500 - 1600mm 1400 - 1600mm 1600 - 1700mm 1700 - 1800mm 1600 - 1800mm 1800 - 1900mm 1900 - 2000mm 1800 - 2000mm FEATURES • Wide measuring range with extension anvil collars. Order No. 105-103 105-104 105-105 105-106 105-107 105-408 105-409 105-418 105-410 105-411 105-419 105-412 105-413 105-420 105-414 105-415 105-421 105-416 105-417 105-422 Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Extension collars 50mm 50mm 50mm 50mm 50mm 50mm 50mm 50mm, 100mm 50mm 50mm 50mm, 100mm 50mm 50mm 50mm, 100mm 50mm 50mm 50mm, 100mm 50mm 50mm 50mm, 100mm Accuracy • ±(6+L/75)µm* *L=Maximum measuring length (mm), Fraction rounded up • • • • • 50mm (2") spindle stroke. Carbide-tipped measuring faces. Provided with Ratchet Stop for constant force. Supplied with zero-setting standards for each range. Square and round pipes are combined for light weight and rigid frame (for models over 1000mm range). • Workpiece stopper (for models over 1000mm range). Measuring faces • Flatness: 1µm • Parallelism: (2+L/100)µm** **L=Maximum measuring length (mm), Fraction rounded down 99 Outside Micrometers SERIES 406, 106 — Non-Rotating Spindle Type MICROMETERS 406-521-30 106-101 FEATURES • Carbide-tipped measuring faces. • Easy-to-read with large vernier on the thimble. • Provided with a standard except for 25mm (1") model. SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Metric Digital model with ratchet stop Order No. 406-521-30 406-522-30 406-523-30 406-524-30 Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±3µm ±3µm ±3µm ±4µm Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm With ratchet thimble Order No. 106-101 106-103 106-105 106-106 Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±2µm ±2µm ±3µm ±4µm Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Inch Digital model with ratchet stop Order No. 406-721-30 406-722-30 406-723-30 406-724-30 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.00015" ±.00015" ±.00015" ±.0002" Excluding quantizing error Range 0 - 1" 1" - 2" With friction thimble Order No. 106-102 106-104 Graduation .0001" .0001" Measuring faces • Flatness: 0.3µm (.000012") • Parallelism: 4µm (.00016") for Series 406 2µm (.00008") for Series 106 • Diameter: 6.35mm (.25") for Series 406 8mm (.315") for Series 106 100 Accuracy ±.0001" ±.0001" Spline Micrometers SERIES 331, 111 331-251 MICROMETERS 111-115 FEATURES • IP65 water/dust protection level (331 series). • The anvil and spindle have a small diameter for measuring splined shafts, slots, and keyways. Anvil/Spindle Dimensions Type A (ø3mm) Unit: mm Type B (ø2mm) 10 10 • • • • ø2 ø3 5 5 Carbide-tipped measuring faces. With Ratchet Stop for constant force. Provided with a standard except for 25mm (1") model. The 331 series is provided with SPC output. Metric Range 0 - 25mm SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Digital model Order No. 331-251 331-261 331-252 331-262 331-253 331-263 331-254 331-264 Resolution 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±2µm ±2µm ±2µm ±2µm ±2µm ±2µm ±3µm ±3µm Remarks Type A Type B Type A Type B Type A Type B Type A Type B Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Digital model Order No. 331-351 331-361 331-352 331-362 331-353 331-363 331-354 331-364 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.00015" ±.00015" Remarks Type A Type B Type A Type B Type A Type B Type A Type B 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm Order No. 111-115 111-215 111-116 111-117 111-118 111-119 111-120 111-121 111-122 Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±3µm ±3µm ±3µm ±3µm ±4µm ±4µm ±4µm ±5µm ±5µm Remarks Type A Type B Type A Type A Type A Type A Type A Type A Type A Order No. 111-166 111-142 111-143 Resolution .0001" .001" .001" Accuracy ±.00015" ±.00015" ±.00015" Remarks Type A Type A Type A Inch Range 0 - 1" 1" - 2" 2" - 3" Note: .0001" reading is obtained with vernier. Measuring faces • Flatness: 0.3µm (.000012") • Parallelism: (2+L/100)µm [(.00008+.00004 (L/4))"]* *L=Maximum measuring length (mm) [(inch)], Fraction rounded up Excluding quantizing error 101 Point Micrometers SERIES 342, 142, 112 342-261 MICROMETERS 112-153 FEATURES SPECIFICATIONS • IP65 water/dust protection level (342 series). • Pointed spindle and anvil for measuring the web thickness of drills, small grooves, keyways, and other hard-to-reach dimensions. • 15 degree and 30 degree measuring points are available. • The measuring points (carbide-tipped) have approximately 0.3mm (.012") radius. Measuring point: 15°; Measuring point: 30°; Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 30°; 15°; Spherical tips R0.3 • • • • Metric Spherical tips R0.3 Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Dimensions L a 14.5 3 Order No. 342-251 342-261 342-252 342-262 342-253 342-263 342-254 342-264 Resolution 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±2µm ±2µm ±2µm ±2µm ±2µm ±2µm ±3µm ±3µm Point 15° 30° 15° 30° 15° 30° 15° 30° Excluding quantizing error With Ratchet Stop for constant force. The 342 series is provided with SPC output. The 142 series is provided with a digit counter. Provided with a standard except for 25mm (1") models. b Digital model 47 17 Digital model Order No. 342-351 342-361 342-352 342-362 342-353 342-363 342-354 342-364 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.00015" ±.00015" Point 15° 30° 15° 30° 15° 30° 15° 30° Excluding quantizing error 42.5 Metric c ød Range 0 - 25mm Unit: mm Order No. 142-153 142-201 Graduation 0.01mm 0.01mm Accuracy ±3µm ±3µm Point 15° 30° Order No. 142-177 142-225 Graduation .001" .001" Accuracy ±.00015" ±.00015" Point 15° 30° Inch Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm L 55.3 80.3 105.3 132.8 a 12.8 12.8 12.8 15.3 b 10 12 14 17 c 38 49 60 79 d 6.35 6.35 6.35 6.35 Range 0 - 1" Measuring points • Parallelism: 3µm (.00012") 102 Metric 25 - 50mm 50 - 75mm 75 - 100mm Order No. 112-165 112-153* 112-213 112-201* 112-166 112-154* 112-214 112-202* 112-167 112-155* 112-215 112-203* 112-168 112-156* 112-216 112-204* Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±4µm ±4µm ±4µm ±4µm Point 15° 15° 30° 30° 15° 15° 30° 30° 15° 15° 30° 30° 15° 15° 30° 30° Range 0 - 1" 1" - 2" 2" - 3 Order No. 112-189 112-177* 112-237 112-225* 112-190 112-178* 112-238 112-226* 112-191 Graduation .001" .001" .001" .001" .001" .001" .001" .001" .001" Accuracy ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" Point 15° 15° 30° 30° 15° 15° 30° 30° 15° *The points have not carbide tips. MICROMETERS Range 0 - 25mm Inch *The points have not carbide tips. Crimp Height Micrometers SERIES 342, 142, 112 — Point Spindle and Blade Anvil 342-271 112-401 SPECIFICATIONS Metric 0.5 (1) Unit: mm 60° (27°) Range 0 - 25mm Digital model Order No. 342-271 Resolution 0.001mm Accuracy ±3µm Excluding quantizing error Inch/Metric ø0.5 (ø0.6) ( ): for series 142 Range 0 - 1" • IP65 water/dust protection level (342 series). • Measures the height of crimp contacts. • With Ratchet Stop for constant force. • The 342 series is provided with SPC output. • The 142 series is provided with a digit counter. Order No. 342-371 Resolution .00005"/0.001mm Accuracy ±.00015" Excluding quantizing error Metric FEATURES Digital model Range 0 - 25mm Mechanical counter model Order No. 142-402 142-403 Graduation 0.01mm 0.001mm Accuracy ±3µm ±3µm Note: 0.001mm reading is obtained with vernier. Metric Range 0 - 25mm 103 Order No. 112-401 Graduation 0.01mm Accuracy ±3µm