2046SB
2046SB
    MITUTOYO(三丰)
2046SB 数据手册
6/24/2021 Mitutoyo - Dial Indicator, Flat Back Dial Indicator, Flat Back 10mm, 0,01mm Item number: 2046SB Description Standard Type, 10 mm Range, 0,01 mm Graduation This is a standard, metric dial indicator. It offers you the following benefits: Bezel clamp and lifting lever (optional) can be attached to either right or left side. They can be easily installed and removed without tools. No through screw holes on the frame and secure adhesion between the bezel and the crystal as well as the use of an O-ring prevents water or oil penetration. Features Range: Range per rev.: 10 1 mm Graduation: 0.01 mm Scale: 0-100 (100-0) MPE any 1/10 revolution: 5 µm MPE any 1/2 revolution: 9 µm MPE any 1 revolution: 10 µm MPE measuring range: 13 µm H MPE (Hysteresis): 3 µm R MPE (Repeatability): 3 µm Mass: 135 g Mass lug/plain: 144/135 g C: 57 mm D: 17.7 mm E: 20 mm F: 16.9 mm G: 19.8 mm I: 7.6 mm Balanced dial: Yes Continuous dial: Yes Reverse reading: Yes 3 Coaxial revolution counter: Yes Shockproof: Yes Digital/Analog: Analog Inch-Metric: Metric https://shop.mitutoyo.eu/web/mitutoyo/en/all/$catalogue/mitutoyoData/PR/2046SB/datasheet.xhtml;jsessionid=635A6D41870CD15CF71AEEE4D816F… 1/2 6/24/2021 Mitutoyo - Dial Indicator, Flat Back Type: EN ISO Standard Stem: 8 mm Contact point: Carbide tipped, thread: M 2.5 x 0.45 mm Delivered: with certificate of inspection, limit indicators fu: 3 µm Functions: ISO type Dimensions Accessories Optional accessories: Limit Hands (green) 2pcs Dial Indicator Series 2/3/4 21AZB195 Price on application Spare parts Consumable spares: Contact Element Ball Point 7,3mm Length, Carbide, Metric 901312 NBR Rubber Boot for ID-B, IP64 Series 2 125317 https://shop.mitutoyo.eu/web/mitutoyo/en/all/$catalogue/mitutoyoData/PR/2046SB/datasheet.xhtml;jsessionid=635A6D41870CD15CF71AEEE4D816F… 2/2
2046SB 价格&库存
很抱歉,暂时无法提供与“2046SB”相匹配的价格&库存,您可以联系我们找货
