500-173.
500-173.
    MITUTOYO(三丰)
    MITUTOYO - 500-173. - DIGIMATIC CALIPER ABS 12"/300MM
500-173. 数据手册
ABSOLUTE Digimatic Caliper SERIES 500 — with Exclusive ABSOLUTE Encoder Technology Mitutoyo's absolute Digimatic Caliper is the next generation of electronic calipers. It keeps track of its origin point once set. Whenever turned on, the large LCD screen displays the actual slider position ready to start measurement. No more repeated zero setting is necessary with the absolute encoder technology as well as no more care for overspeed errors. High quality guide surface finish for smooth slider movement Conventional ABS Digimatic Caliper Direction of the length Direction of the length Ra: 0.126µm Ra: 0.07µm FEATURES • Large and clear LCD readout. • The ZERO/ABS key allows the display to be Zero-Set at any slider position along the scale for incremental comparison measurements. This switch will also allow return to the absolute (ABS) coordinate and display of the true position from the origin point (usually jaws-closed point). • Data Hold Unit (959143) is optional. • Carbide-tipped jaw type calipers are also available. (Refer to the page 9 for details.) (Refer to the page 9 for details.) 500-150-20 Technical Data Accuracy: ±0.02mm (≤200mm), ±0.03mm (≤300mm) ±0.05mm (≤600mm), ±0.07mm (≤1000mm) (excluding quantizing error) Resolution: 0.01mm or .0005"/0.01mm Repeatability: 0.01mm Display: LCD Length standard: ABSOLUTE electrostatic capacitance type linear encoder Max. response speed: Unlimited Battery: SR44 (1 pc.), 938882 Battery life: Approx. 3.5 years under normal use 500-181-20 DIMENSION Unit: mm Function Origin-set, Zero-setting, Data output, inch/mm conversion (inch/mm models) Alarm: Low voltage, Counting value composition error � � � � Optional Accessory � Range 0 - 100mm 0 - 150mm 0 - 200mm 0 - 300mm L 182 233 290 403 a 40 40 50 64 b 21 21 24.5 27.5 c 16.5 16.5 20 22 e 16 16 16 20 959143: 959149: 959150: Data hold unit SPC cable with data switch (1m) SPC cable with data switch (2m) 959143 � 959149 � � � � Range 0 - 450mm 0 - 600mm 0 - 1000mm 130 L 630 780 1240 a 90 90 130 b 47 47 61 c 38 38 50 e 25 25 32 SPECIFICATIONS Metric Range 0 - 100mm 0 - 100mm 0 - 150mm 0 - 150mm 0 - 150mm 0 - 150mm 0 - 150mm 0 - 200mm 0 - 200mm 0 - 200mm 0 - 200mm 0 - 300mm 0 - 450mm 0 - 600mm 0 - 1000mm Order No. 500-150-20 500-180-20* 500-151-20 500-154-20 500-155-20 500-158-20 500-181-20* 500-152-20 500-156-20 500-157-20 500-182-20* 500-153 500-500-10 500-501-10 500-502-10 Remarks (depth measuring bar / thumb roller / others) ø1.9mm rod with thumb roller — ø1.9mm rod — — Blade with thumb roller — Blade with thumb roller Carbide-tipped jaws for OD measurement Blade with thumb roller Carbide-tipped jaws for OD & ID measurement ø1.9mm rod with thumb roller — Blade — — Blade with thumb roller — Blade with thumb roller Carbide-tipped jaws for OD measurement Blade with thumb roller Carbide-tipped jaws for OD & ID measurement Blade — — Blade with thumb roller — — — — — — — — — — *without SPC data output Inch/Metric Range 0 - 4" 0 - 4" 0 - 6" 0 - 6" 0 - 6" 0 - 6" 0 - 6" 0 - 6" 0 - 6" 0 - 8" 0 - 8" 0 - 8" 0 - 8" 0 - 8" 0 - 8" 0 - 12" 0 - 12" 0 - 12" 0 - 12" 0 - 12" 0 - 12" 0 - 18" 0 - 24" 0 - 40" Order No. 500-170-20 500-195-20* 500-171-20 500-174-20 500-175-20 500-178-20 500-196-20* 500-159-20* 500-160-20* 500-172-20 500-176-20 500-177-20 500-197-20* 500-163-20* 500-164-20* 500-173 500-167 500-168 500-193* 500-165* 500-166* 500-505-10 500-506-10 500-507-10 Remarks (depth measuring bar / thumb roller / others) ø3/40" rod with thumb roller — ø3/40" rod with thumb roller — Blade with thumb roller — Blade with thumb roller Carbide-tipped jaws for OD measurement Blade with thumb roller Carbide-tipped jaws for OD & ID measurement ø3/40" rod with thumb roller — Blade with thumb roller — Blade with thumb roller Carbide-tipped jaws for OD measurement Blade with thumb roller Carbide-tipped jaws for OD & ID measurement Blade with thumb roller — Blade with thumb roller Carbide-tipped jaws for OD measurement Blade with thumb roller Carbide-tipped jaws for OD & ID measurement Blade with thumb roller — Blade with thumb roller Carbide-tipped jaws for OD measurement Blade with thumb roller Carbide-tipped jaws for OD & ID measurement Blade with thumb roller — Blade with thumb roller Carbide-tipped jaws for OD measurement Blade with thumb roller Carbide-tipped jaws for OD & ID measurement Blade with thumb roller — Blade — Carbide-tipped jaws for OD measurement Blade — Carbide-tipped jaws for OD & ID measurement — with thumb roller — — with thumb roller — — with thumb roller — *without SPC data output 500-502-10 500-501-10 500-500-10 131
500-173. 价格&库存
很抱歉,暂时无法提供与“500-173.”相匹配的价格&库存,您可以联系我们找货
