543-782
543-782
    MITUTOYO(三丰)
543-782 数据手册
ABSOLUTE Digimatic Indicator ID-S Series 543-with Simple Design Series 543 Features     As compact as standard Series 2 dial indicators. After the initial zero-setting with the ORIGIN button, the repeated absolute positioning is no longer necessary over the entire battery life. Employing the ABSOLUTE linear encoder, the ID-S always displays the spindle "Absolute Position" from the origin at power-on. Also unlimited response speed eliminates over-speed errors. SPC data output. Technical Data Accuracy: Refer to the list of specifications. Resolution: 0.01mm, 0.001mm, .0005"/0.01mm, .0001”/0.001mm or .00005”/0.001mm Display: LCD Length standard: ABSOLUTE electrostatic capacitance type linear encoder Max. response speed: Unlimited Measuring force: Refer to the list of specifications Battery: SR44 (1 pc.), 938882 Battery life: Approx. 20,000 hours under normal use Dust/Water protection level: IP42 (IP53:543-794, 543-795, 543-796) Function Origin-set, Zeroset, Counting direction switching, Power ON/OFF, Data output,inch/mm conversion (on inch/metric models only) Alarm: Low voltage, Counting value composition error, Over-flow error Order No 543-782 543-782B 543-783 543-783B 543-791 543-791B 543-792 Model No ID-S1012MX ID-S1012MBX ID-S1012E ID-S1012EB ID-S112MX IDS112MBX ID-S112EX Parts Break Down Parts Break Down Parts Break Down Parts Break Down Parts Break Down Parts Break Down Parts Break Dow .0005in 0.01mm .0005in 0.01mm .0005in 0.01mm .0005in 0.01mm .00005in 0.001mm .00005in 0.001mm .00005in 0.001m .5in 12.7mm .5in 12.7mm .5in 12.7mm .5in 12.7mm .5in 12.7mm .5in 12.7mm .5in 12.7mm Accuracy .0008in .0008in .0008in .0008in .00012in .00012in .00012in Stem DIA Ø8in Ø8in 3/8in 3/8in Ø8in Ø8in 3/8in 2.0N or less 2.0N or less 2.0N or less 2.0N or less 2.0N or less 2.0N or less 2.0N or less M2.5x0.45 Thread M2.5x0.45 Thread 4-48 UNF Thread 4-48 UNF Thread M2.5x0.45 Thread M2.5x0.45 Thread 4-48 UNF Threa Image Parts Reso Range Force Contact Point
543-782 价格&库存
很抱歉,暂时无法提供与“543-782”相匹配的价格&库存,您可以联系我们找货
  • 1+1378.21927
库存:13