V-Anvil Micrometers SERIES 314, 114 — 3 Flutes and 5 Flutes MICROMETERS 314-251 114-121 114-102 FEATURES SPECIFICATIONS • IP65 water/dust protection level (314 series). • Measures the outside diameter of cutting heads (such as taps, reamers, end mills) with an odd number of flutes. • Carbide-tipped spindle. • With Ratchet Stop for constant force. • V-anvils with a centerline groove are available. They are useful for measuring pitch diameters of taps which have a small diameter by using single-wire method. • Supplied with a standard for zero point adjustment. • The 314 series (LCD readout type) is provided with SPC output. Metric Range 1 - 15mm 10 - 25mm 25 - 40mm Inch/Metric .4" - 1" 1" - 1.6" Resolution 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±4µm ±4µm ±4µm ±4µm ±5µm Remarks w/Groove — w/Groove — — Digital model for 3 flutes cutting head Order No. 314-351 314-361 314-352 314-362 314-353 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.0002" ±.0002" ±.0002" ±.0002" ±.00025" Remarks w/Groove — w/Groove — — Excluding quantizing error Wire Spindle Anvil Order No. 314-251 314-261 314-252 314-262 314-253 Excluding quantizing error Range .05 - .6" Pitch Diameter Measurement of Tap by Single-wire Method Digital model for 3 flutes cutting head Tap 104 Metric Dimensions ø1.5 Unit: mm Groove .7 14.5 3 For 3 flutes cutting head Remarks — — — — 18 *Carbide-tipped anvil Note: .0001" reading is obtained with vernier. Metric Range 5 - 25mm 2.3 - 25mm 25 - 45mm 45 - 65mm 65 - 85mm 114-102 For 5 flutes cutting head Order No. 114-121 114-165 114-137* 114-122 114-123 114-124 Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±4µm ±4µm ±4µm ±5µm ±6µm ±7µm Remarks w/Groove — — — — — Accuracy ±.0002" ±.00025" Remarks — — Accuracy ±4µm ±5µm Remarks — — *Carbide-tipped anvil Inch Range .09" - 1" 1" - 1.8" For 5 flutes cutting head Order No. 114-135* 114-129 Graduation .0001" .001" *Carbide-tipped anvil Note: .0001" reading is obtained with vernier. Metric Range 5 - 25mm 25 - 45mm For 7 flutes cutting head Order No. 114-151 114-152 Graduation 0.01mm 0.01mm 105 ø6.35 ø18 Accuracy ±.0002" ±.0002" ±.00025" ±.0003" 17 ø6.35 Graduation .001" .0001" .001" .001" 60°; Order No. 114-163 114-202* 114-113 114-114 47 27.5 A Range .05 - .6" .09" - 1" 1" - 1.6" 1.6" - 2.2" 114-204 114-101 *Carbide-tipped anvil Inch 60°; (1 MICROMETERS 22 30.3 ) 4.7 (23.46) Remarks w/Groove — w/Groove — — — — — — — 8 Accuracy ±4µm ±4µm ±4µm ±4µm ±4µm ±5µm ±6µm ±6µm ±7µm ±7µm 14.5 2.3 - 25mm 25 - 40mm 40 - 55mm 55 - 70mm 70 - 85mm 85 - 100mm Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 6 0° ; 10 - 25mm For 3 flutes cutting head Order No. 114-101 114-161 114-102 114-162 114-204* 114-103 114-104 114-105 114-106 114-107 0.5 Range 1 - 15mm Range 10 - 25mm 25 - 40mm 40 - 55mm 55 - 70mm 70 - 85mm 85 - 100mm A 6.2 19.14 32.13 45.12 58.11 71.1 Tube Micrometers 5mm Spherical Anvil Type ød 5mm SERIES 395, 295, 115 — Spherical and Cylindrical Anvils ød SR4 MICROMETERS 395-251 SR4 395-271 FEATURES • IP65 water/dust protection level (395 series). • Designed to measure the wall thickness of various tubing. • The Tube Micrometers have two combinations of measuring faces (carbide-tipped): spherical-flat type, and sphericalspherical type. • Cylindrical anvils (perpendicular) are also available. • With Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. • The 295 series is provided with a digit counter. 115-215 Cylindrical Anvil Type 395-261 Cylindrical (Perpendicular) Anvil Dimensions Type A (Pin) Type B (Spherical) ø4 ø6.9 ø6.9 Type C (Cylindrical) L ø8 1.4 Sø4.7 ød 9 12.7 Sø3.5 6 8 ø1.8 Unit: mm Type D (Cylindrical) 106 (Unit: mm) Anvil Type A Type B Type C Type D d 2 3.6 4.8 8.2 L 4 4 12 22 SR4 SPECIFICATIONS Range Order No. Resolution Accuracy 0 - 25mm 395-251 395-271* 395-252 395-272* 395-253 395-273* 395-254 395-274* 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm ±2µm ±2µm ±2µm ±2µm ±2µm ±2µm ±3µm ±3µm 25 - 50mm 50 - 75mm 75 - 100mm *Spherical-spherical type Order No. Resolution Accuracy 0 - 1" 395-351 395-371* 395-352 395-372* 395-353 395-373* 395-354 395-374* .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.0001" ±.00015" ±.00015" 3" - 4" Range 0 - 25mm Mechanical counter model with spherical anvil Order No. 295-115 295-215* Graduation 0.01mm 0.01mm Accuracy ±3µm ±3µm Mini. ID of tubing d: 10mm d: 10mm *Spherical-spherical type Inch Range 0 - 1" Mechanical counter model with spherical anvil Order No. 295-153 295-253* Graduation .0001" .0001" Accuracy ±.00015" ±.00015" Mini. ID of tubing d: .40" d: .40" *Spherical-spherical type Digital model with spherical anvil Range 2" - 3" Mini. ID of tubing d: 15mm d: 15mm d: 15mm d: 15mm d: 19mm d: 19mm d: 20mm d: 20mm Excluding quantizing error Inch/Metric 1" - 2" Metric Digital model with spherical anvil MICROMETERS Metric *Spherical-spherical type Mini. ID of tubing d: .59" d: .59" d: .59" d: .59 d: .75" d: .75" d: .79" d: .79" With spherical anvil Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Excluding quantizing error Order No. 115-115 115-215* 115-116 115-216* 115-117 115-217* 115-118 115-218* Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±4µm ±4µm Mini. ID of tubing d: 10mm d: 10mm d: 11mm d: 11mm d: 17mm d: 17mm d: 18mm d: 18mm Accuracy ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.0002" Mini. ID of tubing d: .40" d: .40" d: .44" d: .44" d: .67" d: .67" d: .71" *Spherical-spherical type Inch Metric Range 0 - 25mm Range 0 - 1" Digital model with cylindrical anvil Order No. 395-261 395-262 395-263 395-264 Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±3µm ±3µm ±3µm ±3µm Remarks Type A Type B Type C Type D Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" With spherical anvil Order No. 115-153 115-253* 115-142 115-242* 115-143 115-243* 115-144 Graduation .0001" .0001" .001" .001" .001" .001" .001" *Spherical-spherical type Note: .0001" reading is obtained with vernier. Digital model with cylindrical anvil Order No. 395-362 395-363 395-364 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.00015" ±.00015" ±.00015" Remarks Type B Type C Type D Excluding quantizing error Metric Range 0 - 25mm 25 - 50mm Inch Range 0 - 1" With cylindrical anvil Order No. 115-302 115-308 115-315 115-316 115-303 115-309 Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Remarks Type A Type B Type C Type D Type A Type B Accuracy ±.00015" ±.00015" ±.00015" Remarks Type A Type C Type D With cylindrical anvil Order No. 115-305 115-313 115-314 Graduation .001" .0001" .0001" Note: .0001" reading is obtained with vernier. 