10.42.8.230.0000
10.42.8.230.0000
    FINDER
    RLY LT DEPEND DPST-NO 16A 230VAC
10.42.8.230.0000 数据手册
10 Series - Light dependent relays 12 - 16 A Features 10.32 10.41 Relays for automatic control of lighting according to the ambient light level Integral light sensor For pole or wall mounting 10.32 - 2 NO 16A output contacts 10.41 - 1 NO 16A output contact Double pole Live and Neutral switching possible with the 10.32 • Sensitivity adjustment from 1 to 80 lux • Cadmium free contact material • Cadmium free light sensor (IC photo diode) • Electronic circuit - transformer isolated • Italian Patent “light feedback compensation” innovative principle Compatible with slow starting gas discharge lamps (up to 10 minutes) • For the first 3 working cycles the delay time (On and Off) is reduced to zero in order to aid installation • Available for supply 230 and 120 V AC (50/60 Hz) • I ST TY REG NI CO D E S I ERED U MM NI TY N ERED U MM CO D Single output - 1 NO 16A for Live switching N REG I ST • G Double output - 2 NO 16A for Live and Neutral switching G • E S I Contact specification Contact configuration 2 NO (DPST-NO) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 16/30 (120 A - 5 ms) 1 NO (SPST-NO) 16/30 (120 A - 5 ms) 120/— 230/— 120/— 230/— Rated load AC1 VA 1,900 3,700 1,900 3,700 Rated load AC15 VA 400 750 400 750 Rated current AC5a Nominal lamp rating: A incandescent W — 5 — 5 1,200 2,300 1,000 2,000 compensated fluorescent W 450 850 400 750 uncompensated fluorescent W 500 1,000 500 1,000 1,200 2,300 1,000 2,000 halogen W Minimum switching load mW (V/mA) 1,000 (10/10) 1,000 (10/10) AgSnO2 AgSnO2 Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/DC VA (50 Hz)/W V DC Operating range AC (50 Hz) DC 120 230 120 230 — — 2/— 2/— (0.8…1.1)UN (0.8…1.1)UN — — 100 · 103 100 · 103 Technical data Electrical life at rated load in AC1 cycles Threshold setting lx 1…80 1…80 Preset threshold lx 10 10 s 15/30 15/30 Delay time: switching ON/OFF Ambient temperature range Protection category °C –30…+70 IP 54 –30…+70 IP 54 Approvals (according to type) 1 10 Series - Light dependent relays 12 - 16 A Features 10.42 10.51 10.61 Relays for automatic control of lighting according to the ambient light level Integral light sensor For pole or wall mounting 10.42 - Two independent 16A outputs with individual lux setting 10.51 - Miniature single 12A NO output 10.61 - Mounting on street light body Single output - 1 NO 12A Miniature size ERED NI I ST TY E S I Single output - 1 NO 16 A ERED U MM CO D • NI TY G U MM CO D • REG REG I ST • N Two independent outputs 2 NO 16A N • • G Sensitivity adjustment from 1 to 80 lux Fixed sensivity 10 lux (± 20%) - (10.61 type) • Cadmium free contact material • Cadmium free light sensor (IC photo diode) • Electronic circuit - transformer isolated (10.42 type) • Italian Patent “light feedback compensation” innovative principle (10.51 type) • For the first 3 working cycles the delay time (On and Off) is reduced to zero in order to aid installation • Available for supply 230 and 120 V AC (50/60 Hz) • Prewired with silicone wire, 500 mm length (10.61 type) • E S I Contact specification Contact configuration 2 NO (DPST-NO) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 16/30 (120 A – 5 ms) 1 NO (SPST-NO) 12/25 (80 A – 5 ms) 1 NO (SPST-NO) 16/30 (120 A – 5 ms) 120/— 230/— 120/— 230/— 230/— Rated load AC1 VA 1,900 3,700 1,400 2,760 3,700 Rated load AC15 VA 400 750 300 600 750 Rated current AC5a Nominal lamp rating: A incandescent W — 5 — — 5 1,000 2,000 600 1,200 2,000 compensated fluorescent W 400 750 200 400 750 uncompensated fluorescent W 500 1,000 300 600 1,000 1,000 2,000 600 1,200 halogen W Minimum switching load mW (V/mA) 2,000 1,000 (10/10) 1,000 (10/10) 1,000 (10/10) AgSnO2 AgSnO2 AgSnO2 Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/DC VA (50 Hz)/W V DC Operating range AC (50 Hz) DC 120 230 120 230 230 — — — 2/— 1.5/— 2.5/— (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN — — — 100 · 103 100 · 103 100 · 103 Technical data Electrical life at rated load in AC1 cycles Threshold setting lx 1…80 1…80 10 Preset threshold lx 10 10 10 Delay time: switching ON/OFF Ambient temperature range Protection category Approvals (according to type) 2 s °C 15/30 15/30 15/30 –30…+70 –30…+70 –30…+70 IP 54 IP 54 IP 54 10 Series - Light dependent relays 12 - 16 A Ordering information Example: 10 series light dependent relay, 2 NO (DPST-NO) 16 A contact, screw terminal connections, 230 V AC supply. 