500-196-30
500-196-30
    MITUTOYO(三丰)
500-196-30 数据手册
Small Tool Instruments and Data Management AOS Absolute Digimatic Caliper CD-AX/APX Series Bulletin No. 2129 A new series of digimatic calipers derived from 30 years of accumulated Mitutoyo technologies. Equipped with the electromagnetic induction type absolute encoder and AOS (Advanced Onsite Sensor) applied for ABS coolant-proof calipers. • Patent registered (in Japan, USA, China, Germany, UK, France, Switzerland and India) • Design patent pending (in Japan, USA, EU and China) AOS Absolute Digimatic Caliper A new series of digimatic calipers derived from 30 years of accumula induction type absolute encoder and AOS (Advanced Onsite Sensor) a The new electromagnetic inductive sensor repels dirt, oil and water ensuring 100% accuracy View AOS Sensor Technology in action www.mitutoyo.com/aoscd Evolution of Mitutoyo's digital caliper 1 1983 1987 1988 • The first digital caliper. • A Digimatic-format measurement data output port is incorporated. • The first solar-powere model, which never ne a new battery. ated Mitutoyo technologies. Equipped with the electromagnetic applied for ABS coolant-proof calipers. ed eeds 500-151-30 Slider with measurement data output port and thumb roller The slider provides smooth, stable and comfortable operation. Strong The ABS (absolute) scale requires no origin setting after power-on and also has no limit to response speed. Smaller acceleration Larger acceleration The quality of the slider working surface has improved with the latest machining technology. Unsmooth operating feel Ra:0.071μm Weak Longitudinal direction Mitutoyo’s old products Power OFF state Power ON 16.38 No need for origin-setting CD-AX series Lower-frequency vibration Rugged feel Power ON Higher-frequency vibration Unsmooth operating feel Rustling feel Assessment of slider operating 'feel' This assessment is obtained from FFT analysis of vibrations during sliding with acceleration sensors mounted on the slider. 500-197-30 Slider without a measurement data output port but with a thumb roller • A battery life of approximately 3.5 years has been achieved under normal use through the adoption of Mitutoyo's ABSOLUTE scale. • The slider configuration features an ergonomic, thumb-friendly shape. • Step-measurement capable. • Font height: 9mm,alleviation of fatigue with the high-contrast LCD • Carbide-tipped jaw models are ideally suited to the measurement of rough-machined workpieces, castings, grindstones, etc. • The data output function allows integration into statistical process control and measurement systems. 1993 • Introduction of Mitutoyo's electrostatic capacitance ABSOLUTE encoder caliper. 2000 2003 2005 An inspection certificate is included standard with each caliper. 2013 • Introduction of an ABSOLUTE • Introduction of an induction type • Introduction of a solar-powered • The AOS induction type encoder caliper offering IP65-level ABSOLUTE encoder caliper offering ABSOLUTE encoder caliper offering ABSOLUTE encoder is introduced coolant-proof performance. IP67-level coolant-proof performance. IP67-level coolant-proof performance. to a standard caliper. 2 Common Specifications Functions • Resolution: 0.01mm • Repeatability: 0.01mm • Power supply: Button-type silver oxide battery SR44 (No. 938882), 1 piece supplied as standard (The standard supplied battery is for the monitor.) • Battery life: Approx. 