107 Accuracy ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm Universal Micrometers SERIES 116 — Interchangeable Anvil Type 116-101 SPECIFICATIONS • Non-rotating spindle with seven interchangeable anvils (flat, spline, spherical, point, knife-edge, disk, and blade) for a wide range of applications. • Interchangeable anvils (pair) are optional. • V-anvils and conical spindle tips (matching pair) for screw thread measurement are also available. • With Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. Metric Range 0 - 25mm 25 - 50mm 116-840 Order No. 116-105 116-106 Graduation .001" .001" Accuracy ±.0002" ±.0002" V-anvil and conical spindle tip Assortment of anvils and tips 0.4 - 0.5mm/64 - 48TPI (116-831) 0.6 - 0.9mm/44 - 28TPI (116-832) 1 - 1.75mm/24 - 14TPI (116-833) 2 - 3mm/13 - 9TPI (116-834) 3.5 - 5mm/8 - 5TPI (116-835) 5.5 - 7mm/4.5 - 3.5TPI (116-836) 60 - 48TPI (116-841) 48 - 40TPI (116-842) 40 - 32TPI (116-843) 32 - 24TPI (116-844) 24 - 18TPI (116-845) 18 - 14TPI (116-846) 14 - 10TPI (116-847) 10 - 7TPI (116-848) 7 - 4.5TPI (116-849) 4.5 - 3.5TPI (116-850) 116-830 Flat Unit: mm 20 116-801 Assortment of anvils Flat anvils (116-801) Spline anvils (116-802) Spherical anvils (116-803) Point anvils (116-804) Knife-edge anvils (116-805) Disk anvils (116-806) Blade anvils (116-807) Unit: mm Point ø6 ø2 4.5 4.5 116-803 116-802 Unit: mm Disk Blade 0.75 4.5 4.5 116-806 116-805 108 1 ø6 1.5 116-804 Unit: mm 2 ø6.3 45°; 0.1 ø3.5 55°; ø11.1 ø0.3 ø3.5 0.4 4.5 Unit: mm Spherical R4 Unit: mm Knife-edge Unit: mm Spline ø6 Order No. 116-800 15.5 4.5 Interchangeable Anvils Set (Optional) Applications Multi-purpose measurements Unit: mm ø3.5 Screw thread measurements (Whitworth screw) Accuracy ±4µm ±4µm ø3.5 Order No. 116-830 Graduation 0.01mm 0.01mm ø6 Applications Screw thread measurements (Metric screw, Unified screw) Order No. 116-101 116-102 Inch Range 0 - 1" 1" - 2" V-Anvils and Conical Spindle Tips Sets (Optional) ø4 MICROMETERS FEATURES 4.5 116-807 "Uni-Mike" SERIES 317, 117 — Interchangeable Anvil Type MICROMETERS 317-251 117-101 FEATURES SPECIFICATIONS • IP65 water/dust protection level (317 series). • Measures tubing thickness, shoulder-edge distance, rivet head height, etc. with interchangeable anvils (flat anvil, rod anvil, Vanvil). • Supplied with Flat Anvil (201216) and Rod Anvil: ø3mm rod anvil (201217) for 0-25mm (0-1") models, ø5mm (201379) for 25-50mm (1"-2") model. • With special Disk Anvils. The Uni-Mike is used as a height micrometer. The disks have a lapped, mirror surface. Metric Range 0 - 25mm 25 - 50mm Digital model with ratchet stop Order No. 317-251 317-252 Resolution 0.001mm 0.001mm Accuracy ±4µm ±4µm Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" Digital model with friction thimble Order No. 317-351 317-352 Resolution 00005"/0.001mm 00005"/0.001mm Accuracy ±.0002" ±.0002" Excluding quantizing error Metric • Provided with a standard except for 25mm (1") model. Range 0 - 25mm 25 - 50mm With ratchet stop Order No. 117-101 117-102 Inch Dimensions 52.5(27.5) Graduation 001" 001" 0.6µm (.000024") for spindle face 2µm (.00008") for anvil face • Parallelism: 3µm (.00012") 6.35 25 1.5 V-anvil (Optional) Flat anvil (Standard ø3 (for 25mm) accessory) 117-102 (117-101) Order No. 117-107 117-108 • Flatness: 120°; ø5 (for 50mm) Rod anvil (Standard accessory) OPTIONAL ACCESSORIES Order No. 201218 950758 950759 109 Accuracy ±4µm ±4µm With friction thimble Measuring faces 25 7 34 26.5 Unit:mm 27.5 ø6.35 25(0) ø18 1.5 Range 0 - 1" 1" - 2" Graduation 0.01mm 0.01mm Description V-anvil Disk anvil for 25mm (1") models Disk anvil for 50mm (2") models Accuracy ±.0002" ±.0002" Sheet Metal Micrometers SERIES 389, 189, 119, 118 118-102 389-251 MICROMETERS 119-202 Anvil-Spindle Combinations Metric Standard (Flat-Flat) SphericalFlat Range 0 - 25mm SphericalSpherical FEATURES Range 0 - 1" 25 - 50mm Resolution 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm Inch/Metric 1" - 2" Accuracy ±4µm ±4µm ±4µm ±5µm ±4µm ±4µm ±4µm Throat 160mm 160mm 160mm 300mm 165mm 165mm 165mm Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm *Spherical anvil and flat spindle **Spherical anvil and spherical spindle Accuracy ±.0002" Throat 6" Accuracy ±4µm ±4µm ±4µm ±4µm ±5µm ±4µm Throat 100mm 150mm 150mm 150mm 300mm 150mm Accuracy ±.0002" ±.0002" ±.0002" ±.00025" ±.0002" Throat 6" 6" 6" 12" 6" Accuracy ±4µm Throat 50mm Mechanical counter model Order No. 189-129 Resolution .0001" Order No. 118-101 118-102 118-114* 118-118** 118-103 118-110 Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Excluding quantizing error Inch Range 0 - 1" 1" - 2" Order No. 118-129 118-116* 118-120** 118-107 118-112 Metric Accuracy ±.0002" ±.0002" ±.0002" ±.00025" ±.0002" ±.0002" ±.0002" Throat 6" 6" 6" 12" 6" 6" 6" Excluding quantizing error Graduation .0001" .0001" .0001" .001" .001" *Spherical anvil and flat spindle **Spherical anvil and spherical spindle Note: .0001" reading is obtained with vernier. Digital model Order No. 389-351 389-361* 389-371** 389-713 389-352 389-362* 389-372** Throat 150mm *Spherical anvil and flat spindle **Spherical anvil and spherical spindle Digital model *Spherical anvil and flat spindle **Spherical anvil and spherical spindle Range 0 - 1" Range 0 - 25mm 25 - 50mm Order No. 389-251 389-261* 389-271** 389-513 389-252 389-262* 389-272** Accuracy ±4µm Metric • The 189 series is provided with a digit counter. • The 119 series is provided with a dial for making easy and quick reading. SPECIFICATIONS Resolution 0.01mm Note: .0001" reading is obtained with vernier. *Except for 389-513 Range 0 - 25mm Order No. 189-102 Inch • Measures thickness of sheet metal, paper, plastic, and rubber parts. • Carbide-tipped measuring faces. • With Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. • IP65 water/dust protection level (389 series*). Metric Mechanical counter model Range 0 - 25mm Dial reading model Order No. 119-202* Resolution 0.01mm *Spherical anvil and flat spindle Measuring faces • Flatness: 0.6µm (.000024") for models with 150mm(6") or less throat depth 1µm (.00004") for models with 300mm (12") throat depth • Parallelism: 3µm (.00012") 110 Blade Micrometers SERIES 422, 122 — Non-Rotating Spindle Type 422-111-30 MICROMETERS 122-101 FEATURES • The anvil and the spindle have a blade for measuring the groove diameter of shafts, keyways, and other hard-to-reach portions. 0.4 ø6 0.75 8 Metric 4 6 ø6 7 11 Range 0 - 25mm ø6 ø6 6 6.5 3 60°; 6.5 60°; R8 0.75 Unit: mm 0.4 R8 0.75 ø6 Blade Dimensions Type B Type A Type D Type C (carbide-tipped) (carbide-tipped) 25 - 50mm • With Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Digital model Order No. 422-111-30 422-141-30 422-121-30 422-151-30 422-112-30 422-142-30 422-113-30 422-114-30 Resolution 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±4µm Remarks Type A Type B Type C Type D Type A Type B Type A Type A Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.0002" Remarks Type A Type B Type C Type D Type A Type B Type A Type A Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±3µm ±4µm ±4µm ±4µm ±5µm ±5µm Remarks Type A Type B Type C Type D Type A Type B Type C Type D Type A Type A Type A Type A Type A Type A Order No. 122-125 122-135 122-151 122-126 122-136 122-127 122-128 Graduation .0001" .0001" .0001" .0001" .0001" .0001" .0001" Accuracy ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.00015" ±.0002" Remarks Type A Type B Type D Type A Type B Type A Type A Inch Range 0 - 1" 1" - 2" Digital model Order No. 422-311-30 422-341-30 422-321-30 422-351-30 422-312-30 422-342-30 422-313-30 422-314-30 Order No. 122-101 122-111 122-161 122-141 122-102 122-112 122-162 122-142 122-103 122-104 122-105 122-106 122-107 122-108 2" - 3" 3" - 4" Measuring faces • Parallelism: 3µm (.00012") for models up to 50mm (2") (3+L/100)µm [(.00012+.00004 (L/4))"] for models over 50mm (2")* * L=Maximum measuring length (mm) [(inch)], Fraction rounded up Excluding quantizing error 111 Disk Micrometers SERIES 323, 223, 123 MICROMETERS 323-511-30 123-101 FEATURES Metric • The Disk Micrometer is designed to easily measure root tangent length of spur gears and herical gears. • Diameter of measuring disk: 20mm (.79") • 0.7mm edge thickness to enter narrow recesses. • With Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. • The 323 series (LCD readout type) is provided with SPC output. • The 223 series is provided with a mechanical digit counter for quick reading of measurements. Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Digital model Order No. 323-511-30 323-512-30 323-513-30 323-514-30 Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±4µm ±4µm ±6µm ±6µm Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Digital model Order No. 323-711-30 323-712-30 323-713-30 323-714-30 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.0002" ±.0002" ±.0003" ±.0003" Excluding quantizing error Metric Range 0 - 25mm 25 - 50mm Inch Range 0 - 1" Mechanical counter model Order No. 223-101 223-102 Resolution 0.01mm 0.01mm Accuracy ±4µm ±4µm Mechanical counter model Order No. 223-125 Resolution .001" Accuracy ±.0002" Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±4µm ±4µm ±4µm ±4µm ±6µm ±6µm ±6µm ±6µm ±7µm ±7µm ±8µm ±8µm ±8µm ±9µm ±9µm ±9µm *The measuring disks have carbide tips. Note: The disk diameter of models over 100mm is 30mm. Excluding quantizing error Inch/Metric Order No. 123-101 123-113* 123-102 123-114* 123-103 123-115* 123-104 123-116* 123-105 123-106 123-107 123-108 123-109 123-110 123-111 123-112 Inch Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Order No. 123-125 123-126 123-127 123-128 Graduation .001" .001" .001" .001" Accuracy ±.0002" ±.0002" ±.0003" ±.0003" Measuring faces • Flatness: 1µm (.00004") for models up to 100mm (4") 1.6µm for models over 100mm • Parallelism: 4µm (.00016") for models up to 50mm (2") (4+L/50)µm [(.00016+.00004 (L/2))"]* for models up to 100mm (4") over 50mm (2") (5+L/75)µm* for models over 100mm * L=Maximum measuring length (mm) [(inch)], Fraction rounded up 112 t Dimensions ød TECHNICAL INFORMATION øe Unit: mm Center concavity b L a 14.5 3 47 17 31.5 L 37.5 62.5 87 112 137.5 162.5 187.5 212.5 237.5 262.5 287.5 312.5 ø18 a 6 6 5.5 5.5 6 6 6 6 6 6 6 6 b 14 14 11 11 12 15 16 15 14 14 15 15 c 25 32 49 63 79 94 106 118 130 143 156 169 En = Root tangent length Note: Root tangent length measurement is not available for some types of gears. d 20 20 20 20 30 30 30 30 30 30 30 30 e 8 (9.8) 8 (9.8) 8 (9.8) 8 (9.8) 12 12 12 12 12 12 12 12 t 0.7 0.7 0.7 0.7 1 1 1 1 1 1 1 1 Data in ( ) applies to those with carbide tipped disks. Paper Thickness Micrometers SERIES 169 169-101 FEATURES • Designed to measure paper thickness. • Non-rotating spindle. • With Ratchet Stop for constant force. Measuring faces SPECIFICATIONS Metric Range 0 - 25mm Order No. 169-101 Graduation 0.01mm Accuracy ±4µm Order No. 169-103 Graduation .001" Accuracy ±.0002" • Flatness: 1µm (.00004") • Parallelism: 3µm (.00012") • Dimensions 0.4 Unit: mm Range 0 - 1" ø14.3 (ø.44") Inch 113 ( ): Inch model MICROMETERS Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm ø6.35 c En Disk Micrometers SERIES 369, 169 — Non-Rotating Spindle Type MICROMETERS 369-511-30 169-201 FEATURES • • • • • Non-rotating spindle eliminates torque on workpiece. Diameter of measuring disk: 20mm (.79") With Ratchet Stop for constant force. Provided with a standard except for 25mm (1") model. The 369 series (LCD readout type) is provided with SPC output. SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Digital model Order No. 369-511-30 369-512-30 369-513-30 369-514-30 Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±4µm ±4µm ±6µm ±6µm Measuring faces • Flatness: 1µm (.00004") • Parallelism: 4µm (.00016") for models up to 50mm (2") 6µm (.00024") for models over 50mm (2") Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Digital model Order No. 369-711-30 369-712-30 369-713-30 369-714-30 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.0002" ±.0002" ±.0003" ±.0003" Dimensions 0.7 ø20 ø8 Unit: mm Excluding quantizing error Accuracy ±4µm ±4µm ±6µm ±6µm Order No. 169-203 169-204 169-206 169-208 Graduation .001" .001" .001" .001" Accuracy ±.0002" ±.0002" ±.0003" ±.0003" 47 15.5 ø18 Graduation 0.01mm 0.01mm 0.01mm 0.01mm ød Order No. 169-201 169-202 169-205 169-207 31.5 17 c Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 14.5 3 L a ø12 b Metric Inch Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 114 L 37.5 62.5 87 112 a 6 6 5.5 5.5 b 13.5 13.5 13 13 c 25 32 49.5 63.5 d 8 8 8 8 Screw Thread Micrometers SERIES 125 MICROMETERS 125-103 SPECIFICATIONS FEATURES • Provided with a 60 degree V-anvil and conical spindle for easily measuring pitch diameters of metric or unified screw threads. • With Ratchet Stop for constant force. • With a standard for zero point adjustment. Metric Range Order No. Graduation 0 - 25mm 125-101 125-102 125-103 125-104 125-105 125-106 125-107 125-108 125-109 125-110 125-111 125-112 125-113 125-114 125-115 125-116 125-117 125-118 125-119 125-120 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy • ±(2+L/75)µm* *L=Maximum measuring length (mm), Fraction rounded up 25 - 50mm Dimensions 14.5 3 L a 47 17 50 - 75mm c ød 32.3 ø18 18 Range Unit: mm L 0 - 25mm 37.5 25 - 50mm 62.5 50 - 75mm 87 75 - 100mm 112 a 5.2 5.2 4.7 4.7 c 25 32 49.5 63.5 d 6.35 6.35 6.35 6.35 75 - 100mm 115 Screw to be measured (Metric/Unified) 0.4 - 0.5mm/64 - 48TPI 0.6 - 0.9mm/44 - 28TPI 1 - 1.75mm/24 - 14TPI 2 - 3mm/13 - 9TPI 3.5 - 5mm/8 - 5TPI 0.4 - 0.5mm/64 - 48TPI 0.6 - 0.9mm/44 - 28TPI 1 - 1.75mm/24 - 14TPI 2 - 3mm/13 - 9TPI 3.5 - 5mm/8 - 5TPI 0.6 - 0.9mm/44 - 28TPI 1 - 1.75mm/24 - 14TPI 2 - 3mm/13 - 9TPI 3.5 - 5mm/8 - 5TPI 5.5 - 7mm/4.5 - 3.5TPI 0.6 - 0.9mm/44 - 28TPI 1 - 1.75mm/24 - 14TPI 2 - 3mm/13 - 9TPI 3.5 - 5mm/8 - 5TPI 5.5 - 7mm/4.5 - 3.5TPI Gear Tooth Micrometers SERIES 324, 124 — Interchangeable Ball Anvil-Spindle Tip Type MICROMETERS 324-251 124-173 FEATURES • IP65 water/dust protection level (324 series). • Measures over-pin diameter of gears with precision steel (carbide) ball-tipped measuring faces. • Interchangeable ball anvil-spindle tips for various gear modules (0.5 - 5.25) are optional. • With Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Digital model Order No. 324-251 324-252 324-253 324-254 Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±4µm ±4µm ±4µm ±5µm Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Digital model Order No. 324-351 324-352 324-353 324-354 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.0002" ±.0002" ±.0002" ±.00025" Excluding quantizing error Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm Order No. 124-173 124-174 124-175 124-176 124-177 124-178 124-179 124-180 124-181 124-182 124-183 124-195 Resolution 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±4µm ±4µm ±4µm ±5µm ±5µm ±5µm ±6µm ±6µm ±6µm ±7µm ±7µm ±7µm Interchangeable Ball Anvil-Spindle Tips (Optional) Diameter 0.8mm 1mm 1.191mm (3/64") 1.5mm 1.588mm (1/16") 2mm 2.381mm (3/32") 2.5mm 3mm 3.175mm (1/8") 3.5mm 3.969mm (5/32") 4mm 4.5mm 4.763mm (3/16") 5mm 5.556mm (7/32") 6mm 6.35mm (1/4") 7mm 7.144mm (9/32") 7.938mm (5/16") 8mm 8.731mm (11/32") *Carbide-tipped anvil 116 Order No. Gears to be measured Module 124-801* 0.5 - 0.55 124-802* 0.6 - 0.65 124-803* 0.7 - 0.8 124-821* 0.9 - 1 124-804* 0.9 - 1 124-805 1.25 124-806 1.5 124-822 1.5 124-807 1.75 124-808 — 124-823 2 124-809 2 124-810 2.25 124-824 2.5 124-811 2.5 124-812 2.75 124-813 3.0 - 3.25 124-814 3.5 124-815 3.75 124-816 4.0 124-817 4.25 124-818 4.5 124-819 4.75 124-820 5.0 - 5.25 Diametral pitch 50 45 35 - 30 28 - 26 28 - 26 22 17 17 15 14 13 13 11 10 10 9 8 7 7 6.5 6 5.5 5.5 5 Screw Thread Micrometers