1 0 . 3 2 . 8 . 2 3 0 . 0 0 0 Supply voltage 120 = 120 V 230 = 230 V Series Type 32 = 41 = 42 = 51 = 61 = 0 Double output - 2 NO 16 A Single output - 1 NO 16 A Two independent outputs - 2 NO 16A Single output - 1 NO 12A Mounting on street light body - 1 NO 16 A Supply version 8 = AC (50/60 Hz) Technical data Insulation 10.32 / 41 / 42 Dielectric strength between open contacts V AC 1,000 10.51 10.61 1,000 1,000 4 6 Conducted disturbance immunity Surge (1.2/50 μs) on L and N (differential mode) kV 4 Other data Cable grip Screw torque Ø mm (8.9...12) Nm 0.8 Max. wire size solid cable (7.5...9) — 0.8 — stranded cable solid cable stranded cable — mm2 1x6 / 2x4 1x6 / 2x2.5 1x6 / 2x4 1x4 / 2x2.5 — AWG 1x10 / 2x12 1x10 / 2x14 1x10 / 2x12 1x12 / 2x14 — Output wires Material Size — — Silicone rubber UV resistant — — 1.5 mm — — 500, ends-ferruled Rated insulation voltage kV — — 0.6 / 1 Max temperature °C — — 120 Length mm 2 Functions 10.51 10.32 / 10.41 / 10.42 LED* Supply voltage NO output contact Supply voltage NO output contact OFF Open OFF or ON Open ON Open ON Closed ON Open (Timing in Progress) ON Open (Timing in Progress) ON Closed — — * The LED is located under the terminal cover, close to the Lux adjustment knob. It indicates the contact status and assists in the test and setting of the correct light threshold level. 3 10 Series - Light dependent relays 12 - 16 A Wiring diagrams L L N N Internal connection Internal connection Type 10.32 Type 10.41 L L N N Internal connection Internal connection Type 10.42 L Type 10.51 F = brown wire N = blue wire 18 = white wire N Internal connection Type 10.61 4 10 Series - Light dependent relays 12 - 16 A Advantage of the “light feedback compensation” principle Light dependent relay where the lighting being controlled does not influence the light level seen by the light sensor Traditional light dependent relay where the lighting being controlled influences the light level seen by the light sensor Type 10.32, 10.41 and 10.51 light dependent relay with “light feedback compensation” recalculated OFF threshold set threshold set threshold Correct functioning - provided the sensor can be shielded from the effects of the controlled lighting switching On and Off set threshold Incorrect functioning where the lamps cycle between On and Off, because their effect is being detected by the light sensor The innovative principle of “light feedback compensation” avoids the annoying and damaging effects of the lamps repeatedly “hunting” between On and Off, due to poor installation Ambient light level as measured by the light dependent relay's integral light sensor. Ambient light + controlled light level as measured by the light dependent relay's integral light sensor. Notes 1. It is good practice to try to achieve a correct installation where the light emitted from the lamp(s) does not influence the light level seen by the sensor, although the “light feedback compensation” principle will help when this is not fully achievable. In this case it should be appreciated that the “light feedback compensation” principle may delay slightly the time of Switch Off - beyond the ideal. 2. The compensation principle is not effective where the combined effect of the ambient light and the controlled lighting exceeds 120 lux. 3. The 10.32 and 10.41 types are compatible with gas discharge lamps that attain full output within 10 minutes, since the electronic circuit monitors lamps' light output over a 10 minutes period to achieve a true assessment of its contribution to the overall lighting level. 5
10.42.8.230.0000 价格&库存
很抱歉,暂时无法提供与“10.42.8.230.0000”相匹配的价格&库存,您可以联系我们找货
    • 5+899.221035+116.55617
