12.21.8.230.0000
12.21.8.230.0000
    FINDER
12.21.8.230.0000 数据手册
12 Series - Time switches 16 A Features 12.01 12.11 12.31 Mechanical time switches - daily time setting - weekly time setting Type 12.01 - 1 Pole 16 A CO (SPDT) 35.8 mm width • Type 12.11 - 1 Pole 16 A NO (SPST-NO) 17.6 mm width • Type 12.31-0000 - 1 Pole 16 A CO (SPDT) • Type 12.31-0007 - 1 Pole 16 A CO (SPDT) • Minimum time interval setting: 1h 30 min (12.01) 15 min (12.11 - 12.31) • • Mechanical daily time switch • Mechanical daily time switch • Mechanical daily or weekly • 1 CO (SPDT) • 1 NO (SPST-NO) • 1 CO (SPDT) • 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount • Front panel mounting Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 1 NO (SPST-NO) 1 CO (SPDT) 16/— 16/30 16/— 250/— 250/— 250/— Rated load AC1 VA 4,000 4,000 4,000 Rated load AC15 (230 V AC) VA 750 420 420 2,000 (NO contact) 2,000 2,000 750 (NO contact) 750 750 uncompensated fluorescent (230 V) W 1,000 (NO contact) 1,000 1,000 halogen (230 V) W 2,000 (NO contact) 2,000 2,000 1,000 (10/10) 1,000 (10/10) 1,000 (10/10) AgCdO AgCdO AgCdO 230 230 230 — — — Nominal lamp rating:incandescent (230 V) W compensated fluorescent (230 V) W Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W Operating range AC (50 Hz) DC Technical data Electrical life at rated load in AC1 cycles Type of time switch Programs Minimum interval setting Accuracy Ambient temperature range Protection category 2/— 2/— 2/— (0.85...1.1)UN (0.85…1.1)UN (0.85…1.1)UN — — — — — 50 · 103 50 · 103 daily daily 48 switching point 96 switching point 50 · 103 daily weekly 96 switching point 168 switching point min 30 15 s/day 1.5 1.5 1.5 –5…+55 –5…+55 –10…+50 IP 20 IP 20 IP 20 °C 15 60 Approvals (according to type) 1 12 Series - Time switches 16 A Features 12.21 12.22 12.71 Electronic digital time switches - weekly time setting Type 12.21 - 1 Pole 16 A CO (SPDT) 35.8 mm width • Type 12.22 - 2 Pole 16 A CO (DPDT) 35.8 mm width • Type 12.71 - 1 Pole 16 A CO (SPDT) 17.6 mm width • Available for 230 V AC or 12, 24 V AC/DC supply • Minimum time interval setting - 1 minute • Internal battery for set-up without supply • Impulse output function: - 1s... 59: 59(mm:ss) for 12.21 and 12.22 - (1...59)s for 12.71 • Automatic adjustment for daylight saving • 35 mm rail (EN 60715) mount • • Digital weekly time switch • Digital weekly time switch • Digital weekly time switch • 1 CO (SPDT) • 2 CO (DPDT) • 1 CO (SPDT) • 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current 2 CO (DPDT) 1 CO (SPDT) A 16/30 16/30 16/30 Rated voltage/Maximum switching voltage V AC 250/— 250/— 250/— Rated load AC1 VA 4,000 4,000 4,000 Rated load AC15 (230 V AC) VA 750 750 420 2,000 (NO contact) 2,000 (NO contact) 2,000 (NO contact) 420 (NO contact) 420 (NO contact) 750 (NO contact) uncompensated fluorescent (230 V) W 1,000 (NO contact) 1,000 (NO contact) 1,000 (NO contact) halogen (230 V) W 2,000 (NO contact) 2,000 (NO contact) 2,000 (NO contact) 1,000 (10/10) 1,000 (10/10) 1,000 (10/10) AgCdO AgCdO AgCdO Nominal lamp rating:incandescent (230 V) W compensated fluorescent (230 V) W Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) V AC/DC Rated power AC/DC VA (50 Hz)/W Operating range AC (50 Hz) DC — 230 — 230 — 230 12 - 24 — 24 — 24 — 1.4/1.4 2/— 1.4/1.4 2/— 1.4/1.4 2/— (0.9…1.1)UN (0.85...1.1)UN (0.9…1.1)UN (0.85…1.1)UN (0.9…1.1)UN (0.85…1.1)UN (0.9...1.1)UN (0.9...1.1)UN — (0.9...1.1)UN — Technical data Electrical life at rated load in AC1 cycles Type of time switch 50 · 103 50 · 103 50 · 103 weekly weekly weekly 30 30 30 Programs Minimum interval setting Accuracy Ambient temperature range Protection category Approvals (according to type) 2 min s/day °C –5…+55 1 1 1 1.5 1.5 1.5 –5…+55 –10…+55 IP 20 IP 20 –10…+55 IP 20 — 12 Series - Time switches 16 A Features 12.91 12.92 Electronic digital time switches - weekly time setting Type 12.91 “ZENITH” 1 pole 16 A CO (DPDT) 35.8 mm width • Type 12.92 “ZENITH” 2 Pole 16 A CO (DPDT) 35.8 mm width • Astro program: calculation of sunrise and sunset times through date, time and location coordinates (longitude • Digital weekly time switch • 1 CO (DPDT) and latitude) • 35 mm rail (EN 60715) mount • Offset function: allows programming of switching times offset (+ or -) from the astrological time • Minimum time interval setting - 1 minute • Internal battery for set-up without supply • Automatic adjustment for daylight saving • 35 mm rail (EN 60715) mount • • Digital weekly time switch • 2 CO (DPDT) • 35 mm rail (EN 60715) mount Contact specification Contact configuration 1 CO (DPDT) Rated current/Maximum peak current 2 CO (DPDT) A 16/30 16/30 Rated voltage/Maximum switching voltage V AC 250/— 250/— Rated load AC1 VA 4,000 4,000 Rated load AC15 (230 V AC) VA 750 750 2,000 (NO contact) 2,000 (NO contact) 420 (NO contact) 420 (NO contact) uncompensated fluorescent (230 V) W 1,000 (NO contact) 1,000 (NO contact) halogen (230 V) W 2,000 (NO contact) 2,000 (NO contact) 1,000 (10/10) 1,000 (10/10) AgCdO AgCdO Nominal lamp rating:incandescent (230 V) W compensated fluorescent (230 V) W Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) 230 230 Rated power AC/DC VA (50 Hz)/W 2/— 2/— (0.85...1.1)UN (0.85...1.1)UN 50 · 103 50 · 103 weekly weekly 60 60 1 1 1.5 1.5 –10…+55 –10…+55 IP 20 IP 20 Operating range AC (50 Hz) Technical data Electrical life at rated load in AC1 cycles Type of time switch Programs Minimum interval setting Accuracy Ambient temperature range Protection category min s/day °C Approvals (according to type) 3 12 Series - Time switches 16 A Ordering information Example: 12 series, mechanical daily time switch, 1 CO (SPDT) 16 A, supply voltage 230 V AC. 1 2 . 0 1 . 8 . 2 3 0 . 0 0 0 0 Option 0 = Daily only for 12.31 7 = Weekly only for 12.31 Series Type 0 = Daily, 35.8 mm wide 1 = Daily, 17.5 mm wide 3 = Daily or Weekly, 72x72 mm 2 = Weekly, 35.8 mm wide 7 = Weekly, 17.5 mm wide 9 = Weekly, 35.8 mm wide Option 0 = With power back-up 1 = Without power back-up (type 12.11) Supply voltage 012 = 12 V AC/DC 024 = 24 V AC/DC 230 = 230 V AC No. of poles 1 = 1 CO (SPDT), 16 A 2 = 2 CO (DPDT), 16 A (type 12.22 and 12.92) Supply version 0 = AC (50/60 Hz)/DC (types 12.21.0.012, 12.21.0.024, 12.22.0.024, 12.71.0.024) 8 = AC (50/60 Hz) Technical data Insulation 12.01, 12.11, 12.31 12.21, 12.22, 12.71, 12.91, 12.92 Dielectric strength between open contacts V AC 1,000 1,000 Other data 12.01, 12.11, 12.31 12.21, 12.22, 12.71, 12.91, 12.92 Power back-up 70 h (following 80 h continuous energisation) 6 years after the first operation W 1.5 2 W 2.5 3 (for 1 pole) Nm 1.2 1.2 Power lost to the environment without contact current with rated current Screw torque Max. wire size solid cable 2 mm AWG stranded cable solid cable 4 stranded cable 1x6 / 2x4 1x6 / 2x2.5 1x6 / 2x4 1x6 / 2x2.5 1x10 / 2x12 1x10 / 2x14 1x10 / 2x12 1x10 / 2x14 Wiring diagrams L L N N Type 12.01 Selector switch: I = Permanently OFF O AUTO = Automatic I = Permanently ON 4 (for 2 pole) Type 12.11 Selector switch: O = Automatic I = Permanently ON 12 Series - Time switches 16 A Wiring diagrams L L N N Type 12.31 Type 12.21 12.22 12.91 12.92 L N Type 12.71 Accessories PC programming kit for type 12.71 contents: programming port, serial cable and software 012.00 - Power supply: via PC - RS232 serial interface Power consuption: < 10 mA Ambient temperature: (–5...+35)°C Protection category: IP 00 Programming port Time switch 12.71 012.00 Serial cable PC INSTALLATION OF PC-SOFTWARE · Place the CD in the CD-drive · Installation should START · Follow the on-screen instructions · Choose your language and COM1...COM4 in “setting menu” 5
12.21.8.230.0000 价格&库存
很抱歉,暂时无法提供与“12.21.8.230.0000”相匹配的价格&库存,您可以联系我们找货