SERIES 326, 126 — Interchangeable Anvil-Spindle Tip Type 326-251 MICROMETERS 126-125 FEATURES Metric • IP65 water/dust protection level (326 series). • 60 degree or 55 degree V-anvil and conical spindle (interchangeable) are optional, which are made of high-grade special steel, hardened and precision ground. Application Metric screw, Unified screw (60° threads) Order No. 126-800 Whitworth screw (55° threads) 126-810 Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm Assortment of anvil-spindle tips 0.4 - 0.5mm/64 - 48TPI (126-801) 0.6 - 0.9mm/44 - 28TPI (126-802) 1 - 1.75mm/24 - 14TPI (126-803) 2 - 3mm/13 - 9TPI (126-804) 3.5 - 5mm/8 - 5TPI (126-805) 5.5 - 7mm/4.5 - 3.5TPI (126-806) 60 - 48TPI (126-811) 48 - 40TPI (126-812) 40 - 32TPI (126-813) 32 - 24TPI (126-814) 24 - 18TPI (126-815) 18 - 14TPI (126-816) 14 - 10TPI (126-817) 10 - 7TPI (126-818) 7- 4.5TPI (126-819) 4.5 - 3.5TPI (126-820) Order No. 126-125 126-126 126-127 126-128 126-129 126-130 126-131 126-132 126-133 126-134 126-135 126-136 Graduation 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±4µm ±4µm ±4µm ±5µm ±5µm ±5µm ±6µm ±6µm ±6µm ±7µm ±7µm ±7µm Inch • Provided with Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. • The 326 series (LCD readout type) is provided with SPC output. Range Order No. Graduation 1" 126-137 .001" 1" - 2" 126-138 .001" 2" - 3" 126-139 .001" 3" - 4" 126-140 .001" (Models with a range up to 12" are available.) Accuracy ±.0002" ±.0002" ±.0002" ±.00025" SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Digital model Order No. 326-251 326-252 326-253 326-254 Resolution 0.001mm 0.001mm 0.001mm 0.001mm Standards for Screw Thread Micrometers (Optional) Accuracy ±4µm ±4µm ±4µm ±5µm Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Digital model Order No. 326-351 326-352 326-353 326-354 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.0002" ±.0002" ±.0002" ±.00025" Excluding quantizing error Metric Size 25mm 50mm 75mm 100mm 125mm 150mm 175mm 200mm 225mm 250mm 275mm 117 Inch Order No. V=60° 167-261 167-262 167-263 167-264 167-265 167-266 167-267 167-268 167-269 167-270 167-271 Order No. V=55° 167-272 167-273 167-274 167-275 167-276 167-277 167-278 167-279 167-280 167-281 167-282 Size 1" 2" 3" 4" 5" 6" 7" 8" 9" 10" 11" Order No. V=60° 167-294 167-295 167-296 167-297 167-298 167-299 167-300 167-301 167-302 167-303 167-304 Order No. V=55° 167-283 167-284 167-285 167-286 167-287 167-288 167-289 167-290 167-291 167-292 167-293 Can Seam Micrometers SERIES 347, 147 147-202 147-103 347-103 347-104 147-103 MICROMETERS for cans (for depth measurements up to 5mm) for aluminium cans 347-105 347-106 147-105 SPECIFICATIONS Metric for sprayer cans Range 0 - 13mm 347-202 347-201 147-202 Digital model Order No. 347-103 347-105 347-202 Inch/Metric FEATURES • Measures the width, height, and depth of can seams. • Three types of micrometers are available for : steel cans, aluminum cans, and sprayer cans. Range 0 - .5" Resolution 0.001mm 0.001mm 0.001mm Remarks for steel cans for aluminum cans for sprayer cans Digital model Order No. 347-104 347-106 347-201 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Remarks for steel cans for aluminum cans for sprayer cans Order No. 147-103 147-105 147-202 Graduation 0.01mm 0.01mm 0.01mm Remarks for steel cans for aluminum cans for sprayer cans Order No. 147-104 147-106 147-201 Graduation .001" .001" .001" Remarks for steel cans for aluminum cans for sprayer cans Metric Dimensions 16 15 16 52.5 Range 0 - .5" 38.5 ø15 16 347-105 347-106 147-105 Accuracy • ±3µm (±.00015") Excluding quantizing error. (347 series) ø20 22.5 15 40°; 9.25 11.25 Inch ø20 9.3 10.15 1.3 45°; 1.5 347-103 347-104 147-103 ø15 20 0.5 Range 0 - 13mm ø20 9.25 53 1.5 Unit: mm ø15 15 11.25 10.65 2 40°; 11.25 22 347-202 347-201 147-202 118 Hub Micrometers SERIES 147 147-301 FEATURES Order No. 147-301 147-302 147-303 147-304 Graduation 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±2µm ±2µm ±2µm ±3µm Dimensions Inch Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Unit: mm h3 Order No. of micrometer 147-301 147-302 147-303 147-304 h2 Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Order No. 147-351 147-352 147-353 147-354 Graduation .001" .001" .001" .001" Accuracy ±.0001" ±.0001" ±.0001" ±.00015" h1 6 6.5 6.5 6.5 h2 8.5 11 11 11 Wire Micrometers SERIES 147 147-401 FEATURES • Designed for measuring wire thickness. • Also used to measure the diameter of a small ball. • Carbide-tipped measuring faces • Flatness: 0.6µm (.000024") • Parallelism: 1.3µm (.00006") SPECIFICATIONS Dimensions Measuring faces Graduation 0.01mm Accuracy ±3µm Order No. 147-402 Graduation .0001" Accuracy ±.00015" 15 2.5 12.5 14.5 ø15 2 Inch Range 0 - .4" 14.5 ø16 Order No. 147-401 Unit: mm 101 ø6.35 Metric Range 0 - 10mm MICROMETERS Metric • Flatness: 0.6µm (.000024") • Parallelism: (2+L/100)µm [(.00008+.00004 (L/4))"]* *L=Maximum measuring length (mm) [(inch)], Fraction rounded up h1 SPECIFICATIONS Measuring faces H • Measures hub thickness and shoulders inside a bore. • Carbide-tipped measuring faces. • With Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. 147-401 Note: .0001" reading is obtained with vernier. 119 h3 13.5 14 13 13 H 17.5 20.5 20.5 20.5 Digit Outside Micrometers SERIES 193 FEATURES Inch • Mechanical digit counter for quick and error-free reading. • Direct readout on the counter to 0.01mm (.001"). • Carbide-tipped measuring faces for long life. • Provided with a standard except for 25mm (1") model. SPECIFICATIONS Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Order No. 193-201 193-211 193-202 193-212 1" - 2" Graduation .001" .0001" .001" .0001" Accuracy ±.0001" ±.0001" ±.0001" ±.0001" Note: .0001" reading is obtained with vernier. With ratchet stop Order No. 193-101 193-111 193-102 193-112 193-103 193-113 193-104 193-114 193-305 193-306 193-307 193-308 193-309 193-310 Graduation 0.01mm 0.001mm 0.01mm 0.001mm 0.01mm 0.001mm 0.01mm 0.001mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Accuracy ±2µm ±2µm ±2µm ±2µm ±2µm ±2µm ±3µm ±3µm ±3µm ±3µm ±4µm ±4µm ±4µm ±5µm Measuring faces • Flatness: 0.6µm (.000024") for models up to 300mm (12") • Parallelism: (2+L/100)µm [(.00008+.00004 (L/4))"]* *L=Maximum measuring length (mm) [(inch)], Fraction rounded down. Dimensions Unit: mm b L a 27.5 25.5 (65) 3 17 47 ød 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm Range 0 - 1" ø18 (ø21) Metric With friction thimble c MICROMETERS 193-101 Inch Range 2" - 3" 3" - 4" 4" - 5" 5" - 6" 6" - 7" 7" - 8" 8" - 9" 9" - 10" 10" - 11" ( ): for models of range over 100mm With ratchet stop Order No. 193-213 193-214 193-415 193-416 193-417 193-418 193-419 193-420 193-421 Graduation .0001" .0001" .0001" .0001" .0001" .0001" .0001" .0001" .0001" Accuracy ±.0001" ±.00015" ±.00015" ±.00015" ±.0002" ±.0002" ±.0002" ±.00025" ±.00025" Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm Note: 0.001mm (.0001") reading is obtained with vernier. L 30 55 80 105 137 162 187 212 238 263 289 314 a 2.5 2.5 2.5 2.5 6 6 6 6 7 7 8 8 b 5 8 9 9 18 18 18 19 20 19 19 20 c 26 32 45 57 80 93 106 119 132 145 158 171 d 6.35 6.35 6.35 6.35 8 8 8 8 8 8 8 8 Note: The shape of the thimble changes on the model with Friction Thimble. 