3.5 years under normal use • Maximum response speed: Unlimited ABS (absolute) measurement function: Enables absolute-mode measurement to be started without any zero-setting after switch-on. The absolute origin position can be set, or reset, with the ORIGIN switch at any time. INC (incremental) measurement function: Enables the display value to be set to zero, temporarily, at the current slider position to enable easy incremental-mode measurement. Low battery alarm: Indicates (with a 'B' symbol in the display) that the battery needs replacing. This allows timely battery replacement before the caliper becomes unusable. External output function: Allows measurement data to be exported using the optional data cable. Hold function: Allows a display value to be held using the optional Data Hold unit. (This function cannot be used along with the external output function.) SPECIFICATIONS Metric Order No. 500-150-30 500-180-30 500-151-30 500-154-30 500-155-30 500-158-30 500-181-30 500-152-30 500-156-30 500-157-30 500-182-30 Range Accuracy Mass 0-100mm 0-150mm 143 g Measurement data output port ✔ – Thumb roller ✔ – ✔ ✔ – – ✔ ✔ – – Measurement data output port ✔ – Thumb roller 168 g ±0.02mm 0-200mm 198 g Remarks Depth bar ø1.9mm rod – Carbide-tipped jaws for outside measurement Carbide-tipped jaws for outside and inside measurement Depth bar ø1.9mm rod – – Carbide-tipped jaws for outside measurement Carbide-tipped jaws for outside and inside measurement – Inch Order No. 500-170-30 500-195-30 500-171-30 500-174-30 500-175-30 500-178-30 500-196-30 500-159-30 500-160-30 500-172-30 500-176-30 500-177-30 500-197-30 500-163-30 500-164-30 Range Accuracy Mass 0-4" 143 g ✔ 0-6" 168 g ±0.001" ✔ – ✔ 0-8" Remarks Depth bar ø3/40" rod 198 g – – Carbide-tipped jaws for outside measurement Carbide-tipped jaws for outside and inside measurement Depth bar ø3/40" rod – Carbide-tipped jaws for outside measurement Carbide-tipped jaws for outside and inside measurement – Carbide-tipped jaws for outside measurement Carbide-tipped jaws for outside and inside measurement – Carbide-tipped jaws for outside measurement Carbide-tipped jaws for outside and inside measurement External View/Dimensions Chart D H C B A L C D 21 14.5 40 24.5 18 50 H L unit:mm 182 16 233 290 L Hold unit C Used for input tool DP-1VR or MUX-10F. 1m cable: Order No.959149 2m cable: Order No.959150 B • Connecting cable Order No.959143 A These accessories are available only for those models with the measurement data output function. C B A • Data Hold unit L B H Optional Accessories Measuring Range A 0-100 16.5 0-150 0-200 20 Depth of outer jaws = 3.5mm Depth of main scale = 3.5mm One Number to Serve You Better D D 1-888-MITUTOYO (1-888-648-8869) • USB direct input tool USB-ITN-C (2m): Order No.06ADV380C • U-WAVE-T dedicated connecting cable Cable for standard use: Order No.02AZD790C Cable for foot switch: Order No.02AZE140C Note: All information regarding our products, and in particular the illustrations, drawings, dimensional and performance data contained in this printed matter as well as other technical data are to be regarded as approximate average values. We therefore reserve the right to make changes to the corresponding designs. The stated standards, similar technical regulations, descriptions and illustrations of the products were valid at the time of printing. In addition, the latest applicable version of our General Trading Conditions will apply. Only quotations submitted by ourselves may be regarded as definitive. Mitutoyo products are subject to US Export Administration Regulations (EAR). Re-export or relocation of our products may require prior approval by an appropriate governing authority. Trademarks and Registrations Designations used by companies to distinguish their products are often claimed as trademarks. In all instances where Mitutoyo America Corporation is aware of a claim, the product names appear in initial capital or all capital letters. The appropriate companies should be contacted for more complete trademark and registration information. © 2014 Mitutoyo America Corporation, Aurora IL 3.5M 1013-03 Printed in USA, Feb. 2014 Aurora, Illinois (Corporate Headquarters) Westford, Massachusetts Huntersville, North Carolina Mason, Ohio Plymouth, Michigan City of Industry, California Birmingham, Alabama Renton, Washington サムローラ
500-196-30 价格&库存
很抱歉,暂时无法提供与“500-196-30”相匹配的价格&库存,您可以联系我们找货
    • 1+1962.18805
    库存:9
