293-832
293-832
    MITUTOYO(三丰)
293-832 数据手册
SERIES 293 – Digimatic Micrometer Technical Data Measuring force: Battery: Battery life: 5 to 10N SR44 (1 pc) 938882 Approx. 1.8 years under normal use Functions • Simple design, such as not incorporating data output, achieves low cost. • Provided only with an origin-set button for easy origin setting. • Increased operability thanks to easy-to-read LCD with 30% more character display area. • Equipped with Ratchet Stop for constant measuring force. • Measuring faces: Carbide Zero setting: A brief press on the ORIGIN button sets display to zero at the current spindle position (zero-setting), which allows easy comparison measurement. Auto power ON/OFF: The reading on the LCD disappears after this instrument is idle for about 20 minutes, but the reading is retained. Turning the spindle causes the reading on the LCD to reappear. B 293-821 293-832 SPECIFICATIONS Metric Code No. 293-821 Range 0 - 25 mm Resolution 0.001 mm Accuracy* ±2 µm Constant-force device Ratchet stop Price £89.60 Range Resolution Accuracy* 0 - 25 mm (0 - 1") 0.001 mm (.00005") ±2 µm (±.0001") Constant-force device Ratchet stop Friction thimble Price £89.60 £89.60 Inch/Metric Code No. 293-831 293-832 * Excluding quantizing error. DIMENSIONS Unit: mm Ratchet stop type 43 275g Mitutoyo operates a policy of continuous improvement that aims to provide the customer with the benefit of the latest technological advances. Therefore the company reserves the right to change any or all aspects of any product specification without notice. 17 143.2 ø18 30.7 2.8 ø6.35 (58.7) 25 9 Friction thimble type 42.5 2.3 3 B-10
293-832 价格&库存
很抱歉,暂时无法提供与“293-832”相匹配的价格&库存,您可以联系我们找货