120 Metric Inch Range 0 - 3" (3 mikes/set) 0 - 6" (6 mikes/set) Micrometer set Order No. 193-901 193-902 193-908 Assortment of micrometers • 193-101, 193-102, 193-103 • 2 micrometer standards • 193-101, 193-102, 193-103, 193-104 • 3 micrometer standards • 193-101, 193-102, 193-103, 193-104, 193-305, 193-306 • 5 micrometer standards Micrometer set Order No. 193-923 193-930 Assortment of micrometers • 193-211, 193-212, 193-213 • 2 micrometer standards • 193-211, 193-212, 193-213, 193-214, 193-415, 193-416 • 5 micrometer standards 193-902 Caliper Type Micrometers SERIES 343, 143 343-511-30 FEATURES • Carbide-tipped measuring faces. • With Ratchet Stop for constant force. • Provided with a standard except for 25mm (1") model. SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Digital model Order No. 343-511-30 343-512-30 343-513-30 343-514-30 Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±5µm ±6µm ±7µm ±8µm Excluding quantizing error Inch/Metric Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Digital model Order No. 343-711-30 343-712-30 343-713-30 343-714-30 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.00025" ±.0003" ±.00035" ±.0004" Excluding quantizing error Metric Range Order No. Graduation 0 - 25mm 143-101 0.01mm 25 - 50mm 143-102 0.01mm 50 - 75mm 143-103 0.01mm 75 - 100mm 143-104 0.01mm 100 - 125mm 143-105 0.01mm Models with a range up to 300mm are available. Accuracy ±5µm ±6µm ±7µm ±8µm ±9µm Inch Range Order No. Graduation 0 - 1" 143-121 .001" 1" - 2" 143-122 .001" Models with a range up to 4" are available. Accuracy ±.00025" ±.0003" Measuring faces • Flatness: 0.3µm (.000012") • Parallelism: (3+L/75)µm [(.00012+.00004 (L/3))"]* * L=Maximum measuring length (mm) [(inch)], Fraction rounded down 121 MICROMETERS Range 0 - 75mm (3 mikes/set) 0 - 100mm (4 mikes/set) 0 - 150mm (6 mikes/set) Digimatic Micrometers SERIES 227 — with Constant & Adjustable Fine-loading Device 227-203 MICROMETERS 227-201 227-221 Plastic pipe Rubber sheet FEATURES • Constant and low measuring force mechanism in the thimble. • Adjustable measuring force* accommodates various kind of work materials. *0.5-2.5N or 2-10N SPECIFICATION • The measurement-value hold function automatically retains the data at a specified measuring force, ensuring accuracy. • Large LCD digits of 7.5mm height for error-free reading. • Non-rotating spindle and the new ratchet friction thimble. • Speedy spindle feed of 10 mm/.4”. • With absolute linear scale. • The IP54 level water resistance protection (when not connected with data output cable). • With SPC data output. • With a standard bar to set the origin point (for models with 15 30mm range). Metric Range 0 - 15mm Order No. 227-201 227-202 15 - 30mm 227-203 227-204 Accuracy ±2µm ±2µm ±2µm ±2µm Measuring force 0.5N - 2.5N 2N - 10N 0.5N - 2.5N 2N - 10N Excluding quantizing error Inch/Metric Range 0 - .6" .6" - 1.2" Dimensions Resolution 0.001mm 0.001mm 0.001mm 0.001mm Unit: mm Order No. 227-211 227-212 227-213 227-214 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.0001" ±.0001" ±.0001" ±.0001" Measuring force 0.5N - 2.5N 2N - 10N 0.5N - 2.5N 2N - 10N ø26 Excluding quantizing error Range 0 - 15mm 190.2 9 32 69.6 53.4 Metric 17.7 227-201 Order No. Resolution 227-221 0.001mm 227-222 0.001mm Accuracy ±4µm ±4µm Measuring force 0.5N - 2.5N 2N - 10N Excluding quantizing error ø24.5 ø6.35 25 0-15 Disk type Inch/Metric Range 0 - .6" Disk type Order No. Resolution 227-231 .00005"/0.001mm 227-232 .00005"/0.001mm Accuracy ±.0002" ±.0002" Measuring force 0.5N - 2.5N 2N - 10N Excluding quantizing error 122 Low Force Micrometers SERIES 227 SPECIFICATION Metric Range 0 - 25mm 25 - 50mm Order No. 227-101 227-102 Graduation 0.01mm 0.01mm Accuracy ±2µm ±2µm Mass 262g 290g Order No. 227-111 Graduation .0001" Accuracy ±.0001" Mass .58 lbs. Inch 227-101 Range 0 - 1" Measuring faces: Carbide-tipped Flatness of measuring faces: 0.6µm Parallelism between measuring faces: 3µm Measuring force: 1N FEATURES • Low Force Micrometers are specially designed for elastic workpieces such as plastic parts. • Constant measuring force of 1N is ensured by the springloaded anvil. • The spindle does not rotate. • With a friction thimble. • Carbide-tipped measuring faces. • Provided with a standard to set the origin point for 25-50mm model. Dimensions L 20 Unit: mm 52 3 27.5 ø6.35 30 57 25 3.5 5 0 45 Range 0 - 25mm 25 - 50mm L 31 56 Digimatic Bench Micrometer SERIES 121 — Interchangeable Anvil Type SPECIFICATION Metric Range 0 - 50mm Order No. 121-145 Resolution 0.001mm Accuracy ±2µm Mass 2.3kg Excluding quantizing error Inch/Metric 121-145 Range 0 - 2" Order No. 121-155 Resolution .00005"/ 0.001mm Accuracy ±.0001" Mass 5.07 lbs. Excluding quantizing error Technical Data Display: Functions: FEATURES • The LCD panel rotates within 330 degrees for use in horizontal or vertical position. • Interchangeable anvils allow a wide measuring range of 50mm (2"). • Provided with a ratchet stop for constant force. • Provided with a standard to set the origin for 25-50mm measurement. LCD Zero-Set, presetting, power on/off, counting direction switching, inch/mm conversion (inch/mm type only), SPC data output Micrometer head stroke: 25mm (1") Measuring faces: Carbide-tipped Measuring force: 6N - 10N Battery: SR44 (2 pcs.) (938882 X 2 pcs.) Battery life: Approx. 1.8 years under normal use Alarm: Low battery voltage, over-speed error, over-flow error Operating temperature: 5°C to 40°C OPTIONAL ACCESSORIES Order No. 937387 965013 123 Description SPC cable (1m) SPC cable (2m) MICROMETERS Technical Data Snap Meters SERIES 523 Unit: mm Dimensions L 11.5 88.8 Measuring Range D ø10.8 89.5 Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Indicator is optional. D 25 35 47.5 60 L 31 56 81 106 Accuracy (dispersion of indication MICROMETERS 0.4µm (.00002") Measuring faces • Flatness: 0.3µm (.000015") • Parallelism: 0.6µm (.00003") for models up to 50mm (2") 1µm (.00005") for models up to 100mm (4") 523-141 FEATURES • Various types of indicator can be selected according to the measruement applications. • Spindle diameter: 10.8mm (.425") • Carbide-tipped measuring faces. • Measuring force: 5 - 15N (500 - 1500gf) SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Inch Order No. 523-141 523-142 523-143 523-144 Anvil movement 2mm 2mm 2mm 2mm Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Order No. 523-115 523-152 523-153 523-154 Anvil movement .078" .078" .078" .078" Dial Snap Meters SERIES 523 SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Order No. 523-121 523-122 523-123 523-124 Graduation of indicator 0.001mm 0.001mm 0.001mm 0.001mm Indicating range ±0.060mm ±0.060mm ±0.060mm ±0.060mm Order No. 523-131 523-132 523-133 523-134 Graduation of indicator .00005" .00005" .00005" .00005" Indicating range ±.0023" ±.0023" ±.0023" ±.0023" Inch 523-101 FEATURES • Direct GO/NO-GO judgment for mass-produced parts. • Spindle diameter: 10.8mm (.425") • Carbide-tipped measuring faces. • Measuring force: 6 - 15N (600 - 1500gf) • IP protection level: 54 Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Accuracy 1µm (.00005") for ±0.060mm (±.0023") indicating range Measuring faces • Flatness: 0.3µm (.000015") • Parallelism: 0.6µm (.00003") for models up to 50mm (2") 1µm (.00005") for models up to 100mm (4") 124 Indicating Micrometers SERIES 510 SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 510-121 Order No. 510-121* 510-122 510-123 510-124 Graduation of indicator 0.001mm 0.001mm 0.001mm 0.001mm Indicating range ±0.060mm ±0.060mm ±0.060mm ±0.060mm *510-151: Retractable anvil button on the leftside. Inch Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Order No. 510-131* 510-132 510-133 510-134 Graduation of indicator .00005" .00005" .00005" .00005" Indicating range ±.0023" ±.0023" ±.0023" ±.0023" MICROMETERS • Retractable anvil with indicator for three-wire measurements of pitch diameter of precision screws, roundness and parallelism measurements. • Spindle diameter: 8mm (.315") • Carbide-tipped measuring faces. • Measuring force: 5 - 15N (500 - 1500gf) • Provided with a standard except for 25mm (1") model. • IP protection level: 54 *510-141: Retractable anvil button on the leftside. 