293-145-30
293-145-30
    MITUTOYO(三丰)
    MITUTOYO - 293-145-30 - Micrometer, Digital, 25 mm Max Measuring Range, 0.001mm Graduations, 9 mm x ...
293-145-30 数据手册
12/11/2017 Mitutoyo - Digital Micrometer QuantuMike IP65 Digital Micrometer QuantuMike IP65 0-25mm, w/o output Item number: 293-145-30 Description This is a micrometer with a 2mm spindle pitch, o ering movement four times as fast as  a standard micrometer. The Digimatic Micrometer QuantuMike IP65 o ers the following bene ts: Faster measurement is achieved by using a coarser thread which feeds the spindle by 2mm per thimble rotation. It delivers approximately four times as fast as standard micrometer with 0.5mm spindle pitch. The device has outstanding accuracy, with only ±1µm instrumental error (75mm or less measuring range models). The dual function o ered by the ratchet on the thimble and the fast drive mechanism ensure easy single-handed or stand operation. Excellent resistance against water and dust (IP65 protection level) enables this micrometer to be used in machining situations that include splashing coolant uid. Features Range: 0 - 25 mm Accuracy: Accuracy: ±1 µm Mass: 265 g Digital step: 0,001 mm / 0,001 mm/0.00005" Flatness: 0.3µm/.000012" Parallelism: 1 µm for models up to 50 mm 2 µm for models up to 100 mm Measuring surfaces: carbide-tipped, precision round, micro-lap nish Battery life: approx. 2.4 years Delivered: Including box, key, 1 battery, setting standard (from 25 mm upward), certi cate of inspection (0-50 mm range) ORIGIN (until 100 mm): Yes ZERO/ABS: Yes Auto Power OFF after 20 min. non use: Yes Function lock: Yes HOLD: Yes https://shop.mitutoyo.eu/web/mitutoyo/en/all/$catalogue/mitutoyoData/PR/293-145-30/datasheet.xhtml 1/3 12/11/2017 Mitutoyo - Digital Micrometer QuantuMike IP65 Digital/Analog: Digital Inch-Metric: Metric Dimensions L: 0 mm a: 9 mm b: 25 mm Accessories Optional accessories: Product Price Digimatic Cable with Data Button IP Type, 1m, Micrometer Type 05CZA662 Price on application Digimatic Cable with Data Button IP Type, 2m, Micrometer Type 05CZA663 Price on application U-WAVE T Connection Cable B with Data Button IP Micrometer Type 02AZD790B Suggested retail price: 97.00 €* USB Input Tool Direct (Digimatic USB) with Data Button IP Micrometer Type 06AFM380B Suggested retail price: 119.00 €* Color speeder for Ratched Thimble Red 04GAA900 Price on application Color speeder for Ratched Thimble Yellow 04GAA901 Price on application Color speeder for Ratched Thimble Green 04GAA902 Price on application https://shop.mitutoyo.eu/web/mitutoyo/en/all/$catalogue/mitutoyoData/PR/293-145-30/datasheet.xhtml 2/3 12/11/2017 Mitutoyo - Digital Micrometer QuantuMike IP65 Product Price Color speeder for Ratched Thimble Blue 04GAA903 Price on application Color speeder for Ratched Thimble Grey 04AAB208 Price on application Consumable spares: Product Price Battery SR44 1.5V 938882 Price on application Color speeder for Ratched Thimble Black 04GAA899 Price on application https://shop.mitutoyo.eu/web/mitutoyo/en/all/$catalogue/mitutoyoData/PR/293-145-30/datasheet.xhtml 3/3
293-145-30 价格&库存
很抱歉,暂时无法提供与“293-145-30”相匹配的价格&库存,您可以联系我们找货
