293-333
293-333
    MITUTOYO(三丰)
293-333 数据手册
2.3 3 ø18 b Unit: mm L b 14.5 a 47.2 2.3 3 43 17 5 0 ø6.35 C ø18 27.5 45 4.2 44 17 43 Unit: mm Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm L 0 25 50 75 132.8 158.2 183.6 208.8 234.2 258 284 309 a 9 9.8 12.6 14 5.3 5.7 6.1 6.3 6.7 5.5 6.5 6.5 b 25 32 47 60 16.7 18.8 19.1 18.2 16.8 18 18 18 c (59.8) (70.3) (91.6) (112.9) (76.5) (91) (103.1) (115.3) (126.8) (139.8) (152.3) (166) SPECIFICATIONS Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm 100 - 125mm 125 - 150mm 150 - 175mm 175 - 200mm 200 - 225mm 225 - 250mm 250 - 275mm 275 - 300mm Metric Range 0 - 25mm 25 - 50mm 50 - 75mm 75 - 100mm Metric Range 0 - 25mm Inch/Metric With ratchet stop Order No. 293-230 / 293-240* 293-231 / 293-241* 293-232 / 293-242* 293-233 / 293-243* 293-250 293-251 293-252 293-253 293-254 293-255 293-256 293-257 Resolution 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±1µm ±1µm ±1µm ±2µm ±2µm ±2µm ±3µm ±3µm ±3µm ±4µm ±4µm ±4µm Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" 4" - 5" 5" - 6" 6" - 7" 7" - 8" 8" - 9" 9" - 10" 10" - 11" 11" - 12" Resolution 0.001mm 0.001mm 0.001mm 0.001mm Accuracy ±1µm ±1µm ±1µm ±2µm Range 0 - 1" 1" - 2" 2" - 3" 3" - 4" Resolution 0.001mm Accuracy ±1µm Range 0 - 1" 1" - 2" *without SPC data output Accuracy ±.00005" ±.00005" ±.00005" ±.0001" ±.0001" ±.0001" ±.00015" ±.00015" ±.00015" ±.0002" ±.0002" ±.0002" Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm Accuracy ±.00005" ±.00005" ±.00005" ±.0001" With friction thimble Order No. 293-335 / 293-348* 293-336 *without SPC data output 89 Resolution .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm .00005"/0.001mm With ratchet thimble Order No. 293-334 / 293-344* 293-345* 293-346* 293-347* Inch/Metric With friction thimble Order No. 293-238 / 293-248* Order No. 293-330 / 293-340* 293-331 / 293-341* 293-332 / 293-342* 293-333 / 293-343* 293-350 293-351 293-352 293-353 293-354 293-355 293-356 293-357 Inch/Metric With ratchet thimble Order No. 293-234 / 293-244* 293-235 / 293-245* 293-236 / 293-246* 293-237 / 293-247* With ratchet stop Resolution .00005"/0.001mm .00005"/0.001mm Accuracy ±.00005" ±.00005" MICROMETERS 42.5 ø18 30.7 c L 2.8 ø6.35 a Dimensions
293-333 价格&库存
很抱歉,暂时无法提供与“293-333”相匹配的价格&库存,您可以联系我们找货