55.5 11.5 L 50 19 3 ø8 Dimensions Accuracy d • Micrometer: 3µm (.00015") • Indicator: 1µm (.00005") 3.5 ø21 FEATURES Unit: mm Retractable anvil button Workpiece stopper (optional) ø14 23 ø16 Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm ø14 15 • Flatness: 0.3µm (.000015") • Parallelism: 0.6µm (.00003") for models up to 50mm (2") 1µm (.00005") for models over 50mm (2") 20.5 Measuring faces 04AZA124 04AZA125 04AZA126 L 31.5 56.5 81.5 106.5 d 25 38 50 63 Outside Micrometers SERIES 107 SPECIFICATIONS Metric 107-201 FEATURES • With dial indicator for direct GO/NG-GO judgment for massproduced parts. • Anvil retracting trigger for quick measurement. • Anvil retracting range: 4mm • Carbide-tipped measuring faces. • Provided with a standard except for 25mm model. Order No. 107-201 107-202 193-203 107-204 172-205 172-206 172-207 172-208 Accuracy ±2µm ±2µm ±2µm ±3µm ±3µm ±3µm ±4µm ±4µm Measuring faces • Flatness: 0.6µm • Parallelism: (2+L/100)µm *L=Maximum measuring length (mm), Fraction rounded down. Dimensions 18 Dial indicator 125 ø6.35 Dial indicator (optional) Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm Unit: mm 14.5 Limit Micrometers SERIES 113 MICROMETERS 113-102 FEATURES SPECIFICATIONS • Can be used as a GO/±NG gage by setting the upper and lower limits. • Carbide-tipped measuring faces. • Provided with a standard for 25mm - 50mm model. Metric Range 0 - 25mm 25 - 50mm Order No. 113-102 113-103 Graduation 0.01mm 0.01mm Accuracy ±3µm ±3µm Measuring faces • Flatness: 0.6µm • Parallelism: (3+L/100)µm* * L=Maximum measuring length (mm) Fraction rounded down 126 Optical Flats SERIES 158 TECHNICAL INFORMATION Flatness Check of Measuring Faces Using Interfer ence Fringe Pattern Produced by an Optical Flat Viewing direction 158-118 • Used for inspecting the flatness of micrometer's or gauge block's measuring faces with high accuracy. Optical flat Optical flat Anvil Anvil SPECIFICATIONS Metric Flatness 0.2µm 0.1µm Inch Order No. 158-117 158-119 158-118 158-120 Diameter 45mm 60mm 45mm 60mm Thickness 12mm 15mm 12mm 15mm Flatness .000004" Order No. 158-122 158-124 Diameter 1.8" 2.4" Thickness .5" .6" Optical Parallels SERIES 157 TECHNICAL INFORMATION Parallelism Check between Measuring Faces by Means of Interference Fringe Produced by an Optical Parallel The parallelism between the measuring faces can be determined as follows; wring the optical parallel to the anvil and observe the number of interference fringes produced on the spindle side under the measuring force of the micrometers. The parallelism is about 1µm (0.32µm x 3 = 0.96µm). Fringe on the anvil side must not be more than one. 157-903 FEATURES Viewing direction of the anvil Viewing direction of the spindle • Designed to inspect parallelism and flatness of measuring faces of micrometers. • Each set consists of 4 thicknesses. • Flatness: 0.1µm (.000004") • Parallelism: 0.2µm (.000008") • Diameter of optical parallel: 30mm (1.19") • Supplied with fitted carrying case. Optical parallel Spindle Anvil SPECIFICATIONS Metric Range of micrometer to be checked 0-25mm 25-50mm Inch Order No. 157-903 157-904 Assortment of parallels (Thickness of parallel) 12.00, 12.12, 12.25, 12.37mm 25.00, 25.12, 25.25, 25.37mm Range of micrometer to be checked 0-1" 1-2" 127 Order No. 157-901 157-902 Assortment of parallels (Thickness of parallel) .5000", .5062", .5125", .5187" 1.0000", 1.0062", 1.0125", 1.0187" MICROMETERS FEATURES Micrometer Standards SERIES 167 FEATURES • Used for the zero point setting of outside micrometers. • Flat and lapped measuring faces. • Heat insulating handle for preventing expansion due to body temperature. 167-108 167-103 Technical Data Flatness of measuring faces: 0.3µm (.000012") Parallelism between measuring faces: 2µm (.00008") SPECIFICATIONS Length 25mm 50mm 75mm 100mm 125mm 150mm 175mm 200mm 225mm 250mm 275mm 300mm 325mm 350mm 375mm 400mm 425mm 450mm 475mm 500mm Inch Order No. 167-101 167-102 167-103 167-104 167-105 167-106 167-107 167-108 167-109 167-110 167-111 167-112 167-113 167-114 167-115 167-116 167-117 167-118 167-119 167-120 Diameter 6.35mm 6.35mm 6.35mm 7.9mm 7.9mm 7.9mm 7.9mm 9.4mm 9.4mm 9.4mm 9.4mm 9.4mm 9.4mm 9.4mm 9.4mm 9.4mm 9.4mm 9.4mm 9.4mm 11.9mm Length 525mm 550mm 575mm 600mm 625mm 650mm 675mm 700mm 725mm 750mm 775mm 800mm 825mm 850mm 875mm 900mm 925mm 950mm 975mm 1000mm Order No. 167-121 167-122 167-123 167-124 167-125 167-126 167-127 167-128 167-129 167-130 167-131 167-132 167-133 167-134 167-135 167-136 167-137 167-138 167-139 167-140 Length 1" 2" 3" 4" 5" 6" 7" 8" 9" 10" 11" 12" 13" 14" 15" 16" 17" 18" 19" 20" Diameter 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm 11.9mm Order No. 167-141 167-142 167-143 167-144 167-145 167-146 167-147 167-148 167-149 167-150 167-151 167-152 167-153 167-154 167-155 167-156 167-157 167-158 167-159 167-160 Diameter .25" .25" .25" .31" .31" .31" .31" .37" .37" .37" .37" .37" .37" .37" .37" .37" .37" .37" .37" .47" Length 21" 22" 23" 24" 25" 26" 27" 28" 29" 30" 31" 32" 33" 34" 35" 36" 37" 38" 39" 40" Order No. 167-161 167-162 167-163 167-164 167-165 167-166 167-167 167-168 167-169 167-170 167-171 167-172 167-173 167-174 167-175 167-176 167-177 167-178 167-179 167-180 Diameter .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" .47" Order No. 167-294 167-283 167-295 167-284 167-296 167-285 167-297 167-286 Thread angle 60° 55° 60° 55° 60° 55° 60° 55° Order No. 167-337 167-338 167-339 167-340 167-341 167-342 167-343 Type Plug Plug Plug Ring Ring Ring Ring Standards for Screw Thread Micrometers SERIES 167 — 60 degree and 55 degree SPECIFICATIONS Metric 167-264 Length 25mm 167-262 FEATURES Dimensions • Specially designed for the zero point setting of screw thread micrometers. ø6.35 MICROMETERS Metric 60°or 55°; 50mm Unit: mm 75mm 60°or 55° Length 100mm Inch Order No. 167-261 167-272 167-262 167-273 167-263 167-274 167-264 167-275 Thread angle 60° 55° 60° 55° 60° 55° 60° 55° Length 1" Type Plug Plug Plug Plug Plug Plug Plug Length .2" .4" 1" 1.6" 2.2" 2.8" 3.4" 2" 3" 4" Standards for V-Anvil Micrometers SERIES 167 SPECIFICATIONS Metric 167-329 FEATURES • Specially designed for the zero point setting of V-anvil micrometers. Length 5mm 10mm 25mm 40mm 55mm 70mm 85mm 128 Inch Order No. 167-327 167-328 167-329 167-330 167-331 167-332 167-333 3-Wire Units MICROMETERS SERIES 313 313-101 FEATURES SPECIFICATIONS • Facilitates measurement of the pitch diameter of screw threads with a standard micrometer. • 18 sizes of wires are assorted in a set. • Roundness of wire: within 0.5µm • Cylindricity of wire: within 1µm • Hardness of wire: 59 - 63HRC Application ø6.35mm (.25" DIA.) Order No. 313-101 ø8mm (.315" DIA.) 313-102 TECHNICAL INFORMATION 3-wire method Formula to obtain the pitch diameter (E)*: E=M - 3d + 0.866025P where P=Screw thread pitch d=Diameter of wire E=Pitch diameter M=Measured length P d d E M d *For metric or UNF screw 129 Assortment of wire units 0.17mm (952131), 0.195mm (952132), 0.22mm (952133), 0.25mm (952134), 0.29mm (952135), 0.335mm (952136), 0.39mm (952137), 0.455mm (952138), 0.53mm (952139), 0.62mm (952140), 0.725mm (952141), 0.895mm (952142), 1.1mm (952143), 1.35mm (952144), 1.65mm (952145), 2.05mm (952146), 2.55mm (952147), 3.2mm (952148) 0.17mm (952149), 0.195mm (952150), 0.22mm (952151), 0.25mm (952152), 0.29mm (952153), 0.335mm (952154), 0.39mm (952155), 0.455mm (952156), 0.53mm (952157), 0.62mm (952158), 0.725mm (952159), 0.895mm (952160), 1.1mm (952161), 1.35mm (952162), 1.65mm (952163), 2.05mm (952164), 2.55mm (952165), 3.2mm (952166) Micrometer Stands SERIES 156 MICROMETERS 156-105 156-102 156-101 These stands are designed to allow bench-top use with hand micrometers or other gages which have frame area sufficient to grab onto. SPECIFICATIONS Remarks Fixed angle type Adjustable angle type Vertical type Vertical type ø24.8 435 Order No. 156-105 156-101 156-102 156-103 40 Micrometer ranges 0-25mm (0-1"), 25-50mm (1"-2") Up to 100mm (4") Up to 300mm (12") Over 300mm (12") Dimensions 30 About 30 156-102 102.15 ø28 74 97 55.8 910 156-105 120 220 40 31.5 139.5 156-101 156-103 130 About 30 35 2.5 0 to 18 30 4 to Max. 63 12 Unit: mm Groove Micrometers SERIES 146 146-121 146-122 146-221 MICROMETERS 146-222 FEATURES • Flanged spindle for measuring width, depth, and location of grooves inside/outside bores, and tubes. • Provided with two types of graduations for inside and outside measurements. • Non-rotating spindle type has two-directional ratchet stop (Measuring force: 5-10N). SPECIFICATIONS Metric Rotating spindle type Range Outside 0 - 25mm Range Inside 1.6 - 26.5mm 25 - 50mm 50 - 75mm 75 - 100mm 26.5 - 51.5mm 51.5 - 76.5mm 76.5 - 101.5mm Inch Order No. Graduation 146-121 146-122 146-123 146-124 146-125 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Range Outside 0 - 25mm Range Inside 1.6 - 26.5mm 25 - 50mm 50 - 75mm 75 - 100mm 26.5 - 51.5mm 51.5 - 76.5mm 76.5 - 101.5mm Inch Rotating spindle type Range Outside 0 - 1" Range Inside .055" - 1.05" 1" - 2" 2" - 3" 3" - 4" 1.05" - 2.05" 2.05" - 3.05" 3.05" - 4.05" Non-rotating spindle type Metric Flange diameter 6.35mm 12.7mm 12.7mm 12.7mm 12.7mm Order No. Graduation 146-131 146-132 146-133 146-134 146-135 .001" .001" .001" .001" .001" Flange diameter .25" .5" .5" .5" .5" Order No. Graduation 146-221 146-222 146-223 146-224 146-225 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Flange diameter 6.35mm 12.7mm 12.7mm 12.7mm 12.7mm Non-rotating spindle type Range Outside 0 - 1" Range Inside .055" - 1.05" 1" - 2" 2" - 3" 3" - 4" 1.05" - 2.05" 2.05" - 3.05" 3.05" - 4.05" Order No. Graduation 146-231 146-232 146-233 146-234 146-235 .001" .001" .001" .001" .001" Flange diameter .25" .5" .5" .5" .5" Accuracy • Accuracy: ±10µm (±.0004") • Parallelism: 10µm (.0004") (230) ø15 32 3 47 Unit: mm 17 ø18 (104.5) ø10 ø18 146-121 146-122 (254.5) 131 (115) 32 3 146-222 61 17 ø18.3 146-221 25 0.75 ø15 0.75 ø10 17 ø12.7 61 ø6.35 3 ø12.7 (194) 32 25 0.75 0.75 ø6.35 17 ø12.7 47 ø12.7 3 ø18.3 ø10 19.5 (170) 32 ø15 9.5 ø10 ø5 ø5 ø6.35 25 0.75 (35) ø3.5 0.75 ø6.35 25 0.75 (35) ø3.5 ø6.35 ø6.35 0.75 ø15 Dimensions Depth Micrometers SERIES 329, 229, 129 — Interchangeable Rod Type MICROMETERS 329-511-30 229-101 129-110 FEATURES SPECIFICATIONS • ø4mm (.157" DIA.) interchangeable rods, with lapped measuring end, provide a wide measuring range. • The rod length can be adjusted in 25mm (1") increments. • With Ratchet Stop for consistent force. • Crisp clear graduations on the thimble. • The 329 series (LCD readout type) are provided with SPC output. • The 229 series are provided with a mechanical digit counter for quick and error-free reading. • Complete with fitted carrying case. Accuracy • Accuracy of micrometer head: ±3µm (.00015") Excluding quantizing error. (329 series) • Flatness of reference face: 1.3µm (.00005") for base with 63.5mm (2.5") width 2µm (.00008") for base with 101.6mm (4") width • Flatness of measuring face of rod: 0.3µm (.000012") • Parallelism between reference face and measuring face: (4+L/50)µm [(.00016+.00004 (L/2))"]* * L=Maximum measuring length (mm) [(inch)], Fraction rounded up • Accuracy of interchangeable rod: ±(2+L/75)µm [±(.0001+.00005 (L/3))"]* * L=Maximum measuring length (mm) [(inch)], Fraction rounded up Dimensions Unit: mm 18 3 65.4 17 101.6 ø18.3 50 Order No. 937387 965013 ø4 OPTIONAL ACCESSORIES Description SPC cable (1m) SPC cable (2m) 129-113 132 Metric Digital model Range Order No. Resolution 0 - 150mm 0 - 300mm 329-511-30 0.001mm 329-512-30 0.001mm Remarks with 6 rods with 12 rods Digital model Range Order No. Resolution 0 - 6" 329-711-30 .00005"/ 0.001mm 329-712-30 .0001"/ 0.001mm Dimensions of reference face 4"X.63" Remarks with 6 rods 4"X.63" with 12 rods Range Order No. Graduation 0 - 50mm 129-109 129-113 129-110 129-114 129-111 129-115 129-112 129-116 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm 0.01mm Range Order No. Graduation 0 - 3" 129-126 129-130 129-127 129-131 129-128 129-132 129-149 129-150 .001" .001" .001" .001" .001" .001" .001" .001" 0 - 75mm 0 - 100mm Metric Mechanical counter model Range Order No. Graduation 0 - 25mm 229-101 229-102 229-109 229-113 0.01mm 0.01mm 0.01mm 0.01mm 0 - 50mm Inch Remarks with 1 rod with 1 rod with 2 rods with 2 rods 0 - 150mm Order No. Graduation 0 - 4" 229-127 229-131 229-128 229-132 .001" .001" .001" .001" Dimensions of reference face 2.5"X.63" 4"X.63" 2.5"X.63" 4"X.63" Remarks Dimensions of reference face 2.5"X.63" 4"X.63" 2.5"X.63" 4"X.63" 2.5"X.63" 4"X.63" 2.5"X.63" 4"X.63" Remarks with 2 rods with 2 rods with 3 rods with 3 rods with 4 rods with 4 rods with 6 rods with 6 rods Inch Mechanical counter model Range 0 - 6" Dimensions of reference face 63.5X16mm 101.6X16mm 63.5X16mm 101.6X16mm Dimensions of reference face 63.5X16mm 101.6X16mm 63.5X16mm 101.6X16mm 63.5X16mm 101.6X16mm 63.5X16mm 101.6X16mm Remarks 0 - 4" with 4 rods with 4 rods with 6 rods with 6 rods 0 - 6" 0 - 12" with 3 rods with 3 rods with 4 rods with 4 rods with 6 rods with 6 rods with 12 rods with 12 rods Depth Micrometers SERIES 128 SPECIFICATIONS 128-101 Metric Range 0 - 25mm 128-102 Order No. 128-101 128-103* 128-102 128-104* Graduation 0.01mm 0.01mm 0.01mm 0.01mm Dimensions of reference 63.5 x 16mm 63.5 x 16mm 101.6 x 16mm 101.6 x 16mm Graduation .001" .001" Dimensions of reference 2.5" x .63" 4" x .63" *The measuring face has a carbide tip. Inch Range 0 - 1" Order No. 128-105 128-106 FEATURES *The measuring face has a carbide tip. • Ratchet Stop for consistent and repetitive measurements. • ø4mm (.157" DIA.) measuring face. • Satin-chrome finished throughout. • With spindle locking clamp. • Crisp clear graduations on the thimble. Accuracy • Accuracy of micrometer head: ±3µm (.00015") • Flatness of reference face: 1.3µm (.00005") for base with 63.5mm (2.5") width 2µm (.00008") for base with 101.6mm (4") width 133 MICROMETERS Metric Inch/Metric 0 - 12" Dimensions of reference face 101.6X16mm 101.6X16mm
103-129
物料型号:STM32F103C8T6 器件简介:STM32F103C8T6 是一款基于 ARM Cortex-M3 内核的 32 位 RISC 处理器,最高工作频率为 72MHz,内置 64KB 的 Flash 存储器和 20KB 的 SRAM。
引脚分配:STM32F103C8T6 有 8 个引脚,包括电源引脚、地引脚、I/O 引脚等。
参数特性:工作电压范围为 2.0V 至 3.6V,工作频率为 72MHz,Flash 为 64KB,SRAM 为 20KB。
功能详解:该芯片具备丰富的外设接口,如 USART、SPI、I2C 等。
应用信息:广泛应用于工业控制、消费电子和物联网领域。
封装信息:LQFP48 封装。
103-129 价格&库存
很抱歉,暂时无法提供与“103-129”相匹配的价格&库存,您可以联系我们找货
